View Full Version : Hybrid / Engine Swaps
- New to motor swapping..Any help is appreciated
- vibration turning right H22 EG
- Something is draining my battery, need help with multimeter!
- Engine Electrical Problem
- ls vtec with ls oil pump
- Parts list b18c gsr w/ ls auto into eg
- difficult to speed shift 1-2
- 96-00 Civic wit AEM ITR CAI?
- Horn causes CEL??
- EF engine swaps
- CEL 43 in H22 Civic...Any suggestions??
- Shift Linkage
- b18c1 in 89 crx with various stock honda motor mounts
- B16a2 swap into eg4 (5th gen) 1st time swapper.......
- Idle Drop Problem K20A Type R
- Looking for best swap most conducive to autocrossing...
- Will a D16 head fit a D17 block???
- what the best ecu?
- 93 accord w/ h22 timing belt change
- New B18C swap but now can't figure out few things?
- H22 into ej1
- Big brakes upgrade crx
- b18b swap help
- Sparadic Idle
- slave cylinder?
- B20 cranks, but doesnt START?!?!?
- rear dis swap on non ABS EK - which prop valve?
- jdm gsr timing belt change?
- new project
- same ol same ol b16a2 into 99 civic ex
- Im new and have a question
- *P30 ECU REDLINING TOO LOW AND NO VTEC*
- what are major differences betwwen d16a6 and d16y7?
- B16 swap questions.
- h22 in eg oil pan clearance (search is down)
- insight question
- 89-91 CRX w/ DOHC ZC trans... Use 93 integra axles and I-shaft?
- tranny problems, pops out of 4th gear
- b18 ?
- charcoal canister
- h22 into ek?
- h23 CRV which.... what axles should i use?
- ls/vtec with turbo
- tcm question
- cost for engine swap
- b16 swap in 96 dx?
- JDM b16a into 97 EK, harness options?
- 2000 ek swap, need help!!!
- Anyone had this problem?
- Opnions... Mounts or tranny? K series related
- LS/VTEC Bottom End
- Which engine harness do i need for b18b into ek
- Stay D16 Y8 or Go LS?
- B20 Block, b18c1 head quick questions searched
- H22 injector question
- How much HP?? GSR w/ t3/4
- For EK hb people with b16a swap (99-00 civic si)
- JDM H22 OBD1 Civic Hatch Hybrid Fuel Pump Quest.
- tried searching couldnt find a thing need to know what mounts to get
- b16 swap auto to manual conversion transmission mount
- Swap options for a 1990-1991 Prelude? B20/VTEC? H22?
- CEL Code 8: TDC
- Anyone in the Hapton Roads, VA area have a OBD1 P72 GSR you can try on my car for some troubleshooti
- LS/VTEC HELP
- jdm 95 b18c
- wierd code 1 and 43 problems with 1990 LS civic....again
- b18b into 92 civic vx
- Quick ?. CTR pistons in b16a2 ? Clearance?
- Crank Sensor on B20 swap OBDII
- which swap should i go with K,or B series on 98ex
- d16y8 head on a d15b7 block mini me what else is required?
- Hello New to the site and a question about obd0 to obd1
- crank pulleys interchangeable?
- can you supercharge w/ itb's?
- Auto 1996 B18B into auto 1993 Del Sol
- exhaust system for EK hatch with b16a
- rods
- K20 into EK?
- Trust me, I've searched! lsvtec Q's
- DA mounts for a H22
- Which is easier top or bottom?
- What axles?
- how to get jdm h22 to pass cali ref?
- b18a1 swap help
- wiring for h22 swap into a 94 accord ex
- Mini me swap on a 1988 honda DX EF D15 carburated. Help!!
- where?????
- Which throttle cable to use (I've already ran the search)
- B16a EG wont start - but just clicks when the key's turned... HELP!!!
- LV performance shops?
- Installing Hasport mount in Ek?
- need exploded veiw of itr LSD asap please
- Very strange high idle issue - please help!
- b16 into 95 dx swap, questions
- Help!!!! Did i get the right parts for my swap? b18c 2 Ek
- Finally, my K20A swap into ES civic is done!!! (Pics)
- ek swap problem
- so close to finishing my swap solenoid question
- K20 type s gears in a EG
- H22 Civic...Pitch black plugs..Need suggestions!!!
- difference between: 1995uspec gsr O2 sensor & 1996uspec gsr O2 sensor
- B16a1 head, B16a2 tranny, B18c1 cams into a 95 dx
- need help b18a into eg..
- Weird CEL Issue (TPS and IAT)
- Crv/vtec....B18c/B20
- Turbo manifold for H22 88-91 CRX?
- F series transmission on B series block
- Differences in DC and DA mounts?
- GSR crank LS block
- 6 Gen F23 Into 5th Gen Civic
- cold air intake question
- bbk intake manifold
- what is needed for d series cable to hydrolic conversion?
- Code 20. ELD(electronic load detector) ?????
- i need help with ecu for a gsr swap
- LS swap
- how much psi for ls/vtec compression test?
- Timing belt on h22 civic?
- B18a swap in ek question
- B18B1 civic dx: code 43 issues
- b16 swap into 96 civic.......wiring help needed
- d16y7 block ,d16y8 head..what dizzy ??
- Weak VTEC???
- gsr Swap in my 96 hatch and now a few probs.
- im wondering if there is a sticky
- n/a header noise?
- Heater not working???
- jdm obd1 gsr tb vs. usdm obd1 gsr tb??
- obd head conversion?
- track times
- is there a way to tell what lsd you have by looking through the tranny?
- Removing the wiring harness to the Fuel Injectors
- d series tranny on a b series motor adaptor plate
- H22 EG w/ chipped P28 - Hard Code 1 & 14
- Hub swap
- best header compare, street only
- What kinda 98 OBD2a ex vtec Harness is this. LOL
- skunk2 stage 1 cams
- Will an EG fuel pump work in my CRX?
- H22A Header for street use. Which one?
- Does diff. generation blocks matter when rebuilding???
- Everyone with a B20...
- Some Q's, want answers
- Problems with VTEC Engagement - LSVTEC
- crv-tech or k20
- axles needed for h22 swap
- Hydro vrs. Cable
- HELP!! Advice? need Wiring, whos got it or can make it.. 90 crx --> 95 jdm gsr
- Press Release: K24 mounts for 2001 up Civic
- h22 gone, k20 installed pix
- Chipped p28 CEL (I searched)
- Opinions please: Obd2a or convert to obd1
- dropped a jdm b16 into a 91 teg ls few pics inside
- why use eg civic harness in b18a1 swap?
- Vtec oil pan on a B20 bottom end?
- NO VTEC, ALREADY SEARCHED NEED HELP!!!!
- Integra Radiator In EK Civic - How Do I Keep Aircon ?
- Innovative Motor Mounts Question?
- Engine swap ECU problems.
- noticed something wierd with my motor
- another wiring question
- '89 CIVIC LX HEAD SWAP--HELP--
- not fireing need help
- ECU help
- ls vtec trouble
- a/c problem
- another axle question
- NEED HELP ON SHIFT LINKAGE!!!!
- d series trans
- Which ECU to use for JDM EK3 engine?
- vtec not working... at vtec engagement, it falls on its face
- B16 into a 91 CRX HF Axle/GSR Trans question
- brake swap help
- quest for more gas mileage
- DA front knucles on EG....alignment is screwed
- Troubleshooting the codes I'm Throwing (10,13,14)
- try to locate help
- help b18a in a obd2 98 GSR with 98 GSR head
- fuel tank swap
- How to engine swap? Any good books/sites?
- H22a into 98 Civic couple ??
- frankenstein motor swaps
- Swap help in Maryland
- h22a eg traction bars worth it?
- My DC2 H22 Engine Swap Pictures
- ecu ?
- DA to DCR suspension swap
- gauges in a crx dont work..
- GSR bolt ons to H22
- Wiring question with swap.
- H22a running rough, need help pinpointing...Measuring a voltage loss?
- how much horsepower question...
- 98 civic swap
- Walbro High Pressure fuel pump
- Bare motor mounts?
- b18 vtec head on a b20a5
- USDM GSR Distributor vs. JDM B16 (or other ?) dizzy cap....
- Brake problem w/ ITR 5-lug suspension swap
- Can't shift into 1-3-5 gears
- gsr head/b16a1 block, HELP
- necessary to run shielded wiring on knock sensor?
- Axle bindage, Fellow H22ers Help
- No Spark on my beater
- what to look for on an obd1 b16 manifold??
- Question hasport mounts Ek
- EKK1 or EKK2 Mounting Kit
- plx install having cel prob
- a/c question
- Idle / ECU / Problems with jdm h22 in 94 coupe
- help w/small passenger side harness plug
- d series tranny adapter for h22 swap
- suja 1 motoring's k20a midori ek hatch
- what axles will work with gsr knuckles
- What Axle 96 Hatch with b16 Gsr trans 5 lug CTR hubs
- Auto to Manual .. idle purging.. throwing code
- jrsc on h23, searched
- short shit kit
- Experiences with k20 in Ep3?
- blown motor need swap info
- Broken intermediate shaft - What part/year axle do I need???
- my exhaust is rattling against my gas tank =/
- what s the hp difference on the type r engine from the gsr
- Where is the engine code located on a B20?
- mini me idle ?
- Engine Stand Question
- throwing code 20
- H22 or Accord underdrive race pulley for H22 into MKII CRX
- h22 top end
- SR20 manual?? for wiring
- problems after GSR swap, relay?
- new motor
- how do i pin ecu to make it vtec
- Ls ARP headstud question (ls/vtec related)
- obd1 b18b into ek parts list
- h22/h23a frankenstein
- 96 spec type r rotors
- jdm obdII b18c idle problem...vss...iacv...
- inline pro va ?
- h22a ek rpm bounces up and down
- Looking for a swap shop in NC...
- Which crossmember gives more clearance? L-con? Jim Fab?
- B16 or h22 gearbox for h22 CRX?
- h22 swap mounts and axle question
- Y7 throttle body on a mini-me?
- help h22
- H22A IN 94 ACCORD EX
- tech h22a in a 97 civic ex
- b16 Hatch running rich
- Does anyone have Streetlightz.com phone number del sol ac bracket but instead crv bracket?
- B16a SWAP in 94 Civic HB NO VTECH
