View Full Version : Hybrid / Engine Swaps
- Vin number checkup
- If one B18c rocks hmmm.
- Anyone been hit with a TEST ONLY required smog?
- 99 LS Dohc into a 97 Hatch
- Which radiator hoses to use on a h22a4 into 98 civic hb????
- who's got a zc sohc vtec in a 4g civic? I NEED HELP
- How did you hook up PCV valve with B20VTEC/CR-VTEC?
- Bay area people: I'm looking for a LS
- 600.00 what can i do to my car.. 100% stock i just got it
- wiring diagram qeustion
- intermediate shaft?
- H22 trap speed
- 2.2L Accord vtec in my civic. need some help?
- Additional H22A Civic Axle Information
- found a p72 obd1 for you hybrids
- lsvtec people need help very soon
- Rebuild Question
- what size wires do i need
- What a good price for a complete ls/vtec motor?
- APEXi USA Factory Garage Sale : March 8th & 9th (Giveaways - civic turbo kit, intercooler, vafc, etc
- b20 vs. ls/vtec
- Swap question??? Please answer ASAP (searched but could not find)
- b16/CRX pros.....calling for assistance
- Help!!! EX motor in a 1992 Civic
- Harness Question/Wiring
- h22 oil pan
- JDM DC 4-1 Header Facts and Myths???? HELP
- Built H22's need your help!
- Engine harness fitment ?
- *I wanna make a page to stop the repeat questions in hybrid section*
- The AWD Civic
- stay SOHC or swap
- Finally: The h22 is dropped in the Teg
- Fuel Line Question
- what mounts do i need????
- Anyone bought from JDMPower in MD
- obd1 gsr in obdo 90 integra wiring
- EF Hydro B-Series Axle Question????
- ls tranny or b-16 tranny
- In great need of vacuum line diagram for obd1 bseries into 92 vx
- Skunk2, or JG Edelbrock intake mani?
- H22 in eg...so what axles? Help
- Power steering cooler???
- Help on doing a Mini-Me Swap
- everyone's opinions please
- wiring problem? (jdm itr OBD-II) into 95 ex
- best rods for NA???
- need to get it started "help"
- is there a place that tells me what everything on the motor is?
- WANTED: 90-91 integra LS(PR4) ecu pinouts!!!!!!!!!!!
- 94 jdm gsr motor in 97 hatch...HELP PLEASE!!
- 2000 sh motor swap into eg?
- z6 head swap anyone ever attempted????????????
- pre-swap parts for H22a into EG
- itr pistons. what kind of rods for NA street????????
- how do i post a pic of my swap
- Where to get jdm F20B dohc vtec LONGBLOCK?
- GSR Intake Manifold clearance in EF?
- What size bolt to plug o2 sensor in a OBD2 GSR catalytic converter? Pic inside!
- could someone explain a mini-me swap in a crx
- Do B20/LS engines have a front engine stiffener?
- Help, swapping prelude motor into delsol
- Del Sol VTEC a/c bracket...
- !!JDMhondaparts.com!!
- Which MSD cap for b20/vtec?
- Car starts, run for while, backfires and then stalls?!?!?!?!?!?!
- What kind of Fuel Mangment??
- Help!!! h22 fuel line
- H23 Civ
- i want manual steering
- Rod and Rod caps
- You guys using your stock charcoal canister?
- 1984 civic (hybrid)
- LS Vtec Question?
- 98 gsr motor into 97 ek - cel 10, 20
- micro polishing and balancing the crank
- who can rewire this ??
- b16a automatic
- B20 crank pulley issue in CRX with HCP mounts
- Need guidance for airflow
- ls vtec in a crx
- VACUUM LINE help needed on 92 vx with 92 b17A Swap. CALLING ALL GURUS
- H22a Accord intermediate ?
- crx swap with d16z6 queston help
- supposed to use old engine harness??
- zc axles
- 00 b18c1 in 94 cx
- Who has OBD0/1 injector clips in stock?
- axles?will they??.....
- release fork ? for b18b in eg
- b16 code 7??? how to fix
- quick swap question
- B16 SIR 2 into 94 civic DX... O2 questions
- crx b16, need heater hose
- H22 secondaries
- Resistor boxes b16a
- Recent swap...problem
- Cruise control, type r cams, and intake/exhaust
- some help for you 88-91 peeps doing MPFI and B16a swap
- dual intake runners
- No heat after swap?????
- Hybrid Revolution
- GSR into CRX how to..please
- can cops do this??? LOOK!!
- possible coolant leak from headgasket area....???
- I hate to ask
- Need some help with deciding on what swap to do.
- OBD II to OBD1 questions
- 5th gen hatch with H22 - so do they really understeer, etc ???
- h22a axle question
- B18C1 Code 45
- Swapping the H22a in a Civic
- EG6 EG9?
- Cables for the H22a
- passing smog with dc header
- Anyone dyno with and without secondaries for B18C1?
- B16 plug wires same as GSR?
- motor mount problem help me out asap
- question on a20a block with b16 head??
- NEED HELP!!!!! get it started!!!!!
- 1.5 l timing belt question.
- 1990 Civic w/ D16Y7 swap... no PS and AC????
- how much did ur times drop
- B20 Swap info
- Engine Inspection, 97 ls jspec b18b
- 91 STD hb and b16a wiring???
- Vtec Solenoid issue for JDM B18C-R into 92VX
- wiring problem B18C into cx (did search)
- B18C5 rods and pistons in B18A block?
- YS1 LSD Info needed
- Fair Price for D15B2 emgine?
- ls v-tec (b16a1 head) cable trans
- USDM Distributor for PR3 (OBD0)??
- Best place to buy ECU adaptors
- Which pistons should I use?
- can i use a jdm obd1 gsr ecu on my b16a2 swap
- will a jdm b20 pass smog???
- need help with swap...ASAP!!!
- 4-speed to 5-speed trany swap in an EF???
- help with building h23 for 94 civic
- Swap Question
- Funky Idel
- Yanking an alternator from an EG with a b16....
- what kinda exhaust would i use for a eg hatch with a b16 swap?
- INFO needed: Internet Copy of ITR Factory Manual Engine Section!!
- ecu throwin code
- pr3 for lsvtec can't understand the comp. ratio
- Please look over my preparations for a GSR into a 2000 EX swap.
- front mount for 91 ef with b16a??
- CEL 4 CKP Sensor (Crankshaft Position Sensor) ~!!!!!!! 94 Del sol
- peak power rpm with cams
- short block question???help
- header on my crvtec?
- 99 LS into 99 ex
- Radiator fan not coming on.
- Bent my shift linkage
- OBD0-------->>>OBD2 *searched* cant find any info
- looking for a cheap b series in so.cal
- spindels on 91 dx hatch...help!!!
- obd2 swap in an obd1 car???
- ECU question....
- looking for some swap tips...
- b16 into EF hatchie, need some directions
- Engine-Land?
- LS into CRX shift linkage cutting
- h23a1 into a 94 accord
- Starting swap on Saturday....any suggestions???
- All Motor Dyno Charts for Keith's swap.....Got torque?
- compression test=blown headgasket?
- 96 accord h22 swap problems
- 93 CX block + d16y7 head = what timing belt.. Anyone..
- ignition/fuel problem with ITR engine in a del sol
- anybody in dallas, tx willing to do an lsvtec conversion for me
- Overheating issues
- GSR internals with lsvtec build up
- 94-95 gsr into 90 crx hf
- Need some speed sensor Info
- on average how long does it take to pull a motor?
- Missing swap pieces, =( Gonna kill my cats.
- b18c5 into ek
- B18 in my 94 del sol
- B18C1 into VX ECU pin question
- cat converter question
- Will a d16 block bolt to my d15 dx tranny?
- gsr bottom end?
- 98 EX swap into a 2G CRX
- any places to borrow a cherry picker or industrial jack?(s.nj)
- H22 Swap
- OBD-1 B18C1 into '92 VX hatch, what to do about O2 sensor?
- Where is a good place to get a B18C5 long block Only (Did Seach)
- Are the engine harness plugs on my B18A supposed to look like the plugs on the D15B?
- You wanna know why ImportAutoSalvage is expensive and still the best!!??
- Questions regarding swap part needed! Please help!
- ecu question
- 99 civic ex swap
- Port and Polish question
- 95 GSR cluster in a 92 civic hatch
- How to hook up AC in a 92 civic hatch with B18C1
- 94 Civic Coupe Power Steering rack to a 96 Civic Hatch Manual Rack
- Need help!!! 6gen civic with h22a swap!
- NO VTEC... cel 21....check 10 times
- eg civics with b18b
- ecu ?
- Type R fuel rail's on B16
- Help on what i need for swap in a 94 civic dx
- LS/VTEC dyno discussion...
- Has anyone have feedback (good or bad) about this company?
- F22 race engine
- h22 swap + 5 speed swap + OBDII-OBDI conversion in the works
- Swap finished, injectors dead...
- Little help with a b16 in a eg, PLease!
- H22 distributor for a 5G hatch
- custom exhaust angles
- ???s on fuel rails for D series engines
- 2000 b16 piston in B18b
- 94 civic cx auto?
- question about an LS on a ek ?
- what mounts for a b18c1 in 96 ek
- CTR std pistons or not yet?
- times with a stock h22 in a 97 integ
- upgrading valvetrain...help
- Flashoption.com....they sell swaps and clips pretty cheap. looking for feedback/experiences
- fuel prob on ls/vtec
- B16a or B20a ?
- HELP! engine swap for a 94 civic dx
- how hard to swap a 1st gen b16a in 89 civ dx?
- H22a
- RHD Rex Help!
- harness swap question
- Are D-series and B-series Slave cylinders the same? Swap question!!!!
- need clutch for zc w/ zc tranny but dont know which clutch
- Ls trani with 99civic si axles
- GSR Swap
- Swap for a 92 Civic
- Auto to Manual Conversion, Hard?
- Need some info re: H22 into EG hatch
- h22 into 95 accord
- h22 swap into a 90 prelude si
- what clutch and flywheel to use with YS1 cble and 97 b18c1
- hybrid springs!?
- Osaka's web page? Where is it?
- 90-91 b18a in a 96 cx???
- 4G63 motor and drivetrain into 4th gen prelude.
- stripped threads inside tranny!
- !!!!!!HELP!!!!!!!!!!!!!!!!!!!O2 sensor stuffed!!will safc still work??!!!!!!!!!!!!
- Please Help. Think I just got ripped.
- EMERGENCY: H23a-DOHC Issues on buildup.
- JDM ITR LSD into a Y1 Cable tranny
- 02 Sensor??
- where is the fuel pump fuse?????????
