View Full Version : Hybrid / Engine Swaps
- tried other forums: b series question - jdm s1 tranny with ats final drive and ats lsd?
- Someone give me the full deal..HCP A/C bracket...
- anyone please help
- H22 in a civic
- HMO H22 Included Exhaust Piping Question
- 1ST GEN B18 SWAP !!!! HELP !!!!
- crx with a type r?>.....
- overheating problem
- dented oil pan
- Is it just me or is there a lot h22 swaps lately..
- Need help with a LS motor swap, possible main relay issues
- power steering with h22
- water pump
- code 22
- h22 swap?????????
- One more F&%$#!@ Problem.... (let me explain)
- swap B-series into HX vs. EX --how much harder??
- h22 swap sites
- H22a Started on First Crank
- i dont get it , dx ecu wit my ls motor runnz better!?
- H22 swap...PLEASE HELP!!!
- H22 Civics!! What Cat. Did you Use?
- in to 94 cx...b20 or b18b?
- half shaft help
- hesitation problems and solutions?
- B18B1 Head??
- H22A tilt. Is this normal?
- Need Suggestions!
- Rebuilding B Series Axles
- this stupid IAB is being stupid. please help me!!!!
- throttle linkage
- b16a2 block with gsr crank?
- Where can i find a detail instructions online on assemblying blocks??
- power steering
- B18B Long Block
- anyone have a spare axle? Bseries?
- Tech Question: Which is better (blocks)?
- D15B7 block w/ D16Z6 head ?s
- JDM H22a tranny type?
- About to buy a 93 Si, Swap Recommendations..
- H22 into 93 CX wiring
- can you use a Hasport h22 kit meant for Eg civic on Ek civic?
- ARP head stud question (with cometic head gasket)
- Q about EGR and H22...
- Best axles on h22 sdn for the money?
- chipped PWO owners, help me out
- automatic and manual axles: are they the same?
- H22 shift linkage...Please HELP!!!
- whos using:pr3 or pwo ecu with single cam vtec in obd0?
- Problems After Swap - Help Me Out.......
- swapping b18...how much?
- '92 ls axles/ecu same as '94?
- Before and after pics
- d16y8 wiring on a crx
- Timing Belt
- looking for ideas on an LS or b20 swap
- Just got my head!
- vtec oil pressure switch
- Does a b16a sir1(first generation) come with vtec?
- were your black ecu plugs(B+C) numbered like this? 90' si hatch
- HELP! Code 4 on my B16A1 ECU.
- 3200$ a fair price for a 96 acura ls with 90,000km, full swap everything ecu, mounts tranny all harn
- best place to source motor....your epxerences..good and bad
- Sold the H22 hatch... what next for new project?
- exhaust for 97 hatch b16?
- Which hatch for a swap (or more !?) ??
- B18 ls vtec wiht p30 pistons...??!!
- What header for a B series in a EG
- Did the brackets to retain Power Steering and A/C for a Ek- h22 swap come out yet?
- b16a swap help!!!
- Stock Injectors
- what is stock fuel pressure?
- JDM D15 engine swap
- Where to buy a swap? Need definite answers!
- ecu code question. 1 long flash then 5 short flashes???
- MAP sensor questions.....
- I want to change my 1.6 16v CRX to a 2.0 V-tech!
- engine swap help...
- all hybrid owners
- h22a civic-PISSING me off
- help, idle problem....
- obd2.2--->obd1 civic
- question about a swap relating to A/C
- Is a ls vtec engine the same as a b20 vtec engine?
- dy1b head
- swap times
- Head oil control orifice on b16a3?
- LS/VTEC--Should i do it?
- zc help
- motor swap
- do i need to use the ac bracket/mount Help ASAP
- automatic to manual conversion difficulty?
- civic h22a powered
- Mounts needed?: '94+ GSR in a '91 GS(engine)???......help!
- CRX B16a Turbo
- 97 ls in an eg
- ECU PIN removal- how?
- 95 civic ex swap questions
- DC2 - Civic Suspension Question
- GSR wiring harness
- help me!!! i can't service connector...
- can i keep Powersteering with a H22 swap in a 98EJ?
- Engine Management for Modded CRVTECs with PR3 (or without)
- B18B/ b20b auto swap?
- which intake to buy?
- I'm mid-swap, one thing left connecting, mid firewall cable to trans?
- 99-00 Si T & V belt work on b16a1??
- 2 questions about b16A tranny problem and ecu trouble code
- Anyone using the copy cat Mugen Twin Loop muffler?
- Can I resuse the Head gasket if tq'ed down for couple days?
- Civic Engine Swap
- Those thinking about B20VTECs, here's what Smokey Yunick thinks about siamesed bores.
- best engine swap for a 1/4 mile, NA car ?
- H22 fuel pump fit my eg?
- H22a into 3rd gen prelude...
- Wiring Harness for GSr into a 93 DX
- H22 powered Civics
- TPS code still on. Something else is messed. Help.
- What is needed to convert to OBD1
- distributer
- loose gas pedal after swap
- H22 civic with OBD2 P13.....wiring??
- 96ek-hcp-h22 running p28 ecu (best program??? - opinions)
- Bought Mugen h22a header and MUGEN exaust need help for CATALIC !!!!
- 96EK-h22 (HCP) install Need info about radhoses part#'s application.
- Should I go for it?
- can i use my stock fuel line
- Anyone have detailed pics/instructions on wiring VTEC?
- Rear engine mount - B18C1 into 93 CX
- s2000 engine in Toyota AE86 pics
- GSR header question
- wire vtec to ecu
- B-series shift linkage the same?
- B16A swap
- Newmann and H22ek!!!!!!! :)
- can a jspec motor pass emissions
- block guards???
- hot mah h22!
- how to wire vtec on 92 DX? (mini-me swap)
- H22 EK mount question.. I have HCP mounts, which STOCKERS do I need??
- ARP rod bolts fit ?
- What rad hoses for 92 cx with b18b?
- H22 powered accord won't start, constant code 3 and a dead battery/alternator! help!
- Hmm.. two wires... IAB
- h22 traction problems?
- How to choose a platform for a swap??
- Auto->manul ECU config. how
- need help
- 97 EK wiring and ecu with b18c1
- help on half done h22 ek swap
- integra tranny in crx?
- aight!!! last question bout h22 in civic
- Swap Starts This Weekend.... Wish me LUCK
- who has arias pistons and installed them yourself... I got some ?'s
- b20 VTEC questions please help !!
- eagle rod install? ?'s
- H22 is it really worth it?
- B20 fuel pressure
- Dyno Day in the Tri-State Area!!!!
- D & B series engine specs (bore X stroke)
- phone # please
- Who has had the MOST hybrid hondas in this Forum
- civic CAI with h22 -- quick question
- Fuel and Timing Maps
- bid on ITR engine
- Getting VIN check on engine?
- Needing more displacement in a B16a
- code 4 crank angle sensor????????????????????
- need wiring diagrams
- Hybrid Fuel Pump?
- Automatic Question
- Knock Sensor
- Trouble with my chipped P28
- What is the deal with ebay ECU Chips?
- project car
- thx for the input
- complete OBD2 wire harness swap into 90 CRX...will it work
- Weird hybrid setup, what would happen...
- small engine
- speed sensor question in civic hatch with h22
- throttle cable question
- Seattle area peeps....
- B20b-D16 obd-2 ecu- Crank Angle Sensor?
- ITR guage cluster into '93 GSR-do wires fit?
- b16a conflict ? gen 1 or 2
- b18b swap!!
- Is the shop on crack?
- H22 EK with CRUISE? Can it be done?
- my obd1, built b20vtec powered, daily driven crx is up and runnin
- sleeper
- h22 HCP AC bracket. Got a few Questions...
- Use of a SAAB Turbo in a Prelude ! ! Is it Possible
- b20 hp/tq vs. b18b hp/tq
- Can someone confirm? Are JDM B29B pistons the same as USDM B20Z pistons?
- Dilemma... to swap or not to swap?
- Burning oil...want to go turbo soon, what to do?
- ITR front end conversion on a 99 civic HB,., do it or screw it?
- B18C Swap into ???
- Interchangeable parts....
- help wiring JDM b16a into 94 civic
- I need help with swap dealing with throttle cable
- JDM B18C-R swap into my Delslow
- Which Guage Cluster?
- Type R B18C5 swap
- high compression tuning
- OBDII -> OBDI harness question
- B18C- OBD1 or OBD2?
- good news , bad news ( h22 info and q's here)
- 99 B18B into 95 LS
- wiring 2nd o2 sensor
- b16a2 won't start in 96 EX (CKF related?)
- Hey need your opinion here!!!1
- WTB: Stock B20Z pistons!!!! (I have already tried the classifieds)
- Carsound cat. Buy it for the eg or for a gsr??
- H22A Swap Motor Mounts (aftermarket?)
- b18b swap in a 92 cx???
- thoughts on ls/vtec or crvtec
- is the gsr and 92-95 civic ex throttle cable the same?
- why wont my car start?????
- I need help with wiring on a harness...
- obd2 wiring harness question....
- WTB: B20a Prelude Crank (95mm)
- B20A3 to B20A5
- 89 SI to 91 SI guage cluster wiring changes?
- swapping 96 teg ls into 98 hatch
- Jdm p72 ?
- b18b wiring
- b16a2 axles/midshaft question
- quick question about 92 civic cx
- Which ARP head studs????
- Which Exhaust (Not Asking About Brand)?
- ITR engine compared to a GSR.....how much more gains??
- Wiring Harness Question
- rear mount question
- H22 in my 92 Civic cx???????
- My bloody install pics. jdmB18C1 into 92 cx
- What are the reasons I am getting no spark?
- where does my fast idle go!?
- B20 Sleeves are NOT strong
- Power Steering woes.... I wanna keep it damit!
- Fuel Pump?
- wiring question..Please help asap
- h22a kits
- b16a swap into a 89 integraRS is it possible and what do i need????
- H22A swap
- 1998 civic LX engine swap...help!
- ignition output signal?
- OBD2 car, OBD1 block
- h22 wiring ek
- Comparison of B20b and B18c throttle bodies...
