View Full Version : Hybrid / Engine Swaps
- Quick question that I am not too sure about.
- 88 Civic/CRX rear lower control arms
- B18 question(s)
- Vtec problem
- SI rear mount question, need quick reply.
- Where to find more info on the bronze Toda GSR...
- anyone used jdm1.com?
- CRVTEC QUESTIONS
- 89 Integra trans swap
- rad swap
- D-series help
- need help on deciding what trans to choose for b series motor
- B16A3 in ek, mount question?
- LS vtec compression
- B series in EF???
- GSR motor into 98 civic ex coupe.....
- what can i do to my integra ls???
- Prelude Brakes in a Civic?
- which motor to get?
- Where to buy B20 in cali?
- FS: TURBO LS/VTEC MOTOR
- B16A2 head..what year is it?
- Help I'm getting really poor gas mileage since my swap!
- Place that has experience in swaps but doesnt over charge?
- hybrid owners steal cars
- h22
- Help! Engine Code on a ZC...
- Anyone looking for or need a JDM P73 ECU
- What motor would you guys........
- wiring
- Motor Clicks but wont turn over
- from what year clutch do i use for an S1 tranny? thanks. n/m
- Could a D15B7 stock wire harness be used for a JDM B16A swap?
- whats a good price for a ZC engine?
- b16a in a 92cx!
- BMW powered by DOHC VTEC?! :)
- Anyone in the bayarea got a Speedsensor ?
- Question about b18a swap into 5th gen Civic (Yes i searched)
- So how does everyone like the Y1 tranny with the B18c?
- Please Help Me
- shift linkage/motor mount question need to know asap
- obd2 distributor in an obd1 car
- will a itr AEM cai fit on my crx hybrid?
- auto to man swap need help please
- cherry picker.
- Wiring a d16y8 Obd2 into a 91 crx si non-obd car Questions
- H22a1 Swap.
- b16a into EF Civic - Radiator Hoses, Part II
- what pistons should i use in my Integra ls
- New York Machine Shop
- how to bypass a immobiler on newer cars like 2000 tegs (itr)
- Check out this new honda site
- cable ls 5th gear into S1
- anybody running a zex kit on a ZC?
- H22A or B18C5 ?
- 97' LS MOTOR!!!! Do I use, GS-R, SI, LS , TRANNY?!?! WHICH ONE!
- lsvtec block 500
- YS1 tranny chit...
- ls in a 6th gen civic
- Car not starting...
- Hmm confusion on tranny and swap?
- fluidyne or gsr radiator.
- Some ZC questions
- ls/vtec questions
- How hard to change Cap and rotor on LS Dist
- FOR SALE-Supercharged LS/VTEC!!!
- more engine swap questions
- Help! A/C and engine swapping questions!
- b18cR (11.3:1 cr/ spoon spec) in a '88 crx si... what program for the pr3 or pw0?
- Car sputtering
- h22 suspension
- what's the compression ratio on a jdm b20b? is it the same as usa?
- GSR valves in LS head???
- Need crx to obd1 wireing help...
- LS swap into EG Hatch
- car won't start....HELP!
- Maryland swap shop info needed, quick
- distributor for jdm b16a head...
- Clutch question
- questions about tranny pertaining to engine swap
- what's the deal????
- VTEC wiring help...
- tubo manifold for B20 ?
- EF H22 swap shops?????
- which INtake
- Quick wiring question...
- B16a differentials; cable vs. any other b-series
- attn:6G coupes with swaps
- New Radiator?
- my hatch
- is LSVTEC worth the troble?
- prelude engine on a accord tranny
- dohc NONvtec hybrid
- Auto to manual crx....
- ZC Swap--Which ECU??
- B18C1 -> EK hatch
- what is better d15 or d16?
- USDM ITR pistions in LS motor. What Compression?
- swap ? for 90 integ
- swap help? B16a1 in a 92 civic cx?
- D16Y8 in 88-91 CRX
- Wiring Harness Questions
- jdm itr engine in a crx... Need your help on peripherals guys!
- B16a in a 91 Civic - Radiator Hose Issues?
- Swap how-to
- who has a b18c in their 6g?
- anyone with h22a civic experiance in here?
- Power steering removal:what kind of damage?
- LS/VTEC question??????
- DOHC ZC head on D15 block?
- What is a good engin to drop into a 97 civic coupe
- question about a crx head swap
- Injector questions, just need verification.
- What type of ECU to use?
- putting a b18c5 into 96 hatch, need help
- ITR trans. brace...
- ATTN: Hybrid Techs - Please help!
- Question: Turbo ZC
- CTR 5 Lug Conversion
- making a B16 into a B18
- Ls/Vtec long term use?
- is it a B18c in a 93 GSR???
- LS/Vtec with Civic Type R Pistons...need help?
- Auto to manual ecu help
- What do CRX Si's with B16a swaps run?
- LS VTEC...
- Type R Parts
- What are CTR front clips going for these days?
- What tire size for an EG civic???
- 1st Gen B16 Head
- Car found...need ideas
- Can't believe no one knows the pin out to a P13 OBDI???
- Building a Hybrid.
- p73 rods on a p72 crank
- B18B/Turbo or B18c1 NA-?
- SHOULD I BUY A MOTOR FROM EAST COAST
- b16a3 USDm into 90 Si Ef
- looking for info on 88 crx si zc and/or b16a swap
- 92-95 Civic front shock forks on a 90 CRX?
- h22 or b18c in a EG?
- need input about motor swaps in so.cal
- A/C & Engine swaps
- My car is surging, and its annoying...please help!
- How hard is it to swap heads?
- b18 Tranny
- Typical cost for GSR Swap into a 92 Hatch?
- Can anyone PLEASE email me an OBD I wire schematic.
- B16 timing belt do not fit on ls/vtec setup????
- can someone help please
- CRX dx with new zc swap, Codes 7 & 14...Suggestions???
- selling my 94 B18 Civic!
- B16A2 Or B18B
- *IDEAL* octane rating for a 10.6:1 c/r?
- does someone reputible offer prebuilt ls/vtec,crvtec motors?
- technical question;hopefully not confusing, please help.
- exhaust questions ,,please help!!
- B16 problems..
- H22 ek
- B16B pistons good enough? Maybe forged instead...
- b20 in an EG... obd I vs obd II
- New engine decision...
- JDM B16, wiring, mounts??
- ls/vtec custom built engines
- does anyone know the website that tells you how to spot real ctr/itr/b16a/b16c cams?
- b20/vtec swap
- LS, GSR Throttle cable???????????????????
- What are the steps right before the first time you start your new swap?fuel pressure,oil pressure, S
- Underdrive Pulleys on Hybrid Hatch
- anyone used del sol rear trans mount, or shift linkage in an EK???
- Honda motors online
- Ls/vtec crx
- My transmissions is stamped P16. Any honda gurus know what this is.
- EF swap ?s
- Oil leaks on B20/vtec?
- Compression ratio help, B16A + boost
- b20 me! yuPppie!
- wiring problem!! need help asap
- B16A head on GSR block? Different timing belt?
- ITR full exhaust header/cat/catback fit on a si
- What engine can I swap ito 2001 civic ex?RSX?
- Can i swap a 00' civic ex engine into an 89 integ
- 97 ITR in to 94 CX - Wiring problems.
- ADJUSTING CAMSPROCKETS ON DYNO???
- which B16A
- HYBRID
- Pictures Of My JDM H22A....CLEAN!!
- Minor oversight, need info on OBDII to OBDI conversion
- What Pistons????????
- Question on A B16 engine
- Difference between B20b And B18b?????
- What compression for lsvtec on 93 octane?
- B16 or B20/VTEC
- b20 injector flow rates!!!!!!!!!!!
- JDM B16a with LSD tranny - Good or Bad???
- ls-vtec head gasket
- Mini Me question
- need new b16a ecu for my crx
- Major help on LS/VTEC rebuild???
- Estimated 1/4 mile time????
- Need Major Help
- LS/VTEC Question
- doing a swap in a 93 civic cx
- ls/vtec wiring help
- need help with overheating problem
- What can I swap - 93 Prelude F22A
- 4000 for an engine swap?
- Boring out h22a or b18, labor?
- what to expect when starting up a rebuilt LS/VTEC motor??
- What times should I excpect??
- ls/vtec power
- prelude engine swap
- Need Assist Please Project JDM Auto:Rear tranny bracket which one?
- Compression of b16a or b18c5 pistons in a b18b?
- 91 Si IACV on a 1rst gen B16A intake mani??
- ---LOW TRAP SPEED---
- ctr cams? or skunk2 cams?
- What goes on during thr resleeving proceess?
- A swap for my car
- looking for easy swap into 89 rex si
- Cali smog question
- Where to buy shortblock?
- Adj. shift linkage
- is mini me possible on a 89 dx 1.5
- took out a/c will the fans still work properly
- Need info on head swaps
- GSR swap... HOW MUCH!
- b16 USDM
- ::O2 Sensor? [B16A]::
- throttle cable for LS swap on a '95 civic
- compression for b17a with..,
- 88-89 wires different then 90-91?
- help tranny swap
- B18C (GSR) into a 93 Civic DX hatch...what else do I need?
- B17A questions
- itr motor or build up b16a to itr specs
- dude, i'm like totally confused or something
- ARGGGGGGH!! Car stolen last night!!!
- favorite engine???
- B16A vs B16B
- H22a in a 98 Civic. Question about AC and power steering.
- good mufflers for a good price
- went to a meet and got some cool pics..
- thinkin of a project car?
- engine swaps in a crx??
- zc smogging
- ARGGG! i need help with gsr axles in a civic,help!
- B16a slugs on LS rods. . .
