PDA
View Full Version : Hybrid / Engine Swaps
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 [73] 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174
  1. ::::JDMCustoms.com:::::
  2. gsr swap parts
  3. obd2a and obd2b integra DC2 engine harness differences??? Need this answered ASAP
  4. Harnesses
  5. ls/vtec tunning question
  6. S1 Trans?
  7. 96-98 Hasport motor mount for a b-18c1 swap
  8. obd1 manifold on obd0 B16A
  9. injector resistor box ???
  10. injector problem h22 ek
  11. del sol radiator for b18c swap
  12. removed charcoal canister. is this ok now? [pix]
  13. del sol shift linkage
  14. Cel on after swap code 21 and 41
  15. back motor mount bracket?
  16. b18 question please help
  17. heater unit
  18. 99 coupe p/s pump
  19. Need to know swap info on b16
  20. Ls-v or gsr built?
  21. B20 on a B16A2
  22. LS/Vtec Oil Feed Head Plug...
  23. Need some help about oil pans
  24. h swap exhaust
  25. P30 VAFC II wiring...need help.
  26. b16a into crx with obd1 conversion PROBLEMS!!!
  27. D16z6 into a 91 Civic DX?
  28. what o2 sensor?
  29. 04 Civic swap?
  30. header clearance in h22 eg
  31. R power steering rack into an EG civic ( 17 mm rack spline into 15 mm column spline?
  32. Please, help me with ITR ECU
  33. h22 75 shot
  34. Replacing the D16Y7 in my Civic CX with a D16Z6 Wiring &
  35. I this is a weird question, but here it goes
  36. Got my motors from JDMSOURCE (www.jdmsource.ca)
  37. question!
  38. My frankenstein....muhahahahhahahhaha
  39. // Hybrid Gods: Please Help- WIRE HARNESS DILEMMA //
  40. jdm motors
  41. jdm motors
  42. which complete turbo kit is best for eg gsr hyrbrid?
  43. H22 not making power help?!?!
  44. Can a h22a fit in a 93 Teg???
  45. OBD1 Conversion harness, which dizzy?
  46. auto to manual mount
  47. Ac and Ps on Ek/gsr swap?
  48. prelude 5 lug on ej1?
  49. Is there away to relocate alternator?
  50. problems with b18a1 in '96 civic coupe
  51. V6 RWD Civic on eBay
  52. which power steering pump/bracket for a poor mans type r
  53. which sensors can be reused in obd0 to obd1 b16 manifold
  54. Heak soaking....
  55. Mini me question
  56. h22 vs b16 vs turbo d16y7
  57. cel " stomped"
  58. rear wheel, v6, 16g turbo civic four door
  59. B18c1 in 99 EK.....right mounts??
  60. what trans do I need?
  61. Anyone know where I can find the Place Racing tranny mount that allows a hydro trans into a DA?
  62. Engine year??
  63. B18a in 91 civic......need help!!!
  64. Question for all you 88-91 CRX to OBD-I guys
  65. ILL
  66. k20 swap
  67. K-series into a DA, have a couple questions.
  68. Help, tps wiring..
  69. D15b vs. B18b
  70. debate > jdm b18b vs jdm b20
  71. Oil Blow-By in B18C/B16A
  72. Code 14 Weird...
  73. buy complete swap???
  74. H22A engine build parts?
  75. mounts and brackets?
  76. d16y7 into 95 hatch - yes I said y7 :)
  77. h22a Vs gs-t
  78. K20a into a Jazz
  79. Where can I get a kit for my head swap?
  80. little backfire
  81. Broken front tranny mount/GSR trans.. Can you just not use it?
  82. 1994 gsr b18 c1
  83. turbo gsr
  84. crx swap question
  85. H22A into a 98 EX--Need help
  86. H22A swap into 98 ex
  87. What's a good compression for nitrous?
  88. GSR motor mount on b16a
  89. Half Shalf question??
  90. a question to all the veterens
  91. looking for a harness for a 98 GSR into a 93 Civic Si
  92. is type r linkage/axles needed???
  93. 1994 civic ex swap
  94. jdm h22a in ek questions///PLEASE HELP
  95. how to install half sized radiator in an integra?
  96. Is this an easy way to do a LS/VTEC setup? *warning: swap n00bie*
  97. anyone still producing the H series to B series tranny conversion plate????
  98. Motors
  99. h22a in Ek need help
  100. Need help with Swap this weekend
  101. si harness for b16a2 ek swap?
  102. Legend/Civic Combo
  103. built h22a
  104. Which Radiator into EG w/B18c (Searched)
  105. B18 swap question...
  106. B18c1 into 99 Civic Coupe ... exhaust?
  107. b18b1 into a dx
  108. B18c5 intoa EG hatch.
  109. Question: D16Z6 to a B16A2/A3 swap??? anyone with experience
  110. For any of you who have respect for the h22
  111. cant sleep B18c1 wont start
  112. please help, custom fab ideas for eg h22 shifter console
  113. 96-98 vs. 99-01 B18C1 into 96 Civic CX
  114. ls vtec stroker help???
  115. general ls/vtec question
  116. odb1 or odb2
  117. ls/vtec questions
  118. Reverse LS-VTEC / B16 NO-TEC Technical Discussion, B16 Block LS Head
  119. b18b crank vs b18c5 crank -ls vtec
  120. Engine swap for 1995 Honda Odyssey. Can anyone help Install?
  121. ek mount question
  122. Already searched: obd1 jdm h22a into a 97 gsr wiring.
  123. Getting code 22 after h22a swap in del sol?
  124. Map Sensor Help On a B18B Swap in to CRX Si
  125. CTR Pistons w/stock GSR rings
  126. H22 swap help [PICS]
  127. 95 gsr swap into a 91 ls?
  128. Advice on Choosing a Distributor Z6/Y8
  129. obd0 b16 head and b18 block build into an obd2 car
  130. help with idle in b18a swap in crx-hf
  131. b20 in ek hatch question
  132. b16 rods and pistons in ls....what compression and displacement?????
  133. Question Pertaining to a JDM H22a
  134. WTB: pnp harness for H series into 96 DX
  135. J35 engine + TL 6speed Manual Tranny.... is this possible?
  136. question about my hb w/ b16 swap
  137. OBDII B series into EG hatch
  138. 96 DX axle question
  139. mini-me problems
  140. H22 Short Shifter/Mounting Brace/and Console Question...
  141. B18B to B18C?
  142. Type R steering shaft/column at lower spline 17 or 15 mm Diameter?
  143. Running shifter cables for h22 in a eg
  144. Nothing fancy just a lil different
  145. B18 vs B16 center axle
  146. k20 into eg headers??
  147. -_Help needed with swap_-
  148. ringing noise coming from axles?????????
  149. NA B20 info needed / advice
  150. 91 Hatch B16A problems (tranny or clutch)
  151. K Series and JDM DC2 5 Lug in EK?
  152. b18c into 94 teg...
  153. h22 power steering woes...
  154. Pics of GSR manifold
  155. which jumper harness
  156. full throttle bogg
  157. b16 to an ls with arp
  158. TSX k24a2 into EK civic hatch...
  159. Some quick B20 questions about compression.....
  160. B18C1 in Ek , few questions.....
  161. Possible to get a B16B BARed?
  162. wheres a good place to buy a d16z6?
  163. Automatic to manual civic eg for K20 swap
  164. LS/Vtec oil tap questions
  165. BLOCK GUARD GOOD OR BAD?
  166. F23a into 94 cx?
  167. Shop that will get my Car Ref Ready In San Francisco
  168. JDM 96 spec b18c5 in 2000 Civic EX
  169. -__AC bracket__-
  170. Crowered H22 Head. Am I ready for boost?
  171. altenator question?? b16a
  172. B16a2 in a DA
  173. 91 integra with b16 need help PLEASE
  174. b18a swap trouble in hf
  175. B18c1 swapped into civic with jdm ecu. Anyone tried to us a scanner?
  176. h22 eg axles
  177. integra suspension on civic??
  178. Engine will not start after swap.
  179. JDM B18C swap problems...Please Help
  180. quick question about a hybrid setup
  181. B18C5 or B16B into 94 EX Coupe?
  182. Which Intake on JDM H22a?
  183. Building a y7/y8 HC mini me
  184. ELD - What does it do?
  185. K20a in a 96 hatch
  186. H22 swapped in 98 Integra - questions - searched already
  187. H22 for CD7 Pics
  188. 88-91 b16 into eg Q's
  189. Hybrid Intake Install
  190. B16 Swap Q's
  191. obd2 b16 in ef converted to obd1
  192. Impossible? newbie needs help please
  193. ef to eg brake lines
  194. OBD 1 ZC dual cam motor, what tranny will work???
  195. Will this trans work?need response fast....
  196. b20/Vtec in a 96 Integra, ECU options
  197. D15b into crx?
  198. d16z6 on a d15y8 block
  199. i got owned by that EGR system, 97 integra with 97 h22 swaps and 96 odb2 ecu. will pay if you can he
  200. labor price for swap
  201. I have a question about vin number locations
  202. H23vtec build plans.....
  203. h22 swap problem?
  204. Video- Removing a b18c backyard style
  205. CEL is on!!
  206. B20vtec PCV valve relocation for VTEC valve cover
  207. jdm b16aII swap into 2g teg?? complications??
  208. ARGH! B18b gas mileage sucks in EG!
  209. itr stock exhasut VS apexi WS
  210. Can I Use the old one?
  211. possibly ecu problem? Need help
  212. wiring gurus, need help! b18c into ef, b16a1 into eg (story inside)
  213. tell me what you think h22 or h23a dohc vtec
  214. processing
  215. h22 resistor box???
  216. More H22 help
  217. my redline CHANGES! limp mode to regular... does it randomly!
  218. str cam seal ?
  219. H22A or a K20 Type S
  220. anyone know anything about rod/stroke ratios?
  221. mini me help...
  222. Swap Help ASAP!!
  223. P73 ecu you help
  224. 01 itr brakes in 95 civic
  225. LS/Vtec project final check list.....
  226. Any h22a4er's out there? this is your question.
  227. Injector problem/distributor problem
  228. B20B into eg: 0BD2>OBD1 conversion harness?
  229. K20A2 Swap into 1994 EG, First Time its been done in Israel ! - First Pics !!
  230. H22 Integra (56K go bake a cake)
  231. what head swap for b16a3? or cams?
  232. H22 help needed
  233. K24 tranny question
  234. How do I identify year of ls tranny???????????
  235. quick question regarding a b7 head w/b8 block
  236. Type R Throttle Body in a 88-91 Civic/Crx??? Will it work???
  237. z6 in 88 std need help!!!!
  238. 2000 accord engine in 97 accord?
  239. LS swap into 92 EG, which shifter bushings?
  240. b18a in 86 CRX wiring
  241. H22 swp into 1st-gen Acura CL
  242. cutting linkage CRX/B16
  243. b18a1 parts onto b16
  244. LS SWAP IN 00 CIVIC COUPE WHAT ECU FOR OBD2 CAN I USE???
  245. Block Gridle To LS Block Cost?
  246. b16a1 into eg civic....loook please
  247. 94 B18c1 into 2000 Civic EX...HELP WITH WIRING PLEASE!!!!!
  248. h22's in crx's
  249. A little help here...h22 ek swap.
  250. question about a integras
