PDA
View Full Version : Hybrid / Engine Swaps
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 [144] 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174
  1. block girdle opinions.
  2. h22
  3. Dist/Ecu question
  4. H22 wiring help...
  5. mini-me:y8 head on y7 block!
  6. Do OBDII ECU's have 4 plug ports?
  7. wiring on a crx to gsr harness
  8. TPS Sensor
  9. '97 LS with '97 P75...is this all I need for my '92 CX?
  10. OBD-I to OBD-II. 97 EX engine into a 93 civic DX
  11. boring out and re-sleeving a B18a
  12. IS IT POSSIBLE: b17a in a crx!?.....
  13. Speedometer Tech Needed
  14. will 90-01 ls axles and haft shat work??Help
  15. How to Keep an automatic transmission in a swap ?
  16. Anyone running a Deckplate,yet??
  17. vtec wiring
  18. Whats the best CRVTEC setup??
  19. Is the GSR tranny or the Ls tranny better for b20vtec?
  20. JDM B16 Wiring...
  21. WTB: 99-00 SI tranny!!!! ASAP!!!
  22. Swap ECU question
  23. knock sensor?!?!
  24. da-9 swap
  25. speedodmeter in 88 hatch
  26. cable to hydro conversion
  27. Turbo Gone, Hello Swap.
  28. How much would it be to make a B16a a 1.8 or 2.0?
  29. Who knows what the (Look Inside)
  30. Exhaust a bit too loud...
  31. 90-93 accord intermediate shaft and 90-93 teg axles ?
  32. B16a2 swap in a 99 EX
  33. front tranny mount question
  34. A few questions before swap
  35. Does anyone know anything bout a b18c swap in crx?
  36. engine stands / LS/VTEC
  37. Question about swap packages. Which is the best deal?
  38. Question on Spindle Nut?
  39. What is my best choice
  40. can 90-91 integra distributor work with 1st gen b16a swap into a crx ?
  41. B18C5 in a 3G teg
  42. USDM ZC swaped to 93 civic hatch...???
  43. any one knows results about any b16a with b18c head?
  44. P74 ECU is that all...
  45. Swap Poll
  46. got CELs
  47. distributor question
  48. I NEED help with B20 VTEC
  49. D16Y8 intake air temp sensor
  50. couple of questions for you guys....
  51. B-Series Hydro/Cable Gears/Syncros Same? interchangable? help soon please..!
  52. B20 Turbo Dyno Graphs Inside. 240 WHP & 231 FT-LB Torque
  53. picked up my crank... and my clutch/fly came today also!!
  54. what do you need to do this swap CORRECTLY??
  55. price for used JDM ITR tranny
  56. Hybrid owners...which fuel pump do you use?
  57. type r block, sir1 head, cable tranny, EF civic???
  58. How do I swap a an OBD2 engine into an OBD1 car????
  59. What do I hook a chain to to hoist the engine out?
  60. 88 civic with b16a, What Knuckles do I Use??
  61. hybrid vaccum line routing
  62. CRX with ITR swap,,, 1/4 mile times?
  63. curb weight of EK w/b18c VS DC2
  64. Which shift linkage?
  65. Cometic 85mm LS/VTEC headgasket!! (junk???)
  66. Tranny for my B20 swap in my DC2!
  67. CTR Mirror???
  68. Where to buy harness?
  69. need help with fuel on my b18c swap
  70. which mount inserts for hybrid? wheel hop
  71. OBD2 to OBD1 Did search...HELP
  72. 2000 jdm b18c/1998jdm b18c
  73. Is the intake manifold support bracket necessary?
  74. H22A A/C Question??
  75. 5G H22 accesory question
  76. WTB: Hybrid in Texas....~7.5K to spend
  77. People with cr vtec questions?
  78. B20Vtec question?
  79. shipping weight of b18b?
  80. b18a or b18b for ls/vtec
  81. Need to ship an engine. Anybody know what I do from here?
  82. 92-95 White EG blue Interior have you kept or changed?
  83. h22 ina hatch
  84. PWO ECU owners
  85. Why is my H22 eating through cams?!?!!?!?!?!?!?!
  86. My first hybrid 94 Accord + JDM H22A
  87. h22a in 95 teggy
  88. b20b - obdI??
  89. back pressure concern ?
  90. need some advice on a swap
  91. Drag racing
  92. B series (B18B) in a Del Sol
  93. Will it fit under the hood?
  94. Code 4 on P23 With B16a?
  95. NGK Spark PLug Part # For CRVTEC?
  96. Engine Swap Concern
  97. B17 intake manifold fit on a B16 or B18?
  98. Importbuilders Wiesco pistons question... thanks!
  99. swap question
  100. d16y7 with a z6 head?
  101. what does everybody think???
  102. B18C5 in a 00 Si, what CAI?
  103. H22 harness?!?
  104. ECU Question - 98' Civic EX
  105. part # for rear tranny SI mount
  106. What cold air intake works?
  107. LSD In GSR Tranny
  108. Can somebody ID the part # for the carrier bearings for diff in 91 JDM S1 Tranny?
  109. b18 rings on b16 pistons
  110. step by step b18c1 into and eg
  111. Which tranny to go with?
  112. Tanabe exhaust BOTTLENECKS!!!!!
  113. b16a2 map sensor prob....
  114. Skunk2 manifold inlet size?
  115. H22 Owners with IAB's working....
  116. What hose is this?
  117. What's my Hybrid worth?
  118. answer yes: front drivers side mount worthless
  119. B20b (in crv) won't stop revving , has LS intake manifold
  120. What tranny came on the 2nd gen ZC that came in EGs?
  121. Anyone have high compression forged pistons for sale?
  122. ITR Manifold gasket??
  123. Gen II Integra swap
  124. Any h22/eg or ek hybrids have times or dyno plots??
  125. How difficult to install Z10 Block girdle (B20) ? How many of you hve done it yourself?
  126. Ok WEIRD O2 question on b16 swap
  127. how to do a b18 swap
  128. JDM H22a vs JDM B18C cost...
  129. B18b FS...DFW area. (sorry mods)
  130. non-obd computer question
  131. CR-VTEC buildup help
  132. anyone buy from H22ek or Nuemann???
  133. Fuel pump For H22 Civic
  134. ****Northeast Meet****!!
  135. Difference in front tranny mount?
  136. b16a2 with a gs-r harness?
  137. ls in a cx question...
  138. Possibly selling my b18b.what kinda price should I be asking?
  139. vtec question. doesn't kick untill I drive for a while.
  140. some pics of my hybrid
  141. vacume advance to electric advance?
  142. Bad idea? (injectors)
  143. hybrid civic test pipe question
  144. Intake Manifold ????
  145. OBD2 IAB question
  146. How do i switch pins around on harness plugs?
  147. Master cylinder/booster and prop valve and Radiator Fan questions for h22/eg??
  148. Any of you guys experience this?
  149. Changing oil pump and what else?
  150. 92-92 Swap question
  151. best place to get a GOOD tranny
  152. 2ndgenb16a?
  153. VTEC Wiring???
  154. WTB SOHC VTEC swap from one of you Hybrid guys
  155. 95 CX with LS swap....B20z cams??
  156. H22 in 93 Hatch?!?
  157. 2 hrs left in my ebay auction (Apex-i N1 catback)
  158. Quick questoin about starters
  159. Need guidance with F/H series swap into Civic (Del Sol)
  160. B20 Crank Pulley Question, Take a look at this Pic, please...
  161. Question on D16 Swap?!?!
  162. engine specs
  163. B20 question
  164. ANY HAVE HAVE BOUGHT H22 FROM www.h22a.com??
  165. Got my mounts,now where do i put em?
  166. B18B for $2750?
  167. Finally.. Pics of my Hybrid!
  168. Si to ZC, Can you swap fuel rail and plug wires?
  169. Anyone put ITR ABS Brakes on 89-91 Civic DX w/ITR drivetrain??
  170. Dropping B16 into 96 ex coupe AT
  171. is $3800 too much for a usdmb18c .....??
  172. rebuild or v-tec
  173. Stock B20b piston/valve clearance with vtec head question.
  174. O2 sensor
  175. joined the "B" side
  176. Mods Required To Use 87 Si Wiring Harness for CRVTEC?
  177. Does a GSR oilpan hang lower than a b20/LS oilpan?
  178. can someone verify OBD1 JDM ecu sends...
  179. Bseries motor in a EK hatch
  180. need wiring help for sohc vtec
  181. Got my ZC, OBD1 question
  182. Cable vs Hydraulic
  183. H22a Type SH questions....
  184. Pulled out spark plug, there was some water....
  185. Help me decide!?
  186. resizeing stock valve reliefs - b20vtec
  187. ECU for Type R in CRX
  188. dynoed my hybrid eg coupe yesterday
  189. uuu...shift linkage won't bolt in?
  190. Cel light on, but wont throw codes
  191. I switched to an R ecu and need some help, asap.
  192. H22a in a 92 cx
  193. need help qwick: valve lash settings for crowers
  194. obd1 b16a in obd0 hatch....
  195. dropping B18c into eg
  196. F22B Head swap for SOHC VTEC
  197. Which radiator hoses for bseries vtec Into EG6?
  198. ZC, Junkyard Integra ECU or Solder in Ebay Chip
  199. CEL 23, knock sensor. How do I fix it?
  200. auto manual engine transmission doohicky swap
  201. h22 prelude throttle body on a b-series manifold?
  202. integra master cylinder into civic question
  203. B18C5 into '94 GSR
  204. Having problems with my gsr swap in my 91 crx si
  205. F22B and H22A Gearbox Compatibility.
  206. TPS sensor help..PLEASE
  207. 400HP Del Sol
  208. h22 del sol
  209. intermediate shaft and axles?
  210. What did you with your stock motor
  211. b16a block with gsr head
  212. 02 Sensor Question
  213. Need a 00-01 ITR wiring harnes or 99-00 SI harness or just the A10 connector
  214. CEL codes
  215. Pissed!!! Went to the track =[
  216. swap question ls/vtec
  217. addressed to any hybrid owners
  218. little qestion about the p08 ecu!
  219. question for people who had a BLOWN ls/vtec or b20/vtec...and opintion on gsr turbo...
  220. what 1/4 mile and hp #'s with this setup?
  221. attention:: Pscorpio
  222. quik question
  223. Q for people who have ordered from HMO
  224. Hybrid Experts.. Please review my parts list for B16 into 91 crx
  225. B18c Leaking power
  226. Questions about transporting a swap.
  227. LS swap into 98 civic dx hatch
  228. jack stand + motor
  229. Installed the Hasport AC bracket
  230. cable to hydro??
  231. 1/4 mi. times with a B18c in a coupe....
  232. b18c swap questions...
  233. help with d15z1 head
  234. Quick simple Question: Easiest Chassis to drop a B18B motor into?
  235. crvtec questions
  236. IN tank fuel pump? do i need to change fuel pressure?
  237. gsr header a good upgrade for an LS?
  238. Math 101 (Cont.d): Compression Ratio of ITR Stock Head on b16a Block with CTR Pistons?
  239. How many hybrids have you owned ?
  240. motors!
  241. Anyone loaded a motor into a pickup truck using an engine lift?
  242. 1/4 mile times with a B18C in your hatch
  243. dash harness
  244. Please help! Check out this B18C1 swap.. Which ECU? Mounts? Does this look right?
  245. h22 civic hybriders -- quick question
  246. If you have done a B18C5 into an EK hatch, help me! (exhaust)
  247. Newbie Question on B18b to B18c or B18c5
  248. Barometric pressure sensor
  249. Third Gear Grind (another poster)
  250. Flywheel Questions
