PDA
View Full Version : Hybrid / Engine Swaps
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 [32] 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174
  1. Noob Q: interchangability between H and F series?
  2. E-85?
  3. dpfi swap to mfpi problem plz help!!!
  4. GSR won't start (no CEL, no ignition)
  5. Another EJ Swap Question
  6. B16 head swap
  7. wanted: honda tuning june 2006 "cool Combo's" section
  8. Final Pre-Swap H22a/EJ Swap Question
  9. Swap in socal
  10. installing dsm's with stock bottom seals
  11. CRX and Brake options. and 5 lug conversion
  12. bad idle :(
  13. lllll Japanese Motor Import--Anyone bought from them before? lllll
  14. B series cam gears, valve springs and retainers compatible with h22?
  15. hybrid em
  16. sohc vtec head
  17. does anyone know the 92-96 accord half shaft length??
  18. innovative cable to hydro conversion kit???
  19. Idle Problem
  20. My shifter has alot of play- already put in ES bushings, new bitch pin... HELP
  21. HELP... B20B into EK running rough
  22. auto to manual EK questions
  23. H22 92-95 civic axle ???
  24. Help How to tell a JDM p73ecu from a USDM p73
  25. Help with s2000 cluster into eg (speedo won't go over 50KM or 30MPH)
  26. 6month old swap. Randomly doesnt start
  27. Hasport h22 crx mount questions
  28. I NEED SOME HELP
  29. b16a rear engine mount
  30. z6 head y8 block
  31. Building B series from scratch
  32. b16a2
  33. K20z1 in 2000 Integra Type R (DC2) swap questions?
  34. eg auto to manual swap mounts
  35. Where 2 find H22/AC Bracket??????????????????????????????????????????? ??
  36. b18a1 od1 ecu
  37. B16 TRANNY ON H22A
  38. H22 Head: Euro or USDM?
  39. Accord OBD Question?
  40. 97-01 b20 swap in to a 90 gs integra
  41. ls/vtec what head?
  42. H22 into ek (wiring resistor box)
  43. CV bearing question
  44. H22 into eg Question
  45. B-swap into EJ8 questions
  46. help needed a couple of swap problems
  47. Any parts Detectives than may be able to help?
  48. which K series to go with ?
  49. JDM H23 Vtec swap to a 96 Lude,,,P13 ecu
  50. Which engine to buy? B18C? or H23?
  51. I used a DA shift linkage on my swap and it does not feel right. LS into EG
  52. fidanza flywheel help
  53. h22 eg
  54. ~~~HELP~~~ OBD2a car... OBD1 engine... OBD2a ECU??????
  55. please help EK h22 swapped hatch problems
  56. obd2b to obd1 and keep airbag?
  57. when its WOT the motor shuts down?? HELP!!!
  58. JDM H23 VTEC fuel line HELP
  59. NEED HELP With My Civic!!!
  60. H22a turbo vs H2b turbo in an EF
  61. what need to be done for a h22 swap
  62. gsr swap HELP
  63. any1 done h22a4 in ek and keep obd2
  64. will usdm itr/gsr radiator fit on jdm itr core ???
  65. brake upgrade
  66. Which axles to use with a jdm B18cR engine swap
  67. S2K converter info - UP TO DATE AND DIRECT FROM SUPPLIER!
  68. F23 / F22 / K20 ... EK
  69. My 91 teg with B16 swap won't pass smog?
  70. H22 vss question?
  71. what should i do for reliability?
  72. EG WITH OBD2B GSR NEED LIL HELP
  73. what parts i can reused from ls to ls vtec
  74. 94 hatch+k20a2+ac
  75. NEED HELP( B18B SWAP INTO 94 CIVIC)
  76. Buying individual retainers
  77. How to tell OBD2A or OBD2B
  78. specs for a K-series
  79. K swap emissions test
  80. 95 gsr manual engine and trans into a 98 ls auto. HELP
  81. Proportion valve id help
  82. type R fuel line ?
  83. P28 or P30??
  84. Check out this Hybrid......not honda(RX7)
  85. k-swap in 90-93 accord
  86. need halp with injectors on h22 swap
  87. Any B20Vtec Supercharged out there ???
  88. H22a swap into 95 accord ex
  89. b18b into 97 civic EX
  90. D-series DC "94-01 integra"
  91. h2b kit for ek in the market
  92. b20 into ek question
  93. 1996 Civic CX hb with b16a1 swap, what catalytic convertor?
  94. Simple question, search yielded no results
  95. how hard it will be to wire 98 base auto into a 92 civic
  96. ls/vtec eg slipping out of 5th
  97. HELP!!! Shift linkage GSR to EG
  98. s2000 cluster problems
  99. h22 swap wiring question???
  100. 98 EK H2B build!!
  101. Engine crooked *LS into EG*
  102. crx h22 code 22 need help please
  103. b1c block ls crank need help????
  104. Better swap for EK H2B or F2B?
  105. H22 90-93 Integra swap - small write up.
  106. quick question!! (f2b related)
  107. JDM civic type R EK pedal set installation on EJ6 CDN (HOW TO)
  108. Need serious help... wiring h22 egr up in 99-00 ek
  109. Power steering hose EK EJ vs B18c Type R Replacement
  110. H22 mounts
  111. question
  112. K20 Motor position with Innovative Mounts - EG/DC
  113. H2b Pulley??
  114. LS/VTEC question
  115. Swapping OBD-1 B18A into EG HELP!!!!!!
  116. H2B Air conditioning
  117. HELP i need the ecu wiring diagram for 94-96 integra LS only thanks guys
  118. b20b swap in ek doesnt start
  119. B20Z ecu question
  120. Is there a " official honda muffler dimensions " thread?
  121. b20vtec questions
  122. is this true prelude b20 crank in a b18c1?
  123. Least expensive way to go K-Series
  124. JDM B20 into EK---- Loom and ECU
  125. HELP WITH H22 EF WAGON SWAP
  126. Burning lots of oil...
  127. h2b in a da question
  128. Auto H22 harness for EG H22 manual, anything ive overlooked?
  129. MPG build EF hatch
  130. **l OBD2 swap into an OBD1 car...Questions!!!!!!!**l
  131. Valves hitting pistons
  132. The code 43 paradox
  133. NEED HELP on LS swaps EXHAUST SYSTEM in 94 civic!!
  134. When buying a motor how can you tell if it is good/
  135. b20 and the pcv
  136. trying to figure out which p2e ecu i have
  137. obd0 to obd1 no start need help.
  138. DA with OBD2 ITR Swap. Need help with problem!!!
  139. chippin p75's
  140. H2B timing belt bracket
  141. quick question about chips for my p30 w/ h22
  142. '97 Accord with H22A Euro R Gurgling noise...WTF!
  143. rwd k20 ef
  144. b20 throttle body in ek... no iacv??
  145. b20vtec timing belt snapped..help
  146. wilwood brakes
  147. air conditioning (h2b)
  148. 5 different sensor CELs - ground problem? OBD2a B18C into OBD2a Ek
  149. Swap from N1 Concepts??...
  150. Picked up a 99 Civic Si today and discovered a pleasant surprise....
  151. need help with hybrid axle,
  152. what to change to convert to obd1..??
  153. turbo ls/vtec build????
  154. Jdm p2t vs Usdm p2t ect
  155. gains from cam timing
  156. HELP!!!! Idle problems with swap!
  157. Are an h23 fuel reg and a b18c1 fuel reg the same?
  158. 4x114.3 rear wheel bearing size?
  159. I need a Pinout Tool!
  160. Green Cars are Sexy
  161. Is it possible to mate a B series motor to a D series tranny?
  162. VSS and VTEC engagement
  163. LS/V PISTON???
  164. h22 (h2b) temp gauge issues.
  165. Timing off by 1/2 tooth due to head milling (need advice from expert on engine combustion)
  166. Obd1 to obd2 help
  167. intake for ek civic with gsr motor
  168. can i use obd2 ecu for h22 swap
  169. 96 Integra LS going to OBD1 quick question.
  170. s2k cluster in a DA?
  171. Having problems with OBD2 to OBD1(colors are different than other posts)
  172. B series timing belt covers , which to use
  173. 95 gsr into 93 civic si hatch confusion...
  174. Need b16a obd1 wiring/troubleshooting for swap in 91 CRX
  175. ek rear t bracket question
  176. h22 block and b20 head will not start please help
  177. Type R ECU???
  178. ESP H2B/H2D/F2B/F2D Front Torque Mount Kit Traction Bar System EG/EK/DC
  179. need HELP with my shifter cables
  180. help putting obd2 gsr motor into my 94 gsr(obd1) what do i need to make it run/legal?
  181. first swap in israel - D14 to ZC eng
  182. B16A CRX - Axle hitting shock fork
  183. first time doing h swap. need help badly
  184. h2d with a twist questions
  185. Need Help:REF won't allow jumper harness(crx/b16)
  186. B18a1 into 89 CRX HF
  187. EF H2B Hood Clearance, is it a
  188. 98 B20 in 99 Ek
  189. Texas- Where to find a respectable shop to do a swap?
  190. K20a into EG Wiring write up
  191. Definitive list of axles for B16A swap into CRX
  192. Where to buy low mileage (JDM) B1B engine?
  193. b16a2 b18c h22a all have the same flywheel bolts???
  194. b20vtec..rs machine pistons..clearance..
  195. b20 vtec help..please
  196. 98 ls auto swap w/ 95 gsr manual
  197. 95 gsr into 93 civic si hatchback wiring questions
  198. hopefully done with b20 turbo build(need guidance)
  199. H22 Ek swap..... FIRST START WONT START
  200. F/H2D and F/H2B EF mounts from Hasport and Bisimoto
  201. B20 Swap Cost
  202. Replacing Drivers engine mount...Washers needed?????
  203. mfactory 3.070 gear information
  204. Front knuckels?
  205. USDM and JDM Integra hand brake cable identical ?
  206. Where do i start????????
  207. Where to find uprated axles 4x100
  208. What do H22's run???
  209. ek9 master relay location?
  210. 96 gsr into 96 ex manual??? <---
  211. LS VTEC sluggish acceleration
  212. My B16 swap all done... Befor and after :)
  213. what half shaft to use with my h22a4 swap???
  214. what rear mount to use for my 92 h22a4 civic???
  215. Accord SOHC VTEC engines into EF civic??
  216. need some help on axles for my h22 swap with accord tranny in my ek99 hatch thanks
  217. H2B ground clearance & engine angle
  218. What axles?
  219. HOW MUCH? 99' EM1, k20a(type r), chassis 59,xxx/engine 15,xxx
  220. Question about core change for axels b16
  221. d15z6
  222. Mini-me d15b8/y8 help pls
  223. quick prelude intermediate shaft question
  224. ELECTRICAL HELP PLZ!
  225. Anyone here in H-T have a H2B EK with Evolution kit??? if so read...
  226. oil cooling options for ls/vtec
  227. a/c and p/s with h2b conversion
  228. H2B cooling question
  229. OBD1 Gsr in OBD2a Civic Dx CEL Errors
  230. s2000 gauge cluster working/customised readings and NO BOXES.
  231. finding motors
  232. 94' DelSol LS/VTEC question
  233. why was the post locked about the guy asking about a k20 head on h block?
  234. exhaust for 99 coupe with b18cR
  235. Official oil pan ground clearance & Axle angle PICTURE Thread!
  236. Oil squirters required for cast pistons?
  237. Please Suggest : B18c(typeR Redtop frm DC2) in a EG/EK
  238. B16 swap into a Ford Escort
  239. h22 transmission with f22 4th and 5th?
  240. DOES ANYONE KNOW THE ANSWER.
  241. What are the Odds of a bad Motor?
  242. 89 civic HB B16A wiring problem!!!!!!!!!!!!!
  243. Need some H2B HELP !!! Won't go into gear
  244. '97 Accord with H22A Euro R running chipped OBD1 ecu IACV wiring help
  245. EG To Ek Swapping Questions?
  246. o2 sensor wiring question
  247. ek civic B swap- AC mount
  248. What oem intake for 92 Civic with B16A2 swap?
  249. doin a small swap and am having major problems
  250. Searched but could not find
