PDA
View Full Version : Hybrid / Engine Swaps
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 [165] 166 167 168 169 170 171 172 173 174
  1. Engine??
  2. need response fast
  3. B16a or b16a2???
  4. Blow off on NA car possible??
  5. WTB: Complete 94-95 1.6L SOHC VTEC Swap
  6. Question for the Experts
  7. 4500rpm idle!
  8. Can i have as many reviews as possible from people who have bought motor swaps from www.JDMclub.com?
  9. b18c5 in '88 crx... What else do we need?
  10. proportioning valve ?
  11. Motor Mounts for b20 into a EG
  12. How do I remove a pin on the ecu???????
  13. Shiftlinkage question in an EG.
  14. GSR into a Type-R whats needs to be done
  15. 1988/89 honda accord engine swap to V6
  16. I thought I posted this last night.....I selling my 97 C2 lookalike GSR wheels
  17. **WHAT PLUGS FOR B16??**
  18. what would be the best set up????
  19. Swap part 4? IT TURNED OVER!
  20. Got any pics of front ITR swaybar installed on '92-'95 Civic HB?
  21. which cat-back exhaust?
  22. What year GSR ecu will work with 99 H22a in 94 Accord EX ?
  23. Area 51 Dyno Day- So Cal...JAN 20th
  24. h22 into eg hatch easy??? hard???
  25. CRVTEC ECU Question
  26. Engine Swap for 88 Prelude please help!
  27. Does a 2000 itr ecu has imobilizer in it??
  28. Installed Field VTEC Controller.. Now Vtec wont come on.
  29. Will the final driven gear on differential case of AT 93-95 Prelude SI work on H22a mT?
  30. i know this topic is brought up alot but need help
  31. b20b crankshaft Take a look.
  32. LS all motor
  33. Radiator Leak Fix HOW?
  34. Got Helms manuals for my car and my engine!
  35. Hi. I have a newbie question. If I swap an ITR motor inside an EG, what....
  36. need upper power steering bracket
  37. Q: how do you guys launch?
  38. Bubbles on the walls of my tires..What is it from?
  39. Thinking about a 00 jdm spec type r motor, I believe they have 36mm axles should there be a problem?
  40. b16a resleeved vs. h22a resleeved???
  41. AZ emissions
  42. B-series valve springs
  43. Techs its a B18B1 engine not the VETC, sorry. (2 engines help?)
  44. CX TO SI SWAP?????????????
  45. how to spend $1500
  46. Need ek swap help...
  47. Sticker for your ride.....
  48. will the 5 lug suspension from a 99-00 jdm integra type r fit?
  49. can someone help me with wiring info
  50. B20 with ITR head
  51. I want to make my B16 a 1.8. What crank can I use and what do I have to modify.
  52. NEED HELP!!! im puttin a JDM b18c(gsr) motor into my 1993 del Sol S
  53. Planting the HP to the ground...your input is needed!!
  54. Ideal Supsension Setup
  55. B16 questons
  56. Does anybody know where i can get an engine shipped?
  57. H series in a EG....shift linkage question.....
  58. What mounts for aJDM GSR into EG???
  59. Anyone have a 90-92 Integra with a Type R swap??
  60. chipped ecu for ls/vtec
  61. B Series Motor Mounts for 91 CRX
  62. EVAP purge solenoid valve
  63. 1.6 liter DX intake manifold help
  64. Pornstar racing video Send your stuff in get it in the video
  65. hp:weight ratios??
  66. anyone know where to get a b16 or......
  67. How much would a Light Flywheel help a b20vtec?
  68. Need tips on installing an ITR 25mm front swaybar on my '92 VX...
  69. swap part 3 PROBLEMS
  70. b16 swap in 88-91 hatch??????????Help
  71. 2 engines; What to hybrid to make strong? Techs
  72. JDM h22a tech questions
  73. What head is this????????
  74. Truth or not about smog check?
  75. Techs: Please Help.. Putting a 95 GSR swap into a 94 LS....
  76. I have a question about some parts I traded. Give this a look. :)
  77. need help with ls\vtec
  78. Help me!!!
  79. IT'S IN!!!!!
  80. intake problems??????
  81. I need head
  82. Where is the proportioning valve??
  83. Trying to put a ITR CAI intake (AEM) on my B18C having a few problems getting the filter to clear th
  84. Check Engine Light......
  85. Swap Part 2
  86. boring out JDM B20B?
  87. GAuge Cluster ??????????????????
  88. CRV drivetrain into Civic hatch?
  89. Swap Questions/problems part 1
  90. tach jumps... but......
  91. List your times LS/Vtec people!
  92. can someone help me out on h22a4 swap ??
  93. engine swap for a 92 teg ls
  94. SWAP....go to mechanic or aftermarket/performance shop?
  95. AN parts and VTEC oil line for frankenstein motors...
  96. B18C (OBD1) into a 1990 LS Integra...wiring question (I did a search...please don't kick my ass)
  97. ned help with accord w/h22
  98. Please post VX w/ B16a horsepower and ¼ times or 0-100mph.?
  99. ITR muffler question
  100. ECU question
  101. where does the vacuum line go to for the butterflies on a GSR motor?!!
  102. B18C1 swap question....
  103. Compression????
  104. look at this.......
  105. look at this.........
  106. oil leaking from head gasket in b18c1 swap???
  107. b18c1 question
  108. b18c1
  109. What would be the first....
  110. Delema time. Spun a rod bearing and need YOUR assistance...........
  111. looking for a shop in NJ
  112. vin numbers
  113. Any pictures of a teal eg with ITR 5 bolt conversion(white if possible)
  114. What type of sealant on VTEC oil plugs/fittings?
  115. G2 B16A into me...
  116. hybrid wiring question
  117. Advance Timing Question...
  118. 1st gen B16 into 95 hatch.........
  119. what intake mainfold to use
  120. sohc swap?
  121. B20 in a HB possible?
  122. 2 o2 sensors
  123. What do I have
  124. Are there any benefits of using urethane endlinks for the ITR swaybars on my '92 VX?
  125. b16a2 in a sol, problems?
  126. Anyone ever had a problem with enlarging the dowels to 9/16" instead of 14mm?
  127. VTEC pinouts on OBDII ECUs
  128. B20b/vtec Rods Question
  129. for a 95 ls motor and tranny, can i use one of these flywheels?
  130. How do I prove I have a B18C to my ins company??
  131. Hybrid People, There is a THREAT To Us on H-T...Read if You Value Your Car.
  132. charcoal canester won't fit... b18c5 in EG
  133. 92 civic hb
  134. B20A3 JG head on a B21A1 block?!
  135. Can i use 92-95 ex/si ECU for ls swap?
  136. Eibach Sportline or H&R Race springs in my del sol with gsr motor? can i see some pics?
  137. b16a2 in a 94 del sol; good idea?
  138. H22A in 94 Accord, How Hard???? How Much????
  139. TRANNY
  140. Anyone interested in JUN cams...
  141. where can i get an LS motor from???
  142. engine swap
  143. FS: B18B
  144. B20 hybrid problem
  145. Why do peeps charge so much for...
  146. Hey guys I need som help....please
  147. CRX Swap question. LSD related
  148. Wiring harness question
  149. HELP!!!!!! Do i really need shift linkge for b16 j-spec swap
  150. car won't go over 2000 RPM's!!!!!!!!!!!!!!!!!!!!
  151. Best swap for daily driving?
  152. Price of b16a
  153. Help in advancing timing on the Hybrid
  154. What CAI in EF w/ B18C5?
  155. clutch slave cylinder question...
  156. Clutch for B16a cable tranny?
  157. b16a
  158. LS mated with b16 (sir II) non lsd tranny
  159. 96 dx motor into a 92 cx help!!!
  160. H22 in a EJ with P/S and A/C.
  161. h22a in a ej ???
  162. OBD1 to OBD2
  163. Help installing B18C, into Civic VX
  164. Car Acceleration Simulation
  165. anyone wanna get rid of there ITR tranny
  166. b20b or b20z??
  167. swaping an OBDII GSR into-->>96 CIVIC (OBDII)
  168. ZC or Z6 in an 89 CRX Si?
  169. MUGEN RNR for sell BID NOW!!
  170. Swapping b18c5 (OBDII) into 92-95 civic
  171. Front strut fork?? Please help
  172. integra parts in a eg hatch?
  173. H22A hybrid 93-95 civic coupes...
  174. B18B in 91 CRX....
  175. b16a head on a gsr block?
  176. "help on AXLES" which axle to use for a B20B w/GSR tranny on a 2000cx?????
  177. planning engine swap, what can i for peformance and not waste money
  178. question about crx vss
  179. question about turbo!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
  180. Code 20 Please help!!!
  181. H22A/Integra swap list.
  182. ECU code 21 on my Hybrid?
  183. Anyone with B18C in crx, could you point me in the right direction?
  184. b16a in 94 LS
  185. Need motor mount help ASAP
  186. Cv joint busted????
  187. need help with engine code
  188. CR for LS head/block and p30 pistons
  189. 94 ls on 90 b18??
  190. b18c5 --> eg HELP!!
  191. Pornstar racing video Send your stuff in get it in the video
  192. Which AEM CAI and how?
  193. looking for people who have raced their car on a track.. (brake fade questions)
  194. b16 ???
  195. ls/vtec idling high
  196. B18C5 into a 93 civic coupe?
  197. part swapping
  198. Any difference in a usdm and a jdm obd1 ecu?
  199. new engine in 92 integra ls
  200. LS/VTEC...OBD1 block-->OBD2 head
  201. for the east coast drag racers...........IMSTARRACING
  202. 1st gen B16 into 95 civic??
  203. how to tell if its a real JDM ITR tranny???
  204. Valve Springs?
  205. Non-VTEC spark plug wires on VTEC engine?
  206. anyone using hcp mount kit for h22a eg hatch?
  207. Wanted to give props out for JSPECJDM.NET
  208. Where in the PHRUQ can I get a Beaks mounting kit for my ITR rear sway bar?
  209. is this right??b20/vtec..tech
  210. :?:AXELS FOR B16A SWAP IN CRX:?:
  211. Pacific North West has a racing board, check it out!
  212. B18C5 Head on B18C1 ??
  213. B18B to B18C5
  214. 99 EX motor in 88 Civic Std.
  215. Anyone have a pic of the Intermediate Shaft?
  216. Integra Type-R Block Code
  217. Wiring (Needles) for EK SiR gauge cluster in a '00 DX
  218. b16a parts
  219. WIRING HARNESS QUESTIONS!
  220. $4,200 '00 gsr complete swap w/13k is that a good deal?
  221. Anyone have instructions for a Fields Vtec controller??
  222. Is a shift linkage off a Jdm motor the same as a usdm one? Can I use jdm axles/ shift linkage when s
  223. JDM B20B Transmission?
  224. kinda long but please help me
  225. GSR front sway bar on an EG
  226. DOHC cam timing
  227. Need help!!!!! Which tranny???? B20Vtech/Turbo
  228. My secondaries are not working!!!
  229. b20/vtec turbo??????
  230. SEEKING HELP: vtec wiring into the crix
  231. code 2 or 20?
  232. Lead me the way.................
  233. Nitrous purge kit help...
  234. 1996 h22a auto ecu part number???
  235. LS/VTEC needs to get smogged. Any Ideas?
  236. ZC problem
  237. -3an too small for VTEC feed?
  238. Polyurethane Motor Mounts (not typical inserts)
  239. LOOKING FOR B18C5
  240. B20Z - CRV or B18C????
  241. anyone order from hondamotorsonline.com??
  242. type r ecu screwing up my emissions?...
  243. need help wiring b-18c1 into a dx coupe!
  244. Need info on a auto to manual tranny swap on a 99 hatch
  245. b16 in a 89 hatch vs 89 crx si
  246. USDM B20 v. JDM B20 for boost?
  247. b20 crv in a 3g prelude?
  248. more wiring problems, whee!
  249. b16 + 92-95 ex coupe = what PS pump??
  250. Need more Gas capacity from a 92 Civic Hatchback.
