PDA
View Full Version : Hybrid / Engine Swaps
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 [153] 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174
  1. o2 sensor question
  2. nos kit for sale
  3. d16z6 into a 89 civic
  4. which intake
  5. B18A into 92 cx (obd0 to obd1)
  6. questions please help!!!!!!
  7. And what about this hybrid?
  8. my track times from the weekend...come and see!!
  9. Light weight hatch
  10. Headgasket questions...
  11. help ASAP!
  12. what do you think of this HYBRID
  13. jdmb16a1 into 91 teg. wiring harness question
  14. TPS cel light(7blinks)
  15. Is this a good deal??????????????
  16. Is it possible to run Integra AC compressor in a eg civic??
  17. Is there a difference in a b16a block and a b16a2 block
  18. Did compression test.
  19. blew up the new swap last night
  20. california speedway
  21. jdm dc??????????
  22. h22 in a 00 SI?
  23. LS/vtec wiring vtec to ecu, B16 head to 2000GSR ecu.
  24. how high would you go?? ( gas octane)
  25. yet another 99 Ek HB swap question.
  26. SR20Det in Civic????
  27. 88 Civic auto -> manual swap
  28. What should this run?
  29. Swapping question...
  30. price on a brand new b18c5?
  31. For all you B18C Hatch backs...
  32. Interior Stripping
  33. what is a z10 or crank girdle?????? I have no clue?
  34. 95 ls in a EG having problems
  35. H23 price??
  36. b16a->b18c header ?...
  37. middle layer of head gasket?
  38. are primary/secondary o2 sensors the same???
  39. questions about H22a in a ek coupe
  40. Can I make this engine work with what I've got????
  41. Will GSR front suspension fit in a 97 Civic hatchback?
  42. Will an automatic engine work?
  43. Has Anyone heard............
  44. Water pumps.... will a b18 c work for a b18 a or b?
  45. What axels and intermediate shaft for 1stgen b16a into EG with jdm ITR tranny?
  46. B20B and B20Z pistons OK for higher revs?
  47. Question about hondamotorsonline.com
  48. Finally a H Y B R I D
  49. Just got my hands on a GSR brake swap, what pads??
  50. SUPERHATCHs 1991 BLACK CIVIC SI HATCHBACK STOLEN!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
  51. CRX/B16 Driver Side Axle problem
  52. ls/vtec ECU question..
  53. 99 civic b18c swap need help!!!!!!!!!!!!!
  54. help on ecu code!!!
  55. 91 J1 cable tranny on 92 LS
  56. Someone please?
  57. Verify: JDM can be registered / pass smog in CA
  58. Jun chip and a p-28
  59. a/c bracket
  60. can you fit an h22 in a 88 civic dx 4dr?
  61. Hickory NC, import heaven
  62. help please
  63. Re-using head gasket?
  64. Trying to put motor on engine stand!!! ->
  65. b20 block bored to 85mm?
  66. Fitting of a sir2 b16 into a 88-91 civic hb
  67. Engine mounts
  68. 96 CX swaping in obd1 gsr motor?
  69. 92 hatch a/c?
  70. I need to get chipped
  71. Ditch my jdm b18c w/ lsd for an H22A
  72. Tranny Question?
  73. h22 hatch a/c question
  74. problem when starting the car
  75. quaife diff. group buy still on
  76. setting timing on a zc, need help with the pulley marks
  77. Just curious...how much for a B20 engine?
  78. New header installed!!
  79. Engine wiring harness.
  80. need information or site on h22 swap on accord?????????
  81. Fastest times for stock or near stock EF's with B16's
  82. How to take off b16 crankshaft pulley???
  83. H22 Fuel Pump>> can it be swapped out with another? ITR, Supra etc???
  84. what would u buy ?
  85. Honda motos is the best i ever dealt with...
  86. any difference ? obd1 b18c1 in a EK
  87. OK its here 86MM/12:1 comp. BLOCK (56k beware)
  88. Anyone ever ordered from these guys?
  89. Everything I own is for sale... jun3s, gsr motor, vafc, jdm header etc...
  90. H22/Egs using Nuespeed strut bar??
  91. ls/vtec computer
  92. B-Series parts questions
  93. automatic swap b18 or b20 to eg
  94. streetimports.com
  95. what to get short shifter for?
  96. CRVtec Ignition timing and idle issues
  97. Anybody have problems with mark from jdmclub.com?
  98. ls/vtec
  99. b18c5 , or b16a2 swap into a g1 integra
  100. 95 gsr swap into 95 cx hatchback...wiring vtec???
  101. B16a or B18c
  102. injector resistor needed in this swap?
  103. For Sale: Parting out 1994 3Dr. GSR
  104. The weight of B16, B18C1, C5 and B20, what are they?
  105. B18b into a 93 VX need help bad
  106. Checking codes in a hybrid
  107. getting my block back on wednesday!!!!
  108. Need help: Throwing o2 sensor CEL code!!!
  109. 99 Ek HB swap questions.
  110. Infamous LS/VTEC
  111. F20c vs RB26DETT vs NSX engine...which is most advanced?
  112. anyone know where i can get an oil line kit for a good price?
  113. b16 vs. b20
  114. Type R exhaust on an EG?
  115. H22a Civic w/ A/C? lets cut the BS
  116. need help on b20 vtec
  117. b18a into a eg
  118. 2001 type-r ecu in a 99 si?
  119. what causes high voltage codes?
  120. B16 into a 92 civic si question
  121. H22 HCP Kit
  122. bypass starter
  123. Super Hybrid page inside
  124. jap spec b16
  125. WTB: your stock orig motor
  126. got a crx what the easiest swap!! with the most gain
  127. How much for a B18C1 swap?
  128. how do u check tps voltage
  129. h22a civic ?s
  130. Second Opinion: Skunk2 Stage2's in PR3 w/ Stock Valvetrain.
  131. Field's.....Do they have a web site?
  132. daily driven b20/vtec?
  133. hybrid crx si in perfect shape for sale
  134. No tach after swap?
  135. transmissions
  136. What specific ecu do i use for my swap???
  137. What motor mounts to use??????
  138. keeping PS with a h22 transplant in a ek
  139. Is my head gasket blown?
  140. JDM b20 ECU question...
  141. security system
  142. no codes thrown, but there should be...
  143. Revving to 8000rpm safely in LS/VTEC ?
  144. identify type r throttle body
  145. OBDI vtec distributors....
  146. 2000 Civic EX
  147. head gasket thickness?
  148. Jdm Map Sensor Question
  149. more torque from b16
  150. Question for ECU guru's(Kenji, Katman, etc. etc. etc...)
  151. b18c swap in beat up crx hf...worth the effort?
  152. labor on h22 into a eg
  153. teg b20?
  154. good place to get mounts
  155. 99 Si motor into a 92 Civic DX
  156. Idle is HIGH!!!
  157. 99 HB W/99 B18c. ITR ECU questions I searched!
  158. which kind of race gas should I use?
  159. Pic Request: 00/01 ITR Cylinder Head
  160. Mixing cams? (ITR in, GSR ex)
  161. obd0 to obd1 for ls/vtec do i want too?
  162. d16 block with ZC twin head, will this work
  163. Who is using rewelded mounts in an 88-91? Axle issues?
  164. help!!! i need a b16 piston!!
  165. Anything I need to know before I install my shunk2 intake manifold ??
  166. help water coming out on the tailpipe!!
  167. will a b20 distributor work on a b16 head ?
  168. (Kenji & Katman or all experts) 90 EF DX install a b16a NEED HELP IMMEDIATELY
  169. H22 map sensor
  170. How much would it cost?
  171. Map snesor wiring on z6 into 91 swap, please help.
  172. 2k b18c in 2k ek
  173. where to buy a ls/gsr motor??
  174. front brake conversion 90 crx hf
  175. header question??
  176. motor specs
  177. do all honda fuel pumps pump same amount of fuel?
  178. What air intake will fit in an EG wit a 98 gsr swap?
  179. Cold Air Intake?
  180. Hood weight
  181. Car smoking, what is the cause?
  182. How much is this worth?
  183. Throwing a code 1
  184. kAli sMog help.....
  185. 95 gsr in 1996 ek
  186. ATTN. hybrid with a toda headers
  187. What cool N/A hybrids can One make w/ a b17a motor, I got one within my grasp for cheap!!!
  188. ZC swap info needed
  189. I can't get my car to idle no matter what.
  190. where is the vtec pressure sensor on a 95 h22a?
  191. ls/vtec
  192. Engine Techies: HELP! Removed Header and 3 chambers were pretty clean and 1 was completely black! C
  193. Need help with d15 swap
  194. if i get a usdm stock header and put it on my gsr swap will my stock cat bolt up or will it be too s
  195. will a 1st gen DOHC VTEC ecu control a SOHC VTEC mini-me swap?
  196. Check SRS Sign
  197. Desperate distributor for an EG-B16 swap
  198. shortest alternator belt for B16
  199. Car wont start
  200. what about the knock sensor
  201. wiring help
  202. Can I put this engine into a civic hatch?
  203. Do I needa new CAI w/ my skunk2 IM?
  204. obd1 gsr motor and obd ITR tranny, will it work
  205. JDM b16a1 in DA
  206. B16A1 swap in a 90ls Code 15
  207. K20A2 into a EK?
  208. Will AEM CAI for '94-'00 GSR fit B18C1/EG?
  209. OBD1 conversion for b16 in EF...
  210. D16Z6 Swap...motor is not running right!!!!
  211. what throttle body to use with ITR manifold
  212. 93 civic ex swap to Si
  213. CRVTEC head gasket question
  214. si manifold on a hf crx?
  215. checking for broken sensors
  216. Compression question Detonation
  217. swaping b18c5 into 92 dx ?
  218. will this work?!?!?!?
  219. One last check before I buy parts...
  220. just got a cam so here's pic of my hybrid
  221. Injector....
  222. Airflow for a 65mm t/b into a stock GSR i/m
  223. How much b20 Vtec gonna cost in CRX Si
  224. How heavy will this car be?
  225. Axle question - EK
  226. v-afc
  227. replacing Cv boots on 90 SiR axles - which boot?
  228. clutch line.
  229. Obd1 ECU
  230. JDM ITR engine swap
  231. Need Distributor
  232. just another "is this possible" post
  233. Engine harness rewiring on hybrid
  234. d16z6 into a 91 civic
  235. Re-torque on cylinder head
  236. car won't idle...white smoke...help
  237. Gaskets and seals question, need help guys.
  238. h22 eg shift linkage?
  239. O2 code after 30min on road?????
  240. How many gallons
  241. Technical ? for the wisemen
  242. at work, don't have my hybrid how to notes......need some OEM part #'s please!
  243. H22a/EG Civics check in...
  244. ES Tuning System Muffler
  245. Thumping sound! Think i blew my JDM tranny? !!HELP!!
  246. Just got my 93 CX today...question about wiring a tachometer
  247. gsr in a VX, did a search
  248. PLEASE - New product, need to determine tooling costs AFC+VAFC+AFC-R
  249. Wanna Run high 13's N/A.... help.
  250. how much should i pay for a D16Z6??
