View Full Version : Hybrid / Engine Swaps
- Can Someone Match These Alternator Wire Colors For Me See Picture Inside
- I need axle advice!!!
- Hasport EG Hyrdo-Cable Trans Conversion Questions.
- H22A in to my 94 accord
- h2b dizzy ?s
- need help!!!!
- H2b w/b18c1 trans questions.
- K20A3 Swap 97 civic Sedan?
- Enhancing performance of a Civic Hybrid - Has anyone tried different plugs?
- which axle? b16civic
- EGR Vacuum Control Valve and Solenoid H22
- EK w/ Mazda Rotary mated to K series tranny
- D15b o2 sensor question....
- Will a 1997 B20 block work????
- First timer doing a swap, EJ2 getting a GSR, ok to remove power steering pump?
- B16A swap 99% complete, Honda GURU HELP needed!
- which power steering pump do i use
- H2B axle helpp!
- Air conditioner.
- 96 coupe ---pulled 97gsr motor---> swap in JDM LS b18b help
- B18c Harness
- B18B head....
- B18C into '91 Integra, need some help
- Code14 Wont GO AWAY =[
- f2b
- Ls/Vtec GSR head problem :(
- 91 jdm b16a and gsr tranny swap
- b16a bottom end and b18c1 with type r valvetrain in 99 ex?
- air conditioning possible with a k series swap into an eg/dc or ek
- jdm 96 type r swap in 95 civic si
- !i!i! (K20 swap info) i!i!i!
- f23/h22 in a 90 cb7
- Fitting B16A into Ford Fiesta ECU Problems
- f22 swap into a Del Sol
- h2b in 5th gen lude?
- k swap questions; searched and didn't find this out??
- So I've been searching and I think Megan Racing has the Best Cheap Header to Mod for H2B/2.5 Collect
- B20 Swap from an integra into my del sol
- I'm new, got a del sol and need engine swap help
- B18b/B18c
- engine mounts
- DC suspension on DA question
- Can anyone help me wire up my DA H2b
- b16 gen 1 gen 2?
- Couple quick questions about the F23 block!
- h22 Battery / Alternator Problem
- 2000 si b16 into 96 ex?
- please help
- NEED Electrical help ASAP b18b OBD2 into 97 Civic EX No charge!!!!!!!
- rear disc brake conversion 94 accord lx 2 dr 5 sp
- where can i buy those ecu pins for pinout modifications?
- 1988 accord dx, what swaps available
- Is 92-96 h22 header different from 97-01?
- auto to manual
- Engine stabilizer bolts spin in place...
- GSR in a CRX what rear mount?
- starter wont work help!!
- 00 d16y8 into 96 hatch?Obd2b engine into a obd2a hatch? configs!
- brand new motor, lil leak :(
- AWD Wagon, CRV Tranny??
- d16z6 into 88 civic dx
- Rear bracket
- H22 Eg intake question
- Which clutch for H2B??
- carbon syncros....anyone!?
- B20z2 swap question????
- EF B swap help!!!!!
- 96 civic axle and bearing probloms
- JDM b18c into USDM GSR
- please help bogging
- 1st R swap
- h2b av1 integra
- removed SRS unit, still have SRS light
- b16a rods on b17 crank!!
- H22a ECU
- no tach...ITR engine harness OBD2b and 92 CX sub harness with P28
- r18 pistons.
- B20B swap won't start...I've searched.
- how to wire a 93 cx car-side harness to a 4 wire 02 sensor for b16 swap
- B16B type r motor HELP ME!!!!
- what else do i need with this??? please help
- f22b2 block h23 head is this possible?
- B18C5 swap
- obd0 to 0bd1
- EFH1 Problems
- Headers for a JDM f22b DOHC ????? 93 prelude si??
- EG/EK H22 Swaps - - What Size Tires Are You Running?
- Do I have to do this with the QSD kit too????
- h2b T bracket
- did cable to hydro need help
- GSR rear disk swap onto ek troubles.
- blox intake manifold with stock throttle body
- b20b swap
- b18b1 into ek coupe
- f20b in 97 accord
- h22a tranny
- Swapping gear sets and diff from Hydro case to Cable case whats all involved???
- h- series franckinstiens
- eg hatch/ls rear t bracket install after engine/tranny drop
- How-To: H22 Swap into a 96-00 Civic (135 pics) by: GenuineRolla from shockerboys
- Quick and easy question re: b20 ecu
- What to look for in a swap?
- B18a1
- GSR , LS, or B20 BOOSTED???
- h2b mount
- Help! Type R engine into GSR Car
- JGE valvetrain???? good or waste of money??
- B18C or B20B??
- MEGASQUIRT( i want to try it for my k series build)
- 1996 civic ex gsr swap question.........
- B series axles male or female half shaft into an Ek
- Pr3 ecu question
- trans issue. spewing fluid WTF?
- my car cranks but not starting
- Stupid injectors!!!
- wont start after swap
- need vtec wiring diagram
- b16 swap into 92 civic dx
- f23/h22 question
- Jdm itr axles
- WILL A B16A Sump FIt A B18C2 ??? :)
- 5 Lug Conversion to EG questions
- Calling All Emissions Specialists - high NOx, and yes I did my research
- 95-ITR cams
- b20 swap question
- '00 acura CL navigation into integra????
- 2000 jdm b16 swap
- b20 swap question
- B18b dilema
- My H2b 2000 GSR Build/Restore - Theft Recovery
- f22b DOHC>> ????? trans cable
- Lsd worth the extra coin??
- H22 Swap with RSX shifter
- Difficulty of swap: 96+ obd2 into EK VS. obd1 into EK
- cvcc swap
- B18C1 into 96 ek D16Y7 question...
- b16a hp ?
- new rings or new motor
- Evolution kit into eg questions
- b20b in an 94 integra, which rear motor mount?
- b18b in a 98 civic dx
- H22a Eg6 ITBs ? ? ?
- HELP! OBD1 CONVERSION
- DC5/FD2/FN2 Steering Wheel into an EG
- 14400-PT2-004 Timing Belt for what engine??
- need help with crank
- Any Suggestions on an H2B Header, Because I'm having a Problem here
- how to: obd2b engine/harness/distributor is obd1 integra chassis
- Vibrations Under Acceleration, Lack of power. Please Help
- coming back to the honda camp with a eg h2b swap plans!!
- intake for swapped DA
- b16a instruction needed
- OBD0 ECU question
- Hasport vs. Hybrid Racing K20 into DC Motor Mounts
- k20z1 swap in ef help
- ENgine Torque damper question?
- ek torque mounts
- K24A1/base RSX tranny mount puzzle
- how to tell oem lsd gsr differential vs. aftermarket?
- JDM H22A fuel milage
- help motor problem
- F23/H22 question
- Headers
- HOW TO WIRE evap purge solenoid to P28 ecu PINOUT b16a2 SWAP
- Is a/c even possible on H2B??
- EK H22 Axle problem. Wrong axles or need to be modified
- h22a
- F2D hybrid tranny question
- OBD1 P75-A01 PINOUT????
- 91 da b18a1 into 92 eg hatch
- Where to buy h22 longblock??
- 97 civic ex distributor
- f22 axle
- p28 ecu question
- h2b quick question??
- NEED HELP WITH LS SWAP IN EF!
- H22 EK axle/tranny problem, help Please
- NEED HELP BAD!!!!
- Whats the correct starter for my set-up?
- H22 with F22 transmission vs w/ H22 Trans. Looking for actual 1/4 mile data, anyone?
- Reading Codes
- 99 gsr motor in eg - tranny or clutch problem
- is a 96-98 HX Engine Harness same as an EX 96-98 ?
- EJ8 Coupe Swap Possibilities
- H22 > CRX BAR'd + Smog in CA?
- Sluggish H
- Help: Upper balljoints replacement
- AVID Motor Mounts
- h22 dizzy wiring
- D15B non vtec to D16Y8 vtec swap
- What is The cheapest and best site to get the alternator relocation bracket for H2B
- start up woes- ( tach, speedo problems)
- Need Help With Engine Wiring
- EG and DC Top Driver Side Mount the Same?
- knock sensor?? wont rev up right
- check light after swap?
- b20 ek swap help!!!!!
- my h22a4 EK runs!
- H22 civic swaps with lowered suspension - how low did you go and how's clearance/axles?
- D16z6 oxygen sensor wires??????
- d16z6 in 4dr EF want to hookup A/C and P/S
- h22 / p13 ecu in civic - EGR issue, any way to eliminate?
- possible kpro ecu problem... any1 got one?
- f20b block with h22/h23 head? possible?
- WHAT AXLES FOR CABLE TRANS IN EG SOL ????
- B20VTEC
- obd2a h22 motor in obd2b car
- H22 Vacuum Line Issues
- Grind the gearbox bolt? H22 EG civic swap
- JDM DOHC F22B TIMING BELT
- HOW CAN YOU TELL????
- Need help after new swap!!!!!
- need advice!
- f2d auto
- Speedometer going crazy
- jdm b16 block onto usdm head/transmission
- Power steering: Civic rack, prelude pump
- few ?'s about the p30
- stock ITR springs fit on stock 92 civic CX shocks?
- Hybrid H build and stuck
- wiring jdm f20b in a 97 acc
- D15A2 question
- D16y8 into 94 CX
- GSR question...
- JDM B16a ecu help
- h22 swap....please help.
- Accord K tranny
- Ek civic H22 swap info. Some questions need answers.
- B18C vs. B20vtec
- Is it possible to....
- Whats The Difference Between Regular ACL Bearings And ACL Race Bearings
- clutch dilema
- What to do now? JDM H23A VTEC OBDII swap into 99 Accord Coupe
- ls integra swap
- ***aftermarket shifter cables for k-swaped honda?***
- OBD1 y8 q's
- 93 civic with an h22 wont run right
- I want a safe rev limit
- JDM H22a Auto
- H22 Swap Axle Thread.
- EJ H22 Idle Problems- - - Vacuum? Fuel?
- what kind of gas mileage?
- LS/VTEC Oil Passage?
- Need Help with H22 swap EK CEL 16
- Motor Mount ???
- OBD2 ITR harness into 92 EG with P28, Do I need to make any wiring changes for the OBD2 distributor?
- b16 coolant leaks
- LS Vtec
- h2b dc2 help
- b16a1 swap using stock d-series radiator, running hotter than normal
