View Full Version : Hybrid / Engine Swaps
- b16a2 in 4th gen hatch trouble
- why does my h22a hatch hesitate from 1500 to 2500 rpms
- HELP... 96-98 Civic w/ 99-00 Si Engine harness ** NIGHTMARE**
- Need confirmation. 90-91 TEG ECU same as 92-93???
- obd1, obd2... obdconfused
- F22B Injectors size
- cracked b20 sleeve pics..
- Prelude Si 4WS!!!
- OBD0 -- OBD1 conversion web site...who has it????
- VTEC help!!! Works when the car first starts, then nothing!!!
- injector size, crx and b18c1?
- shotpeened vs. Glass Bead
- How To Videos on swaps
- H22 Shifter & Shift Cables... will these fit?
- Can anyone tell me what size TB a B17 used?
- No block stamp?
- Forgive the repost - Does H22A drop into 92 accord like B18C into 92 civic?
- 97ex > JDM B18C swap Lessons learned?
- Wiring Vtec in 92 civic w/ b17a motor *pressure switch *Intermediate shaft
- HASport Hydo to Cable convertion kit...
- Throttle cable question for h22 civic?
- gsr reliabilitiy
- HELP!! Axel wont come out!
- p13 wont rev past 6500 rpms.. check engine codes 14,21,41..help.
- Has anyone in Cali tried to smog an engine with higher then stock compression?
- exhaust ?
- just spent about 8 bills, did i do good with it??
- putting a h22 in a 94 integra, got questions
- Swapped a 99 ex Y8 into a 97 HX y5, need help converting to 4 wire O2 sensor
- GSR and CX throttle cable didn't work with my swap....
- fuel pump
- question
- 96 dx b series swap. ex wiring harness yes or no?
- H22 Radiator questions.....Which one is better option?
- K20A2 Powered EM Civic
- 93 Civic EX to 92 Civic VX 99% Done!! finally 56k people, nope.
- good price for b16a2?
- Tach problem for a B18C1 into EG Hatch..
- Who has a b16a2 in a EF?
- H22A into EG mount question with HASport Kit
- need a shop in jersey to swap!
- ek hatch into the 12's
- B18 piston upgrades
- clutch for a JDM D15b with 90-19 Si tranny
- Wiring difference for H22a into Usdm Prelude si
- 92 civic dx motor swap
- Distributor question
- wiring a distributor on swap
- Ls/vtec Header
- check it outttttt
- H22 swap into EG...few questions...
- where to get helms manual!!??
- wiring harness difference
- b16 y1 tranny 3rd gear problem
- swap is done!! finally
- Still no luck in tracking down suspected vacuum leak. Anyone have any suggestions???
- ls help
- tps sensors
- pics of my finished h22ek swap!!!
- 2nd day and a TICKET in my gsr'd hatch!
- B20-91 civic DX hatch
- H22a Swap Shifter Cable Q's
- thinking of fitting B18 block to my B16A1 head, can i use my original gearbox?
- dx to b16
- 97 and up tranny into an integra/civic
- B16 ecu in d16
- 90-93 accord intermediate shaft
- B18B Swap into EG , info much appreciated
- Anyone in SOCAL know GSR/EF wiring...i will pay for good work!
- H22a civic swap
- help dear god/ B20 problem
- Did I get screwed?
- Damn ECU!!
- turbo swap
- b16a2 into ek swap guide?
- Need to know asap!
- quik question?
- Ah, the memories...... (BAR steeker)
- HELP!!! Crank pulley bolt impossible to remove!!
- MY HYBRID people, please help me on quick timing belt question, URGENT
- 99gsr in 94dx
- b16
- b16a1 swap
- What radiator are you using?
- Those of you with 92-95 Civic VX Hybrids, please help!
- D16Z6 problems
- B16a2 Swap in 4th gen Hatch wiring
- H22a- F22a Crank Pulley
- Has anyone here gotten a B20 CARB approved? Not CRVtec
- B18A1 to LSVTEC compression ratio.
- Need Help.. injectors.
- I am new to this forum, I need help desperately LSVTEC 1st generation
- To all my h22 hybrids in the NY area.. Check in!!
- Safe to temp run a P06 (DX ecu) with a d16z6?
- Need wiring help for 90 Civic to Mini Me with P28 ECU?????
- 92-95 cx/vx/dx/lx/ex/si fuel injectors... any one have more flow than the other?
- How do I correctly hook up the MAP sensor in an H22 Civic hatch swap?
- axle set rings
- OBD2 LS motor into EF with OBD0 electronics
- Resistor pack quick question
- D16Z6 Swap--Wiring
- quick question about b17 rear tranny bracket..
- H22 clutch question
- Tach Problem
- i want to use my obd1 d16z6 wiring harness on my 98 b18c-R
- b16a2 in ek hb? questions?
- My h22 swap plans.
- bigger throttle body?
- ::B20Z ecu::
- H22A "master swap info" guide- someone made one long ago, and I lost it. Anyone have it?
- B18C-R axle problem
- TODA header!!
- Nor Cal Group Dyno Day May 10th, cheap!
- Just a few problems: JDM GSR into EH Hatch!
- Gauge Clusters
- converting my 98ex to a manuel rack..need help.
- p28 ECU for what car?
- k20 into EG?
- h22 running problem!? this is driving me crazy!
- Need help with B18C6 wiring...i'm an idiot
- will this work?
- Ported and Polished
- motorswap= redlining at 7500 help!!!
- I need some help with swap info
- Vtec oil pump = Vtec water pump?
- ECU Question
- b20vtec in 88 crx just a quick question for anyone with similar combo
- B18c1 sitin in the garage....wire help needed.
- f22b1 into ek- what shift linkage?
- f22b1 into ek- what axles?
- f22b1 into ek?
- B18B engine mounts?
- Will it cost this much????
- D16y7 to D16y8 swap .. please help
- noise form driver side engine bay
- B18C1 into 92CX Help
- new pistons.... 8.8:1 comp
- Why is my car idling @ 1100 RPMs????? PLease help
- Which Rc Injectors do i need for my Crvtec??
- H22 Wont Start!!!
- b18c1 power steering in eg?
- weird, starts then shuts off
- Wiring Gurus: JDM B18C into a 93 si...questions about the IAB
- New to hondas........which engine for 92+ hatch????
- Thinking about a Type R Hybrid.......
- hydro/cable tranny size
- For my cx 5th gen....LS Turbo or Build my H23 for boost....
- H22 guys... what clutch you guy running?
- Complete D16Z6 swap
- Spreadsheet for motor swaps with 1/4 miles times?
- a quik question
- SI in a 92 civic
- horsepower TV gsr swap on this weekend
- gsr harness
- GSR Gauge Cluster
- Ordering a Motor Online..
- h22 swap info ??
- (second try) started GSR swap in a 92 hatch and it idles at 1300-1500 rpm
- what do i need
- Radiator hoses for b18c1 in EK?
- lsVtec
- Engine question
- Choice... B16a1 or 90-93 b18a into EG hatch (94 cx)
- Quick ECU question... 98 Civic DX / 98 B18B
- skunk 2 or JG and GSR's
- sir cluster
- please help, tranny making whining noise
- ls/vtec in 89 civic?
- 92+ injectors on a obd0 ecu?
- What harness?
- AN-R or hotshot header for h22a civic????
- what clutch?
- Help i need axels!!!!!!!!!!!!!!!!
- Radiator Hose (JDM GSR into EH Hatch)
- stock b16a rods??
- B16A2 or not
- current tranny setups w/ b18b?
- Ls shift linkage??
- just finished my swap and need help
- any tips on picking out my engine?
- What would you do? (need hybrid guys opinions) Car buildup.
- whats the diffrence between obd0 and obd1 injectors???
- JDM b16a in 90 teg with PR3 ecu...VTEC wires???
- b16a1 in crx si , battery light is on?
- h22 suspension
- GSR swap in EG. I want Air con.
- Z6 tranny on a Y7 flywheel+PP+Clutch
- Exhaust for h22a civic
- www.jaydm.com
- H22A issues... It won't go no where!!
- wiring issue after gsr swap. Help!!
- Problems with JDM B18C GSR swap in EK
- rev limiter after auto to manual swap?
- H22a Compression test
- CTR swap into 97 Civic DX....ECU problems....Help
- h22 axles - custom
- What map sensor to use
- this is not a honda, but......
- jdm y1 tranny question
- newbie question obd1 or obd2?
- Help deciding which motor in my eg hatchie
- ATR Crank Pullley for h22 hybrids
- Odd problem. Perhaps you can help?
- Oil light on. B16. HELP!
- JDM Automatic GSR
- HCP EF mount kit a prob?
- need some power steerng help...
- b16a or b18b turbo
- dopping an h22
- Eg Hybrids! Did you upgrade your radiator cap or use the stock civic cap?
- ... what ecu to run with h22a civic?
- Totem traction bar for h22 swaps
- H22A/VX...would you road race ??
- HCP Engineering - Motor Mounts
- Hybrid oil weight
- P28 Dinan ECU Chip?
- NSX 3.0 into a 2000 EK Si
- JDM B16 ECU???
- Honda Accord EX - Engine No. Horror (Help!?!?!)
- quick question about putting an obd1 gsr in a 96 hatch??
- what spring rate should i use?
- obd1 wiring diagram/table?
- H22A into a DC2
- What harness should I use???????
- Cusco, Quiafe, or Kaaz LSD?????
- Where to buy the Dowel Pins for LS/VTEC ??? Thanks
- ? N/A fully built H22A into 5th Gen. Civic, a few questions...
- driver side mount keeps ripping!!!!
- best swap for a 97 a civic dx...
- b16a2 in a 92 civic dx?
- register/legalize b20z?
- Anyone looking for a side job for extra cash? (NoFL, CFL, SoGA)
- h22/civic 1/4 mile time sheet
- difference between auto and maual axles
- will a coupe exhaust fit a hatch
- I HATE CARS!!!!!!!!!!!
- I need info on swapping a b18a1 into a 00' cx
- can HASport H22/EG mounts work in a BB6 Prelude
- H22 Header
- JDM GSR in 00SI?
- swap for my hatch
- Question about B16B
- b20 in crx???
- D-series hybrid
- thinking of JDMFaze.com?
- 2000 civic power stearing
- IM BACK!! : ) b20 questions in ef crx
- try this place
- are there any body kits for and 85 civic hb?
- distributor
