PDA
View Full Version : Hybrid / Engine Swaps
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 [75] 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174
  1. which ecu to run on a new motor???
  2. ac swap?
  3. Where to find INFO on K20 swap into a EG???
  4. what plug is this for? obd2 dx harness
  5. what kind of master cylinder should i get?
  6. JDM ITR Front end on a 98 Civic Coupe???
  7. ls to gs-r
  8. d16z6 power steering pump on b18c1
  9. LS crank in a GSR block
  10. BEST BANG FOR YOUR BUCK ENGINE SWAP! have price$ below. 93 HATCH!
  11. H23 with a H22 Vtec head
  12. AC question please help!
  13. icm( ignitor) voltage
  14. Is it hard?
  15. ZC into 89 dx hatchback
  16. Help me swap i need the experience!!!
  17. CEL problem
  18. LS Transmissions
  19. putting a big throttle body??
  20. teg swap
  21. H22 In Civic
  22. Help! IAB Question (searched)
  23. Which Evap Purge Solenoid for 96 ITR ?????
  24. Last q's about brake upgrade
  25. obd0 B16 head which block??
  26. Any STOCK H22 EK coupes run 13.5 or lower on street tires?
  27. ECU Code 2 ??? PR3 ecu
  28. Ls Tranny problem. Help!!!!!!!!!!!!!1
  29. Post a pic of a 96-98 EX harness on a b series swap.
  30. K24 with K20A2 Head questions
  31. ls/vtec leaking oil.
  32. help! no spark jdm b18c swap
  33. usdm K20 type s swap on ebay
  34. 1994 gsr swap into 1994 si hatch, anything i'm missing?????
  35. Recon Engine....Any Good?
  36. b18b1 into my 96 dx
  37. Need info on clutch line for del sol h22a
  38. 98 b18c1 into 91 ls integra
  39. swap or not?
  40. Vtec solenoid
  41. 00ls into 97ex.. which a/c to use???
  42. What Brake Lines to use?
  43. I'm putting obd1 harness on obd0 motor, any diagrams that would help?
  44. Need help on the ITR manifold in a B16?????
  45. Crx crossmember and adjustable radius rods.
  46. B18c1 swap problem...mounts
  47. Any Advise For b20 vtec
  48. How we remove engines in Norway....
  49. brake swap q's: please help
  50. Help need a quick answer: just YES OR NO
  51. K20+NOS+Hookups dyno= over 300WHP!!!!!!
  52. read disc question
  53. Injector Problems, HELP!!!!!!!!!!!!
  54. RSX R swap into EG????
  55. 97 Civic DX engine into EG 92-95 civic???
  56. OBD2a Dist. on OBD2b harness
  57. 2001 b18c1 into 96ek coupe mounting issue
  58. What gears are interchangeable?
  59. h22 civic hb tranny problem
  60. auto to manual....reverse lights
  61. 88-91 crx k motor info
  62. i have a jdm b16a2 in my 93 del sol..can i put it in a crx?
  63. JDM swap in my 97 GSR question
  64. Bseries flywheel bolts vs Dseries !!!FACT!!!
  65. is it true that there is no way to pass SMOG for hybrid if
  66. EG/JDM integra gsr automatic swap??
  67. h22a knock sensor
  68. Any Info on a B20 in 88-91 crx??
  69. B16A2 into EJ1 Civic Coupe Error Code Help
  70. how much did u pay for your k20a?
  71. K20 into 95 Civic Hatch ***PICS INSIDE***
  72. OBD0 to OBD1 conversion
  73. d series vs b series crank pulley
  74. d15b jdm d15
  75. crazy idle...
  76. ls/vtec timing marks
  77. 1st gen B16a in CRX, radiator
  78. b20
  79. ek ___b20z wireing trouble
  80. b18c1 crx started, died!
  81. P28 ECU problem *urgent*
  82. I don't have a cel light
  83. List Your Car's CURB Weight HERE
  84. Clutch line issue in h22a SWAP...help me out guys
  85. One sad day for my accord project
  86. ecu help
  87. K20 Prelude
  88. siR cluster into a 89 dx hatch with no tach...help!!!!
  89. b16 cam cap tightening specs
  90. H22 distributor question?
  91. B16A2 ECU or any B16 ECU for that matter.......
  92. Help me out guys..fuel line issue in h22a del sol?
  93. adapt a d serie shift link to a b-serie
  94. Hasport EFB2, DC2 mount brackets work?
  95. B16 Knock Sersor LocatioN
  96. anyone have power steering in their h22/eg?
  97. What's the best way i sholud do, Using the type-r manifold or my stock B16 manifold?
  98. d16z6 swap to a b16a2
  99. anyone with a k20a3 swap?
  100. when a turbo car is run without an air filter.........
  101. B18 in an old Mini Cooper
  102. Intermediate Shaft and LSD question
  103. H22A EG Complications
  104. pr3 obd1 ecu vs p30 obd1
  105. Using Hasport driver side mount on 96-00 Civic and a B-18c
  106. B16A RWD Powered Golf Cart.
  107. VX O2 fix??? knock sensor???
  108. what is the conversion between steal hoses and regular hoses?
  109. Back engine mount
  110. ktwizzle t shirts...
  111. EF9 w/ b18a1 motor mount questions
  112. distributor compatability on b-series (search server down, sorry if repost)
  113. integra auto to 5spd mount
  114. EF/SI Sub-Harness
  115. AMP Male pin Part # for OBD2a>OBD1 harness
  116. h22 Ecu info
  117. b16 swap: clutch won't engage
  118. Site for K20 swap info?
  119. anybody here do sr20det swaps?
  120. 6th Gen Accord with 97+ Prelude ECU
  121. b16 Prob
  122. z6 cam in a y8 head using p28 ecu (timing)
  123. s1 tranny
  124. Switching from 4-Speed to a 5-Speed
  125. What motor for the EG???
  126. K20 into 2001 civic
  127. 97 B18C1 in to 98 DX Swap Problems
  128. b18a crx problems
  129. what do I need? b18a with cale tranny in a 93 ex
  130. B16 crank and rods in a B18c block??
  131. engine serial number locator
  132. MOTOR MOUNT HELP....
  133. what tranny to use for DOHC ZC in CRX Si
  134. K20 into Accord
  135. interchanging parts????
  136. ls/vtec torque specs
  137. has anyone used a itr gearbox with a kaaz 1.5 diff in a civic b16 dohc hatch..
  138. K20 into CRX
  139. My K Twizzle
  140. K24A with RSX Head?
  141. PROJECT CRX .. never gunna happen...
  142. B18 vs B20
  143. need help! 95 LS b18b into a 99 civic EX?????
  144. b18 swap into eg ???
  145. NEED HELP FAST ls in a 99 si
  146. Intermediate axle question
  147. h22a engine codes
  148. f20c?
  149. vtec manual switch??
  150. possible engine hybrid
  151. Wiring VTEC in a 94 DX Coupe
  152. Posting Pics?
  153. HELP: Type S tranny.... How to tell?????
  154. JDB obd2 & 92si swap
  155. Questions about EG civic h22 hasport mounts
  156. Parts List for Automatic F22 to Manual H22 Swap in a 92 Accord.
  157. If I wanted a drag car...
  158. how do i get the a/c working on my car
  159. Questions about this swap???
  160. washing motor??????????
  161. b20vtec but no vtec??
  162. QUICK QUESTION: Will car start without a TPS sensor??
  163. Swapping B18C5 Short Block for B16A2 Short block
  164. B20 Vtec in a CRX
  165. does this look complete??
  166. OBDII GS-R in OBDI CX problems
  167. Civic H22 shifter...
  168. 04 TL swap into dc2, can it be done?
  169. Question about b18c1 swap into EG Dx
  170. B16A O2 Sensor Question
  171. BYPASS OIL PRESSURE SENSOR FOR VTEC?
  172. FREE Intake for BASE m/t RSX!
  173. B20z/gsr frankenstein
  174. 2001 Civic Swap
  175. Anyone with Dynos of a D15/Y8 and/or D15/Z6 minime?
  176. Which swap should I do: H22 Euro Accord TypeR or jdm b18c5 motor?
  177. Got my swap today. HMotors :thumbup: x infinite...
  178. How to tell if obd1 ecu is Faulty ?
  179. rev limiter problem
  180. what? nobody knows?
  181. SiR cluster wire up into a DX Ef without a tach??? Anybody??
  182. difficulty of h22 eg hatch swap?
  183. 00 SI SWAP INTO 96 HX HELP??????
  184. Accord vtec ecu question
  185. which air intake fits a EJ1 with a GSR? Help!!!
  186. in a eg coupe what should i do
  187. Will D series trans Bolt to F22??
  188. main relay problem... yes i searched...
  189. h22 eg
  190. shift linkage?...help pleasee!!!!
  191. a stock dx hatch. with a addition of a B18c5 motor What else should be done?
  192. LS/VTEC swap in sol cal?
  193. B16A2 with ITR Cams/Springs/Retainers - Should i get T/B and Inlet too?
  194. H22 Accord or Civic
  195. simple question about intake
  196. brake how to? integra->civic
  197. K24 - differences between Accord, TSX, and CRV?!
  198. 93 hatch
  199. ls/vtec question
  200. EG H22 CAI which one???
  201. How hard is it to swap a B18B into a HF CRX that has a ZC swap already?
  202. Obd0 to obd1 engine conversion
  203. b16 swap into an eg question
  204. swap problems
  205. Biggest honda engine in a CRX
  206. Engine stand
  207. need help on transmission problem
  208. B18c1 into CRX
  209. Odd Swap...
  210. JDM h22 in a 1990 Prelude
  211. what DOHC engine fits in an 89 accord?
  212. egr valve issues with b18b hatch. HELP!
  213. Oil Sandwich question...
  214. B18c1 w/ si trans ?
  215. how mucxh for a k20 ??
  216. nead a lil help
  217. b series cable/hydro differences?
  218. dc2 k20a-r
  219. my k20a dc2
  220. How much to complete my set up? Boosted K20A2 into a 99 Civic
  221. When doing an engine swap....
  222. Best All Motor Option For Fast Road/Track Day Teg
  223. Where to get a carb# sticker for CAI
  224. fuel pump priming....
  225. distributor problems (B16 in CRX)
  226. 97 ls motor swap into 95 ex
  227. 1996 ITR 4x114.3 Rotor Fitment
  228. No more worrys b16 tranny bolts to h22 motors!
  229. 2000 Civic with GSR motor.. ECU immobilizer problem.. PLEASE HELP
  230. EK-K20 Throttle Cable ?
  231. Euro R on jdm head
  232. GSR motor differences? did search
  233. d and b series transmition
  234. Electric Power steering in h22 civic?
  235. K20a2..does anyone have good knowledge of D.I.Y. Wiring harness into ek?
  236. Introduction to the new Honda 2.0 I-Vtec-i
  237. DC2 ITR radiator in EK?
  238. A/C bracket?? Is it needed??
  239. b18c1 crx question.
  240. Lsvtec ecu and harness
  241. gear problems after B18c transplant
  242. Feeler: How much do you think my Hatch is worth?
  243. itr b18c5 longblock only
  244. WTF???? PLEASE HELP it is to cold
  245. My H22A!!
  246. big ? to do with a gsr swap
  247. come on guys need answers!!!!!!!!!
  248. Y8 Manifold Z6 Head
  249. friend needs help!!
  250. 2001 f23 vtce into EG
