View Full Version : Hybrid / Engine Swaps
- CRVTEC injector size ?
- need SERIOUS HELP!!!! with swap
- fuel pump ???
- Question!
- guages for the swap?????
- took the H22 eg to the track today.......
- B20/VTEC builders... Will this be the way to go??
- Which AEM CAI for a b18b in a 92-95 hatch?
- '90 CRX 1.6i 16v DOHC (D16Z5): Swap to B16A2?
- Will '96 GSR clutch fit '91 b18a motor?
- Car is disabled for now. H22 story.
- b18b turbocharged anyone?
- Clutch suggestion?
- JDM H22A/H22A-S differences?
- code 2
- H22 swap questions
- Adjustable Shift linkage
- Shimming the hybrid tranny
- Rear brake swap on EK
- VTEC pressure switch
- swap question
- Damn harmonic balancer....
- b18a blocks
- Some pics of my project hatch
- H22 INTO 93 ACCORD (Info Please)
- need help crv vtec swap but i am lost
- Do I have the option to use my stock vs GSR mounts
- Which bolt-ons for 92-95 hatch with Crvtec
- ls throttle body??
- Need all your info on EG H22a swap!!
- ALL MOTOR - built ls vtec or built H22?
- sohc vtec (d16z6) in a 91 crx si.. Which distributor do i use?
- CEL 14? Things to check? IAC?
- Need Help: need pic's of OBD2 to OBD1 engine bays...
- which studs for b18b1 in EK?
- B18a into a 00 civic, whats need HELP.............
- Broke the green vtec oil pressure sensor on my H22a....
- EGBCC Cable Conversion Kit has anybody used this ????????
- p28 ecu codes with LSVTEC setup
- throttle rotor removal...
- Will this fit??/
- What size throttle body???
- HMO = Good Shit (56K Killer)
- obd2 teg motor in crx-what harness to use??
- crx swap help-obd1/obd2
- how do you install 99-00 SI block bracket on 96-00 civic?
- distributor?
- H23 in 4th gen accord
- 1st gen b16a to obd1 setup
- piston/rod combo?
- Got to wire in vtec -- What gauge wires should I use?
- Changing pistons out... How hard is it?
- Need a whole new wiring harness for a b16. where do i get one?
- Buying a blown H22
- 88 Civic hybrid
- I need a pinout pic of 0bd2 ecu...
- Trans Question
- 12 second B18c1 hatches.....whats your secret?
- b18c1 in 97 ls?
- Harness Question??
- compressin test went not so bad.. need insight.
- S2000 F20 in a Civic - eva been done?
- Orange County smog hookup
- osaka might have screwed me... need some help.
- B16A From Password JDM Just Got Here - 56k link at bottom
- disadvantage of using p75 LS ECU for ls/vtec??
- HELP! on my B18c1 swap Wiring Issues!!!!!
- B16A2 engine, where do you come from?
- Is it possible to fit stock radiator fans onto a PWR radiator?
- How much Whp will a B18c1 create in an eg hatch? is it really worth it
- ek h22 shifter and engine code ???
- has anyone used place racing h22a weld in mounts
- ZC Motor Smells Bad!
- Hybrid Automotive H22 Coupe hit 13's last night
- obd2 LS into 1989 CRX Si wiring questions!
- Post your dyno results --LSVtec N/A only--
- 5 gen auto swap help
- will ls linkage and.....
- I hate WIRES!!!
- CEL light doesnt blink, jumper wire in..?? and another Q
- LSVtec VS CRVtec horse power?
- 1st gen b16a to type r intake manifold upgrade: questions...
- Swaping an integra B18c1 motor in a civic Eg hatchback
- Mitsubish injector??? I can use them on my swap??
- JDM B16A3 Wiring Harness
- The infamous oil leak by the engine code...
- (ls vtec hatch)
- Help me plug in these vaccuum hoses!!(PICS INCLUDED) Bseries swap in EG
- supratruck theory... can 4wd stil be used???
- OBD2b to OBD1 problem
- Fuel Pump?
- b18a crank pulley, how to get this thing off?
- Axles keep coming loose!!!???
- head gasget help (h22)
- Will a d-series clutch fork release spring work with b-series?
- Will a gsr aem CAI fit a b18c in a eg civic???
- will a 00' gsr wire harness work in a b16 swap in a ek
- $1000 to spend on a D16A6 build up – need advice
- i need pic of hacked mount for h22 in eg
- What JDM engine?
- b20vtec, which tranny ls or gsr?
- hp on a d15?
- hybrid exhausr system set-up ?
- 99 civic sedan auto, hybrid ?
- What ecu should i use?
- My F'n oil squiter broke in the #1 cylinder WTF
- 98 hx into 93 hatch..distributor?
- cr-vtec computer
- who sells the obd1-obd0 conversion harness
- parts list needed for d15z1 to d16y1 in a vei
- Wiring problem with my swap
- How to wire up my swap????
- code 23....ks not wired
- Weights of engines...
- ECU Queston? For h22
- got CEL 15
- ls vtec bolt-on
- EK hybrid mounts questions
- B16 SWAP o2 sensor question
- 2k gs-r ecu Immobilzer feature?????
- where are the knock and IAB sensors on a b18c1?
- slight GSR build up with ITR pistons
- Clutch master b16a1 ?
- Civic 93 swap for integra TYPE-R 2001
- Hasport use with Hcp A/C kit on h22
- help...b16head, gsr block...bog at 5 g's
- gsr motor in 94 dx?
- reliable online SWAP-SHOPS..do they exist???
- ITR cams lobe specs
- mpg for different motors
- Can I use a 88-91 SI engine harness on my DX with a B18A?
- VTEC wiring w/conversion harness?
- Vibration at certain mph with H22
- 4th gen accord tranny swap
- Reliable online swap shops. do they exist???
- Safe to heat Axel hub nut?
- b18 ek - need a new BATTERY
- fuel return shooting out fuel...help!
- h22 auto tensioner sucks ass!
- IAC wires?
- Day 2 working on the Eg / GSR swap (One pic to summarize day)
- h22/eg throttle cable
- 2000 B20Z into a 1991 Integra, issues?
- GSR swap, have exhaust for 2000 Civic coupe, what cat to use?
- Insurance
- JDM Transmission Parts - OH NO! H-E-L-P!
- I want to do an ls vtec.
- Dumb question but i am getting frusterated
- GSR exhaust on a hatch
- What Rim Size for Drag racing?
- hp on b18a?
- Pedals
- How much wheel power??????
- will this work ???!!!
- Exhaust System for h22 eg Hatch
- h22 tranny question
- ls shortblock f/s
- exhaust gasket between 'a' and 'b' pipe??
- Anyone running HCP mount with AC?
- Monarch Trading Company
- 2.5" collector question?
- H22 civic- time to do suspension. GC's or Neuspeed? Opinions? Experience?
- gsr door panels into ej 95 coupe?
- Intermediate shaft and axles the same?
- ZC into 88 crx hf......what steering knuckles?
- Good places to get a complete/legit USDM B18C?
- wiring a b18c1
- Any problems expected when using 89 octane with a B16A?
- OBD-1/0 Problems
- h22 hatch alxes?
- How to tell if my B18c1 Block is really a '01????
- Need Info on Ls/Vtec Setup?
- ecu for a h22a
- Aircon in an EG B16a swap
- JDM b20b == USDM b20z?
- I have a 94 hatch h22 wiring problems
- jdm itr or ctr pistions? daily driver
- H22a cx update
- B16A2 w/ 97 GSR ECU??? no VTEC???
- ls or gsr?
- civic1st gen crx swap questions
- b20vtec hp???
- ls value cover...what fits?
- Intake air sensor code help...
- zc vtec
- Throwing Codes!!!
- HOW TO: put new fuel pump in an EG
- h22 videos!!!???
- h22 dist and engine madness!!!
- Pic. request: 90-93 accord shifter assembly for H22EG swap
- Weighed Civic before and after H22A swap (pics & info)
- h22 accord won't turn over.
- CONS of stroking my b16?
- Question about fuel pump/injectors on Ls/Vtec?
- Cr/vtec cost... Can anyone give me a honest answer?
- b16a1 head and b16a2 block?
- All Motor B16 even worth the time ?
- b16 engine on an '89 accord????
- what cap?
- b18 c1 into 93 EX will the ex harness work?
- swap
- Welded diff. questions
- "Poison" few question for h22a
- 94LS/ gsr wiring
- 91 crx doing b16 swap
- power steering in a ek with a gsr swap
- Help installing my oil pressure gauge
- Vacum line
- h22a4 install help!!!!
- GSR crank in b16a block???
- CRV long block
- breakin up at High Rev!!!???
- fuel rail and reg for crx w\b16
- places to buy motors in NY
- ecu for ex in hf
- Which one should I do?
- D15B7 with D16Y8 Head
- H22a EG, 1/4 mile time
- 3rd gen (90-1) 'lude with H22A swap
- 85 accord for $500, what swaps are possible?
- my car and its progress
- best ECU for NA street??
- Doing a b20 swap into my EG. Need a few double checks...
- Need help with swap...ASAP!!!
- lets solve this once and for all
- 92 with B18c1 Wiring Question
- B20 questions?>
- which is better ls ecu in b20 or dx
- gsr tranny into ls?
- s2k motor in a miata?
- how much extra cost
- 98civic dx to 88-91 ZC
- This is my first time.....not a virgin in the motor swapping after today.
- B18C5(R) Swap into 96 DX...Need some Info.
- can you confirm this about h22's lsd
- haltech install on civi del sol
- 94 dx/gsr wiring
- screw the p28 or not?
- H22 into a del Sol? the real 411
- My b16a3 sounds like crap.... Help please, VERY detailed info included
- LPH?fuel pump question...help???
- Honda Part Number for Civic Type R Pistons, What is it.
- how to do timing on b16?
- swap issues
- Quiet exhaust for B18C
- socal hybrids....
- running lean
- chipped pwo ecu is worth?
- h22's in civic/integras etc
- whats the difference?
