PDA
View Full Version : Hybrid / Engine Swaps
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 [107] 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174
  1. Engine Code 91.
  2. NE importers of JDM engines on east coast?
  3. h22 thermostat
  4. b16 pistons on ls rods, shaving?
  5. will a stock GSR exhaust bolt right up to an EK B20 swap?
  6. How Do I Wire Up A Resistor Box In My 93 Civic Hatch??
  7. Idling problem with ek B20Z swap, help!!
  8. how do u distinguish B series transmission
  9. HELP WANTED: dpfi to mpfi conversion in San Diego, CA. I will pay you big bucks!!!
  10. Calculate Engine Size in Cubic Inches and CC's
  11. 93' Civic PS pump in 99' Civic?
  12. tranny problem after swap
  13. engine rebuild?
  14. p12??
  15. H22 del Sol backfiring when shifting
  16. help
  17. Newbie with a question!
  18. eg w/ b16 Radiator hose problems
  19. Test pipe problems!!
  20. sohc p28/gsr swap...
  21. GOOD and BAD parts of a Civic hatchback(5th gen) with h22 swap.
  22. Speed governor on a JDM H22A??
  23. LSD INSTALLED? SPEEDO GEAR?
  24. D-series transmission with a B-series
  25. p28 simple questions
  26. T/O bearing question(J1 tranny/90 Integra clutch)
  27. Wiring a OBD1 JDM H22A into a EK
  28. engine year and type?
  29. thermostat and thermo switch (b18c1)?
  30. distinguishing between the b18c and b18c1
  31. Please help, swap question for CRX
  32. b16/ef fuel problems
  33. B-series interchangable part question?
  34. help swaping a d16z6 into a 92 civic cx
  35. how to wire 02 sensor for b16/ef swap
  36. b18 c questions
  37. Came back from the track
  38. Fuel cutting off while driving.....
  39. What are the head bolt torque settings for b16's.
  40. How long did your engine swaps take?
  41. H22 swap, NEED TO FIND SHOP TO FINISH JOB
  42. H22 resistor box
  43. obd2 complete head going into a obd1 car
  44. H22a hybrids..anyone disappointed in theirs?
  45. h22 in 92 cx hatch,,, will JRSC fit?
  46. EK cable tranny Swap question into an automatic.....
  47. APEXi N1...(question involving exhaust)
  48. Will the 95 LS intake mani work with a 97 B20b?
  49. H22 Tranny Hoses/Lines?? Where do they go??
  50. CTR Pistons in a B16 block with a GSR head ???????
  51. b16 intake manifold to b18b?
  52. h22 eg -dss level 2 problem-
  53. where can i find an MR2 Tranny?
  54. How much to install ARP rod bolts onto an LS block..
  55. Complete OBD1 B18C1 into Civic VX Wiring instructions.
  56. H22-accord speedo and IAC problem
  57. Wiring Dilema - I'm tired of being a tired of this
  58. Code 20 Circut overload?? + Po2 Sensor
  59. any difference in 98/00 ls motors?
  60. need wiring help
  61. HELP! Solid CEL light
  62. Post all your questions for K20-eg here......
  63. Just got an R swap into my eg, shifter problem?! HELP
  64. D16a1. Worth anything???
  65. good turbo kit for h22eg!!??
  66. d16 in 94 sol s
  67. jdm itr swap in gsr
  68. northstar v8
  69. Problem with the IAC
  70. d16z6 into 94 cx
  71. b20b into a ef9 hatch..good price?
  72. Intermediate shaft bearing leaking?
  73. so long D
  74. identifying a gsr
  75. swap question
  76. motor swap
  77. 2001 civic swap
  78. Adding a CKF to an OBD1 engine. Hurdles?
  79. its here its here
  80. obd1 h22 in ek distributor problems
  81. how/were to get b-18
  82. B16 removal and install help
  83. In need of a helpful hand in So-Cal
  84. b16a into an 01 civic HX
  85. a couple b16 ?s
  86. need some info on 94 cx with JDM type R swap
  87. mini me wiring?
  88. CAN SOMEONE PLEASE PLEASE HELP ME!!!!!!
  89. JDM vs. USDM wiring,
  90. no oil light after replacing oil pump
  91. axle sizes?
  92. Turbo kit is sold, now what?
  93. Anyone/Shop Willing To Help Give Me Details On A H22 Into An Ef...
  94. help on del sol swap?
  95. b18 c1 w/ b16 head running rich ... but no cel
  96. what kind of motor mount do i need for a b series swap in a 96 honda civic hatchback?
  97. d15 non vtec to d16z6
  98. Electrical system Help F22b swap into 94 accord
  99. H22a1 Swap into a 92-95 Honda Civic coupe. How hard is it
  100. sr20de in a crx, true?
  101. fuel injectors and diszzy diffence
  102. Mazda Engines (sorry not Honda)
  103. secondary o2 sensor - does it affect motor performance/function? LINK TO TECH
  104. How do you check cel on a 4th gen accord with a OBD1 ECU
  105. need to find out the pin locations for vtec on a pw0
  106. b20b into 97integra... CPS sensor?
  107. All wheel drive civic
  108. Which motor?
  109. where can i buy 3" aluminum pipeing to make a CAI for my EF
  110. Will 94+ teg axles work on a 92 eg with an h22a?
  111. I need 96-98 JDM P72 Pinout
  112. run lean need help
  113. swaping B16 into a Civic?
  114. Hayabusa motor
  115. WTF broken hasport mount?????
  116. timing belt teeth?? how many please help
  117. i know its not a honda but
  118. OBD questions
  119. Redrilling 4x100 to 5x114.3 a bad idea?
  120. Is it worth to RUN a CTR motor with LSD tranny or GO with YS1 92-93 GSR Tranny?
  121. Difference between Prelude and accord shafts
  122. 98 H22a4 swap into 00 EK....
  123. All Skunk2 head, b16 2nd gen
  124. upgrading injectors!
  125. considering doing an h22 in a 96 hatch... need help....
  126. Which cap, rotor for JDM H22A1
  127. Axle breakage
  128. poor man's type r
  129. LCA and rear hub questions
  130. b16/b18 hybrid questions
  131. b18c1 into EG swap...a/c powersteering question!! hELP!
  132. OBD0 Swap into EK w/ hydro tranny
  133. which distributor? b20z motor w/ pr4 ECU
  134. Rear Engine Mount 93 civic with b16 2nd Gen
  135. 93 eg with b16 2nd gen throttle cable
  136. b20-vtec valve spring and retainer?
  137. lets see some pics of h22egs!!
  138. Wiring Harness
  139. Searched: Mounting b16 in EK
  140. Anyone here running a GREDDY timing belt????
  141. What IACV's will fit my JDM b16a
  142. First time at the 1/4 mile track with my B20 non-VTEC EK
  143. b17 rods?
  144. h22 help
  145. CR-V-tec Idle prob
  146. Rear tranny bracket question- EG/GSR swap
  147. B16 removal and install help
  148. CEL when i slow down?
  149. JDM GSR HELP
  150. H22 guys... anyone go to E-Town?
  151. OBD1 JDM B16 SIR-II into a 2000 Civic Si OBD2b Questions???
  152. 1990 integra swap idea need ideas
  153. will a gsr knock sensor fir an h22,
  154. those with b18s in eg's and ek's...
  155. Hi guys, placing a ZC DOHC motor in my 88 honda CRX DX
  156. crvtec life??
  157. Need help on fabricating shift linkage????
  158. 93 accord auto to stick tranny swap problems
  159. wtb: please need a D- series swap , or zc dohc, or d15b vtec
  160. dohc zc into '90 dx, i need help in san diego, ca.
  161. What is better I-VTEC or VTEC?
  162. 92 Civic. What VTEC wiring is there? I searched...
  163. Looking for USDM ITR motor
  164. b16a into 95 dx
  165. how much power
  166. B18 into 95 Hatch..Wiring help...
  167. N/A H22 1/4MILE TIMES!
  168. Best motor swap
  169. B16A/2 Engine Swap
  170. NEW K20 - 92-95 Chassis thread
  171. '94 USDM Del Sol B16 Into '96 CX Hatch --- Help
  172. callin all Illinios hondata and or ECU reprogammers. where you at???
  173. b18c5 into dc2 integra ls wiring help :-)
  174. Question about Civic SI
  175. How important are these two screws
  176. Shifter Cable broke!!!! Help
  177. wiring question?
  178. I have a 88 Civic Wagon 4WD... Will i be able to swap a B18B1 or B18A1 in without any modification??
  179. oil filter
  180. My dumb questions for all the pro swappers out there...
  181. Choosing an engine/trans swap.
  182. a2 tranny parts into a1 box
  183. Swapping an h22a (5spd) into a 1990 DX (5spd)
  184. need suggestions on what to do next...
  185. dynoed my car need to know how badly off the dyno was
  186. Has anyone done this B16?
  187. question about a hybrid honda???
  188. ecu pin problem
  189. B20 VTEC QUESTION??? SCHOOL ME!!!
  190. B18A1 in a 90-93 accord
  191. Who has blown up a LS/VTEC motor with a stock bottomend?
  192. Messed up wiring. Radical solution.
  193. 98CTR with LSD Hydro into a 91 STD hatch > Running OBD1 Currently.
  194. B16A2 IM vs B18C5 IM
  195. Crank Swaps
  196. 97GSR into a 93 DX hatch > ECU wiring ??
  197. can anyone help, 5 lug rear trailing arms?...........
  198. gsr swap question
  199. Which air intake for my hybrid
  200. H22 into 90 Std
  201. B18c5 axles
  202. Running to lean...
  203. Using a stock P28 on H22 hybrid...
  204. Help with check engine light!
  205. when sleeving a b18a for lsvtec?
  206. can someone explain these transmissions to me?
  207. best fuel 2 air ratio
  208. b16a head on b18c block wiring?
  209. Exhaust in eg/ls swap
  210. engine swap question
  211. accord/h22a question
  212. Picking up my swapped del Sol tomorrow, what should I look for?
  213. help...can i use a VAFC instead?
  214. itr in vx
  215. auto->5 speed howto thread?
  216. F22B won't idle when warm.
  217. Will this bolt up to my B18C hatch?
  218. JDM ECU
  219. Tranny Issue
  220. H22 Swap List
  221. Tri state H22 hybrids!!!?
  222. GSR swap questions for my 95 coupe
  223. nice clean wiring
  224. Tokico Illumina's + Ground Control coilovers, cheap alternative to threaded body!?
  225. b16 swap, having tranny problems.
  226. B16a1 just shut of on the way home!!!!!!
  227. b16 in 95 EG Si,, smokes like a hog, blows mad oil, ????
  228. H22A mount kit for ED/EF?
  229. H22 WHP???
  230. will obd1 head work on obd2 block?
  231. h22 pic
  232. Anyone go OBDII to OBDI in Texas?
  233. B16 Idle is Choking
  234. any other b18c/eg swaps with non working rad fan??
  235. F20b in a 6th gen Acc
  236. bottom build
  237. b16a2 air conditioning??
  238. Evergreen College Ref in San Jose
  239. Re: JDM vtec solenoid
  240. HCP mounts yay or nay?
  241. b16b wiring
  242. I have no freaking clue..
  243. H22EG Intake
  244. Finally got a GSR motor for my 95 Hatch...Couple questions...
  245. h22 problems
  246. EG coupe W/B20 driverside motormount problem
  247. have anyone deal with Zerolift from from Cincinnati
  248. Oil cooler question:
  249. Adding wires (shock to ecu harness)
  250. Does the year matter with JDM swap?
