dpfi-2-mpfi 2-step @2k rpms: (searched)
Old 04-21-2011, 05:46 PM
JHJams's Avatar
Default dpfi-2-mpfi 2-step @2k rpms: (searched)
I purchased a '89 civic ran fine it was already a dpfi-2mpfi converted chassis. Has a d15b7 swap but staying obd0 using a pm6 and si distributor. Depinned the distributor clip and drivers side engine harness clip. I have went over them and I drew it up as I depinned so nothing could be crossed up.
I double checked my work a ton so far, maybe 4 times a day and still nothing. It will crank up and run and drive but only up to 2k rpms. It started throwing a code 8 so I replaced the distributor still code 8 and still a 2-step. I even hard wired the new distributor to the ecu w/new wire and great connections. I am stuck I am at a loss and can not figure this out.
Any input to help is appreciated.
extensioncordy
10
10-30-2006 07:21 AM
psycho.chicken
07-21-2006 09:34 AM
blk89crx
10-28-2005 11:46 AM
CivicHatchback14
07-14-2004 12:00 PM
EF_LSVtec
02-20-2003 05:46 PM
Quick Reply: dpfi-2-mpfi 2-step @2k rpms: (searched)
