View Full Version : Hybrid / Engine Swaps
- Swap noob here: PROS & CONS of piecing together a B18C1
- auto swap to manual
- can someone help plz with knock sensor question??
- Wiring domestic injectors to obd2 car?
- d17a as low cost replacement in 93 civic dx
- need some info
- GSR IAB
- h22 bolt ons? what should i purchase?
- Ls/Vtec compression question
- OBD2 to 0BD1 related..........
- MPFI question
- k24 issues
- PUTTING NATURAL GAS PISTONS IN D16Z6
- Complete K series swap parts list?
- 91 DA-LS to a JDM B16A-need help w/ wiring and vacuum
- Timing Belt
- h22 writeups???
- B series starter question.
- i have a question about the axels on my civic swap to a gsr motor
- GSR Swapped 94 Si Cutting our when Accelerating
- are all b-series axles interchangeable?
- jdm b18c(r) swap?
- Whats the difference
- b16a problem's
- For The H22 Guys...
- Please settle a dispute. Integra LS question.
- Question about b17a???
- Tune up parts list for JDM B16A
- B16A or B18C
- want to know if possible
- map sensor pinout.
- MC Reservoir - 13/16 vs 15/16
- EF LS/VTECH WIRING HELP
- TPS sensor differences?
- Neo-Rod 1950 Willy's engine choices, imports and domestic engines.
- NEED HELP car won't start b18b in to a civic ex
- SHIFTING PROBLEMS.... EG W/ LS SWAP.. **please look**
- Civic Disc Brake Conversion
- Smoke from ECU???
- need some help post on this plz
- which would be better, and maybe cheaper? b20 or rebuild?
- b18a1 swap in ef question
- wiring plx300 wideband to ecu
- B18C3 Confuddled!
- '94 Teg Coilovers in '91 CRX
- What am I missing for my LS/Vtec Conversion!
- B.A.R question in california... Searched w/ no answer
- New coil and icm... rpm jumping at 7k STILL !!!
- eg + built h23
- H22 Fuel Line
- Can anyone confirm the prop valve ratios for the various brake setups
- i search and didn find
- Question about header fitment?
- Huge problem, will paypal $20 to person with the solution, $20 + food if you come figure it out. Car
- Pix of my cb7 soon to be f22b dohc powered
- Nice chi-town swap shop?
- first timer planning a swap help is nice
- Transmission Problems
- EG swap "new question"
- can i put a gsr flywheel on my b20??
- code 10 ? please help
- b16 wiring diagram...
- ls fit problem in 96 hatch
- B-Searire in a pickup...
- h22a or f20b
- 97'civic ex suspension
- 97'civic ex 98' h22a swap help
- B18C oil pressure with relocator.
- 99 Si Tranny syncros bad = replace them with ITR syncros?
- JDM H22 Bogging issues...need advise
- Ported and Polished GSR Head ??
- 1st gen hasport motor mount question 88-91 b series...
- GSR head on a TypeR block???
- JDM Type R Front End
- h22 part on b16
- 97 JDM Type R in an EK Hatch
- Building 1.9L B16
- S80 LSD TRANNY NIGHTMARE
- 99-00 civic ex harness
- heating / cooling problems b swap into 92 4door dx civic
- H22 Start Problems
- h22a eg a/c
- h22a eg suspension
- 1994 honda civic h22a smog legal?
- Obd-1 jdm h22a distributer....? Need one but which one do I buy?H22a owners?
- Legal or not to do engine swap in Cali?
- header issue
- hasport a/c bracket for b series in eg
- Need Engine Swap Help!!!
- ECU problems
- wiring help 99 si head on 01 crv b20z block
- ls-vtec issues
- code 15 need help
- Finally got a start on my swap (pics)
- preferred ECU for swap
- need help ls vtech not fireing
- Desperately need axles specs for Hasport mounts, please help....
- car not starting...kind of strange
- Fuel Injectors?????
- how little is to little?
- Wiring 95 LS for VTEC. Help!
- JDM b16a in EK4 (oil Seeping out between)
- 97 Gsr into 97 Civic hatch... diirect bolt swap???
- K20 swap
- OBD 1 to OBD 2 95 GSR swap into 96 Civic.
- name this part
- ********question about O2 sensor*********
- b16 in Sand rail
- swap question
- question about motormount hardware + tranny bolts
- I Need help with my 89 CRX Si D16Z6 swap please
- what years from an integra b18b tranny will fit the b16a tranny?
- B18a1 89 crx swap - Won't start
- dc5 cluster into honda jazz, POSSIBLE?
- question about Swapping Diff. into JDM tranny.
- HELP: Which transmission bracket for this swap?
- obd2 to obd1 swap wiring
- ***HELP*** car runs like sh#t after swap
- will these 2 IM's swap out??
- LS-VTEC spark plugs
- my engine smells like moth balls when i stop
- usdm dizzy in jdm engine
- B-Series Transmission question (LSD)
- ITR motor w/cable tranny
- B18C5 for 93 Integra
- 96 civic ex swap b18c1 ac bracket????
- another quick bracket question
- need help asap... 96cx to 00si
- y1 and ys1 clutch interchangability?
- B16 with LS crank
- help JDM B16A2 on 98 hatch .
- zc help
- Will DA linkage fit in my ek for my b18????????????
- check engine light
- Swapping from b16a to d16z6
- B18C swap.....stock harness or JDM harness?
- Why won't this car start??
- Looking for a good shop near Philly
- wut break pads for wide 4 lug type r?
- will phantom grip lsd fit and LS tranny as well as a b16 tranny?
- Swap Help....Yes I searched EVERYWHERE
- B16a swap bogging???
- B20Vtec boosted
- SOHC ZC ?s
- crx dual point to d16a6 swap fuel pump problems!
- 97+ prelude 5spd shifter mechanism/cables the same as 92-96 Prelude and 90+Accord?
- EG H22 suspension and brake setup
- question for cali people...?
- 00 b16 in 91 si hatch
- 1991 integra rs tranny swap question
- help about obd crap....with a b20z/vtec
- NATURAL GAS PISTONS
- OBD2A JDM B16 Distributor to OBD2B USDM Harness ???? JDM B16 into 99 Ex !!
- Knock sensor pin number for OBD2 (PCT ecu)
- ZC VTEC possible?*************
- Question about swapping out shift cables in an H22A EG--->HELP!
- GSR or b16 Questions
- tranny question?
- quick bracket question
- H22 Exhaust Connections and size and such.
- will the upper driver gsr mount fit my b16a on a 92 hatch???
- K-series in 96-00 civic..need some facts
- Clutch pedal switch problem. Starter not engaging.
- need help with a 01 crvtech in a 98 civic ex
- Wiring help (Searched)
- Front main seal for a JDM B16A?
- my ls/vtec setup what do you think????
- H/F series axles into JDM hubs?
- Ecu Pinout/ Function for p2t ECU "A" plug 32p (did search please click)
- ls/vtec swap
- p06 h22
- tranny problems
- usdm h22? (where to buy?)
- Need a RELIABLE place to purchase the RB26dett from..
- Anyone ever swap a b16 in an EG on stock suspension?
- Rebuilding an LS/VTEC because of a busted rod...need labor pricing
- h22 w/ p28 Q's
- Pinout for this?
- Wierd Clutch problem, Please look.
- pickin up h22 in station wagon?
- Integra springs in EG with b18c swap? tried searching
- JDM d15b7 with a Z6 head and cam
- i need help quick PLEASE!
- b16 tranny or b18c1 tranny???
- DOHC VTEC oil pressure at head problem
- VTEC kick in at 6200rpm?
- Where can I get a rebuilt H22a block? (HMOTORSONLINE.COM SUCKS!)
- Blond moment: Need quick answer to hybrid question
- simple solution for a cooling problem?
- GSR block girdle in LS block
- Where to buy shielded wiring in Orange County
- 1st ever H22 Hatch run @ E-town...your feedback is appreciated. (*also posted in Drag Racing Forum)
- LSD
- HELP! B16 89 CRX Engine trouble
- emissions help!!!
- h22 into delsol
- Prelude Type SH Tranny for swaps
- wiring swap question
- vtech cylinoid kicking on an off
- HCP or HAS motor mounts for h22 swap.
- hotshot header ?
- Auto Tranny Install?
- B18A1 on a crx!!!!
- 4 lug conversion on 94 civic? Is this an easier way?
- automatic B18A into automatic Civic?
- [FAQ] 96-00 Auto to Manual Swap in full detail!! (44pics)
- over heating problem
- 04 TL complete changeover into an EK? can it be done without difficulty?
- NEED HELP BADLY...CLICK,LOST POWER
- header
- Question about radiator hoses???
- anyone heard of flashoptions.com?
- head tapping clacking noise
- F23 with H22 head??
- New and need advice
- insight swap???
- help w type r swap
- need help with type r swap
- 00 Si w/ 00 b18c
- Need 99-00 usdm SI vaccum diagram
- wiring conversion
- using ITR/b16 manifold on GSR head
- quick mini me question
- A/C BRACKET
- Gauge Cluster
- SOHC VTEC Head Differences
- transmission/motor mounts
- Help : Decoding wires off of 97 Civic EX Harness for swap
- motor rebuild GSR and B16 mix-matching parts for turbo
- K20 powered insight
- ls/vtech swap extra coolent line from the head
- What Metric size bolts do Honda's never use?
- Swap Checklist (OBD1 B16A into 89 CRX SI)
- d16z6 into a 89-89 civic/crx
- Please Help Troubleshoot a B18A swap in to EG!!!
- S2000 head??
- b18c type r swap into 99 civic si
- JDM D15B into a 90 EF Hatch
- 1994 LS MOTOR IN A 1994 CIVIC DX!!!!!!!!!!!!!
- h22 in dc2 wiring harness?
- EG hatch with h22 putting in 92 integra radiator, need some info and pics plz
- fast 4 door???
- harness and ecu for 99-00 si into 96-98 EK? which ones? obd2b, obd2a issue
- i need a p28 ecu!!!
- s2k motor in miata
- timing on lsvtec need help ASAP
- Running Rich Still
- My h22 swap has a 97-00 Accord Shifter box on it
