- K20 into a GSR and keep ABS?
- b18 swap idle problems
- B20B in Ek hatch throttle stumbling issue.
- pros of jdm b18 gsr?
- Need help with h22 civic axle seal
- Eg with B18c1 swap mount suggestions
- D15B2 <-> D15Z1 engine block interchange or compatibility?
- CV Joint on civic gsr swap.. Help!
- Limp mode
- ED7 mini me options
- B18 swapped eg8 no start after tune up
- Dizzy help!!! please Asap
- where to buy ARP studs for d16y8 w/z6 head
- H22a obd1 engine harness pinout
- i need a wiring diagram for honda ecu obd1 obd2 jumper
- B20b into 2000 Honda Civic Ex Coupe
- Civic h22 external coil help
- My B18C1 EG HATCH has been sitting in my garage for the past 13 years...
- D16y7 swap in 89 civic lx
- 2000 EJ8 Build
- 94 accord post engine swap quandaries...
- ** EJ8 JDM B18C W/ TPS ISSUE **
- VSS and vtec help
- H22A Serial Number Help
- B16a misfire.
- 97 civic ex Gsr swap IAT ???
- F22b2 swap not starting
- Swap from EH SI to EF Sedan
- What harness do I need to fix this thing?
- 97 Civic/B18c1 swap - IAT code 10
- Possibly an engine swap???? Help !
- H2B high end header / test pipe
- D15b7 mini me
- REALLY LOOKING FOR SOME HELP!!!! Pleeeeease
- 1997 Civic H22a1 swap project
- Honda Del Sol B Swap + basic info
- Eg hatch obd2a Ls swap
- D16Y8 in a 2000 Si
- What Clutch/Flywheel
- concerns about tuning
- vtec assembly in head issues??
- OBD2 USDM Prelude bb6 to OBD1jdm Distributor
- B20v issue...
- unknown issue need help plz !!!
- 92 prelude f23a1 swap
- picked up a cheap H22 civic , runs weird
- B18B1 with 220,000 miles rebuild
- AEM AFR wideband readings ?
- 00 SI with a JDM ITR motor - Throttle body question
- 96 CX Hatch Motor Swap Help
- BAR ing a b20b in Civic possible now??
- D15z1 questions.
- Poor Mans ITR
- HELP 2000 lx jdm gsr swap runs great BUT no power past 4k ...
- H/F OEM mounts into EK?
- 94 cx lsvtec /Code 43 fuel supply system.
- Back pressure problem
- Thinking of buying this car , what to look for
- A/C in EJ h22 swap
- Back from the brink of death JDM h22a crx
- Distributor & idle issue
- B20v compression help
- 1995 civic b18b1 swap question
- B20b in ek hatch wiring problems obd2
- B18b in 98 ek hatch
- F20b
- 1991 civic si hatch b16a1 problem.
- Heater core questions 88 crx
- D series to B series swap help...
- 1991 Honda civic Si hatchback distributor
- F23-h23 swap
- Power Steering in B18C EK Chassis
- 94 honda civic b seirse swap
- G23 h22/f23 with k24 pistons question
- Honda N600 mid-engine CBR1000RR street / track build @ Blackbird Fabworx
- Lsv
- Rbc pistons in an f23
- D series flywheel dust shield swap.
- High comp boosted poor mans tr
- Poor mans CIVIC Type R
- Y7 to y8 swap
- 1997 ej6 civic hatchback/ ls motor b18b1. Poor man typer???
- Engine Harness/ECU/Vehicle Harness
- B20b swap in ek hatch problems.
- B18b1 Assembly/Project Advice
- 4th gen trans into 5th gen accord
- EK JDM H22A Swap Wiring Questions
- I NEED HELP Honda ppl
- Automatic to Manual shop around Chicago
- Civic ef d16y8 swap
- Strange idle issues b20b in 2000 si
- civic ls-vtec actn up
- F20b swap issues
- 1998 civic dx hatchback engine swap? What else on the car do I have to upgrade?
- 93 honda civic auto to b seirse manual transmission mount
- Anyone got or experienced with h2b eg's?
- B18B code 4 help
- Can I use a obd2b ITR ECU in my 00 EJ8?
- Gsr iab help!
- Finding the right catalytic converter
- B7 disttibuter cap on a Z6 distributer
- can a D16Y7 motor swap fit in a 2002 honda accord?
- Just a Hint of advise guys thanx.
- D16a?
- P75 wont prime my fuel pump 2000 si b20b swap
- B18C Swap in EK questions
- Overheating b18
- Im doing an all motor, j32 swap
- 99 Civic Si G23 Mounts
- CRX SI GSR
- BB4 prelude H22a7 swap questions..
- VX trans into 96-00 EX. Worth the effort?
- 2.4 ivtec in a 98 prelude
- 03 accord 3.2ivtech in a 98 prelude?
- Help!! 2000 Civic D16 Swap!!
- the f20b of 2016
- A/C setup for 93 Ej2 with z16
- How hard would it be.
- Crank crank crank
- 00 Civic/B18 swap - stumbles and sputters
- d15b2/z6 mini me swap help
- Ecu help!!!
- b20 with idle problems
- F20b to d16
- Cut my harness when I shouldn't have. Junkyard fix?
- Eg b20 swap
- f20b swap>>>>????HELP PLZ
- Bogging at low rpm after B18c Swap
- 2.2 rail build
- B16a2 swap no throttle response
- Ls swap into eg hatch HELPPPPP!!!!!!!!
- Ls swap into 90 civic hatch HELP
- D16y8 to B18b1 (help)
- B-Series 1st Gen Insight
- F20b rear balance shaft
- H23 Blue Top Question
- F20b wiring question.
- B20b auto Engine convert To Manual trans
- seized at first now oil in cylinder
- EK Coupe H2b Slow?
- H2B Hard Start After Fill Up
- car keeps dying
- B20b What OBD2 P75 ECU should i get
- Ek b20
- 96 cx b18b1 swap motor mounts
- K Series into an older body style...Emissions issues?
- F20b transmission
- EG B18C1 Swap- weird o2 sensor problem
- B series in a 99 dx hatch?
- 96 JDM Integra type R Engine (OBD2) into 95 Integra LS (OBD1) car.
- EG swap GSR hood clearance
- GSR eg swap hood problem
- P72-A04
- GSR Swap hood won't fit
- F23/F20b combo questions
- Axle Angle for H swap?
- b16b head codes
- 94 bard civic ls
- b18 swap help needed!!
- 2012 Si trans onto k24a2
- 99 itr swap
- 2000 EJ6/H22 swap - Hard starting
- EF>Kswap with A/C
- 1995 EG Civic R18 Swap
- Lsvtec swap in ek
- Car vibration after B18C Swap
- 94 civic EX won't shift out of first gear
- Untuned b20/16+t engine in a 93 EG Civ
- JDM Vtec Solenoid on P73 OBD2A ?
- 94 Coupe B20 to 99 Sedan swap. Questions
- EG h2b which h22 motor for obd1 without wiring issues?HELP..
- ecu help!
- 90 civic hatch std b16A Swap
- Hayabusa powered Beat maybe on the market
- H22a Swap and Exhaust Question.
- b20 swap sensor issue
- Anyone out there that has put a h22a7 into a ej9 have few questions
- Coil on plug with no dizzy
- JDM B18C with USDM
- New hear
- 98 civic si b20 (Need help)
- Obd1 engine in a obd2 car
- 97 Del Sol shell questions
- a6/z6 mini me swap questions
- B20v Build
- H22 swap help
- k20z3 swapped es1
- B18C wiring
- Help - Dying when running. GSR
- H22a vs h22a7
- engine choice track car
- 2001 Honda accord with h22a4 swap.
- gt500 super charger on stroked 3.7L v6
- Any trick for plastigage Forged rods
- Need help
- K series or B series
- B16a2 swap into Del Sol
- replacing cat. converter
- Built LS to Vtec... maybe
- Weird vtec issue, please help lol I'm desperate.
- H23 96 cd5 swap wire harness help
- Ckf bypass diagram
- O2 sensor set up
- VTEC swap
- Newer D15 auto into ef sedan??
- b20 vtec mild build
- 91 si b18a1 spark plugs question
- Need Help
- 97 cx hatch with D16Y8 swap
- B20B engine with P75-5 head swap into 95 Integra RS
- H22 stroker 250hp+ club
- 91 crx si
- 5 speed B Series in Auto OBD2B Civic? Tips?
- B18C1 into VX wiring evap purge control solenoid
- G23 build
- H2B Ek keep AC ?
- Mini-Me VS B16A1?
- '97-'00 CL1/4 Accord shifter for H22 Swap: can it be done??
- 99 civic ex with jdm 96 spec b18c itr - codes please help
- B18C4 engine swap 1991 Civic S4C ITBs - How to To guides on YouTube
- b18b1 in 95 CX..bogging, help?
- 2000 ek h22 swap
- In need of help.
- Modified P75 Head vs Stock B16 Head, which one?
- HELP with my engine build
- Help!! H23a swap idle problems !
- Engine swap problems
- Help!!! Having trouble with a jdm h22a swap
- H2b injector size
- JDM H23A into CRX
- B20 prep
- Detailed Cost analysis of my Del Sol S D15 -> B18C ITR swap
- Swap
- 96 civic with LS sputters Help
- [OBD2A in OBD1] - ECU Diagnosis?
- Looking for D16z6
- 93 eg hatch gsr vtec swap sputtering and bogging
- H22 swap fuel feed line identification
- Fresh swap JDM 98 type r into EG civic cx not starting
- h22a into 99 civic si
- 93 civic/H2b swap - injectors not firing
- Quick EF swap question
- having a problem with my h22a swapped civic PLEASE HELP
- B18c5
- Vtec won't engage
- b16 valve seats with Supertech springs
- Swap
- First honda first time doing a swap phx az
- HELP!
