View Full Version : Hybrid / Engine Swaps
- Torque-ing my H22 civic
- JDM GSR Swap into and LS...distributor wiring help needed
- gsr swap with chipped p28
- b16a oem headers on b20z
- h22 swap into my eg wantin know experiences and suggestions
- B20 short block swap?
- $$ Need H - Series wiring... Upstate NY $$
- Which cat to use? EK Hatch with GSR swap
- GSR swapped civic, CEL Light, Rev Limitor at 7200, Need help.
- prelude B20A cable tranny on a B16A2 ???
- ls swapped crx cutting out at wide open throttle?
- 87 crx swap
- h22a4 trans gears into a f22 trans case?
- wht would happen if u put ur clutch backwards
- H22 cutting out early and tach bouncing!
- D series blocks questions
- Does a crv (b20) water pump fits a B16A2 ?
- SWAPING SINGLE VTEC INTO CRX WHAT DO I NEED?
- How can I retain power steering? OBD2a civic, OBD2a GSR swap
- 94 B18b1 in 96 Hatch Question
- Exhaust Options on swapped 92 hatch
- car wont go to gear when its running
- Which way is easier.
- LS/Vtec bogging problems. >:O
- My swap finally came in B16A
- 5 lug 6thgen Si
- my k24 eg build
- 93 GSR B17 ECU INFO????????
- What year Integra GSRs are OBD2b? Do any of them NOT have immobilizer?
- If LS/VTEC is so great then wouldn't honda have made it?
- p75 auto ecu for manual swap???
- a little turbo
- built h2b turbo project 56k beware...lots of pictures!!!!
- VSS wiring colors, would love some help.
- just a little help
- 96 Del Sol A/C Bracket Question
- 83 Lude, what are my options???
- mounts and axles question....
- b18c5 swap wont run help!
- Axle wobbling and car shaking ????!!
- H22 Swap in EK.... Crossmember w/mount 100% nessesary?
- Anybody ever done a five lug swap into a DA?
- 1993 F22 cam upgrade???
- Buying motors from reputable companies...Are they RIPPING us off?
- which axles will fit b16b into ek 96 coupe swap ??
- can I run an obd-0 b18a1 on my stock p06 ecu??
- WHAT SWAP IS RIGHT FOR ME!?!
- H22 Tranny spins in Neutral ???
- pictures of hardware for EKH2 Hasport mounts?
- help pleaseee
- H22 NOS EG
- fighting lsvtec
- after swap questions.
- knock sensor Drill depth?
- max torque on ls vtec head studs?
- WHAT THROTTLE CABLE ON B20VTEC?!?!?!
- Smog in California
- No Spark, Pease help its driving me nuts!!!
- RUNAWAY MOTOR b17 del sol swap
- WTF!!!!!!!!!!!!!!!!!!! 3RD GEAR POPPING OUT
- Not a Honda, repost? THIS is a hybrid.
- ATTS replacement shaft?
- a/c in eg with a b16 swap
- ITR swap wont get spark.
- Going from a blown 99 ITR to a 94 GSR in an ek hatch, have some questions...
- What Parts to go with GSR Head on ITR Block?
- oh damn the 22 code
- vtec pressure switch ?
- Motor Mount problems with a GSR SWAP INTO A 97 CIVIC EX
- EF B18A swap HELP!!!!!!!!!!!!!!
- H22 EG worth it?
- y8 manifold write up
- my car idles rough and I don't know why!!!
- help! h22 swap jumpy tach!
- 1st Gen CRX w/ B series (what is needed???)
- ***F22B Accord motor in EJ8***
- What do you lose with a K20 swap into an EK?
- LS rods in a d16???? help
- O2 sensor help
- Green and White wire sensor ground ?
- Build up of Race H22A EF Civic
- Exhaust Question
- 96 Gsr swap Into a 97 Civic Ex.
- b16 ef/si swap, need help with the 4 wires
- Which o2 sensor is which? b16sir into ef/si swap
- Is this vaccum line needed for b16 sir into 88crxsi?
- engine mounts and axles for b16b/a into ek ??
- 93 Integra GSR B17 Mounts for a EG?
- JDM B16
- TPS Adjustment Problem
- Compression Ratio... ITR pistons in LS block
- H22 MOTOR WITH H23/F22 CRANK AND RODS (WHICH BEARINGS AND RODS???)
- CEL problem with B18C1
- H2b Kit & plate Dimensions
- Anyone in the philly area wanna hook up vtec in an eg. GSR swap
- jdm obd1 h22a into 97 prelude - crank senor problem
- i need advice
- so...if i swapped a d15b...
- Y8 head on A6 block ?
- Hello i need help
- p28 and stock harness for gsr motor swap?
- pressure switch test??
- What are these plugs for? *pics included*
- h22 block + f22 crank...which bearings and rods??
- need help with my b20b swap
- I need a 97 Civic EX Transmission swap write up.
- help finding part!
- OBD2.B ECU with OBD1 Injectors and Clips?
- HELP!!! B18 swap 92 civic SEARCHED!!
- a few questions
- still confused about my swap
- pre swap Q's
- What clutch/flywheel to get?
- JDM H22A gurus...different rods for different years??? Picture inside!
- Head swap?!?!
- will a manual f20\f22 tranny fit a h22\h23?
- GSR swap wiring question
- JDM B16 w/ LSD y1 starter question
- boosting my d-series over a swap?
- what compression for all motor b2ovtec?
- h22 axel question
- same hp but why the big price difference?
- Prediction!!!!!!
- Started up my B18C in my 98EX today...I have problems. *Pics and vid
- h22 AUTOMATIC HELP!
- civic coupe (ek4) 96 engin swap to b16A/B ??
- B20 swap?
- please help, quick question.
- K20 vs. H22 in a 96 civic dx coupe???????????
- I need some good advice here.
- Engine won't start
- obscure CR-V 4x4 question
- jdm d15 questions
- Which vtec harness for a b18c5 swap into 93 eg?
- Dual cat exhaust - would it work?
- which shift linkage i need for a b16a2 with a s80 in a ek?
- B18 LS Alternator Bracket Question
- swapping a b16a2 into 98 EK coupe...
- converting the LS Vtec back to Type R motor
- PIC request H22 eg with innovative mounts
- For those with a IE header in their 92-95 h22 honda civic hatchback
- anyone try or have in mind a 06 si motor swap ?
- opinion on swap. dont' eat me alive :)
- Bad Swap Pics
- Disable or Enable IAB on H22A?
- Are H22 and H23 fuel rails interchangeable?
- b18a1 swap in a 95 civic
- Cruise control in an H22A
- another b20 question
- P28 and hondata
- K20a R vs Built LSvtec turbo
- H22/EG Avid drive shafts?
- Vtec Problem: cel then no cell??
- Need some clear answers on b18c into eg civic
- Anyone order from JDMCARS.COM before?
- Difference bet. Accord and Prelude Shifter for H22A Swap ???
- Smog question for JDM B16 swapped 92-95 civics
- pp4 ecu.... for which engine\car is it?
- HELP!!! Highest recommended h22/eg swap shop in socal?
- AWD CRX del Sol - CRV driveline swap
- h22 in ek, need help!
- help with b20 swap
- obdI h23 in obdIIa coupe
- Buyer Beware
- OBD DLC issues
- h2b oil line????????
- b16a1 to b16a2
- Need Vtec wiring diagram
- Accord H22a misfire. I cannot find the problem
- K20A2 in an EP3
- any h2b dynos yet
- Timing On a CRV
- P7J CRV Compressor mount bolts
- P30 ECU Code 8 HELP
- question about trans swap
- wire harness question
- Chipped ECU?
- h22 vetc eg check me out yo!
- which throttle cable on a B16A swap into a 94 civic Si hatch
- ls/vtec Do i needa run the knock sensor?
- help me finish up my swap. Dont know where 2 hoses go
- Fuel Pump
- H22 into ek mount problem.
- Which header fits JDM H22A
- JDM H22A stock header vs. cheaper aftermarket brands
- Is it possible to keep ac in an H23 Integra?
- How-to removing GSR intake manifold butterfly secondary?
- b16 in eg.. messing up... reving problem
- h2b turbo kit need help???
- I came across a H23a1
- o2 sensor from usdm 88crxsi work in my b16a gen1 swap?
- GOT A P28 NEED CHIPPED WHO IS GOOD!!!!!!!!!!!!!!!!!!!!
- AC and Power Steering removal
- i want to wire in vtec into my 97 cx harness for my b16a help please
- Rattle....need help
- B16A swap into 95 cx wiring help
- Nice car. . .
- SiR exhaust on a dx?
- 99 ex harness problem
- 1993 Acura Legend Swap Qs
- cad drawing
- ef civic iac problem
- b16a sir1 into 88 crx si-speedo cable question.plz help
- Where to find good deals on swaps?
- Radiator and catylic converter for 95 Civic with B18C?
- h22 swap and have no reverse
- GSR B18C Clicking noise
- In process of getting swap...
- D to B? Any conversions??
- How many of yall using stage 1 DSS or Gator axles?
- ecu pinout
- are explicitspeed360 mounts any good for the h22 swap
- so who runs without the flywheel cover plate?
- lifter swap
- DSS Stage 3 Axles for H22 EG - what other hubs will fit ?
- Which Cat Converter will fit for me?
- b16a2 vs b18b
- B16A Swap Help
- swap help
- B18C Starter hitting Pressure plate!?
- Oil Drain Plugs
- 88 CRX swap, I'm going to a b18a1 and need some help!!
- a swap keeping all the options
- 92-93 YS1 Tranmission with 94+ B-series clutch
- H22 Wiring Question
- Head Code Page?
- JDM engine harness....will it work???
- K20 Type S in a CRX....
- question on gsr header
- Hot Engine
- what about those older B- Series motors
- B16A SIR-II Auto Swap! Help!!!!
- H22A M2B4 LSD Tranny - What Oil do I use?
- Anybody playing with a B17? 93gsr swap? Buying one to go into a EG... opinions?
- OBD1 vs. OBD2 alternator plugs - which is which???
- y7 bottom end y8 head compression test
- ECU ? for H22
- h22a part numbers
- where are all of the do it yourself threads?
- WHICH THROTTLY BODY???
- Flywheel Bolt Question
- good places to buy swaps
- 1990 civic w/ITR motor --- "GREMLIN" problem
- B20z swap won't start.
- b18b swap
- H22 ITB's in 00' Civic
- GSR AC Compressor on B16A
- OBD 1 pinouts
- Quick question on installing B16A 92-95 (SiR-II) into 1995 DC ls
- K-Series ECU interchangability
