PDA
View Full Version : Hybrid / Engine Swaps
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 [102] 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174
  1. First year the immoblizer was put into integra?
  2. intake sensor?
  3. ECU Problem for a swap
  4. b18b in an ek. bogging
  5. Please Help!!!!!
  6. b20z/vtec question? ITR part swap.
  7. Make me feel ok about my setup!!
  8. better head for a LS/VTEC swap a B16A2, or B18C3
  9. what size pistons?????
  10. cali smog- hybrid veteran help
  11. cat-back exhaust with gsr ek
  12. jdm itr headers ??
  13. type r oil pump?
  14. prelude hubs + brakes work?
  15. h22 vacuum bypassing the egr valve
  16. b18b1 swapper
  17. ZC swap, Axels? Clutch?
  18. 94 ls into a 99 civic swap ?
  19. Can you swap a B18 in place of a D17A?
  20. Brakes 4 my 'ReX
  21. b16a head pr3-4 what year and model did this head come out of?
  22. 92-93 Integra RS Transmission Work on B18C1
  23. I need some help
  24. Relocating ECU...Extending harness. Questions!
  25. H22A CARB BAR Legal Street Legal Anyone Out There? Make this the thread here.
  26. Stand alone?
  27. IT WONT FIT!!!!!!
  28. Get an EK or keep the EG...?? (H22 motor)
  29. Pictures of my H22 DC2 are FINALLY up!!!
  30. b16 swap to 98civic
  31. Civic H22 Pics......Something not right??? LOTS OF PICS & ??? !
  32. Need some help...
  33. Ls/Vtec tapped head on a b-series vtec block?
  34. B18C1 in 00 Civic DX what is needed?
  35. ZC swap, ECU?
  36. JDM H22a injector size???
  37. power gains/losses from rigged up exhaust
  38. ITR del sol swap w/ ITR ECU question
  39. quick question
  40. EK/ITR hybrid up and runnin'!!
  41. h22 eg w/ auto to manual swap wont start
  42. How do u tell the difference between b16 tranny and others
  43. obd2 ecu or obd1 ecu?
  44. couple of CEL codes with gsr ek
  45. b20 non vtec top end power?
  46. Need to change synchros in CTR Tranny..same as (US) ITR or 99/00 Civic SI tranny?
  47. OBD1 ---> OBD2 conversion harness??
  48. Stuck on what to put in my EH2
  49. s2000 motor in ek?
  50. Just dropped motor in and will not idle
  51. trouble with cel code
  52. All Opinions Please!!!!
  53. Replaced battery cables and now starter just clicks
  54. Help! what lower mount bracket Do I use for a cable tranny in a 94 dx
  55. mini me swap is done and car wont start?
  56. My H22A CRX
  57. h22 99 si
  58. SUSPENSION HELP 3rd gen
  59. Injector Clip Question...
  60. 94-01 integra H&R sports fit on an EG??????
  61. what ecu are you using with your H22 swaps
  62. B20A, B21A - New ideas and new thoughts
  63. Best place to find motor packages....
  64. proper fitment... crx w/ b16a... help please!
  65. need help asap
  66. JIM FAB traction bars into h22 civic eg today!!
  67. H-22 swap into an 97 Accord
  68. Does anyone have any pics of a b16a motor ?
  69. mini-me in 91 hatch need rpm activated pill where to buy it at?
  70. Anyone help me with CEL-
  71. d16 to y8 head
  72. block problem
  73. B18c block gridles?
  74. what belt to run on a B16a2 w/o AC in EK
  75. (98-99)b18b swap into 93 teg
  76. speedpeople.com sucks!!!!!!
  77. flywheel question
  78. accord/cl harness connect with 97+ h22 harness
  79. How much you pay for your P54 A/C bracket ?
  80. 92 z6 block with 99 y8 head
  81. Let me know what you Experts think!!
  82. tranny mount help ..... 94-01 integra???
  83. need help with 96 itr brakes
  84. will 1997 gsr breaks fit onto a 1991 crx si
  85. Which tranny mount do I use?
  86. b18c internals into b18a?
  87. TRANNY SHIFTING HARD??
  88. hondata....yes or no?
  89. Hondata in my crx
  90. putting Y8 in CX EG
  91. B21 ?
  92. H22 swap into a 97 Accord
  93. best way to transport a shell????
  94. Bar Approval on a K20a2 or K20a ( searched... )
  95. exhaust/header/cat
  96. Intake manifold!!!!
  97. b18b in 89 si wiring questions
  98. help
  99. H22 injector resistor box
  100. tranny problem
  101. swap ? d16y8 or d15b easier into 93 si???
  102. Any one using prelude injectors on their b-series motors??
  103. coolant sensor
  104. B18C5 into 92 Integra
  105. What OBD 1 B-series header has a O2 sensor?
  106. eg h22 shifter cables
  107. Anyone w/ B18C in EK HELP!!
  108. B16 swap in 95 EX wont start.....
  109. will siR shaft work with hydro?
  110. B20B/Z question (Did Search)
  111. Should I get the cat with the swap?
  112. obd2 d-series alternator on a obd1 b-series
  113. o2 sensor question
  114. Dilema
  115. my problem..
  116. 94 civic engine swap into a 82 civic.... can we do it?
  117. b16a swap into 1990 crx si
  118. '99-'00 si cluster in '93 cx with gsr swap...can't get vtec to work (vss-cluster-ecu related???)
  119. B20 VTEC Reliable?
  120. H22 wiring in accord
  121. jdm itr engine (did search)?
  122. b18b with auto tranny for my eg 4 door?
  123. obd2 - obd1 distributors, are they interchangable?
  124. sohc vtec head on a a6 block??????
  125. lsvtec reliability
  126. 92 gsr tranny
  127. b16 ????
  128. Which traction bars for an EG work/clear/fit with an H22 swap?
  129. OT: How much would you chare to wire up a VAFC2!?
  130. wiring help needed - obd1 lsvtec into an ek
  131. B18C1 into a 91 hatch
  132. water temp gauge
  133. new website
  134. 95 b18b1 in 85 crx
  135. Need Wiring Help, Please! JDM B-Series into '97 EK...
  136. Accord to EK H22A swap...
  137. h22 mounting question for 96-00 civic
  138. wat car do i buy a clutch for?
  139. Motor Mounts
  140. 95 ls with 92 ls tranny into a 90 civic hatchback non si
  141. B20/VTEC question....plz
  142. Another B series swap problem
  143. anyone ever use osaka motors?
  144. Need some answers regarding B20Vtec in a DA
  145. White smoke problem
  146. D15B7 mini-me
  147. b18c swap in ek
  148. is this fixeable????
  149. question on b18c5 and eg civic
  150. Getting my engine soon. What all do I need?
  151. del sol rear disk
  152. FS...today only...'99 gsr swap w/ '93 civic...San Diego...
  153. -{Need help on chage in clutch pedal due to swap? or installation?}-
  154. 97 ls into 96 coupe
  155. Intermediate shaft measurements please!
  156. LOUD NOISE SUPPOSEDLY COMING FROM TRANNY ON MY H22
  157. After swap, Electrical Charging problems....please help...!
  158. CL injectors vs. Prelude H22 injectors?
  159. Stroker Motor - Some build up pics
  160. which throttle cable in EG w/B16
  161. CRX Si wiring harness in a DX?
  162. h23 in a hatch
  163. Exhaust
  164. A16A6 non vtec change
  165. what would you do with my cat
  166. 98' H22 into an EG hatchback?
  167. Best tranny for an 97 h22a4 in a 93 civic 4dr dx?
  168. Y1 tranny synchros...
  169. Wiring conversion harness for ek to h22
  170. B18 Removal
  171. Disconnecting EVAP after OBD2 to OBD1 conversion with Y7 Y8 mini-me?
  172. b16a2 into 5g hatch mount question
  173. 4th generation H22's with Accord Euro R intake manifold question regarding intake application
  174. any differemces in 99-00 ex and si wiring harness?
  175. Rocket Scientists & Brake Specialists...
  176. *NEWBIE Q* GSR SWAP INTO EG
  177. What plugs are different between OBD1 and 2?(Civic/Integra related)
  178. what size cat do i need?!?!
  179. problem someone help
  180. OBD-0 to OBD-2 for BAR
  181. using a b16a2,3 with obd-0 ECU?
  182. H22 obd1 wiring into a obd2 99 CL
  183. Car doesn't want to run after I get gas?
  184. does b20 have knock sensor?
  185. B16a1 into EK?
  186. hasport S.W.A.P. tshirt?
  187. i need help with axles!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
  188. Integra petal assembly does it fit an EG?
  189. b series into eg, motor mounts?
  190. The truth behind low-priced JDM engines
  191. Fuel Line?
  192. headgasket crvtec.
  193. Hasport wiring help!
  194. Hybrid CRX axle question
  195. b16a swap or b18c swap which one
  196. h22 obd1 or 2??
  197. Can i use 99 Si ecu for my GSR engine?
  198. type R tranny
  199. obd1 conversion harness & hasport subharness
  200. new thought what about a all stock b20z in eg hatch with turbo !! No CRVtec
  201. CAn K20 fit in a 4th gen prelude?
  202. B20Z to EG swap parts list...?
  203. Tranny noise while decellerating and other issues
  204. What are the perks of the different motors?
  205. EF mounts on a 92 INTEGRA?
  206. b16 to b18c block question
  207. H22 Del sol,,, just need to clarify some issues...
  208. EVAP Canister Shut valve ?!?!?!
  209. obd1 b16a wiring in 88 crx hf
  210. 92 ls into 96 civic hatch
  211. automatic h22 ??
  212. H22A into EG/DC axel question
  213. Need some help on a few problems after swap...Please take a look...
  214. cherry picker
  215. Using 94 vx harness for JDM b18c swap. Where to run wires?
  216. H22A?????????
  217. ITR injectors w/ non OBD ecu...
  218. B20VTEC Question....
  219. i know i cant be alone on this one (swap bolts) 180$=2fawkin much
  220. h22, b18, b16, d-series....
  221. Another CA Smog Question
  222. 91 INTEGRA DISTRIBUTOR WIRES
  223. B18CR or B20 hybrid
  224. H22 into EG question...(i searched)
  225. H22 Eg Intake manifold Removeable?
  226. 1991 civic swap question
  227. What ECU(s) for b18b into 91 CRX Si? any wiring mods?
  228. Aftermarket ABS system?
  229. HELP on rebuilt engine swap...
  230. B18 SWAP INTO CRX
  231. transmission input shaft bearing? for b16 in crx
  232. I need confirmation on swap details please.......
  233. b18 ls swap does fuel pump need replaced?
  234. ABS from a ITR
  235. OBD0-OBD1 Conversion...
  236. knock sensor question
  237. Rattling noise
  238. which timing belt for ls/vtec?
  239. 99 si b16a2 into a 96 cx hatchback, wiring issues
  240. Please help me with DPFI to MPFI conversion. Will pay for your time and work. San Diego, CA.
  241. EG coupe with either GSR all-motor High compression or Turbo low compression?
  242. B18C Reasurrance!
  243. civic gsr nos
  244. 92 da teg b20z/vtec set up, could stock fueling handle motor?
  245. Bloomsburg OBD2 to OBD1 harness
  246. Difference in Axles for 96-00 Civics
  247. bored out throttle body. which intake arm are you using?
  248. socal peeps: prospeed vs autolink?
  249. stock harness not fitting help!!
  250. Anybody have pictures or a k24 in ep3?
