View Full Version : Hybrid / Engine Swaps
- Is the Vaccume Box (Purge Kit) Needed in My 1991 crx si with a D16Z6?
- No more vibration(H22a setup)
- converting my 91 crx/si to accomodate my GSR hydraulic (LSD) tranny
- New Idea, please help
- b20a question
- post your all motor lsvtec
- b20z compression ????
- B16B EVAP problems ... HELP!
- Swap or not? Please Help!
- LS/Vtec - Give me opinions on my setup...
- GSR swap to Civic EK???? OBD2!!!
- Removing engine from underneath the car?
- DX EACV plug wire colors??
- will not rev past 3k b16 swap
- how many of you guys took out a loan to get your swap?
- will my 99 civic throttle cable work with my gsr motor?
- CAN I USE .....
- will my 99 civic distributer work with my 95 gsr motor?
- ls trannies??
- chech engine light after swap
- need to buy jdm h22a front clip
- b18b with gsr clutch and g/box?
- H22 into 1989 CRX, anyone?
- reasons why honda products suck!
- oem lsd?
- Distributor Ignitor Question (all obd1 the same?)
- Anyone recommend reliable shop for USDM B18C Swap to '93 Civic (SoCal)
- c5 into cr-x swap questions???
- I have a Important Question On B20 Vtec motors ?
- obd1 motor into obd2 car
- Cam shaft app.
- Purge Cut Soleniod Valve?? Where to put it on a d15b VTEC
- A/C compressor took a shit, help me with which one I can use
- Battery and Coolant connections! Just 3 pics inside! Eg / GSR swap!
- Where does this GSR engine wire harness go? Eg/GSR swap! Pics inside!
- what else do i need for a b20b swap
- Help me wire a 91 LS distributor onto a dx to si 89 Civic.
- h22 swap into 98 accord coupe
- i need a pics of h22 civic linkage
- B16 header won't fit B16
- del sol body/GSR engine
- b16a2 pistons, rods,and crank in d16z6
- B17 tranny? 2 hoses by speedometer cable
- Help wiring 4-Wire 02 Sensor to ECU!
- Cam....?
- Whats the weight difference between D16y8 and B16a?
- oil filter...dumb question
- Too cool....H22 Insight Hybrid
- 92-93 B17A Dist. OBD1??
- 95 gsr running to rich in OBD 0 91 CRX
- H22 euro R single runner intake mani
- H22/civic ECU Question about EGR?
- i really dont know what motor to get now
- difference between auto and manual motors????
- LS VTEC or B17? i have both which to use?
- OBD1 P13 for the h22/civic hybrids....
- Are the 99-00 SI ECU pluggs same as the 99-01 GSR and what wires have to be changed to make it work?
- H22a Clutch ???
- A different type of Hybrid....................
- ls/vtec which axles???
- Imagine Engineering H22A/Civic Hybrid Header
- WHP from stock B18b and JDM B16a1 ???
- which engine mount and axles to use?
- b185 Del sol passes emmissions with kenji ECU!
- swap shops in so cali?
- Flash Option
- Moroso Oil Pan for Crvtec
- H22 Civic wiring conversion harness: Where do I get it????
- Civic VX 02 sensor and B16B engine.
- How much could a B18a go for?
- clutch question for my d16z6 swap into 88 crx
- ODB0-ODB1 engine wireharness Question -- Need help
- mpfi swap done but idles at 5000 rpm!!
- Swapping a 97 JDM ITR into my 98 Civic EX Coupe.... Anything else I need? Help Thanks
- H22 Hatch saw its first NX last night!
- 94+ Integra GSR Door Panels in 93 Civic DX
- is it true that motors are stamped one year behind?
- Swap begins soon. Please look at my list and see if i am missing anything.
- changing out 3rd gen prelude s pistons
- dizzy question??
- GSR swap into Civic EK????
- What does it take to do LS/Vtec?
- b18b in an EG lower rad hose
- ecu pinouts for swap?
- b18c1 into a eg
- 1999 Civic Ex/Gsr Swap Question
- H22a Help
- add ckf to obd1 engine?
- did a swap, now im frustrated
- do they make 93 b18c1?
- need help asap pleaseeee-- putting 98 type-r swap in a 92 VX hatch i'm lost
- b16 smog question
- Should I go b20 or b18c
- B16A into 91 hatch.. got a few questions
- How to tell if ecu is for auto or manual?
- One last question for the H22 EG SI... O2 sensor.
- Update to distributor issue with h22 hatch..
- which motor and head should i get
- d16y8 head and intake manifold on d16z6 block
- Shift assembly setup!
- Removing Shifting Cables
- why my car sucks.......
- Dropped a B16B into my 92 Civic VX - Will Not Start .. HELP!!!
- Civic GSR Swap problems.....Help!!!
- b16a2 locating
- Where to find b18a's?
- h22a p13 ecu question
- Just finished a DX t0 ZC swap....no power----need help
- Need some advise
- Beat motor swap
- air conditioning hooked to the intake in summer. worth it???
- b18b in an EG
- wiring harness pins
- how do i wire in a four wire O2 on a 1 wire car? THANKS
- gsr secondaries.
- need help wit a gs swap into my 96 civic
- b18c1 swap into 2nd gen Integra
- I improved my 1/4 time! 2000 Civic EX/B18b
- OBD-0 to OBD-1 conversion harness
- P72 block/P73 head; Where is ECT?
- How do you convert from 1 wire 02 to a 4 wire 02?
- stupid freight company
- Automatic Swap
- JDM P73 specs?
- Prelude Master Brake Cylinder ...
- For people who have swaps: Did anybody go through the DMV inspection and passed?
- b18c head removal???
- just finished swap now car wont start.
- Eg / GSR Hybrid! Someone post a checklist of what needs to be wired up / connected!
- Help with HONDATA tuning>>>>>>>>>>ATLANTA
- Jimfab crossmember w/ H22 in teg/civic??
- H23 into teg using LS ecu / what style injectors?
- obd2 dx ecu on b18b motor?
- tranny swap help --<please>--
- guys with a B16a CRX, I have a few questions...
- Adjusting B18B1 Timing
- D series Dist B series Motor
- Car grinds (loud) when I turn hard... Any Clues?
- usdm obd1p72 vs. jdm obd1 p72
- HELP!!! Car wont go into gear!!!!!
- JDMpower.net???
- GOD DAMN THIS SWAP (wont start)
- why does my car surge?
- How much would B18a go for?
- b16a in crx si code 22 how do I fix it?
- B18C into Del Sol
- How many people that got the jdm type r motor got the cf cover and chrome oil cap???
- Timing belt looks like its going to come off!!!!
- Si head on d15 block
- How much are b18a or b swaps?
- Fuel Pressure settings for optimum gas mileage on B16A with mugen ecu.
- Defeating VTEC oil pressure switch
- H22a Swap Guide
- the swap headache continues (throttle cable bracket)
- Avg. Cost for B18C shortblock
- B17 parts list
- h22 swap just finish !
- First gen B16 head on a CRVTEC swap - OBD1 car
- 1800 for a full obd2 gsr swap?
- EK w/JDM GSR Hybrid Problems!! Please Help!!!!
- Looking for a good place to buy a swap
- '93 JDM H22 into '96 Accord -- Wiring Question
- h22a Vaccum diagrams
- vtec wiring thread that showed DETAILED of soldering the wires, where?
- modifying valve reliefs on stock b20 pistons for CRVTEC?
- jdm d15b need advice
- NEED HELP B16 Swap Complete No reverse no fifth
- H22a in CRX?
- which setup would you choose??
- B20 Swap
- Will a PM7 ecu work for a B16 swap.....
- ODB1 - ODB0 Conversion?
- Stupid Hybridized Stuff
- B20 with B18C5 head?
- keep breaking drive shafts H22a lsd Eg Hatch
- Help help....altinator compatibility
- !!!HELP ASAP!!!!can i use a obd1 resistor box to upgrade my hf to multipoint
- Anyone been following the K20 swap for 3rd Gen Tegs
- the best b-series tranny
- hybrid insurance
- Wiring up Vtec for swap
- What to look for when buying a hybrid?
- http://www.hondarecycler.com/
- Car started!! but I have 3 error codes :(
- Will integra axles work with Si(R) intermediate shaft?
- Looking to buy a 98 & Up Type R (C5 Preferably J-Spec) Swap!
- I need help
- Clutch Problem - Hydro system or clutch components???
- H22A setup
- how to increase rod stroke ratio on B20/vtec ??
- h22a4 into 97 dx hatch- What is needed
- someone who knows something about ecu's. take a look. poeple with skunk 2 intake mani look too.
- anybody use b16 program on a sohc vtec???
- VX and Si interior harness?? the same?
- LS Vtec? Good or Bad?
- p28 wiring instructions
- ok, car cranks now, but doesn't turn over......
- B18c1 swap mount bracket help needed
- 96-00 Civic/GSR swap
- h22 swap mounts???
- Throttle Cable Bracket for Hybrid?
- Picked up the motor and it looks good
- H22 harness question
- building an SIR axle--having a hard time getting the cv tripods off of the shafts.
- I have a 97sh prelude, but i need a new motor and tranny?
- What tranny is the V4D????
- Traction bars for a H22 EG?
- B16a1 into 95 civic info?
- h22-h23 injectors
- Day 3 working on the Eg / GSR swap **56k stand back about 8 miles**
- what gauge clusters are you guys using?
- Which throttle cable to use: GSR or EG's? Eg / GSR Hybrid! Pic of both inside!
- Am I wiring the vtec wires right?
- car wont crank! H22 eg
- Rebuilt B17 swap having small issue.. Ideas?
- Question about B18B into 6G
- JDM b18c into a 1998 Integra LS (PLEASE HELP!!!)
- D series motor question
- I need a dyno chart of an LSVTEC motor with Type R internals
- JDM B16A SiR1 to JDM B18C
- 92 4dr Civic LX Auto....
- prelude in a delsol?
- Best Intake Manifold for N/A - CRVTEC? And other tuning Q
- B20 into Civic price.....What extra parts are needed? Price?
- can i do ?
- i am getting so much shit at work about an h22 in my civic
- obd0-1 conversion wont start
- Longblock?
- does any one have a p13 ecu for sale or know where i can get one????
- need help!!
- ok, someone has got to help me with my IAB!!!!!! please!!!!!
- B18a/b & B20 have interchangeable rods?
- Fuel Filter for h22 eg?
- What Drive shaft?
- b16a w/p28 ....need help.
- Need Help A.S.A.P
- itr swapping help. i tried searching
- needed parts for 95 B18c1 into 96 cx?
- need serious help... problem is driving me crazy...
- Knock Sensor broke.
- Type R Fuel Pressure
- Eg / GSR swap! What motor / engine mounts to mix and match?
- CRX hydro tranny mount?
- Fuel Line
- using a ob2 harness in a ob1 chasis?
- type r swaps
- exhaust gasket between manifold and pipe?
- HELP!!! b18c1 into 98 civic ex, wiring harness help
- Purge control solenoid valve help: B20 into '96 EK
- Lets play what is this part?
