View Full Version : Hybrid / Engine Swaps
- 90 gs in ek?
- HELP: Greddy oil block adapter
- B16A Camshaft Question
- h22 hybrid fuel pump
- obd1 ls into ek .. wiring questions
- BUYING THIS CAR.
- h22a4 in my civic....need new spark plugs which ones?
- OBD 0 PW0/PR3 oxygen sensors connections SOLVED.
- Aftermarket Honda ECU chips (Kenji) and Scan Tools
- how much power and numbers?
- B18B into a CX
- 97HX = 96-98 EX Harness?
- Are all 98 H22a4 blocks the same or the SH ones different?
- d16y8 tranny housing
- zc=no vtec which means i dont want it! help!
- D16z6 into 1990 Civic Dx. Need Parts List
- 91 DA swap
- Can I rev that high???
- Flashoptions.com?
- Minime...
- o2 sensor sucks
- Help... ticking sound in motor, what you think?
- h22 head on accord block, is it possible
- jdmpower.net I need help
- H22 EK ---> B16 EK?
- 12.82 @ 110 H22/Civic
- Do B16A throttle plates no open all the way?.....should i get a new pulley?
- b16 no power at all low end
- What are the difference is 1st and 2nd gen B16a heads
- Go away you damn oil light!!!!!!!
- B16a in '93 CX...what axles?
- ex slave cylinder on gsr tranny?
- Just received my Imageingineering H22 Civic Header
- Are 1st Gen. B16A Valve Guides Prone Too Failer?
- Ek Ha Sport h22a mount kit questions
- hcp engine mouont problem
- Anybody got nice and big Diagrams for me? (battery wiring)
- tranny code..
- How long does your exedy Clutch last?
- B18B Into 92 EG O2 Sensor Q's
- o2 Sensor and Knock Sensor
- ?89 hatch w/92-95 vtec vti,obd1 confusin..
- need opinions on intake manifolds and tb's on b18c1
- Anyone in Greensburg/Pittsburgh area that can help with b16
- Damn sensors!
- are Japan Domestic Motor and Osaka Motor the same?
- b16a head on b18c1
- ECU error codes
- whats needed to put a JDM B16a1 into a 2000 Civic Si OBDII
- What mount's for h22 integra swap?
- B16 in 93 eg no power
- Knock Sensor please help
- passenger side mount Auto-Manual swap
- reverse light ?
- need help now
- 93' B16 in 95' civic
- B18C Block with B16 Head.. what Head bolts to use
- Wiring differences for an OBDII Integra LS auto to manual swap.
- what 1/4 mile time? for h22a euro-r powered EK
- how much for a converted civic to Type R
- gsr clutch into ITR swap?
- Wiring on obd2 h22a to oo integra ls?
- Hybridgarage reliability
- H22EG almost finished
- fan on h22eg
- sneak peak of abunairacing.com's OG MUGEN S2K!!!
- VAFC Question. Shitty running car!
- h22a4 into 93 accord
- H22 specialists Need help W/axles.Any that knows their axles Help
- B18B->EK, which PS Pump?
- Couple of H22 Tranny ?'s
- Transmission options
- What is the vtec difference B16/GSR???
- will this swap plug and work
- H22a into 92-95 Civic
- auto or manual ecu?
- JDM GSR into EG problem...
- JDM Swap
- Piston Slap on Built Motors???
- best way to convert 2nd gen teg from OBD0 to OBD1?
- what a difference ...
- Tranny question
- civic si 99 ecu fit in a 99 civic hx?
- Any one in miniopolus that can do my wiring
- flashoptions.com?
- JDM B16 SIR-II into a 00 SI - CEL question to do with IAT Sensor
- Help on how to swap a B18c to a 93 civic hatch?
- 90 Ingegra (B18A) swap into EG (automatic!!!!) questions
- question about mount b20 into ej
- swap info needed into ek
- 90-93 INTEGRA jdm b18c swap help
- OBD0 ECU on OBD 2 motor
- need help on b16 swap
- y8 in to civic
- Want a Front Crossmember mount for 93 civic w/ H22 using Hcp kit
- Very Bad Gas Mileage! Did Search Please Help
- A/C & PWR. STR. brackets?
- b16 into eg tranny problems?
- DO I NEED AN OBD2-1 HARNESS?!?!?!?
- swaping in EuroR manifold into ek
- anyone tried to change timing belt on h22 EG?
- what ecu for 91 zc?
- tranny question
- I need help finding info
- 96 gsr swap into a 94 ls (auto) plugs dont plug up on pass side
- Best Motor Mounts: Mugen or Hasport
- Does F20B have FRM sleeves?
- http://total-boost.com
- JDM CTR Harness work in USDM Car?
- d16y8 swap into 98 cx hatch
- where/how can i get my B20swapped EK smog in so cali under this restraint?
- My fist time to the track w/the swap.
- Help with CRX D15b SOHC VTEC SWAP!!Help!!
- AEM ITR cold air intake
- stick with b18c or go for h22?
- gsr swap in crx...no Vtec
- Battery Question
- Help with swap in Rochestery NY
- oil pressure wiring
- What do some of you 88-91 CRX Si hybrids weigh ?
- obd0-obd1 wiring conversion please help no spark and fuel
- Doing a C5 swap in a EK hatch....
- Reliability of swapped honda
- 93 dx civic b16a2 swap a/c lines?
- parts swap
- CAI question
- auto to 5 speed on a 94 integra, 2 wires from the clutch??
- NEED HELP WITH PROBLEM!!!!!!!
- 88 CRX w/B-16 and JRSC on Super2nr tv today at 12:00 PT
- Dead ignitor... Or ecu?
- rebuilding motor....
- jdm eg/gsr swap story...long
- 84 b18 block with newer vtec head?
- P28 auto ecu in a manual swapped motor Possible?...
- I THINK I SCREWED UP BAD
- Clutch Problem, clutch backwards??
- CRV pistons in a b18C5 block
- will p61 ecu work with jdm h22a???????????
- would a 00 Civic si fuel rail w/injectors fit a 97 LS intake manifold?
- itr swap complete but...
- NEW POST... Old problem! heres the Cut up harness
- RPM's not working on my tach. (92vx w/B18C5)
- help with d16 in 92 civic wiring
- B16a power? 200+
- OBD1 Distributor Wiring For OBD0 Conversion TO OBD1?
- O2 Sensors And Plugs For obd0 over TO obd1 Conversion
- Koyo Rad........ fan??
- 94 Canadian GS-R Cluster in an USDM GS-R
- How much is this worth?
- JIM FAB traction bars in h22 eg civic?
- attn: B20b/z swap owners!!!
- has anyone bought this swap?
- please help on if a B18B LS nonvtech is the best for all the way to go for a all out turbo setup????
- B16 ---> B20 cooling fan?
- B16 -> GSR OBD-0 (Built Race Engine Project Begins)
- 2, o2 sensors... Where do they go?
- any body have cruise control working with air bags disconnected?????
- does anyone have a obd1-2.1 harness i can borrow to test something???
- driveaxle trouble
- What size belt for H22 with no AC?
- JRSC fitment issue
- Suspension Suggestion for my eg h22
- Doing VTEC ecu conversion. Need some info please.
- B18B into CRX Guage cluster problem
- obd1 gsr swap into 93 civic dx (vtec wires)
- 92 Cx engine to 92 Civic Dx
- what tranny do i have??.s80 3006973???
- Wiring help h23-h22
- JDM motor in US frame ... help with wiring...
- Need Swap Help
- DAMN EBAY>>wrong harness
- Burnt GSR integra in accident.
- just completed LS swap....hittin fuel cut at 5600?
- HELP! B18C4 Swap - ECU problem.
- What is the code for Defective ECU?
- tach
- transmission bolt on
- is this soldering right??? alternator wires
- my options for cat?
- Is the H22a4 without tranny just like any other h22a????
- B17 into 90 4door teg ls??
- [FAQ] ***H22A into Civic EG/EK INFORMATION Post all H22A Hybrid info here***
- B18C swap into 90 CRX Si w/ place racing motor mounts
- ***Okay Let's Cut Down on the Repeated Qs about Certain Swaps - Post Links HERE***
- would JDM ITR fuel rail/injectors fit a 97 LS intake manifold?
- swap ? 96 civic dx jdm d15b
- Pics H22 EG vacum lines
- alot of swap questions
- H22a in 92 hatch swap QUESTIONS
- De-Stroke, or death wish?
- my swaps done
- JDM H22A --> 99 EK Wiring, HELP!!
- Integra H&R Sports springs in a '92 hatch?
- Drivetrain weird Noise : Help
- Euro / JDM ITR B18C + Gearbox on a 95 B16A2 Civic
- any 4 lug 11" brake by Honda?
- DYNO DAY!!!!
- Car wont start Help.
- 92 SI HATCHBACK?GSR CLUSTER---IN A BUBBLE?!?
- Power Steering B-series Swap.
- Missing Valve Spring Nut...is this bad?
- Vtec question and valve question
- ** Vtec is not activating on LS/Vtec. Please help **
- 94 Civic DX and Engine Compatibility
- Putting a b18c into civic
- p 13 pinout chart
- where to get a 90-91 b18a1 swap??
- Ek Lower mount?
- goin to a stand-alone system in the DA
- im buying a h22 swaped civic and....
- well they match?
- B16A clicking noises
- h22 euro-r installed into EK, problem with the IACV
- What ecu with d15b vtec?
- Search but found nothing
- knock sensor problem i've had since february....tryin to get it fixed once and for all...
- b18c5 or b16b
- no catalytic on the crx i bought help.......
- OG Hybrid Board
- Ohhh O2 sensor, where do you go on my swap?
- Ls/Vtec Adjustable cam gears on B16A2 head, what settings?
- timing belt?
- NEED: Evap Purge control solenoid and Valve 92-95 eg
- fuel pump
- b16 into 93 eg
- 99 B16 into 97 Coupe - I have no B16 mounts..what do i need?
- Quaife LSD - speed sensor ?
- hybrid cable tranny
- H22 in a 89 Honda civic HB
- d series mounts + b series motor?
- b16 vacum lines question
- smog legality of the k20 swap
- H22 SWAP INTO EG HATCH.....
- Testing a Swap before install?
- 92-95 civic h22 hybrid with jim fab
- Where to buy honda crate built ls vtec engine?
- H22 into 92 CX HATCH need help with swap.
- Which OBD 1 Distributor(s) For B16a or B18c5 Head?
- B18C1 is in my CRX
- CRV Fuel Pump?
- B20b or Z swap into a EK, need help, searched
- h22 hybrids--- how to wire distributor external coil in civic
- Part # request`
- crx b18c swap
- sohc vtec EG6 post yours
- ARRRGHHH....stupid motherlovin bolt!!(pics) 56k dunno??
- Anybody ever put an accord v6 in a civic?
- Repost from Accord Forum, any help is appreciated
- Gsr fuel pump?
- JDM LSD in a USDM Case...
