View Full Version : Hybrid / Engine Swaps
- CROWER STAGE 1
- Which JDM 1st gen B16A's had knock sensors?
- helping friend put a b20, in an 89 crx with an integra wiring harness
- (SEARCHED)*****B16a2 Vs. Poorman's Type R Boosted?????????*****
- GSR Cluster
- OBD1 EG4 with OBD2 motor
- h2b trans
- DISTRIBUTER QUESTION
- I finally got me a Type Arrrr...
- Heater problem NEED HELP plz?
- please help!!!!!!!!! odessy battery messed up my h22 civic
- GSR into 88 CRX SI: Need help on a couple last things
- EG9 RHD rear harness wiring?
- Best place to buy a USDM B16A3 in S. California?
- K20 in eg or H22 questions ( yes i searched )
- Motor Mount Insert Install
- Integra 1" master cylinder in 96 ek hatch which brake lines?
- Can you use a OBD2B distributor with OBD2A wiring??????
- H22 swap
- look what i found on ebay- kit car w h22
- z6 into em1
- Here is what I have done and I cant figure out why my hybrid is running so rich
- vss and 02 heater cels please help
- Sputter, baffle ... B20c problem
- vtec not getting power
- H to D Adapter Plate
- Intake manifold SKUNK2 HELP
- B16A automatic swap into 92 hatch... having problems with shift cable
- H2B EK, power steering?? Also wiring Q
- having a few driveabilty problems with h22 94 cx.
- what motor!?
- H23/h22 Head Swap Question HELP!
- b20/b18a ?'s -please help answer few ?'s
- Fuel pressure/vacuum pressure/fuel rail Questions
- B18b ECU's
- Best online places to shop! Valve cover gasket kit? Also! Best way to repaint my valve cover?
- Swap Exhaust
- Quick n easy distributor question
- OBD-1 B16a into 93 Cx --- Extra plug need help
- k20 with ac?
- A little help here guys.
- Ebay Axles?
- h2b kit in eg ??????
- Wiring harness question
- F22 VTEC??????
- I need small B18C1 parts, please help me find them, not engine related but engine BAY related
- eg swap question
- Has anybody had problems with Golden Eagle head gaskets before
- wiring harness
- K20 swap wiring question need help
- h22 vss
- Instantly keeps blowing ecu fuse under the hood?!?
- IAVC Help/ Suggestions
- JDM CTR brakes on a DC-2
- h22 Engine cuts out at high revs!
- What all does it take?
- AWD CIVIC H2D
- anybody wanna trade a stock 99 b20z2 for an H22?
- 2 questions about B18C1 into a 95 civic dx
- h22a into a 96 hatch need help wiring it up
- What is this plug for?
- tranny leaking fluid from shaft??? where??? what seal??
- ECT question, searched, not what I need.
- i need to know the truth about engine swaps anyone from Massachusetts
- URGENT- Detailed pictures of back of B18C1 please
- F20C in a EK
- what ecu do i need for a 99si in my 97civic
- ------~~~~Help! What DOHC VTEC head fits on the F20A Block!!??~~~~-----
- Which wiring Harness, JDM ITR Swap into Del Sol
- exhaust for 93 hatch
- Code 4 help B18a1 crx dx
- ITR in Del Sol, Hondata/Connectivity Issue's, Please Help
- What causes the main relay to kick in?
- i blew my h22 should i buy this?
- Cincinnati tuning shops are a joke.....................
- need help? converting obd0-obd1
- h22 eg irritating PROBLEM!!!
- JDM YS1 LSD transmission clutch disc
- B18A1 Torque Specs
- IACV problem...PLEASE HELP ME
- is it worth upgrading h22 tranny?
- 2000 ex wiring harness on 96 jdm b18c IAB wiring!!
- Please help!!! 97 JDM H22(P5M ECU) INTO 97 Accord LX.......ECU wiring ..got hasport conv harn.
- b18a1
- P28 for H22 tune question, not big problem, but annoying!
- obd0 to obd1 with a d16z6 into a ef
- help
- Help what axel do i need to get
- lsvtec wireing
- Automatic or MT ECU??
- Engine cuts out at high revs!
- H22 - HCP Mounts - EK Chasis Axle Dilema, help.
- ??'s for 1976 civic ..SWAP B OR D info?
- How do B20Vtec engines compare
- smog for 90 crx with b16a swap
- can anyone please help me ? =_=
- h22a yr ???
- GSR swap wiring question!!
- For the people with B20 swaps in Cali, what do you guys do for smog?
- S2000 motor swap in accord?
- obd2a to obd1 conversion question
- Has anyone tried swapping a D-series motor into an 83-older Civic?
- Slave Cylinder
- Which resistor box should I be using?
- few quick questions
- crvtec: where should vtec crossover?
- OBD1 Engine Conversion
- OBD0 to OBD1 (1990 B18A1 into 1992 EG)
- throttle cable ?
- GSR Brakes into 93 VX - P-Valve and MC help
- Anyone have a h22 in a DA write up??
- d16z6 in 90 ef w/obd0 need help
- EF, b16, cable ls tranny, what axles? Tried searching
- Integra rad + D series motor..what hoses?
- NEED HELP!!
- i have done about three swaps. Never a non vtec. Quick question.
- Tapping Noise?
- b16 SirII swap in my 91 teg Need Help
- Anyone with a GSR swap - which AEM intake?
- k series into eg axle/brake combo
- distributor and alternator wiring
- Place Racing mounts.
- Need some advice/opinions. K-series swap EK hatch.
- New part
- h22 teg won't rev past 6500
- Full Pictures of a B18C1 not in a car? Or at least detailed pictures please?
- B17 questions...
- Help ASAP- Identify Hasport H22 mounts
- a few k-series ?'s
- F20B / F23A1 Hybrid motor?
- Throwing a code.. PLEASE HELP!!
- gauge clusters for an EJ (EG coupe)
- Got swap and not finished.. HELP
- Quick question before I buy an H22 swap:
- h22 eg swap
- What to look for in an engine swap?
- motor swap how long will it take
- Accord H series AT swap wiring?
- b20b
- "No-Tek" hybrid engine build, first in the world??
- What needs to be changed? OBD2B Question
- h22 wont rev past 6500
- which throttle cable for lsvtec in an ek dx civic?
- resources for rewiring 87 CRX to 96+ D15B?
- eg h22 wont startup
- 1999 Civic Ex Auto With 1996 B18b with auto tranny swap... yes its in the car now...
- h22 swap question on vacum
- Topendmotorsports?
- Just Got Engine: BLACK OILY CRAP in TB!!
- H22 swap question
- What half shaft to use?
- VTEC GROUND QUESTION
- how to make a 92 da in to a comp. obd1 ??
- My car is running rich, could the reason be a CEL that I have?
- Has anyone used Bisimoto's H22 to D series tranny adapter??
- HONE H22 AT SCHOOL FOR MAHLE PISTONS!!!!!!!!!
- Can't get Brake Hubs off, trying to remove axles, HELP please
- Using 2001 CRV engine and harness in a 98 civic with 99 si Aem computer.
- GSR swap... will it run?
- WHAT SHIFTER LINKAGE AND SHIFTER BOX FOR MY H22 SWAP??
- integra and b16 axles
- H/F Series Eg Avid Racing Rod Linkage
- gsr w/ctr crank?
- throttlebody questions
- So I'm looking for an ecu for my swap....
- Ls/Vtec swap How To?
- eg motor in ek
- EX ECU ON LS MOTOR...WILL IT AFFECT THE PEFORMANCE?
- 89 prelude motor b20a5 will P75 b20b head fit?
- H22 del sol hell
- 96 obd2 GSR into my 94 obd1 dx hatch
- EK b18b swap power steering question
- Build a motor or purchase a pre-used for a swap? (B-Series)
- what do I need to do to run a 99 SI b16a2 using my 98DX engine harness?
- how does this ls/vtec setup sound to u
- Would you want Honda to have crate motors?
- 93 Prelude w/ EURO-R H22 SWAP. BYE BYE H23...advise needed
- B18A to EG swap...where's the info???
- B16B vs B16A?!?!?!
- H22 DSS stage 1 axles leaking trans fluid into inner CV joint? WTF?
- 99 gsr suspension on 91 civic
- B16B and the Top fuel Turbo K3T
- Need steps on a B18B1 swap into a EG(94) civic
- High Rev Problem
- p30 on ls/vtec
- Header
- vacume lines
- Brake caliper bolt won't come out - What to do
- have 98 auto, can i put use 99 ex 5 speed harness?
- h22a question on injectors and throttle body???
- b20b
- JDM B18C5 or USDM B18C5
- ok h2b h22 in civic question
- jdm b18c5 wiring harness in a 99 si?
- OBD1 EG5 ZC swap into EK, how should it be wired(search terms too short)
- Can't even take it anymore!!!
- acura tl 97 2.5 motor swap?
- F23 single cam vtec into EG?
- What is this part called and what is the part #? B18c1 GSR motor
- ek h22 swap info
- Should my H22A tranny be hitting the frame?
- USDM ITR Tranny W/ JDM FD Kit
- k24 into CRX swap question
- B18C5 into my 99 CIVIC SI - what do i need besides the motor?
- which tranny should i get for turbo gearing
- help on a ls swap
- WEIRD SWAP PROBLEM...
- b18b intake manifiolds
- can the p07(chippable version) be programmed as a p13?
- LSVTEC
- obd1 b18c into obd2 car using obd2 car harness and ecu jumper harness
- h22 power steering question.
- h2b kit anyone have one on an eg????
- H22 swap in Integra need helps
- h22 in eg with nitrous, anybody running a set up?
- misfire at 3000-5000 rpm
- Can't get TPS minimum voltage
- Automatic staying automatic Civic motor swap
- h22 swap troubles (searched)
- which shift boot to get?
- more power out my b16a3
- Axles/Shift linkage question for b16a gen1 swap into 88 crx si
- Ask your B16A's Questions here
- DIY : B-series Engine Removal/Install Detailed Pictures Updated
- B16a2 IM weight?
- H22A & H23A Same Mounts and Tranny ??
- speed sensor
- how much would it cost?
- 5 lug on h22 civic with hasport axles?
- H23 VTEC... SPECS...
- Which transmission?
- quick question on pcv and intake manifold
- b20vtec ecu question?
- h22 and what!
- B18b into a EJ??
- timing belt on b20vtec?
- gsr block b16 head????
- Wiring question regarding B18C1 in 93 Si hatch
- shift linkage?
- 05 K20a2 motor swap in EK... feels laggy help!
- H2B : Are stock H22 Transmissions really that bad ??
- CRX track car ready to roll!
- h22 into vx hatch?
- need help car wont turn off 8(
- b18b1 question
- CRV AC bracket not working with swap
- P72 with low redline
- h22a into 93 vx question.
- Clutch Cable to Hydro H22A Conversion Kit
