PDA
View Full Version : Hybrid / Engine Swaps
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 [60] 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174
  1. Big problem.. after ITR swap ppl must help me out!!!
  2. h22 starting problems
  3. B SERIES AUTO TRANNY ?
  4. Anybody got videos of people doing swaps?
  5. b18a1 into 95 ex
  6. How to identify my distributor and replace dizzy parts
  7. H22/H23 parts list?
  8. b18a block b18b head obd-1 wiring need name of sensor
  9. Swap into 90 Hatchback
  10. Which build????
  11. CEL CODE 54... car isnt' drivable.. need help
  12. wut u guys think would be the best choice
  13. swapping b16 head for b18c1 head...hoses?!?
  14. building up an mini me swap....got a few problems.
  15. b16 obd question
  16. K series swap into a dc2 writeup?
  17. b18 swap
  18. problems with b16 in eg
  19. Might have a chance at a '95 GS-R Engine...
  20. Help me troubleshoot
  21. putting a d16y8 in my ek?!?!
  22. b16a swap ecu question
  23. My HCP Mount broke... what to do!!??
  24. B18B Swap into a 95 civic coupe
  25. k20a2 into an EK
  26. jdm b18c confusion
  27. check engine light/ spedometer
  28. eg b18c1 swap help needed
  29. ctr lsd into a cable y1 tranny?
  30. code 19 on a b16a manual swap, hesitated acceleration?
  31. Anyone knows what CKFM sensor is? plz help
  32. how to tell if the motor is jdm or usdm
  33. no vtec with USDM ecu, OBD2a JDM b18c
  34. HybrId/HasPorT MotOr mOuNTs?!?!
  35. Car/motor shakes on highway
  36. Gauge cluster issues with swap.
  37. D16Y8 - B18B1 swap
  38. h22 swap will barely run please help
  39. had a b16a now i want an LS. how hard is the swap?
  40. sedan harness on hatch
  41. Intermittent VTEC engagement...
  42. 8 pin engine harness plug 9 pin dizzy plug?
  43. sr20det swap in a del sol?
  44. Bolts interchangeable
  45. EG B18C swap
  46. h22 firing order?
  47. Cleaning Blocks
  48. vtec ?
  49. 96 civic ex with b18c What studs do I use on the civic si driver mounts?
  50. b20vtec; Alternator and throttle cable PROBLEMS!!!!
  51. mini me problems please help me last resort
  52. V-tec solenoid question
  53. which shifter to choose.. anyone have a oem integra shifter in there ek? (gsr,type r)
  54. How do you check ODB2 codes without a scaner???
  55. Turbo-Super Charged???
  56. wiring procedures for b18 in ek !
  57. obd1 and ob2 question
  58. 94 civic h22a axle problem
  59. CEL 20
  60. axle wont pop in...
  61. obd1 b16a into 99 civic with a twist
  62. Question about Air Conditioning, "K20 SWAP pics WOT!! WOT!!"
  63. gs-r motor...
  64. Black Can Near Oil Filter? PICS
  65. how to keep ps for a b18b in eg?
  66. which ecu and wiring harness do i need for a obd1 b16a2 ?
  67. k swap in EK help
  68. block info
  69. 40/40ProportionValve
  70. gsr vs turbo single cam
  71. engine swap - hELP!!!!
  72. OBD I B18B into EG with OBD II harness
  73. ecu ground
  74. heyy
  75. help please!!!
  76. H22 Help. Bogging when letting off the gas/coming to a stop.
  77. exhaust suggestions
  78. what year si does this engine belong to.
  79. itr swap now the axles dont fit !!
  80. B18c swapped into 00 Civic SI
  81. can someone post OBDI and OBDII dist clips pics
  82. b16b cali ref?
  83. how to stop paying registration on track only car in cali????
  84. D-Series into da...Have a handle on everything but Axles. What to use???
  85. DOHC F22 Q's
  86. Axles and tranny
  87. How do i ID a dizzy
  88. 1997 to 1998 D15Y7 Swap
  89. Fuel Pump and Fuel Pressure for LS/Vtec w/bolt ons
  90. JDM H22 Type S.. what car to swap it into??
  91. need help with a b16a swap / what car comes stock with a p72j ecu
  92. can some one tell me what car does the p72j ECU come from
  93. Need Help with my JDM H22 swap
  94. need to know which trannys are compatable w/ b18a1??
  95. need to know which trannys are compatable w/ b18a1??
  96. anyone know how to do a auto-manual convresion on a DA???
  97. gsr swap help
  98. front brake swap on a crx--parts needed?
  99. ECU PROBLEM (ECU GURUS HELP HELP HELP)
  100. which ecu for ls vtec??
  101. LSvtec help
  102. mini me vtec swap vtec not working
  103. Will USDM parts fit JDM motor?
  104. Steering Rack - 93 SI HB
  105. help with IAB(secondary runners) on B18c1 swapped civic!!!
  106. H22a/H22a4 a/c compressor Q
  107. B16a1 into 89 civic
  108. Clutch Release Spring....?
  109. ITB Specialist/Tuner in So cal?
  110. nee some help with my EDM ecu "P3Y"
  111. gsr dash
  112. wtb hydro gsr tranny....cant post in classifieds yet.....uggg
  113. what driver side mount B16 into auto civic
  114. ls b18 swap into 1990 civic hatch?
  115. Can anyone identify this alternator bracket?
  116. need some opinions on this
  117. JDM motors... any break ins?
  118. What to do what to do
  119. Shift linkage problem
  120. GSR/EK loopy idle
  121. B Series Losing vacuum after driving.
  122. F20 Rev limit
  123. 1st Gen B16 Alternator belt
  124. >>>best ECU for a ek9 with an ITR swap<<<
  125. >>>Whats the BEST ECU?<<<
  126. OBD2a and OBD2b ecu pinouts the same?
  127. Oil Dripping all over the top of the tranny??? where from?
  128. h22a eg's with supercharger?
  129. EG w/ B18B1 shift linkage
  130. eld code with jdm h22 in canadian 96 ek
  131. ZC intake
  132. flywheel install
  133. I hate to be a pain.......
  134. obd0 to obd1?
  135. Very loose shifter/selector rod ... Tranny bad?
  136. DA integra motor mount help
  137. Smog question
  138. quick fuel pump question
  139. ok wtf! lowering engine into car problems.
  140. TL motor into 2002 coupe?
  141. integra d16a1 -> civic d series tranny wont work? why?
  142. D-series power steering on LS B18B
  143. S2000 ENGINE IN A CRX???
  144. 96 civic ex wiring vtec solenoid but no oil pressure switch jdm b18c?
  145. B18C5 FULLSWAP w/tranny and LSD how much?
  146. Civic ex b18c engine need wiring info?
  147. What timing belt for my setup
  148. b18b1 in the bay area...
  149. zc swap
  150. OBD 1 vs. OBD 2
  151. im all mixed up...swap parts question.
  152. Radiator fan relays?
  153. CRX swaping
  154. ecu/harness question
  155. AEM Hybrid Intake for 92 EG wit gsr
  156. REALLY stupid question
  157. OBD-1 D16 motor in OBD-0 D15 HF CRX???
  158. K20/K24 in a Civic - WITH air conditioning??
  159. Tranny mounts on 99-00 civic
  160. head Gasket
  161. Swap: H22 Type S swap into Prelude type SH
  162. fault codes.
  163. LS Swap Exhaust question
  164. vtec ecu with LS motor.
  165. avid H22 race linkage
  166. D16Y5 Vtec wiring
  167. is hte type r brake booster the as a gsr booster
  168. quick question
  169. PROJECT F20B into EK
  170. wrong forum but i duno where to post
  171. B16B swap questions(del sol)
  172. ^*^*^*^Tranny Chattering only in 1st???^*^*^*^*
  173. Need help, throwing codes and not sure why....
  174. wiring vtec into a p30 computer
  175. Are D-series and B-series FPRs the Same?
  176. how hard is it to swap a k20a into a eg
  177. Hasport Mounts; H22 93 civic Ex. Will Power steering work?
  178. HCP ac Bracket0 H22 93 civic- anyone have any experience with it
  179. B18c1 is this worth it....
  180. Need conversion diagram obd1 dizzy, obd2b harness
  181. Mid engine... why the h22?
  182. quick question
  183. finally got my engine
  184. ITR Vs. H22 swap Q's
  185. swaping gsr and ls parts
  186. type R throttle body onto GSR manifold ?
  187. GS-R with b16 tranny MPG
  188. h22 shifter
  189. H22 into an 95 integ
  190. h22 swap nightmare
  191. hope im on the right forum
  192. Anyone keep there power steering and a/c?
  193. No Gauge signal in swapped eg??!?!
  194. D16Y8 to JDM B16 Fuel Filter and Map Sensor??????????
  195. h22a conversion
  196. B20vtec Swap, no throttle?!?!? HELP!!!
  197. obd1 jdm b18c into obd2 integra questions
  198. h22a individual throttle body????
  199. Next project. Very Unique. Dual Engines, crx
  200. AN-R Header!
  201. A/C Bracket question
  202. itr in ek! what header to use?
  203. b18 swap
  204. '99 civic ex engine swap to '00 civic si b16a2 - Swaping Questions?
  205. what's the best lsd for the money?
  206. Alternator Differences?
  207. B18C1 Wiring Swap info
  208. h22a4 with ATTS into EG civic???
  209. h22/ h23 question
  210. guys need help with cv joints where to buy
  211. Swap help
  212. B18c into eg Overheat help?
  213. SiR tranny question. Need help
  214. H23 or GSR
  215. Quick K20 Question in EH
  216. OBD2 Car OBD2 Engine Convert to OBD1? H22 Wiring experts please Help!
  217. are b18b mounts in the same location on a EG hatch
  218. h22 help please
  219. 93 eg with 98 b18c1. use which map plug?
  220. H2B adaptor plate... Anyone else makes it?
  221. JDM CA state ref
  222. BAR'ed in CA? I need your advice -- State Referee Question
  223. ex harness b16 swap???
  224. '00 Ex Auto --> b18c1 5spd
  225. b16/R oil?...
  226. The Death of My Civlude
  227. b18b or b16a?
  228. wondering what linkage i used for a b18b with gsr tranny into a eg?
  229. jdm h22a tranny mitsubishi gears ANYONE???
  230. Can I Or Not????
  231. Auto to manual wiring.
  232. okay i've had enouhg with my car (ek h22)
  233. 96 LS into 92 CX
  234. 96 Civic Cx is it OBD2a or b??
  235. Already Searched: Need H22 help
  236. Rear disc conversion prices
  237. R & I engine without transmission?
  238. can I use obd2 injector clips for 0-1 conversion???
  239. h22 ek axle problem (90 accord mid ,91 integ driver ,91 integ pass with prelude inner) pass vibrates
  240. Noob to Honduh's
  241. Friend doing a mini-me swap, a few questions
  242. Anyone swapped a Honda Engine to a VW Beetle?
  243. H22 Axle Guide
  244. Lookin for a place to get a swap done in CT
  245. Poor Man's Type R + JRSC
  246. hey guys what do you think about a b20vtec turbo in a crv
  247. Help identifying plug!
  248. Does polarity matter on the I.A.T
  249. adapter for d series sohc manifold to fit dohc zc head.
  250. If I have a B20 with Si tranny...
