Injector Help?
Old Apr 4, 2011 | 05:01 AM
snowman2805's Avatar
Icon2 Injector Help?
so i need some help here fellas. i have a 98 civic coupe, with a h2b setup. ive converted the system from obd 2, back to obd 1 in order to run my hondata. im running into a problem with my injectors being the wrong size, wrong type, or just faulty. i have a resistor box wired so i can run peak and hold injectors. now my problem is, i have a few sets of injectors, but they are all saturated injectors.
if i remove the resistor box, can i run these saturaded injectors, with the rest of the system converted to obd1? or do i have to stay with the peak and holds in order to run the system obd1?
Old Apr 4, 2011 | 07:22 PM
*EFilliated*'s Avatar
Default Re: Injector Help?
if the injectors regardless if its obd1 or 2 need a resistor box, then use one, if the injectors dont need a box then dont use one, idk if that helpsor not, but good luck
Old Apr 4, 2011 | 08:39 PM
i actually found a set of dsm 450s i had laying around, so im going to give those a try. trying not to change my wiring at this point. but if it comes down to it, i guess i will unwire the resistor box and run saturateds.
hbyrd8701
Mar 26, 2010 05:01 AM
immorality
May 24, 2008 03:46 PM
f1 vtec
Feb 16, 2006 07:57 AM
killa rex
Jan 25, 2006 02:54 AM
drSquish
Jan 19, 2006 01:54 PM
