PDA
View Full Version : Hybrid / Engine Swaps
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 [124] 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174
  1. What Size Piping..for exhaust
  2. GSR Ignition coil and plug wires..??
  3. Which CAR?
  4. help I need answers by tonite before I order tommorrow!
  5. Help!!! No fuel and no spark in B17 swap!!!!
  6. What knock sensor to use?
  7. wiring gurus i need your help!
  8. TypeR swap ?'s
  9. B16 with i/e what numbers??
  10. 2.0 L VTEC....B18 or B20
  11. Eibach Srpings in a 22 civic question?
  12. 6th gen EX exahust manifold on 6th gen DX??
  13. Where did you buy your swap from?
  14. is this gsr motor worth it?
  15. Stock EK Hatch Weights.
  16. Green harness under intake manifold on GSR motor?? IAB solenoid?? PICS inside!
  17. would a clogged ls/vtec line cause the MIL to come on?
  18. Anyone have pics on the shifter assembly for a h22 ek?
  19. O2 wire colors
  20. Difference in GSR and SiR B18c?
  21. What is this thing on the transmission?
  22. Streetimports?
  23. Having Problems
  24. did you use HCP or HASPORT for your h22 ?
  25. Brake rotor question???
  26. b18b and b20z cams, are they the same???
  27. Shifting Problems!!!! Help
  28. Skyline Motor
  29. Knock sensor woes
  30. will my GSR header fit on a b16 ?
  31. Distributor Question
  32. oil coming from valve cover breather
  33. Got a question ( I am a beginer) about swapping motors
  34. I got 2 engine codes. PLEASE HELP!
  35. Hondata & H22's on GSR programs
  36. B18B or B20 in a EK?
  37. b16a2 into a 97 Hx
  38. code 23 ?
  39. Hey, what will i need to go from AUTO to STICK? (basic rundown)
  40. swap d15 to d16z6 turbo...info please
  41. h22a in 98 integra
  42. whats the best tranny for a b20/vtec swap
  43. b16a/92 civic
  44. B20z or jdm b16a2??????
  45. bigger rad in hybrids?
  46. CEL code 43
  47. swap problem!? very weird!?
  48. What Setup Should I use????
  49. Need some help with my power steering, come on guru's of Honda tech i know you know
  50. tranny question?
  51. B18c5 Head removal
  52. What is a better swap Gsr, H22, or Ls/Vtec swap in a 92 eg hatch?
  53. what company makes a-arms
  54. GS-R intake manifold, how restrictive?
  55. Auto to Stick WITH a B16A swap into EK...
  56. itr air box question
  57. H22 Wiring problems.....HELP!
  58. new to hondas... 91 civic si engine swap questions
  59. NuImage LS swap...Yea or Nay?
  60. Do I need to wire up the VREF?
  61. standard or overbored size piston???
  62. Honda/Acura Engine Performance...good book?
  63. Interesting tach question...b20z
  64. What is needed for a b16gen2 into a ef hatch back??
  65. ys1 tranny/ what car
  66. b16a1 swap into crx, having problems, need HELP!!!
  67. HASport sucks!!!
  68. Non-vtec chip in p28 ECU, will it work?
  69. ls to gsr?
  70. Ever seen a H22 motor dropped from 6 feet and rolled?
  71. Trasmission Gurus please help!
  72. code 54, obd1 engine obd2 ecu
  73. price on the b20 longblock
  74. H22A head on F22A block!?!?!?
  75. Header Compatability
  76. Does a d series bolt directly in a 87 crx?
  77. 93 EX Coupe Swap Info
  78. JDM H22 in crx...need to change fuel lines?
  79. OBD1 Car w/ OBD2 Motor?
  80. 2nd o2 sensor
  81. car wont start????
  82. swap shops in or around orlando
  83. B18b EG Swap Wiring question
  84. ??? on lsvtec setup
  85. JDM D15B Studdering at 4000rpm????Help?????
  86. have b16 swap and now want to do b16a,crv block...
  87. 1996 Civic EX with a PRELUDE swap
  88. Gas Mileage. D16 to B18
  89. D.S. GSR axle NEED HELP removing it!!
  90. H22 Civic with Radius Arms?
  91. LS motor. Long or Short block??
  92. auto integra swap to auto civic swapNEED HELP ASAP!!!!!!!!
  93. broken crank pulley.... osaka FUN!
  94. sensor on intake mani..?
  95. ne one know tranny code for h22!?
  96. Can A H22 engine bolt up to my automatic tranny in my 96 accord?
  97. Are civic, CRV, integra , prelude ECU plugs the same?
  98. Calling out V-AFC Gurus!!! Need help on tuning for N/A
  99. where to buy motor for swap
  100. B16 CRX flashing CEL #2 ???
  101. Do I need Engine Mounts to drop a JDM ITR Swap in a 98 EX Coupe?
  102. Transmission question
  103. H22 guys... I need estimate on horsepower.
  104. b18b into 95 civic
  105. EG auto to manual
  106. wiring in a 93 civic cx with b16???
  107. buying a b18a1
  108. can i use skunk2 chip with stock valves.....
  109. b20, ned h-t help.
  110. OK you swaping guys
  111. ??'s for goin from 12.5 all motor to turbo set up
  112. pulling out motor
  113. d16 is out and b18c1 is about ready to go in
  114. D15 vtec...vx motor
  115. Idle Problem - can someone help?
  116. no vtec in ls w/ gsr swap??????
  117. b18c1 into 2000 CX..what throttle cable?
  118. mount kit for bseries in ef civic?
  119. b18c1 wiring ???? HELP
  120. best setup?
  121. Shift linkage??
  122. OBD2 O2 sensors??
  123. ecu pin outs on eg
  124. Where do I hook up these wires?
  125. shift linkage PIN????
  126. EG + B18C = 5th gear grind?
  127. couple quick questions on h22a's
  128. civic swap help.
  129. car wont start
  130. Motor Choice Help Needed
  131. mini-me questions??
  132. v-afc worth it!!??
  133. 00 civic H22
  134. Swap B18c into 01 civic
  135. nsx/hatch tube chassis?
  136. CTR pistons in a b18c1
  137. H22 Civic brake question, booster-master cylinder?
  138. Max Power= 151.0 Max Torque= 107.0
  139. Will Vtec not work if the coolant temp sensor is not working?
  140. Few pics of my h22 swap
  141. ls motor into 2000 ex
  142. vtec oil sensor...........help
  143. Which Helms Manual?
  144. What do you guys think?
  145. Swap in a coupe?
  146. h22 distributor...
  147. obd2 swap questions
  148. o2 senor?
  149. timing question..
  150. b20vtec w/OBD2 gsr ecu
  151. interchanging heads...questions
  152. Hybrid Transmission... ZC With Si Final Drive.. on a D16Z6...Few questions...
  153. Pre-Swap distributor question, 2001 B20z diz, 96 DX harness
  154. B18/B16 swap
  155. Wiring GSR IM
  156. best CAI on eg with gsr?
  157. hmotorsonline is #1
  158. Can anyone vouch for DIY_Racing aka Del Emerson
  159. LS EG Swap Mount Question
  160. obd 2 b18b into 92 cx
  161. 88 crx b18c swap alternator ?/problem
  162. Using a Prelude Srv 1996 Automatic Ecu
  163. a question for those very experienced with h22 swaps
  164. JDM b20a + b16 vtec head?
  165. Header heat sheild?
  166. b18c1 and b16a2 pin outs
  167. DX tranny
  168. need help with planning a project for a senior exhibition
  169. zc head onto d16y7 block - help please!
  170. need oxygen help!
  171. B20B engine mount bracket
  172. 90-93 integra LS to GSR engine swap questions
  173. B18b1 EG Swap Question
  174. Hasports + HCP A/C mount?
  175. **problem with starting car after rewiring**
  176. how do i wire a 97 ls distributer to a 99 civic for a gsr motor
  177. O2 Question
  178. gsr secondaries?
  179. What intake should I use in my EK w/ b18c1?
  180. JDM B20b vs USDM B20b
  181. Question about which motor to go with
  182. 96 civic to gsr
  183. H22 Intake Control System?
  184. any 7.0 d.f.i users??h22a turbo
  185. built gsr engine
  186. how to wire an OBD0 dizzy plug to OBD2
  187. Car wont crank after auto-manual swap...
  188. What to buy?
  189. has anyone dealt with an ef civic b16a front clip???
  190. What cap and rotor, fuel filter and plugs for b20vtec?
  191. Code 43 and leaking tranny
  192. i hate code 14
  193. what do i need for d-series swap?..i searched
  194. DSS Stage 1's, do they still exsist
  195. h22 hybrid guys...What did you do about your clutch line?
  196. All you "h22 eg's" are your shift linkage tight.....
  197. Enjo V.S. DSS drive shafts..... which are better?
  198. suspension for h22 swap in 92 civic
  199. b16b in 99 civic dx
  200. evap control/vacuum problem (00 b16/97 dx)
  201. i need a obdII.5 to obdII conversion harness.
  202. Someone please clear up the wiring confusion!
  203. How to find a 96 GSR engine wiring harness (or, type R)
  204. H22 or B18? HELP!
  205. Anybody heard of RJCtrading?
  206. Engine Temp Guage is stuck on HOT!!
  207. Anyone using a JDM ITR 4-1 header in an EG w/ B series?
  208. What tranny's will fit my H22Eg swap
  209. D16Z6 problems
  210. S14EK22HybridHatch
  211. cams for h22a
  212. Setting B16a Ignition Timing in a CRX
  213. 97 prelude engine into a 97 civic
  214. H22a civic hatch track times....disappointing!! im pissed (h22 1/4)
  215. p13 ecu auto and manual
  216. H22 Hatch tranny got suddenly noisy- call for alarm?
  217. ZC Problems!!!
  218. B16a or Ls/V-tech
  219. IAC valve on mini me
  220. Houston Area Shops?
  221. compression ratio
  222. b18b1 Swap into EK9 Coupe
  223. Worth it to swap and h22a into...
  224. ok just confirm this for me...
  225. CEL free... but another problem. ls/vtec pros enter
  226. hybrid question
  227. ?'s i need answered!!??
  228. yo paul vang!
  229. jdm itR Pistons/rings, part # ??
  230. B16A Swap?
  231. ls in 92hb clutch ?
  232. Just dynoed my h22 coupe
  233. hasport needed asap
  234. H22A'n a CRX questions
  235. B16a2 With a Ls Tranny??
  236. Running a P28 instead of P13..
  237. H22a into a 98 CL
  238. LS head/block question??
  239. 96-97 type r motor?
  240. swap q!? tranny leak from axel input?
  241. Idle issue. Got any ideas?
  242. 93 LS motor into 92 Civic HB
  243. B20 driver's side engine mount problem?
  244. B18c block.....
  245. Does is make sense?
  246. just got my b18c into my crx si, need some wireing help...
  247. What would you do? (wiring)
  248. vtec wiring! Quick Question!
  249. vtec solenoid gasket?
  250. Another retardrd swap question . .
