PDA
View Full Version : Hybrid / Engine Swaps
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 [85] 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174
  1. 99 b20 in 99 Si...starting problems, help!!
  2. d16A1 obd0 to obd1 conversion questions
  3. ls swap in crx
  4. sway bar and tie bar in EG (cx)
  5. What axles or combination of axles to use for crx K series swap?
  6. totaljdm.com experiences and comments
  7. Several issues! Just finished b16a OBD1 & cable YS1 into 90 crx dx.
  8. Are 90-93 Teg Brakes Interchangeable with 92-95 Civic Brakes?
  9. Which radiator should I use for EG with B18C and A/C installed?
  10. How hard is this 88 - 91 Civic LS Swap
  11. B18C Into 99 EK Civic - Some answers if you could ?
  12. Please Help....
  13. Need help with shift linkage
  14. H22 Shutting Off/Starting Issues....Help!!!
  15. Whitfield H22 Turbo Civic
  16. H22 STOCK LSD INSIDE A H23 TRANSMISSION? TO BE OR NOT TO BE?
  17. B18B Swap (PLEASE HELP)
  18. Wiring h22 injector resistor
  19. yea i have a question need yall help
  20. H22 into 97 Civic EX
  21. B16A1 head, Integra GSR block: which head bolts?
  22. B16A1 head, GSR block: which timing belt?
  23. exhaust
  24. where does this hose go??(b16 swap)
  25. Civic Drag racer engine swap
  26. K series into EK evap valve ?
  27. h22 AXEL problems?? cant find right axel >>????
  28. Has anyone purchased anything from Hondaautomotiveparts.com?
  29. which ecu to run with h22 civic swap without having to repin harness
  30. I searched i swear eg rear disc brake install help
  31. Budget Swap
  32. My mini me has problems...please help!!!
  33. First TSX Swap into DC5 in Canada, possibly us too...
  34. South Florida / Treasure Coast shop for accord engine swap
  35. Auto Tensioner
  36. Which ecu??? Help anyone?
  37. Which wires do I add from the 00 h22a4 harness to my 97 Acura CL harness?
  38. H22A in 90 Accord EX
  39. GSR into EG coupe mounting problems
  40. b16 problems at 115
  41. VTEC WON'T KICK IN - HELPPP
  42. K swap into EK fuel ?
  43. 99-00 Civic EX wire harness
  44. H22 swap
  45. a few quick questions
  46. First K20aDC2 swap in NorCal
  47. MOTOR DROP!!!!! NOW!!1
  48. IAB, where do I run this wire to?
  49. Pin Removal
  50. obd1 comp. p72 for a 98 gsr
  51. quick question about CAI
  52. What catalytic setup for EK/18c
  53. Engine Swap ? (did search)
  54. Mini Me questions, what all is needed?
  55. IAB not working. Help with vacuum.
  56. help with d15b7 engine into d15b8 cx hatchback
  57. obd2 b18b1 into 94 cx ?'s
  58. Piston Question ???
  59. b16a2 head, jdm b16a block questions
  60. LS/Vtec quick question
  61. JDM B16 into EG question
  62. Car pops outta gear
  63. After market pistons?
  64. b18b1 into ek hx coupe..how hard is it??
  65. were do wires from dizzy go
  66. HELP!! v-tec doesn't work and Speedometer is dead!!
  67. 92 SI HATCH SWAP WANTING INFO ABOUT B18B1 INTO IT
  68. about to swap, procedures and tips
  69. help with 94 gsr swap in a 91 crx
  70. obd2 gsr into 90 crx si, wont start *searched*
  71. DIZZY Question
  72. Dark exhaust gases when in vtec
  73. obd1 to obd1
  74. b series questions
  75. Ran the Quarter mile with H22
  76. posted this in all motor, but thought it might go well here too. b18crx problem
  77. Zdyne One wire ECU
  78. Engine not starting need suggestions...
  79. 94 d16z6 into 92 civicvx how to!!!
  80. b20 on 98 gsr????
  81. Petition for Englishtown Raceway Park
  82. Motor Swap Question?
  83. car studdering
  84. External Coil Accord.....Internal H22?
  85. Need K series swap ecu/immobilizer help!
  86. b16a & b18c same head gaskets???
  87. surging/loping idle B18c1 swap
  88. Why Can't I Smog??
  89. Finished swap, but have questions.
  90. what intake should i get and will it fit?
  91. need help....have searched
  92. 92 si hatch b16a1 qustions?
  93. swap ideas
  94. compression ratio?
  95. K24/K20 VTEC or Superchargerd B20/VTEC In EG Coupe?????
  96. 87 Si
  97. Has anyone done the ITR swap into a civic?? If so have any pics?
  98. Anyone have a OBD1 gsr engine harness?
  99. How long is too long for a motor swap and mild engine work?
  100. Not revving past 4700 RPM
  101. car not starting. fuel? 89 civic DX w/ ZC
  102. Please help me decide how to build my 2 Hondas
  103. Need some info
  104. B16A...B18C1
  105. mount kit question for swap
  106. 92-95 H22 with Hasport mounts, 90-93 shaft to short
  107. Whats the best way to built? H-series..
  108. 91 accord engine swap Q's
  109. LS vs. Turbo
  110. Please look! Need help on b16 swap!
  111. Difference between obd 0-1 engine coolant tempature sensor?? b16
  112. After Swap Q's?
  113. which 4d/motor is best?
  114. B Series swap in a 89 Civic hatch DX
  115. Which swap in an eg hatch????
  116. GSR Swap CRV AC Bracket or Del Sol Vtec ?
  117. AEM need a 94-01 Integra w/H22 swap for test fit...you get a FREE intake!!
  118. 1st Gen Crx / b18c swap need Info!
  119. best way to run a d16z6 obd0?
  120. AEM EMS question??
  121. B16a emissions
  122. Evap Purge Solenoid, does the B18c use this?
  123. power related problems
  124. Swap Method Question
  125. Just installed a USDM itr motor in a 92 cx..and having some problems
  126. LS/VTEC DA power stearing set up ?
  127. No oil light, car won't crank anymore...electrical problem? Help!! I give up..
  128. Pinning Harness in OBD2a EK
  129. tranny conversion
  130. 99 4dr non-vtec brake conversion
  131. b18 fuel rail with b16 head?
  132. Knock Sensor Wiring
  133. d16y7 to d16y8 swap
  134. Removing Driveside axle
  135. Exhaust Compatability
  136. b18c5
  137. Cat question??
  138. motor mount inserts
  139. integra motor in crx
  140. HELP which alternator
  141. Geting my itr on friday need help!!
  142. de-stroked b20??? heard a rumor once...anyone know???
  143. 95 saturn
  144. Help!!How to install a B18c4 Motor in a del sol Vtec
  145. Y1 cable LSD: gear, clutch, or viscous?
  146. IAC / Swap problems
  147. zc motor, l3 tranny, 90 crx si, which axles do i need?
  148. Tranny question
  149. What dió I need when I swap a B18C1 into my EG6??
  150. need some help with wiring
  151. oem parts for jdm b16
  152. swap w/o car lift?
  153. Gauge cluster problem.. please help
  154. Fuel Pump Question - Type R
  155. simple question.... LS motor or B16A1??
  156. 1996 ITR DISTRIBUTOR, help!!!!!!!!!!!!!!!!
  157. Will b16a2 dizzy work on a b18a1?
  158. Osaka Trip!!!!! 56k take a nap
  159. Wire Harness??????
  160. 1999 p30 b16 si head on 95 b18b block
  161. did mpfi swap car wont start
  162. gargling sounds comes from engine when reved help.
  163. Distributor Question…
  164. The K-series killer a need to know
  165. what radiator (A/C? in the future) & what fuel pump for k20a swap EK
  166. wiring swap help please.... pics included
  167. b16 head on 1gen b18a
  168. YES!!!! How to wire a k20a into EG !!!!! pnp Harness!!!! THANK YOU HONDATA !!!!!!
  169. need help on questions on engine swap out
  170. Redynoed H22 hatch
  171. LS/VTEC oil line size?
  172. do i need b18c engine mounts
  173. Where can I buy that Hasport harness for the h22/accord?
  174. JDM B16A2/3 into EG5 Civic Hatchy..
  175. Viable Gen 3 civic swaps
  176. wiring choice, obd1 or obd2
  177. fully built b20/vtec running good just one problem???
  178. Hasport Ques. EG/H22
  179. mount question
  180. engine code HELP on 4th gen accord->h22a code 20
  181. engine code HELP on 4th gen accord->h22a code 20
  182. engine swap
  183. K20 v.s. ALL
  184. Throttle Cable help!
  185. opinions? b16 positioned improperly?
  186. 92 civic w/ b18c Need Help Plz
  187. GSR swap into EG, coolant line problem?
  188. My LS swap is bogging??
  189. b16a1 cam question
  190. H22 92-95 civic with prelude intermediate shaft?
  191. Need help with my LS/VTEC (Knock sensor, Thermoswitch)
  192. 96 LS swap in a 92 CX hatch problems
  193. k20swap. emissions/smog?
  194. Exhaust Question - So I buy the right stuff . . .
  195. Options for mounting H22 shifter box... Here's MY WAY (Pics included)
  196. Knowledge Performance inc has anyone had problems with them on there motor swaps?
  197. Turbo H22/H23 How much WHP have you seen on the dyno?
  198. JDM itr ecu vs. USDM itr ecu?????
  199. Shift linkage
  200. OBD 1 problem b16a obd-0 obd 1 block CODE 6
  201. b18a1 engine swap
  202. OBD conversion questions
  203. CEL PROBLEMS???
  204. how far forward does the h22 sit in a civic
  205. in socal:! how much to swap a ls motor into a 96 coupe..
  206. b20 vtec head studs
  207. swap question.
  208. Speedo problems (electronic/cable) with B16A into CRX Si
  209. HELP! FWD Drifting at NCDA and now car wont start!?!
  210. What Parts for Second Gen Jdm B16 Can I Use?
  211. What do you know about a SOHC ZC NON-VTEC engine?
  212. HELP MY DE-RICE
  213. B18C1 SWAP IN AN EG HATCH PROBLEMSSSSS
  214. b16a Fuel injector Mix n' match Question.
  215. H22a into 99 Dc2...I Got Wiring PRoblems! HELP!
  216. 96 EX wire harness question
  217. Noise coming from front suspension!!!
  218. JDM K20A AT to MT SWAP ES civic Complete in 4days! CANADA
  219. d15 something
  220. B20 into Del sol swap problems
  221. usdm b16a2 to a jdm b16a2?
  222. B18c IT-R swap into 91 CRX question
  223. Problem with B18B swap in EG
  224. which starter
  225. D16Y7 to Y8 swap...problems.
  226. any problems with the a/c bracket from hcp for the h22 swap into ek??
  227. b16a into 95 Civc CX, can I use my stock drive shafts?
  228. Looking for advice on this setup.
  229. How tough is a swap? D>D
  230. 93 Accord Harness with B16A???????
  231. Hard to get in first gear. Need some advice
  232. weight of b series motor?
  233. need help fast!!!!!!! female half shaft, part #?
  234. B18C-R Fuel Filter
  235. Help what swaps are viable for 82 LX Accord
  236. What would make the SRS light come on?
  237. throttlebody vacuum leak after aebs install
  238. h series -->sol (idle spiratic (sp?))
  239. h series -->sol (idle spiratic (sp?))
  240. h series -->sol (idle spiratic (sp?))
  241. h series -->sol (idle spiratic (sp?))
  242. I took my dash out of my 93 4d and cant figure out were this reen plug goes
  243. h series -->sol (idle spiratic (sp?))
  244. h series -->sol (idle spiratic (sp?))
  245. b16 auto into eg?
  246. Tranny mount holes and bolts, ok if I use these bolts?
  247. Are D-series and B-series distributor cap rotors the same?
  248. OBD2 LS swap into a OBD2B 00 hatch
  249. k20a into eg
  250. What year of integra coilovers bolt directly into 92-95 civics?
