D16z6 Block, D16y8 Head + Dizzy, S300, Obd1 harness - Crank position sensor CEL
Hey guys,
Currently the situation is. I have a ERL built D16z6 Block with a D16y8 Head. This is in a EG Civic running a Obd1 Loom / harness with a Hondata S300. Obviously i have had to run a D16y8 Distributor and i have changed the Obd2 distributor plug to Obd1 to match the loomb
The Car fires and runs however throws a Crank position sensor CEL. From the searches i have done so far i believe this is a common problem for the setup i currently have.
Question is how do i get around this problem ? Any advice / links etc
Thanks in advance
Regards Lyle
Thanks in advance
Regards Lyle
dafuzzbudd
07-02-2008 05:16 PM
ComputerJLT
05-19-2005 06:48 PM
sportcompactpower
04-25-2005 04:39 PM
