View Full Version : Hybrid / Engine Swaps
- iacv on my h22 civic
- HP and 1/4 mile time guesses PLEASE
- b-18 into 99 civic hatch
- AVID mounts?
- 97 ek dx + c1 + OEM cat & exhaust = which OEM/aftermarket header? ls,gsr,itr?
- Cali Smog...O2 sensor Question
- B-series Transmission stripped mainshaft
- Idler Pulley Question
- San Diego people wanna help me out?
- ECU Program Suggestions
- can it fit??
- 37820-pr3-003 Manual or auto Ecu ?
- h23a non-vtec hybrid
- H22A Shifter Cables (new pics)
- VTEC solenoid's....
- d16a1/zc trannies??
- doing mpfi conversion with d16z6 manifold.. a few questions!
- 99 gsr into eg hatch
- Hybrid Smog Testing
- what mounts do i need for b20 in eg?
- F22B DOHC Trannies
- what parts do i need for B18 into crx?
- Alternator question?
- Anyone with a RSX type S motor in there 96-00 Civic???
- which OEM header... eg 4door + B18c1 + STOCK cat/exhaust
- Where did you buy your harness from?
- question about rear disk conversion on ej
- i got my B20 civic to pass smog, yay but one little problem...
- auto b16A swap ?s
- >>>D16Z6 Swap HELP!!!!!<<<
- what do you think of an h22 in an ef
- 2000 ex motor in 96 hatch question
- B18C (GSR) or H22
- Help with Ls/vtec problem Asap
- GSR swap problems...URGENT!
- AWD PRELUDE?
- just threw a couple of codes what are they
- Need help with ticking sound...
- head internals swap between series? *have searched*
- obd2a->obd2b conversion
- h22 tranny question
- Since this is the Hybrid forum, I thought maybe there is some lsvtec experts in here, or at least th
- H22a4 crank in a h22a1? (searched)
- which modells which swaps possible?
- H22 Hatch Headlight Clearance, Place Racing Kit.
- Pricing on converting my B20 over to Vtec?
- Surging idle... WTF
- Help with obd1 engine into obd2 car
- b18b, p75 ecu in '99 civic (auto to manual conversion) won't start
- buying a swapped hatch
- Want to Hybrid HF
- if you had a chance to do it over agian....
- B18B1 swap questions, HELP!
- I need help with my RSX-Type S in my 98 Civic Sedan! plus I have other questions like insurance, how
- B16a swap in ek
- b18b1 OBD2 question
- belts?
- which shift linkage (i know it's the same question, but need help)
- Wiring Problems HELP !
- Swapping a B18C1 [94 IntegraGSR] into a 2ND Gen Prelude
- OBD1 P72 ECU - 92 DX Harness
- I have two questions...
- Axle issues... need some advice
- d16z6 into 97' civic wiring help!
- Catalytic convertor question?
- my b16 in an ek
- moving to scramento, Ca from GA
- H22 into 98 CX Hatch
- Stock, or hybrid?
- Idle Air Control Valve on a Euro R ( H22A ) Throwing CEL Code! HELP!!!!!!
- engine swap wut axels??
- Need to know what mount to get???
- Will a D15 DPFI intake mani work on a D16 motor?
- 2000 dx hatch o2 sensors interchangable with 2001 B18c1 swap?
- locash racing harness
- best "sleeper" exhaust for my h22 hatch????
- 92 teg radiator fit in EG?
- stainless brake line?
- Swap running too cold
- Question about B18c1 swap with CTR cat and CTR exhaust in EK.
- B18C5 engine swap to 99 civic ex
- Which Sump To use?
- Radiator for H22/EG that clears Jimfab Bars??
- how much?
- b20 question/not b20vtec, just b20
- greddy header in my h22 dc2, will it fit?
- Exhaust sytem on LS/VTEC
- does anyone know the weight of a f22 + tranny?
- Edelbrock 65mm Throttle Body worth it?
- check out my throttle body mod
- Type R(b18c5)????
- b18a obd0 into obd1 EG
- Rebuilding CTR Tranny..What fits?? Synchros & Bearings from (US) ITR or 99/00 Civic SI?
- What radiator and fan to use with h22/EK
- price for swapping in a new long block
- B18cr into EK hatch... mounts??!?!!?
- Trouble Installing Skunk 2 Intake Manifold Please Help ASAP
- H22 Mount Pics?
- Code 41, O2...why????
- Anyone know about 87 Civic Carb swap to Fuel Injected????
- h22 vs. b20vtec
- will a b16a Dizzy and Alternator fit?
- What power steering bracket to use???
- 4th Gen Civic ZC D16 Swap questions
- Brake/Suspension Swap on 90 Civic HB, 4 Wheel Disc Brakes?
- obd2 gsr swap into 96 civic hatch
- B16A swap into 93 Integra using a P30 ECU throwing Code 13
- jdm map sensor same as usdm map sensor?
- f20b........open or closed deck?
- Transmission Question
- Axel problem...need help ASAP
- B20z PHK pistons + vtec head = valve contact?
- b18c into 94 del sol si....harness question
- itr AEM CAI on a 99-00 ek
- Hybrids with HASport mounts...
- EF8/EF9 owners with hydro tranny swap plz respond
- hybrids!!
- Does this swap sound like a good deal?
- What is a reasonable price to pay for a 4040 proportiopning valve?
- real tech only please 97 gsr b18c1 into 97 civic dz WILL THE GSR HAVE ALL THE PARTS i NEED?
- Built B20B4 block.
- injector question.
- Where could I buy a b16 tranny?
- Sir-I throttle cable
- I need a shop to do engine swap (Bay Area, California)
- b18c1 into 88crx dx how fast should this be???????
- MA, RI, TN, WA, CT, & GA JDM Hybrid Owners Please Respond
- H22/eg header clearance pics/ suggestions
- b18c into a 1992 ls idle and throttle problems.
- Paper work for motor?
- EG with Type R motor, Will a CTR exhuast bolt up with JDM ITR cat?
- Intake mani. question
- H22 tuning problems?
- Motor Swap in a 03 DX
- The Time has come!!!!
- gsr brake booster and mc with an h22 hatch
- Comptech Air Intake Q's
- Ole Skool Hybrids...
- What are your thoughts on this Longblock?
- Does it matter what you start with?
- Need Pics~~~~~~~~~!
- ? about jdm sir II rear disk brake conversion onto eg
- Full integra suspension on an eg..
- B18C4 into a Civic EK -96
- AXLE! problem and question!
- How to install integra A/C in a Hybrid EG6
- 93 h22a into 97 accord se
- b18b1 into my eg
- HELP with wiring
- Axle options! Need help ASAP!!!!
- LS/VTEC (B18a/B16a) Questions.
- Dyno Day...Its Official.....Free Dyno Run....Feb 21,2004
- New Poll: Quaife Differential - How Interested R U in...
- ..THE AMOUNT OF H-SERIES SWAPPED EG'S OUT THERE
- B18C1 in a DA pictures??
- b18c1 from 97 gsr into 97 civ dx
- help... jdm itr swap... bogging problems help
- need vacuum diagrams for 1992 ls and 1997 gsr
- Engine Swap Prices
- VAFC Best Fix for CEL Caused by Oil Pressure Sensor
- b20/vtec advice!
- will a JDM B18C (GSR) pass CA smog tests?
- hydro conv. into 88 crx dx what do i need to know????
- B18C1 powered CRX guys-- I've got a few not so simple questions....
- Determining the year of an engine
- h22 traction
- Clunking noise in transmission
- H22 eg wont go past 2 grand
- just finished b20 vtec... need help with idling
- h22 ek axle and mount issues
- ecu work with a usdm obd2 b18c in a 1992 ls
- B16 AC bracket and alternator question
- Power Steering options for 96 Coupe with 99 B16
- B17A into a CRX Si?
- 2nd car swap Question?
- h22a here I come!
- P28 hondata in 1992 eg with H22 questions.
- Frankenstien crank question
- after LS swap, car wont idle ecu code 14
- d16y8 into 89 crx dx -- obd2 obd0 distributor question
- D series breath
- Any Companies make ENGINE wire harness conversions????
- some questions about b18c1 CRX si
- AUTO INTEGRA LS TRANNY INTO A D16Y8 (2000 CIVIC EX)????
- Swap Harnesses, or cut and splice Harness plugs???
- How to tell if a tranny is still good
- fuel line pulsating
- Who wants to lend a hand??
- LS/VTEC in a Civic Coupe
- h22 swap in eg
- OBD1 Sohc Vtec D16 Into A 96 Civic (obd2a) Questions Inside....
- Injector and fuel rail compatability?
- H23A DOHC VTEC?
- Question for mista bone
- grounding valve cover
- Machine Shop for LS/Vtec build and assembly
- b18c block head possibilities?
- K20A + ITR DC2 = ?????
- Need a pic of an engineless EG6 please!
- 91 civic lx w/ d15b2....what are my swap options??
- Rewired car -> back to stock, which engine?
- Where to get a RSX Type S engine swap or the K20a ITR
- LS/Vtec Buildup questions
- urgent transmission question (b-series)
- RS Akimoto? Does it work????
- motor hitting hood HARD
- z6 pistons?
- is it worth keeping the jdm ecu?
- need some opinions on a 98 hb swap please
- will a y7 tranny fit on a z6?
- fuel line d-series/b-series
- Looking for good shop or mechanics for b16 swap->to 91' CRX..
- why do i get such bad gas mileage?????
- Supid wiring question
- B16a distributor rebuild OBD0
- ecu might be fried...check this out
- how to secure LS throttle cable end on an EG gas pedal
- quick ef swap question
- Sad, sad question
- Has anyone ever bought a GSR knuckle (just the knuckle) ? Price ?
- LS swap into 94 civic hb.... exhaust won't bolt up????
- EG6 W/ H22 DONE WITH IMPLANT CAN'T START!
- Searched! D15B7= Bolt in/plug n play in an OBD1 CRX?
- B18c-5
- looking for parts for swap / parts for sale
- tps ?
- Where is a good place to look for K series engines?
- 4 wire 02 sensor installation help
- I NEED HELP!!! B18C in 88 CRX SI
- ALL INFO NEEDED!!!!
- HELP ASAP!!! FUEL PRESSURE REGULATOR PEGGED PAST 100
- help me..... please
- Will A P75 ECU plug into a civic harness? and what the hell are these orange wires??
- header fit ? b18c1 in 1992 cx
- idle surge no top end power !
- HELP!!! car in gear, revs up, but wheels dont turn... wtf???
- D16 Swap
- Shops in Gerogia
- Knock Sensor Question
- AEM EMS with H22 Hybrid Civic
- ***HELP ASAP**** PROBLEMS WITH LS SWAP
- What distributor for b16sir2 into 98 civic ex?
- 93 civic with typr r motor wrecked
- ok people.. ideas for hybrid site.. i need input
- 1972 Honda 600 (2cyl) hatchback!!!!
- a few questions to finish up swap...
- trade for a B18c5?
- just did my LS swap, cant get into any gear
- 92-95 Civic Turbo Intercooler Kit ? for B16A2
- What bracket do I need? QUICK PLEASE!!!
