Clearance issues. F20B Swap
About to drop in an F20B into my 93 delsol. I heard issues with clearance for the alternator. I did some reasearch and i didnt find much. Couple pictures hear and there but nothing that anwsers my question.
F20b is physically smaller than a h22 so do i ignore this.. whats is a balance shaft....
Re: Clearance issues. F20B Swap
An f20b is not smaller in size externally, only internally. If this is a straight swap with an h/f tranny then you have no issues. Google can be your friend if you want to know about balance shafts.
so i should be fine with my setup. I have a hasport mount kit.
T2T4 tranny
accord inner cv shaft with DA outer shaft.
i just dont want anything to hit.
T2T4 tranny
It shouldnt hit,everything should clear with a swap like yours,test fit it first to make sure,if it hits then just knock the frame rail abit till you gain clearance...
Sick. i read up on the balance shaft.decided since imma throw in a different flywheel might as well. Im hoping its a straight drop. i want my engine bay as clean as possible so dont want to bang nothing in.
gulftiresinc
12-14-2007 07:44 PM
