PDA
View Full Version : Hybrid / Engine Swaps
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 [131] 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174
  1. new mounts?
  2. I searched, I still need more info on B18A wiring into a 91 DX hatch.
  3. EG into '92 VX, need a small clarification
  4. h22 breaking axles
  5. header question for b18b
  6. Is this a gsr or ls throttle body?
  7. Downsides of an H22.
  8. Who has converted from ODB0 to ODB1?
  9. H22 in a Ef chassis. Saw an HCP kit but is this doable? Without a machine shop.
  10. engine code 13 how do i fix it ?
  11. Need help and fast (B18C swap on a 91 STD hatch)
  12. 2000 h22 into civic eg hatch
  13. auto and stick tranny mount. are they the same?
  14. vtec in 1st but not 2nd or 3rd
  15. A engine swap kit for my CRX
  16. H23 in 5th gen ciVic HB?
  17. Best engines for Na or FI
  18. H22a Question
  19. cr-vtec?????
  20. Shift Linkage, need help or ideas!!!!!!
  21. got my b18b for the hatch
  22. k20 in a 97ek
  23. Has anybody had problems with Midnight Performance in sac?
  24. pics of h22 linkage in a teg?
  25. what kinda car for 5k
  26. New EK Driver Side Mount... coming soon
  27. light goes on and off after swap...
  28. SMS magnaflow muffler size?
  29. header heat shield: necessary?
  30. Throttle cable difference between b18b and d16y8
  31. 97 hx into 93 cx...don't ask_ecu ????
  32. B18b swap
  33. auto to manual?
  34. question about the upper driver side motor mount....
  35. 2000 H22 Swap Possible???
  36. obd1 ls to obd2 gsr swap
  37. k20s?
  38. noobie Q.. maybe. about pouring oil
  39. JDM h22a Thermostat
  40. need help with h22a please!!!!!
  41. EX Engine Harness
  42. best place to buy a swap on the net?
  43. Anybody have troubles with Asylum Motorsports.com
  44. OBD0-to OBD1 ecu conversions
  45. no power steering on 2k civic ex with b18c.. will it affect reliability in the long run?
  46. integra 97 coil spring--->civic ex 2k
  47. WHat JDM LSD units will fit a USDM GSR trans???
  48. can you reuse piston rings? and if so...
  49. engine rebuild
  50. Shop to swap in s cali?
  51. What do you guys make of this???
  52. B18C5 A/C bracket fitment for EK swap
  53. swap question
  54. Quest. For all Ceramic Puck Clutch Owners????
  55. B16a Intake air temp sensor
  56. b18b swap or d16y8 turbo...help with my options please...
  57. Alternator Belt
  58. 0bd0-Obd1 conversion with SOHC Vtec distributor..fitment problem?
  59. TODA vs MUGEN headers???
  60. can someone help me out so i dont get ripped off
  61. :::Gauge cluster question:::
  62. Beater pictures during and post swap
  63. my car is trowing a code I need help!!!
  64. Help. Need to rebuild block. Reliable shops in socal??
  65. Tranny Swap?
  66. i got my motor today!
  67. Hyper Ground System
  68. H22 mount kit for EG
  69. Header fitment: LS/GSR/ITR
  70. OBDII motor w/a p13 conversion harness?
  71. motor swap???...HELP
  72. my friend wanting to do an GSR swap
  73. oil leak
  74. Finally purchased a GSR motor for the hatch! Pics when it arrives!
  75. Finally put a stock gsr exhaust on my hatch...
  76. obd1 GSR wiring harness on lsvtec...
  77. JDM b16 SIR II vs USDM B16a2 differences??
  78. JDM H22A EG swap hp/tq (thread moved to here)
  79. Has anyone been to Hmotorsonline lately.???
  80. dash in civic
  81. B18C1 + 99 Civic EX + $1400 AEM EMS = headache?
  82. Where do i buy this bracket for my hybrid!
  83. 96 GS-R swap into 92 Civic CX (hesitation when accelerating)
  84. question about integra block wiring.
  85. Will ODD2 Distributor fit on JDM b16a head with 94 civic dx wire harness
  86. AIC wiring 96dx to 99b16a2 help!!!!!!please!!!!!
  87. which fuel pump is which?
  88. h22a swap ecu
  89. LS/VTEC vs. B18C for 90 Integra
  90. More questions about EG/EH swap.
  91. Oil Light Is Blinking NEED HELP!!
  92. Where did you get your motor shipped?
  93. LSD Transmission identification.
  94. B16B longblock......how much is it worth?
  95. crx zc motor swap
  96. Daily Driven Crvtec.....Hondata or Chipped p28 with v-tec controller
  97. Check it out!!!! My swap is all done!!!!
  98. Which header for H22/civic swap?
  99. when do use????gas ..n00b
  100. where do u ger race gas at? n00b
  101. b18a in a 90 si wiring?
  102. Really stupid wiring questions, somone help me out please
  103. crvtec rev limit before bottom end build up
  104. miles on ls/vtec?
  105. AC Autotechnic Al. Oil Filter Block?
  106. H22a Clutch Problem
  107. h22 in civic INTERIOR.......(center console)
  108. www.jaydm.com ?
  109. Just a question out curiosity, how hard..
  110. ok tell me how you guys with b16's in your crx like it
  111. B18C5 wiring into a '96 EK
  112. Super 2NR TV "Club Battle"
  113. weird idle with type r intake mani
  114. Ok got my teg harness , now what
  115. H22 Valve adjustment: What'd the DEALER say when he popped YOUR hood??
  116. help with integra engine wiring harness
  117. Finally got my swap done.....I have on more question (ECU)...
  118. lsvtec pistons??
  119. What's the going price for a B18c these days?
  120. Apex-i Power FC: Who uses one?
  121. OT: 4G63 (Eclipse Turbo) into a 1999+ Mirage?
  122. Radiator hose
  123. 00 B18b and using the 96-98 wire harness, few questions?
  124. ECU options for EH swap.
  125. Ls/Vtec question??!!
  126. Motor mount for CRVTEC in a 92-95 hatch
  127. ITR calipers on a 95ex?
  128. best kill with ur hybrid!?
  129. D16z6 into Canadian 92CX, Wiring question...please help
  130. type r cam question
  131. hose question?
  132. Need someone to chip my p28!! kenji? anyone?
  133. another lsvtec question?
  134. obd0 distributer to obd1
  135. H23aVTEC build
  136. B series Swap question...
  137. My Osaka experience (search words-they suck)
  138. are type R cams worth putting in a jdm b16 motor w/turbo later?????
  139. 93 sohc vtec into 90 dx civic hb
  140. Busted Knock Sensor?
  141. Helms manuals
  142. obd2 to obd2.5 ?
  143. has anyone swapped a whole hydro clutch setup into a CRX???
  144. Shift Linkage Question
  145. Tranny....DEAD!!!
  146. A b18c1 In EJ2
  147. mounts: b18b into EK
  148. b20 in 92 hatch
  149. Which intermediate shaft?
  150. Shop in NH for b20 swap?
  151. Need help on buying cams help me out!
  152. Wiring diagram for h22 into 94 integra
  153. ecu question
  154. Ebay Skunk2 ECU Chip ???
  155. axle nut and clutch cylinders question
  156. where's evap purge on 2nd gen JDM B16A...
  157. dropzone coilovers!?
  158. ??Questions about doing an engine swap...??
  159. I did my FIRST swap!
  160. 91 CRX Si to ZC // pre-purchase questions
  161. what makes a motor a certain year?
  162. H22a ahhhh
  163. hondata vs Vafc agian.......
  164. question....need ur help again?
  165. p/s AND a/c can be retained in 6th gen. H22 swap??? Possible?
  166. h22a into integra test pipe??
  167. OBD II96+ Vs. 02?
  168. b16 into EK hatch specific questions
  169. Anyone got an EMT of a 00 OBD2 B18B?
  170. Necessity of matching b18c head to 84.5mm bored block
  171. ok civic lsi ´92 1500cc what engine fit?
  172. obd1 or 2??
  173. difference in suspension between 89 crx and 92 teg
  174. what motor mounts?
  175. Any1 pushing 5-7lbs. on SOHC?????
  176. looking for a 1.6L crx si motor
  177. a lil swap questions?
  178. EG B16A swap obd1 to obd2
  179. Should i wait for 12s or settle for 13s now??
  180. Which Helms to get??
  181. Which Mounts for EK type r Swap????
  182. Hmotorsonline
  183. d15b7 on a d16z6 block?? PLEASE HELP?!?!?
  184. What motor is best for Turbo?
  185. Anyone else have Issues with HCP???
  186. Compression good or not?
  187. Any B16B owners out there?? A few Q's...
  188. b16a
  189. B20 block in Si(R) engine
  190. Fuel pump will not prime!
  191. Radiator Ideas (H22--> Eg)
  192. b18c in a ek!!??
  193. how do you use a stock civic radiator outlet to a GSR radiator hoses ?
  194. Vibration coming from.
  195. Osaka or HMO
  196. Building LS/VTEC.......Should I buy...........
  197. Got the h22 in the EK....lshatchturbo's Review
  198. Need advice!
  199. couple of question about an LS swap
  200. Which Harness???
  201. Random Check Engine Light JDM B16A SIRII in EG Hatch
  202. B18B vs B16a2 w/ FI
  203. I didnt know where to post this but help me out.
  204. 1st Gen Integra with B-Series Swap
  205. ITR Wiring harness into a CRX
  206. cable tranny question???
  207. Engine sitting in junkyard for 5 years....
  208. Would anyone be interested in a Spark Racing motor mount groupbuy?
  209. LS/VTEC Piston question?! Need advice from experts!
  210. JDM P73 Type R Ecu?? Will it do a b20/Vtec and good??
  211. EK vtec and misc. wiring for swap
  212. B20 Vtec Price Expectations
  213. 96 OBDII B18C1 into a 92 OBDI civic hatch
  214. 93 ex coupe
  215. p28 vtec wiring
  216. swap Q. what do i need to put a jdm type-r motor in a 1990 rs integ??????????
  217. ls vtec questions
  218. need help....please read!
  219. what is needed in an h22 swap into a 92 dx??
  220. OBD0 to OBD1 conv. for 88CRX for B18c turbo?? answers needed!
  221. walbro's in, hasports are in, where are my axles???
  222. question about engine swap and weight
  223. GSR rods $
  224. How much is a 94' b18b with 97k miles worth??
  225. swapping for a jdm B18C5
  226. ctr piston?
  227. JDM VTEC Solenoid - no pressuere switch - What to do???
  228. Swap is finally done!!!
  229. Engine harness question
  230. H22 in 2000 Accord, used search cant find nothing on it.
  231. Comments on GTP International Inc.
  232. jdm b18c in 96 coupe - some questions *used search*
  233. ZC axles and Clutch
  234. 02 sensor problem on B16a
  235. Will ANY b-series driver's side mount work with a B20 going into an EK?
  236. h22 ek fuel pump question
  237. jdm 2nd gen b16s, do they come OBDII 96+
  238. h23 swap
  239. str intake manifold for H22
  240. Where to get JDM synchros for B16a tranny?????????
  241. Need Some Info ON a H22a Swap
  242. Vtec problem
  243. B16A Swap ????????????
  244. Spoon motor mounts
  245. JG head
  246. after swap car wont start when rain
  247. getting my b16a!~!~can't wait but confuse about this one part...
  248. thread to propose a rear mounted motor. input welcomed.
  249. another swap question: intermediate shaft
  250. gsr oil squriters into ls block
