View Full Version : Hybrid / Engine Swaps
- 92 Civic VX/B18B1 swap - code 41
- Finally k20a3 in crx
- f20b high idle/iac
- CR-V B20B4 to B20Z2
- 96-00 b18c into my eg.
- Deutschland, home of the unmolested Hondas
- B20B with D16y7 harness and 0bd1 p75 ecu
- Rywire buget B series
- F20B front engine mount bracket
- DX EKcivic swap WIRING QUESTION please help
- 85mm destroked CSS b20v 1st build opinions & advice needed *pics*
- h2b lack of power and inadequate fuel pressure
- B18c4 swap problem :(
- 91 crx w/b18 question
- Suggestions for engine swap!
- Does anyone know if I can fit a d1.5 engine onto a D1.6 transmission ?
- B18c b20 build
- 97 prelude h22 to h23 swap
- F20b swap running rich/no vtec
- Power steering
- 95 GS-R 5 speed swap into 98 Civc EX coupe Automatic (Full Conversion)
- JDM B18C in EK exhaust / catalytic converter fitment
- d15b7 to d16z6- can i use the d15s trans?
- what head os best for a b20b with gsr tranny b16b or a type of b18?????
- Will B16 harness work with lsvtec
- Obd2 with obd1 motor
- Ls vtec Periodic stalling/ loss of ignition. HELP ME PLEASEEEE
- F20B IM IACV Fix
- d16y8 engine harness with no evap purge solenoid plug?
- Intricacies of K24A (jdm) swap into 7th gen Civic
- G23 Head Gasket
- built b18a1 vs ls/vtec
- H22A codes 3, 7, 8, 9, 10, and 22
- HELP ME!!! will be the most difficult swap question of the forum in years ???
- H22a EJ6 hatch
- 1990 Ef civic B16 hesitation
- engine swap b18 or a b16
- May have found my Idle issue on my B20 Swap
- OBD2b No Tach
- 92 eg f20b swap with a h22 lsd issues
- Awd civic
- Need Help! Obd2b engine/harness/ecu in Obd2a Car
- 91 prelude with d2a4 tranny and a f23a engine?
- Need opinion on buying a swap
- Rewire Dash harness possible? OBD2A -> OBD2B
- F23A1 Turbo Swap -> 95 EG Sedan
- Help Please - 85 Crx Obd-0 To D15B Vtec Obd2a
- jdm b20b crv ?
- 94 GSR misfire/struggling to stay on
- Re-use JDM Harness??
- 98 Accord coupe v6 swap issues
- runs fine for random periods, stalling then not starting
- B7 Intake manifold on Y7 question
- EJ8 D16A swap?
- 89 accord lx-i motor swap options
- more F20B questions.
- Need your help!
- Mini-Me my Girl's 95 LX
- SOHC ZC OBD1 in EF hatch OBD0
- B20 wiring
- Honda CRX HF engine swap questions and opinions
- 96 civic with b18a/b swap - EGR block off vs EGR delete
- H22a swap questions
- lsvtec
- My 85 Corolla GT-S build / F22c swap thread
- D17a1 head swap
- 92 eg hatch b20b swap issuses
- JV6 miata swap car checking in
- B20B wiring in a non-honda copnversion
- What i should do with my 1999 civic si
- B20b project 99 EJ8 Help
- Blackworks half core radiator
- b20b hi comp into 1990 integra da9 help!
- need help on my swap
- 91 hatch d16y8 swap/ radiator suggestions
- Gsr Swap Into EG HELP!!
- 99 civic hatch project motor Trans swap questions
- B20b or b18b1 swap for daily driver
- CRVtec swap into 98 Civic.
- Fully built H22A or Fully built H2B
- B20 Swap please help!!!!!
- H22 Head Stamp Question
- D15b and Y7 swap
- Need info for swapping my cd4
- Best engine swap!?
- Auto Tranny recommendation needed, B18A1
- Fix - Hot air coming through shifter?
- B20 head on b18b block??
- B20V css 85mm b17 crank turbo
- Need help reinstalling air conditioning!!
- Which gasket K24Z3 + K24A2
- Ls swapped civic build thread
- D16y7 engine in a vtec1997 Del sol
- What dizzy do I need?
- Planning dc2 h2b swap
- 93 cx eg part list for a jdm 1998+ ITR trans
- 92 EG -H22A/H2B - Zero crank - All power to dash
- 1995 Civic Ex: transplanting a '99 b20b with 5 speed from CRV
- Oil Cooler replacement.....help
- N22b
- Timing on Frankenmotor
- 2000 EK Civic with a B18c4, where to go from here ?
- Building a '99 b20b non-vtec dohc with 5speed from a CR-V from my '95 Civic EX
- RDX injectors in B18b in 94 EG
- H2b balance shaft elminator
- 98 Civic - CRVTEC engine swap
- In need of help. 93 hatch
- NEED HELP WITH MY H2B DIZZY
- ****LS B18 SWAP IN 98 CIVIC *** HELP!!!!
- D15B7 to B18A1swap info needed.
- b16a/b18 block
- Anyone ever seen a BAR'd J swap?
- h22 in eg bubble
- J35a4 Miata Swap
- b18b vtec
- Kpro error ignition off
- 2000 civic ex d15b7/96 y8 head help
- Dc5
- H2B EG hatch - Alt Relocation Kit Question
- I need help
- K24Z6 possibilities?
- First Question Of Many
- 91-96 H23A with 96-01 H22A Head.
- OIL PROBLEM I NEED HELP!
- 1993 Civic EG h23a swap electrical issues
- f20b dohc vtec into ek9 hatch need help
- f20b dohc vtec into ek9 hatch need help for parts
- 92 EG Hatch - HH2A EuroR - Header clearance issue
- H2B swap intermittent Vtec issues
- 95 GSR jdm into 99 civic ex HELP.
- h22 eg motor angle?
- F20b swap
- Civic with h series swap doesn't want to stay on???
- B18A1 84mm bore questions.
- SWAP HELP NEEDED
- B Series Long Block Weight
- OBD2 SOHC ZC non-vtec into eg/del sol?
- B18C OBD 1 or 2 question
- Ls to gsr in a eg
- Looking for a good shop to get an engine swap done at.
- Y5/Y8 hybrid, ran fine now won't crank or start
- F20B Swap into EG Coupe
- D16Z6 running on P2P ecu
- h23a swapped ej1
- LF RSX-S shifter mechanism
- Need help! Car dies like it lost Power.
- B18 gsr-r swap into 97 civic EK hb
- 93 hatch with h swap won't crank or start
- 00' civic with h series swap not starting
- Car going crazy
- I'm conflicted
- Gauges stopped working
- Boosted b18b1
- h22 k2h rbc intake manifold need iacv?
- EM1 steering rack!
- H22a4 del sol won't turn on
- Steve
- Gauges went dead
- D16 auto to b18
- engine torque damper with billet mounts
- intake manifold clearance question
- B20 into 96 civic
- Help! B18b1 into 1990 integra
- Code 21
- Help!!! D series to b series. Won't run
- Help choosing a catalytic converter for a B18C1 with 00 GSR exhaust in an EG
- Power steering in EG 4dr GSR swap
- 1993 honda eh si hatch h22 swap HELP!!!
- H2B lacks power help
- CEL code 20 Canadian Civic
- will this distributor work?
- 1996 integra engine mounts not lining up
- Need help with motor blower plz
- H2B Obd2 question
- QSD vs EVO kit
- At wits end..... constant No start no crank symptoms B20 swap. help!
- what is this connector?
- Code 9
- D15B into a 95 DX
- need help building a b serious engine for my ex civic
- Engine swap
- b18c civic.. intake help!
- Ultra series street skunk2 im
- H22A Engine swap
- 1998 HONDA civic engine swap
- B18b1 with B16lsd tranny. Headers? Help plz!
- Adding A.C. to my 94 EG H22 swap
- advice on h head f22b build
- hesitation issues (still) on my H2B swap HELP......
- Best place to buy Innovative steel mounts or something similar in quality
- 06 rsxs (k20) motor into ef hatch
- k2h shifter swap issues
- swapping d-series engine
- Sputter bogging problem
- 1999 b16 into ef. Need wiring help
- Erratic Speedometer after CKF delete/fix.
- What Swap Is Right For Me
- Error code 20 ELD after swap
- How to tell which halfshaft i have for my h22 swap?
- H2B ac
- Ls K20 Swap Cost By a Shop?!
- ANOTHER OBD2 engine into OBD1 car swap Thread - **PICS**
- LS Engine rough idle/misfire etc.
- F20b fuel problems
- B18B1 swapped 98 EX power loss while driving.
- Swapping B18B1 into GSR shell
- y8 swap in 2000 Civic CEL on
- 2000 prelude type sh with h23 cranks but doesnt start
- B18B Engine Swap, Need HELP
- 1996 Civic ex w/ gsr swap header/ exhaust options???? Please help!!
- Anyone have any experience with a half shaft making noise?
- 2001 honda accord
- 1999 civic b20 dies after 5 mins of idling
- Trying to build a B20B into a 1995 Honda civic coupe
- H22a eg- gifted motor dyno!!
- Oil Pump Q&A
- thinking of doing a motor swap.
- H2b Motor sitting on a side tilt
- Need some input for a swap
- Identifying correct pcm?
- Engine swap '99 Civic EX
- 2015 Type R Turbo Conversion
- Best swap for a Honda Civic dx hatch back please help!!!
- H22A engine Harness in eK
- Need help b18b1 swap on 96 ek ..tranny mount or bracket
- B18C into EG hatch just a few questions
- Fuel tank floor lid after AN conversion
- EJ9 D14Z2 into D16ZC ecu not detected?
- B20B Injector problem? HELP PLEASE.
- Help with d15b8 to d15b2 swap/ecu
- LS Swap using B20 dizzy in 98 EX, no tach.
- wiring 2001 B18B1 CKF (3 wire) to 1997 D16Y7 harness (2 pin) ignore black wire?
- Obd1 JDM B18c knock sensor code
- NEED HELP PLEASE!
- timing and skunk 2 ecu
- h22a4 eg hatch mis at idle
- P0117 ECT circuit low
- ek sedan with f20b rebuild
- z6/y8 combo dizzy help
- 86 crx 1.5 sohc
- My not so new eg
- do i have a mini me swap?
- jdm d15b(non vtec)
- H23a jdm 2.3 liter with DOHC......need info please
- Compression test and more
- h22 intake manifold
- New to engine swaping
- 0bd2b D16y8 swap knock sensor
- b18a1 in vw golf mk1!!
