View Full Version : Hybrid / Engine Swaps
- Anyone looking for a swap?
- hybrid experts-PLEASE HELP! long
- Is this a Good Deal for a swap?
- need help!!!!!!!
- need times
- I need help tonight if you can
- JDM ITR motor..octane use?
- Hybrid Sluggish after .. / suggestions please...
- Engine swaps=stiffer springs?
- 96-98 Civic Hybrid
- Hondata, anyone using Stage 4 setup?
- have zc-need alternator?
- What would be better for Ls/Vtec?
- Who's got B20 hybrids? (prices??)
- nyc swap shops/dealers......?
- how much should i pay?
- Stock GSR Exhaust
- 5th gen B16A swap shift linkage problem
- 93 dx hybrid wont start..HELP!
- NO VTEC!!!!!HELP?
- Z10 Radius rods
- Automatic P72 Ecu whats the deal?
- HCP mount kit?
- place racing x-member?
- B16a into EF, a few questions. Need Help ASAP.
- anybody have a HB for sale?
- Another compression ratio question( I know all you geeks can help me out)
- installing PR3 pistons
- ITR Final Drive Gear Question Help!!!!!
- Help< what do I need for this swap?
- Dont you just hate it....
- JDM Block Experts
- Identifying a JDM B20B block.
- Prelude or Not
- Turbo H22A in a Civic Hatch
- roll cage im 88 honda civic hb
- stolen engine, JDM engine anxiety, please help!!!
- 91 Si rear disc swap question????
- Hybrid Manual to Auto Install HELP Available !!!
- Vigor engine code
- OBDI GSR to EK - wiring Q's
- will a turbo fit in a b16a crx hybrid?
- Si Brake rear brake swap.....what parts are needed???
- What is the best way to do this?
- Obd1 Injectors VS. Obd2 Injesctors(GSR)
- need advice on rear mount
- HELP!!! B20 Confusion!
- CX tranny
- Still having idling problems...
- ls tranny w/lsvtec???
- Ls/vtec vs. b16a
- what exhaust should i use for a EG w/ b18c1
- any of u guys insure your hybrid?
- Visual differences between motors..
- Any good Honda parts yards in the Tri-State area???
- B18c GSR parts questions
- HELP!!! what shift linkage do I use w/ my B18C1 into my Delsol
- Which shop to do a swap in LA area?
- CODE 15
- Any noticeable differences that I can check on this?
- Fuel injector size q's...
- will a b18 fit into an '88 crx?
- OK, who has used aftermarket axles in their swap???
- Any one did a 6 gen civic auto to stick?
- True or false??? JDM Engines cannot be traced
- Anyone hybriders running a chipped P28 on a stock B18C intake manifold???
- The infamous Cali. Smog Question
- PLEASE help with engine code!!!!
- DA Integra Hybrid setup
- My B18C1 hybrid doesn't want to start after sitting for a few days...
- Good shop for a Civic B18 swap in Ontario, Canada?
- LS/VTEC USERS/PROS/GURUS/ETC.
- Anyone know where to get a 1.6 SOHC (non-vtec) JDM Si-R cam?
- 94-96 Integra susp. swap into 92-95 civic? vice versa?
- 1st gen b16 worth puttin in a 92-95 hatchy?
- CTR & ITR cam project or TODA/JUN-TARGETING 190 WHP
- My friend bought a stolen engine and had installed it!!!
- JDM Steering wheel
- Milled Ls/vtec head?
- prelude powered crx
- milling the inside of PR3 pistons or rods
- will b18c1 tranny mount fit onto a b16tranny
- Throttle Body choice for Modded b16a Swap
- Guys, how heavy is a b20?
- obd1 and obd2 questions
- ITR B18C5 into 92 Civic: Will Civic fuel pump be enough?
- JDM header on a 95 civic coupe w/ B16a
- can i swap in a 90-93 integra GS-R engine into my 98 civic ex?
- 99si b16a2 ?/ p28 chipped or p73 97/98 ecu?
- What rad. hose for 5g b16a swap?
- how much did you pay for your paint jobs???
- anyone know the pin out of the p13???
- exactly what from a R can go into an EK?
- BEST PRICE ON A B16A?!
- 97 B18B in a 2nd Gen (92') Integra...Swappin Questions!!!!
- WHERE CAN I GET THE BEST PRICE ON A B18B?!?
- alittle EnginE iNfo PLEASE?!
- Redline on jdm b18c?
- GOT A POLL!!! B18B OR B16A?!?!?!
- hybrid experts please help!
- help pistons or cams???
- 92 civic cx a good start?
- price for b18c
- B18C vs H22A.....which to go for?
- JDM or USDM engine
- LSvtec to CRvtec
- SHOP NEEDED 4 CRVTEC CONVERSIONS.........
- Custom wire harness
- B16a header clearance....
- how much should i pay for a 1997 JDM ITR complete swap with 12k miles on it?
- Any hybrid people driven or raced a GT-S
- HELP!!!!!
- Swap in some Honda magic...
- D16Z6 TO d16Y8 HEAD SWAP HELP!
- which AEM intake for a GSR swap into a delsol?????
- ZC- O@ sensor placement
- Help Crx whoes!!
- what is NOT included when you buy an engine?
- b20 into 2nd gen crx... Shopping list?
- OBDII 97/98 P73 question for 99SI B16a2 swap in 96 CX
- D series/B series engine weights with respect to power for autox
- Where to find a LS-Vtec
- **anyone in new england area**
- CRV engine into a 6 gen Civic??
- poor performance from b18c1
- 95 Integra GSR Sedan - Swapping in H22A? Info?
- Anyone know a step by step process web site for this <Look inside>
- V-afc?????Tell me whats good and bad about it?
- Anybody have info for a EF to EG/DC wiring swap..?
- changing an 86 accord tranny to newer
- jdm pr3 pistons or usdm itr pistons?????
- knock sensor on ls vtec???
- Intake manifold swap for a B16Y7
- IAB Signal
- Where to order ls swap online??
- best way to wire for a swap?- long-
- head gaskets for a ls vtec
- water from tail pipe.
- Mini-Me
- whats the best way to get a 92 civic hatch to run 12's
- LS wiring
- Where to get B18C motor in either LA or SF area
- what front strut tower bar will fit over a H22 Accord hybrid? ('92 EX)
- need help choosing a motor...
- whats the weghit of an EK hatch?
- what should i do quick?!?!?!
- help...
- GSR ECU vs Integra Type R ECU
- Type R engine swap into 90 Integra GS
- disconnecting the rods from the pistons???
- ecu chipping vs. sfc tuning
- Type R engine swap questions
- Swap Laws
- Do i need a cable tranny???
- Civic w/LS distributor...
- Update on Car not Starting
- R to Del Sol
- B20VTEC Crate Motors???
- H22 P13 ECu
- deals on boring, balancing, honing, and milling
- Code 20.......WTF!!!!
- Need you help .... Where to get a 1st gen B16A in MD/DC/VA area???
- jdm cluster dimmer not working?
- what are good numbers for a compression check on a 1st gen b16a?
- 1988 hybrid wiring help
- Group Buy on HonData ECU conversions/upgrades
- JDM Tranny Swap
- tranny swap, question about shift boot
- I have a 97 civic dx need to change to a dohc what fits?
- how much, and how hard?
- Engine question (B18C1 & B18C5)
- Toda Spec A Cams in GSR or ITR motor.
- question
- ITR LSD in a 99 Si Tranny
- 6spd tranny swap??
- 1993 Legend motor/tranny into 97 CL
- Skunk 2 ecu reprogram
- B18B in EG6 w\ Y1 Tranny: Car wont Start, Detail Inside.
- who has a aftermarket oil pan (moroso)
- b16a wireing 101what do you think
- i found another one!!!
- Tranny swap
- where could i get some parts off a Y-1 JDM tranny?
- Oil squirters???
- Need some help, B16 swap in to a 90 Civic Si
- Injectors - Saturated or P&H?
- B16A.....into a 98 civic ex?? is it allowed?
- hesitation caused by ??
- Type R in a civic ex!!
- N e pics of JDM Eg civics ?
- B18C5 head on a GS auto
- boreding pistons??
- D16Y8 intake manifold on Z6 ?'s
- ITR Final Gear in a B18C1 engine (EG hatchback)
- GSR swap!!
- stupid question
- who wants to see a crappy car, PICS inside
- quick!?!?! how much will this cost?
- LS Auto Owners with VTEC Motors
- AC in GSR EG, need info...
- Need Help Only Getting 150 Miles on a full tank of gas!!!
- ls vtec setup
- Too Good of a Deal ??????
- starting problems....please help!!
- Is it the Block?
- jdm vtec
- Connecting Rod?
- b20a into a G2 Prelude
- vtec solonoid wireing help.
- Question for Hybrids w/H22A
- 1st gen B16a and 2nd gen B16a Distributor
- just crashed my R
- I Finished my Mini Me swap today!
- NEED HELP ASAP!!!!!!!!!
- Sohfast motors...
- NEED shop for SWAPs in New Jersey
- Texas Hybrid Laws
- b20z swap..good for turbo..
- LOOKIN for CIVICH22
- EF-9 B series swap
- Identify JUN Valve springs!
- Please help! LS/VTEC Engine Swap but engine will not start up
- My new toy........... GRAPHIC INTENSIVE!!!! No dialup's, you'll regret it!!!
- ITR suspension on EK Civic?
- Which Injector for ls/vtec?? venom?
- B18B with Y1....Which Intermediate Shafts, Axles?
- toda or jun intake cam with ctr/itr exhaust cam
- Who has the wiring schematics for a P72 ECU?
- How many Hybrids in Los Angeles
- Don't Just look.........REad..........Help.....
- CX civic with B18c1 owners, I have one question
- convert b16 to b18c5
- Chicago Hybrid People here?
- max angle?
- Which A/C system to get?
- Questions on H22A into a 93' Delsol
- Cams in a b16a 4th gen
- stock b16 manifold?
- Best suspension for a H22 EK hatch.
- obd1 p72 for a si or ls/vtec swap??
- HOW much can i get for selling b18c1 block?
- half carbed ex motor on the street.........
- Quick question!
- 93 B18C1 into 93 CX, I have a couple of questions
- 97 ek strut tower bar
- Very techincal problem, Help, Help, Help !!!
- [REAL Hybrids from Thailand] Prelude with Mitsubishi 4G63T engine
- [REAL Hybrids from Thailand] EG Civic with Nissan SR20-DET engine
- [REAL Hybrids from Thailand] EK Civic with Toyota 3S-GTE engine
- OBD II motor into OBD I car...what to modify??
