PDA
View Full Version : Hybrid / Engine Swaps
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 [18] 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174
  1. Hope some of youi guys can help
  2. JDM H22A w/LSD trans in EK Hatch Axle Question
  3. mounts recommended for k24 into ek
  4. no power to igp2 or igp1
  5. OBD0 engine into OBD2 chassis HELP!!!
  6. 3 questions before I start buying stuff plz.
  7. D16Y8 harness -> H22A ?
  8. f2d mount brackets
  9. H2b Qsd kit question
  10. K24 Block w/ K20 Head
  11. h2b ek motor mount question
  12. B series swap into Acura 1.6EL opinions
  13. F20b vs H22a
  14. Eg6 w/ k20a2 swap. rev issues
  15. Got a 93 civic ex , trying to swap need advice please help
  16. B20 install parts list for 92-95 Civic?
  17. h22 into eg. ? on extending the alternator wires
  18. Sorry, another Q about B16A2 (SIR-II) into EK
  19. resistor box install for dummies w/pics
  20. f20b swap ?
  21. k24 slugs on f23 rods. 4my G' ?'
  22. J32A2 - Pie Cut Intake Manifold
  23. QSD H2B car in So cal?
  24. EK with GSR swap. I need heat.
  25. axle help h22
  26. K20A2 ECU Help
  27. Idle/vacuum problems h22a4 crx
  28. new flywheel and clutch kit. now cant shift into gear
  29. H22a axle problem
  30. H series swap to 95 honda civic ej1
  31. h2b swap ek, no CEL but limp mode
  32. Ef4DR LS/V AWD setup in the making...
  33. Shift Problem: 2nd, 4th, 5th = Shift Cables or Tranny?
  34. 93 civic swap..maybe?
  35. OBD2B GSR into EG trouble
  36. k24a1 block with k20a2 (head and oil pump) what oil chain?
  37. Euro R h22 idle
  38. Dented the hell out of my oil pan on h23a vtec
  39. wiring harness website?
  40. [Australia] EK Sedan, H22 Conversion. Q's
  41. So I ordered my H23a vtec from jdmenineworld.com
  42. rod and main bearing question
  43. Question on doing an Automatic EG with a k swap?
  44. My First Motor Swap Help
  45. Thermal intake gasket leak
  46. f20b swap question
  47. innovativemounts
  48. Help!! Immobilizer solution
  49. H2B in AF (84-87 civic/crx) info?
  50. innovativemounts
  51. H2B oil pan/oil pickup issues
  52. B18C Swap arrived
  53. OBD0 auto to manual
  54. OBD0 auto to manual
  55. how to install skunk2 vtec solenoid cover??
  56. F20B DOHC VTec Euro Type R vs. H22A DOHC VTEC
  57. h22 eg hatch axles problems
  58. Which A/C Compressor for H2B q/ QSD kit
  59. H22a Swap
  60. For those of u running a single cam f2b what mods are being done to mounts?
  61. H2B Clutch for Autocross
  62. H22 Swap Overheating after short drives.
  63. D15B into EF, Complete rebuild for turbo, building for deployed soldier and friend.
  64. B18C1 suddenly wants to misfire....
  65. 3inch or 2.5inch?
  66. em1 with h22a4, ecu help.!!!!
  67. JDM 96 Integra Type R Swap
  68. eg hatch with lsd h22 swap
  69. h22 swap in an em1 ecu help
  70. gsr swapped ek trying to pass inspection
  71. Pro Parts USA
  72. Want to swap 96 Civic EX
  73. b16 swap crx axles binding
  74. Turbo J32A2 S2000 Build Thread
  75. h22 in a civic issues.
  76. qsd wont responsed!!!
  77. F22b+H22 head?
  78. EK hatch refresher
  79. Ls swap in ek, fuel pump wont cut on
  80. Someone please tell me what exhaust this is (J-swap into Civic)
  81. Will 90-93 Teg axles/shaft fit 88 Crx Si knuckles?
  82. LS Crank GSR block what rod bearings to use ?
  83. crazy build idea
  84. Best way to fix a stripped block head stud hole (idk)
  85. H22 VTEC Problem
  86. h2b questions .. injector size...blah blah
  87. H22 swapped EM1 Axle bind
  88. F22a6 head - Enlarging CC bore to match f23a1 block
  89. H22 ek what intake are you running?
  90. Need advice on engine replacements.
  91. clutch master cylinder
  92. Distributor question
  93. H22 head swap oil block off???
  94. GSR head on B20B JDM high comp motor.
  95. 50mm vs 55mm mains
  96. H22a Into 96 Civic EX
  97. ls/vtec won't idle, runs rough.
  98. JRSC H23A EJ8
  99. H22 love from kaizenspeed
  100. 93 b16 head on jdm gsr block?
  101. Engine Swop
  102. H2B...I NEED HELP!!
  103. F22a1 Dohc Vtec build using F20b head and F20b pistons on F22b1 rods
  104. h2b build how much power??
  105. starting h2b build
  106. H2B: Pilot Bearing
  107. H2D mounts
  108. codes from hell. cel 3 & 14 on crx dx b18a1 obd0 swap
  109. crazy thought
  110. eg H2b Swap TPS question
  111. H23a Vtech Swap in a 00 civic SE??
  112. Need a K-Swap Guru
  113. 93 Del Sol H22a1
  114. harness
  115. 3 wire evap to 2 wire help
  116. odb2/odb1 intake mani diff?
  117. CEL
  118. evolution h2b kit?
  119. LS-Vtec Piston help
  120. I need some assistance with identifying the plugs on my obd2a y8 harness
  121. Airk box EK4 with b18c1 swap in civic 4d
  122. 2000cx d16y7 to 98 d16y8 swap
  123. obd2b to obd1 dizzy harness
  124. b18c5 with 1 piece harness into eg with 2 piece
  125. h2b swap with out a kit
  126. 99 civic ex automatic/manual jdm gsr swap/chipped P06 ECU - Won't rev past 3500 rpm
  127. G23 Discussion Thread
  128. F20C in a 2009 Civic Si?
  129. 89 crx engine harness
  130. EK H22a - Chipped OBD1 ECU (Code 1 Problem)
  131. H2B flywheel.
  132. Does 92-95 coupe/hatch dash cabin harness fit sedan?
  133. H22 into EG Silicone Hose?
  134. B20B with a LS head help
  135. Eg 4Dr H2B
  136. Looking for some insight..J swap in EG
  137. Integra gsr vs civic gsr
  138. f23 long block, k20 pistons,delta 272 grind
  139. H2b race car q's. min required
  140. need info on getting a motor bar'd
  141. h22 vtec ek
  142. VSS/TPS/Wiring Issues - H22 in 99 Civic EX
  143. LS Turbo Or LS/V Turbo
  144. EK H22 Swap Mount Debate...Need Help plz
  145. Weird hesitation problem with lsv.
  146. obd2 gsr in 00 civic si pass smog?
  147. hybrid hydro/cable LS trannys??
  148. H2B owners with a/c
  149. Block posting:material and position
  150. Block posting:material and position
  151. Which ECU will to use to pass California BAR
  152. Confounded Tach Problem
  153. Help! Auto to manual clutch switch??
  154. Project: Auto to Manual - '99 Accord LX Sedan
  155. Chevy big block/ls series in a integra
  156. F20C pistons into f22b possible?
  157. YONAKA AXLES = GARBAGE
  158. 99 sir swap into 99 dx
  159. Looking at this possible hybrid set up
  160. How I bypassed my knock, secondary o2, and CKF sensors on my 96 DX hatch
  161. EG H22A4 swap, axles/mounts?
  162. Snowman's forever and a day build.
  163. After much research, I still need some help in deciding what to do
  164. Fuel Injector Question
  165. f20b mod questions.
  166. NooB 89 Wagovan mini-me help
  167. Tach doesn't work in K swapped EM1
  168. Need help car idles at 3000rpm
  169. [H2B SWAP PICTURES] POST THEM UP
  170. everyones h2b setup built or stoc
  171. Eg ls swap question
  172. h22 valve train
  173. Tell me your H2B experience
  174. The Beast gets a makeover..
  175. Wild engine swap Ideas, need some info
  176. JDM H22a OBD1 Dizzy to OBD2a (Throwing Code 9)
  177. need chase bays wiring help for EM1
  178. 01 Civic w/ k20a2 swap Ball Joint problem
  179. where do most h22 swaps fail in 96-98 Civics?
  180. B20a5 head onto b20b block?
  181. H22 pro 1
  182. 05-06 tranny with 02-04 ecu harness add S2k
  183. F2B Ek minor issues.
  184. 2jz s2000 aac build
  185. Lost of motvation h2b LOL!!
  186. Please post ef h2b swaps
  187. Where can i buy a complete k20 motor swap
  188. Harness Pinout obd2 Gsr
  189. OBD0 to OBD1 jumper harness questions
  190. N22A2 i-CTDI turbo diesel into EG
  191. h22 head, f22 block
  192. B16B into ek?
  193. need help with p28 ek cel!
  194. o2 Sensor Question - Pinouts...
  195. QSD motor mount adapter on 99 f23a
  196. question about denting frame for b series swap into ef
  197. F22 in eg hatch???????
  198. F22 in eg hatch plz help
  199. V6 studffed in my EG. help
  200. need help
  201. OBD2a HX O2 Sensor -TO- OBD2a 4 Wire O2 - Assistance Needed
  202. 90-93 Accord half shaft on H22 swap
  203. H22 Maual Tensioner Conversion - Timing Belt Walking
  204. Bolt size for back of head to attach chain to
  205. OBD1 GSR in EF : code 7, 20 and Secondaries
  206. QSD shipping
  207. The Definitive Guide to a GSR-EG Swap!
  208. f20b help!!!!
  209. H23 VTEC Ethanol Fuel in Brazil - Starting NOW!
  210. H2b problem in Integra
  211. K series shifter box with H22 swap?
  212. H22 Tensioner Conversion Question...
  213. 92 prelude h22a swap distributor help please
  214. 93 integra Da Radiator
  215. Issues with Rywire Harness in EM1 *please help*
  216. exhaust size question for 98 Civic with ITR Engine
  217. f23a to obd1 distributor wiring
  218. What Works
  219. g23 oil squirters?
  220. k23a1 questions????
  221. F23A Swap Questions
  222. Cj h2b project
  223. New Info for B-series swaps into '96 - '00 Civics
  224. GOLDEN EAGLE COVERSION VS BLACKWORKS RACING CONVERSION
  225. H22 into Del Sol swap. Where to run Cable Linkage?
  226. Ls block b20 head
  227. OBD2b car, OBD2a motor & OBD1 ecu?
  228. d16a6/d16y8 Mini me build questions
  229. checking for cel on p28 in ek.
  230. '05 Hybrid headlights
  231. Need help passing WA emissions in '00 Civic
  232. I'm about to drive this thing off a bridge! B18B1 in eg.
  233. My 225 bhp TODA B20 EK9
  234. will dc integra p/s line fit b16 delsol ?
  235. injector question for h22
  236. Help! H22 halfshaft won't fit Jdm type-s block
  237. H2b Oil Pan by KAIZENSPEED / KStuned.com
  238. B18c Type R Swap into a 2000 Civic Si
  239. H23a blue top w/ t2t4 tranny - is vss same as m2a4?
  240. CEL Code 9 after z6 swap in 91 STD EF. All correction options unsuccessful. STUMPED!
  241. Crx b16a flooding/OMFG
  242. Heavy Load from AC: Ideas?
  243. F23 with H22a4 internals or Stock G23 and boost.
  244. P2P ecu running a B18c Type R?
  245. integra obd2 harness pin out question
  246. K-Swap into RHD DB8
  247. F23a5 Vtec oil passage
  248. S2K CLuster Swap in EK FUel gauge
  249. valve spring choice help
  250. New guy could use some help H22A nightmare
