PDA
View Full Version : Hybrid / Engine Swaps
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 [35] 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174
  1. D15Z - What D Head Will Fit that block??????
  2. GSR axles on EK with B16A3?
  3. i need some help guys
  4. I don't know why i lost
  5. B16 in EK, will GSR axles fit??
  6. need help compiling a piece list for a b20vtec
  7. Has anyone in cali tried BARing a b20 into a 4dr integra? if yes what is needed?
  8. 93 del sol s SWAP
  9. 98 D16y8 into a 97 ek coupe(non-vtec)
  10. jdmb16a1 swap into my '89 civic
  11. da knuckels on eg
  12. hybrid performance?
  13. k20 cb7
  14. D16Y8 BLOCK AND D16Z6 HEAD
  15. quick tranny question, just double checking myself
  16. F20A with a H22 Head got some ????????? Searched
  17. 93 H22A swap into my 98 civic
  18. H22A into EG with stock fuel pump from D15 okay?
  19. Maybe flywheel problem
  20. H22 coolant hoses... NEED PICS!!
  21. H2B H22A or F2B F20B??????? HELP!!!!!!
  22. eg h22 computer (i know I know search) but none really answer all the q's...
  23. CDN SiR B16A2 Swap
  24. Wiring Harness question...
  25. ek vti need wiring help.
  26. Need wiring help... B16A2 (99 Si) Motr into a D16Y8 (96 EX)
  27. crank gear install???
  28. f20b or f22
  29. running rich
  30. where to find k24s and k20
  31. h2b
  32. h22 swap revs up and down not fitv ot iacv
  33. Help!!! I cant figure out whats wrong with my H22 swap
  34. B16 into 93' civic
  35. H.T. NEED HELP FAST
  36. An idea! F22C/f20c/h22 internal swap.
  37. sup H.T.
  38. PLEASE HELP??? I am stumped I can not figure out what is wrong with my H22 swap
  39. 5 lug on an EG. What axles do I need?
  40. k24
  41. F20B Spark Plugs same as H22?
  42. 98+ spec jdm type r still stuck with CEL
  43. Which sparkplug wires?
  44. computers!
  45. Comp Cam?
  46. Easy Question on Throttle cable
  47. nitrous on h22 in a eg
  48. H22a type-s into eg question's
  49. my h2b never ending project(spiderman)
  50. Which computer should i use???
  51. Help, 98' LS swap into 97' EK Hatch.
  52. Ek H22a swap with skunk2 IM
  53. h22 swap into 97 accord..
  54. Need advice.
  55. toe in bolts
  56. 2000 b16 swap into 96 civic
  57. VTEC pressure bypass..works, but then causes CODE 21(solenoid)
  58. forged pistons
  59. Spark plug wire sequence
  60. h22 into 96 integra
  61. exhaust question
  62. H22a civic overheating issues! I NEED HELP PLEASE!
  63. H2B Turbo CRX...... my never ending project!!!
  64. F2B Swap no vtec. works from a roll but not from a dig? HELP!
  65. Wat is the dizzy code for a LS ODB1&2 b18b1 « »
  66. wait a sec
  67. Another "b18c swap ek question" thread
  68. p28 ecu
  69. k&n filter
  70. clutch help
  71. has anyone in cali tried BARing a B16b into an ek
  72. PRELUDE AND S2K
  73. 2000 Integra GSR with a B18C JDM OBD2 engine
  74. LABJUNKIES.COM?
  75. GSR tranny and LS engine ?
  76. will the a/c fan work for my radiator
  77. h22a1 swapped for jdmh22a4?
  78. d15b crank in d16a6 block
  79. B18 into EG with A/C: easiest way to keep my A/C?
  80. Quick!! swap mount question GSR in EG 2 or 3 Bolt mount ??
  81. Help with this one... Please!
  82. Motor ?'s guys
  83. F2D or an F22B1 Turbo
  84. Hydro Tranny, DA axles & halfshaft, what axle seals?
  85. How Much Better is Hybrid Car Gas Mileage?
  86. GSR Civic Wont Start! please help.
  87. How to wire IAC for B18C5 in EK?
  88. wont pass smog
  89. the differences between B/H/D series vtec solenoid
  90. VTEC kickin in better with P13 or P28?
  91. p30 GSR
  92. H22/H23 question
  93. crank bearings the same????? please help thank you.
  94. EK H22 swap....
  95. another h22 bogging thread..but different?!!!!!!!!!!!!!!!!AHHHHHHHHHHHHHHHHHHHHHHH HHHHHHH
  96. WANTED B16A LONG BLOCK OR B18A/B18B ONLY. ENGINE ONLY.
  97. JDM tranny
  98. H22A correct vacuum reading on vacuum/boost gauge - anyone knows ??
  99. How long do you think it will be before the K swap cuts the price down in half?
  100. any help with axles??? asap
  101. motor questoins HELP searched.
  102. B18a Del Sol swap?
  103. idea's on 84 CRX swap
  104. b18 swap
  105. h22 swap in eg civic. What all parts can be omitted???
  106. Need help after swap
  107. How far can you stroke a B16a?
  108. CRX JDM B16 OXYGEN SENSOR REPLACEMENT QUESTIONS.
  109. GSR swap... Now having speedometer problems.
  110. My H series nightmare... Need a little help
  111. h2d or regular h22
  112. Which pinouts are for the TPS Sensor on a p13 ECU h22 civic!
  113. z6 head/distributor in 99 ex car
  114. About this Header thing...
  115. Chipped P28 for f20b?
  116. h22 crx fuel pressure solenoid wiring !!!!!!!!!!!!
  117. 98 type r motor, 97 type r harness...HELPP!!
  118. USDM H22A4 head on JDM H22A block..
  119. Problem with check engine codes on h22a civic
  120. gsr vs accord iacv?
  121. h22a1 and h22a4
  122. b18c in a crx si question
  123. LSVtec oil leak help
  124. do civic axles fit in a crx? d16
  125. 2004 civic hybrid transmissions
  126. What radiator setup for h22 eg?
  127. tools to pull a tranny
  128. H2B strut tower brace...
  129. H2d question need help. clutch peddle staying down
  130. Please help, Searched but no answer
  131. type r swap into a 94 ls teg.
  132. Just got my camp1320 header on
  133. h23/h22
  134. SOHC 1600 into vtec problems
  135. Info on swapping 92 gsr to 90 lss
  136. 89 civic hb swap
  137. d15b in 00 civic ?
  138. obd2 ecu pins?
  139. What clutch?
  140. H22a s2000 transmission question...
  141. H22a Type S Into 1994 Accord KEEP IT AUTOMATIC!!!????
  142. New to the site... with a question!
  143. h22 axles in eg swap (i know search, but new question)
  144. B16B with no acceleration after VTEC
  145. H22 w/tiptronic in another platform[eg,dc..] other than a prelude?
  146. h2b crx
  147. help, no vtec did everything,
  148. EG rotors EK rotors
  149. What Engine harness to use for h22a4 into 92 civic CX?
  150. One labor intensive engine swap...
  151. Hastport 2 Mount Passenger Axle Angle Problems (Searched)
  152. 97 Integra getting a jdm 98 spec b18c swap.
  153. ek gsr swap wiring issue
  154. avid motor mounts
  155. looking for others that have this swap.
  156. gsr bogging issuses
  157. B20B Partial throttle misfire
  158. Need info on obd2b and obd2a GSR swap to EK
  159. JDM H22A to Type SH
  160. obd2a engine swap in obd2b car. no tach signal to gauge.
  161. Midnight Performance Tuning
  162. b18b on a ek
  163. Gsr crankshaft...ls rods...
  164. My DC4 H22/H23 VTEC Qs? Moved from Integra to Hybrid for help :)
  165. 1998 civic jumper harness
  166. Please Help... Civic Exhaust on an H22A
  167. 2000 cx motor into ej1 coupe. Which rear tranny bracket do i need?
  168. OBD2 distributor on OBD0->OBD1 conversion?
  169. what half shaft do i use for a h22 swap in a 88ef?
  170. OBD2a to OBD1 conversion diagram confusion
  171. b20 into 00 hx
  172. PGM tester wont recognize new PCM!
  173. Intake manifold bolt pattern!
  174. b18a into 90 civic hatch, need vacuum routing please
  175. 97 F20B in a 93 civic Si Distributor problems
  176. hatch 93 honda civic dx d15b7 swap B16A 92-95 (SiR-II) complete change over package hmotors
  177. k20 + ek
  178. where does this plug to....
  179. p28 obd1 question
  180. 00 d series NON vtec into eg.. searched
  181. K20 DC2 in progress... Custom brake lines and fuel completed
  182. 4.7 Final Drive for H2B setup - Yes or No
  183. Dohc ZC Question
  184. itr water pump/b16 timing belt
  185. where to get great deals on water pump timing beltsssss
  186. <<HELP>>97 EK Hatch engine harness
  187. ATTN: anyone with a hydro dohc in a 6th gen civic
  188. HELP! Axle problems with innovative h22a mount in EG
  189. B16a1 or b16a2
  190. Vtec Problems *HELP*
  191. HCP mounts!!!
  192. automatic LX engine harness on a D16Y8 Civic EX, what to do?
  193. dohc zc distributor wiring
  194. abs issues in k20 eg civic
  195. k24 pistons which ones to get
  196. looking for H22a Turbo Base Map crome P28 or hondata S300???
  197. wiring issue need help asap
  198. Little help-trying to keep power steering
  199. Help Smokey B20B VTEC Build
  200. F20B interchangable parts
  201. Does ITR parking brake wire fit Civic EG4?
  202. vtec!!
  203. Matts 4wd CRX project
  204. h22 with p28?
  205. h22 tranny gears
  206. [FAQ] How-To: K20 into 92-00 Civic/94-01 Integra
  207. Q45 or Mustang Throttle Body
  208. PCV valve on b20vtec
  209. B18C swap in Civic EG4 engine harness plug problem
  210. wiring harness questions that couldn't be found through search
  211. /\/\/\/\/\/\/\/!!!!!del sol k 20 question!!!/\/\/\/\/\/\\/\/\
  212. what exhaust and what turbo?
  213. odd problem w/ b16 in a CRX
  214. h22 teg won't start
  215. About to buy a b20/gsr motor in an Integra, need advice.
  216. what is the best short ram intake for eg w/ h22 swap
  217. K20a2 complete (exterior) motor disected & labeled! **Pics**
  218. type r in an ls
  219. type r in ls
  220. h22 shifting problems..
  221. H2b Nitrous what shot?
  222. b18a1 obd1 dizzy guts into b18c1 obd2 dizzy shell?
  223. Swap done, starts and drives but bogs out at 3k rpms
  224. ls motor swap in an ek
  225. h22 swap...not reving...
  226. MINI ME SWAP HELP!
  227. B20B in my DA with Hydro Tranny
  228. fan help
  229. eg shocks and springs on a crx
  230. H22 type r
  231. 91 CRX SI d16z6 help
  232. 00 si front suspension on an eg hatch
  233. jdm B18C type R, bogs at low RPM
  234. What can I use for my swap, b18b into ek
  235. Difference between CD5 and BB4 mount locations
  236. odometer on s2000 cluster won't show anymore
  237. header for 89 civic hatch with obd-0 b16a
  238. jdm b16 lsd trans??
  239. need help with an L bracket
  240. How much is compatible? (F20B/H22A)
  241. help which distributor do i use
  242. throttle cable and exhaust 02 sensor
  243. B20 Wire Harness
  244. vtec wiring diagrams deleted!!!!
  245. A/C Vibration (h22 swap)
  246. no vtec (did some troubleshooting...see inside)
  247. Hydro tranny mount for DA
  248. H22 swap alternator noise / squeal
  249. b16 tranny with b18a internals??
  250. Reccomend a garage in New England
