PDA
View Full Version : Hybrid / Engine Swaps
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 [115] 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174
  1. k20 type s/r swap in ep3
  2. what internals interchangable on h to f series?
  3. swap advice or help needed...
  4. Took the H22 VX to the track yesterday! Check it....
  5. H22/Civic's with cold air intakes part 2
  6. Need HELP With Partially Stripped Tensioner Bolt On Hybrid!
  7. confused about Hondata..
  8. JDM H22a swap...what do I need?
  9. IAB wiring?
  10. Throwing engine code 22 (vtec oil pressure) on b18c swap...
  11. First gen b16 in 94 EX?
  12. b18 A + 2000 dx = ?
  13. Need to know about B16B ?????????????
  14. H22 Civic Troubleshooting/Problems. need some help on this one!
  15. About to swap having second thoughts about which motor................
  16. ecu adapter harness
  17. OT: can anyone get nissan engines?
  18. A/C belt
  19. H22 EG swap - my shifter cable is too short!!! - what to do...
  20. What part needed 4 ls/vtec
  21. b16 with gsr head
  22. best place to buy engine?
  23. need engine quick, which company to buy from
  24. B16A1 into a 5th gen ex
  25. target b18b water temp?
  26. Final Drive Gears for Cable tranny's????
  27. How much HP does an LS-Vtec hybrid put out?
  28. Redline/revlimiter only 7200rpm on my itr setup help
  29. b16a first gen VS b16a second gen
  30. which ECU chip does not look for knock sensor?
  31. B18 into a 91 civic hatch
  32. h22 in a 01 Civic? or k20 ?
  33. temp=loss of power
  34. Which intake do I use for B18C EK Hatch?
  35. b16 or gsr tranny
  36. b18b in a 5g civic: o2 question, need help
  37. need a new alternator pulley for b16, where to get?
  38. p72 with h22 eg civic?
  39. obd0 to obd1
  40. Stupid ECU pins
  41. URGENT EK H22a problems! (HCP MOUNTS)
  42. tranny ? b18a1 with 94 tranny
  43. 85 civic 3door swap to a d15a3
  44. Sohc Turbo In My 99 Hatch Should I?
  45. Emergency Swap in Dallas-Fort Worth...Help?
  46. H22a eg 33 mph on hwy
  47. exhaust for h22 eg
  48. h22a Parts?
  49. h22 and broken axles
  50. Installed MSD Digital 6.. Can you say more power!!
  51. b20z track times... new project...
  52. distributer question
  53. four wire o2 conversion...through the shock tower harness
  54. 92 si hatch w/ jdm b16a2 swap map woes...
  55. Spark plug Question for all b20 vtec peepole
  56. My Hybrid...
  57. ObdII B18B swap into 95 si.
  58. Chick Wrencher: Bad-ass or too butch?
  59. B16 vs B20 (please read, not another comparo thread!)
  60. h22 civic with p28 computer?
  61. supercharged h22 civic eg
  62. TP, MAP, vtec pressure
  63. OBD2 H22A into EG
  64. GSR spring rates on EG?
  65. will itr springs work
  66. Swap question
  67. HELP! Stranded w/ blown engine!
  68. you H22/Civic guys that say you use Type-R cold air intakes.....
  69. GSR into eg parts list?
  70. OBD2 to OBD1 conversion for a H22A in an Accord?
  71. Making a hydro tranny work on a cable car...
  72. Gathering EK wiring information ...
  73. JDM H22 into 92 civic hatchback BAR APPROVED
  74. 97 jdm itr into 97 civic dx hatch
  75. Heater hose question in B18C swap.
  76. Swapping LS motor into 93-95 Si hatch
  77. Project Auto GS-R
  78. wiring dx-siR, distributor wires dont match up, need help fast
  79. Engine Swap????????
  80. HATCHBACK ENGINE SWAP!!
  81. DFW: anybody from dfw thats done a few engine swaps that could help me, please do!
  82. Swapping d15 for a d16z6 ??
  83. Pistons are back from SwainTech
  84. using B18B Dist. on B18C1 (both OBD1), possible??
  85. H22A in 99 civic Si,wiring question.
  86. Maryland Emissions
  87. Building an LSVtec with B17A1
  88. d16y8 into 92 VX, couple questions?
  89. Which distributor do i use?
  90. whats the speed limit on a p30 ecu
  91. B18 in EG shifter query
  92. 92 civic engine/tranny swap to 96 dx
  93. Puting together my own swap... Need your help, thanks!!! obd0 head??
  94. S. California swap shops
  95. Easy Question: JDM 2nd Gen B16a swap into 92 hatch: Mounts??
  96. OT: getting married!
  97. b16a swap in 97 civic EX, was running, but now it won't crank!!
  98. B series in EF guys, thermo sensor question.
  99. can anyone make a wiring harness for obd1 h22a in a 1988 civic dx?
  100. Swap Prelude into Civic
  101. baromatic sensor code
  102. Wats faster (Stock)
  103. 99 civic gsr swap dist. problems
  104. fuel leaking at rail
  105. coolant in weird area?
  106. can someone me please..engine swap
  107. Need Help with fuel system problem
  108. O2 sensor plug?
  109. 10 MPG HIGHWAY!!!!!!!!?????
  110. HMO questions
  111. which heads are the best?????
  112. conversion
  113. Im a dumbass...please help me with my wiring problems...still isnt running right
  114. B18C1 into EK intake questions............
  115. will the 94 integra automatic engine harness plug integ 93 ex harness?
  116. b16a swap in 90 civic hatah si
  117. weird idle and temp gauge problem
  118. 94 gsr p/s pump on itr motor?
  119. B20B/Z into EG
  120. axle question
  121. H22EK R.I.P
  122. Its ALIVE!!! H22-EG is born on 7-7-03!!
  123. 99-00 SI mounts for EG??
  124. ZC swap for EG civics
  125. Blew my motor. Please help!!
  126. any info on f22a in 4th gen civic?
  127. Where to get jdm engine harness?
  128. H22 in a 96civ Coupe?
  129. swap Idea...good or bad???
  130. B16 JDM vs. USDM difference
  131. i need help real bad guys!
  132. B18c1 in a del sol 94
  133. just bought JDM D15B need to get parts...
  134. want a h22 in a hatch
  135. My Euro (JDM spec) ITR transmission woes..this is what was making the strange noise
  136. Can someone tell me the CR?
  137. what 1800lb and has an H22?
  138. header/exhaust b16a problem?
  139. can you hear vtec on b16a?
  140. began the project h22 project today... need some help.
  141. Crx Si trannies?
  142. Tips on removing axles in an EG....
  143. 5th gen h22a head on 4th gen h22a block??
  144. need help with my wiring bs...b18c into eg(cx hatch)
  145. F20C Motor w/ K20A Tranny
  146. hybrid intake?
  147. I need help for H22 civic
  148. Need Help! H22 EG hatch SI hybrid. I'm from Europe.
  149. ?? how do u repin a 99 si to use a p73??
  150. gsr block w/ b16 tranny in g2 teg
  151. new swap running hot? temp gauge is fine
  152. HELP... which tranny should I use
  153. b18a into 92 civic hatch?
  154. ctr swap???
  155. purchasing a new motor???
  156. Need clarification B16A (99-2001)
  157. h22a problems!!!
  158. Attempted to start the h22 last night
  159. 92 B18a1 can it use a p75 ecu?
  160. Check engine Light On MPFI swap
  161. B-16B manifold help !!!!!!!!!!!!!!!!
  162. WTT: Possibly 15" Gunmetal Regamaster EVO's w/ Azenis!
  163. someone please help me with these swap questions? am i getting a good deal!! please i need help here
  164. Speed Sen. Problems
  165. What is all involved in doing a RHD conversion in a DC2?
  166. pr4 question
  167. wich tranny do i have ?
  168. b18b into ek
  169. Need help with wiring harness from jdm b16a to 98 civic ex
  170. Newb Question about 4th gen Accord engine swaps...
  171. best swap for crx if money not a problem
  172. CRX hf with B16A1 wants to get a ref sticker
  173. Need help bad, H22 civic wont start.
  174. B16a1 in 92SI
  175. what kind of times do you think i'll run???
  176. H22 civic disater possibly....
  177. having a problem with my B20...long, but PLEASE HELP!!!!
  178. obd2 engine harness question
  179. honda or nissan?
  180. EW block and D16A1 head?
  181. Possible compression ratio issue?? Please read and help if possible
  182. b18 into civic....
  183. broke the spring inside my b16 tranny, where can i get a new one?
  184. USDM H22 would pass the state ref?
  185. Has anyone put a MPFI in a 1989 Civic non MPFI?
  186. OBDII H22a into 5th Gen civic
  187. jdm motor swapped break in?
  188. how hard will it be
  189. anyone do motor swaps in phoenix?
  190. car wired up for ITR motor W/ P28 ECU, plug in for LS swap?
  191. b18c5 swap in 97 hatch with 99-2000 harness
  192. I can't find an 8mm pin punch. I've looked everywhere
  193. damn 7500 for h22 swap
  194. What is wrong with my speedo? (already did search)
  195. Calling All Torontonians! Any decent junk/auto yards in the area?
  196. ls into eg no fire to sparkplugs
  197. B16A head with a B18C block...who has it and how do u like it???
  198. b20 into ek need help with mount!!!!!!!!!!!!!!!!
  199. need help on b-16b head
  200. Advice on some parts ?
  201. civic was hit
  202. d16z6 swap into dx EG
  203. Where Is The Vin Number?
  204. what intake ITR in ek hatch
  205. B16A into an EF (ED)? Smog legal in california? What is needed?
  206. code 16, fuel injector?
  207. Finally got my hybrid "completed" - PICS
  208. wiring question
  209. ITR ECU pinouts
  210. Want to install a B16 in my integra. possible?
  211. what cheaper
  212. thermostat housing Q's
  213. CEL Light Flashes
  214. H22 eg swap - grounds to ecu wire or chassis...
  215. does any one know the phone # of holeshot racing in cali
  216. does anyone know the phone# of holeshot racing in Cali
  217. H22 Integra GSR pic
  218. Will this work to pass inspection?
  219. D16z6 mini me help!!! please respond
  220. h22 guru's. i need help
  221. is there any trick ways to pass the sniffer test?
  222. ew witWhining noise coming from engine bay
  223. F22B DOHC or F20B DOHC VTEC
  224. b20/gsr into del sol
  225. anyone know of a test pipe that will fit
  226. LS with GSR tranny
  227. K20 into 96+ Hatch Back
  228. Internal vrs external coil
  229. H22 IAB sensor question?
  230. MSG to Poison
  231. can i do this ?>>>>>>>>
  232. need front mount for b20 into ek no clue which one to use
  233. ::B16a1 in a 96ex::???
  234. help please.....blue wire on first gen b16 what is it
  235. b16 swap questions
  236. price matching?
  237. Hey 2 all of honda fans i would like 2 ask about
  238. B16A2 vs. B16A3
  239. mang you guys
  240. Anyone with pics of a custom 91' Crx hood?
  241. Press release: Hasport H-series mounts for EK are now shipping
  242. eg Gsr question
  243. Do I need to buy any new hoses....
  244. GSR quest
  245. 1.8 dohc vtec
  246. who can make jdm itr motor smog legal?
  247. d16z6 wiring help.
  248. Need Help Installing MSD 6A and Coil
  249. any smog shops in Cali that can pass my h22a eg?
  250. what are some of the faster h22 hybrids doing in the 1/4?
