View Full Version : Hybrid / Engine Swaps
- What would you do? - B18C5 in a 92 HB
- Question Re: B16 A/C Mount
- extra ose on ZC...???
- B16 cam seals
- Bigger brake master cylinder swap?
- Question on B20 swap
- Gains from increasing CR by 1.9 points...?
- has anyone ever ordered an engine from okinawaimportmotorsports?
- B18C1---->EK
- b18b boosted or b18c1
- Best axles for a B16
- differences in stock suspension
- b20/vtec vs. built b20z theory
- My fan won't come on and the engine gets really hot.
- Cat
- Need opinions about a B20 swap
- H22 into 95 CIVIC EX Coupe
- fuel setup for ls/vtec
- another honda-tech meet in southern cali
- Help on a swap having big problems
- Civic with B18C5 OBD2 to OBD1?
- ZC engine owners
- buying a helms manual.....but some questions first
- B16a Gaskets and seals?
- b20 ? need help asap
- jspec engines
- crate motors
- where can i get a reliable built LS Vtec from?
- compression of b16 w itr pistons?
- b18c1 in a 2nd gen teg
- s20
- To those with obd2 engines in an EG
- Swap Sites
- ZC vs. B16 (1st gen)
- JDM B16A TB gasket - which one works? n/m
- B16 install question (i know, I know)...
- wiring to ecu...
- if you have swaped a b16a2 to a 96-98 hb please reply
- I still don't have vtec GOT RICE!
- Is a B16A1 automatic slower or less powerful than a manual?
- b18b time slips? quarter mile, what are you guys running with i-h-e?
- Vtec Head on non vtec block without hooking up the vtec
- Any webpages that would help with Auto to Manual swap?
- JDM ITR in a 93 Civic Si?
- Help on a B16A mounts
- hybrid trans question ;)
- any one done an auto to manual?
- questions on LS/Vtec
- 99+ GSR wheels/tires for sale
- ITR Swap Question...
- b18c1 in 4th gen hatch question..
- new to honda-tech
- JDM B20B gurus?!?! help with block identity...
- to those who have an ITR mc/booster in a 5th gen civic...
- b18c1 vs. b16 (si) transmission
- My b16 wont start. Need some advice..bad.
- Stage 4 Gen III Turbo Kit B18 RS/LS/GS...
- where to get swap
- B20 Help!
- Compresion on B-Series...
- which throttle cable do i need?
- ls/vtec, which headstuds
- first or second gen B16
- What do I need to fit a b20 into a 91'si???
- HELP! no spark no fuel.
- anyone have drag gen3 kit on a b16a crx
- B16 clutch setup
- best price for engine swaps
- sr20det into 95 civic coupe
- Engine swap woes: all help appreciated.
- pin assignments for h22 p13 ecm
- help w/ wiring
- who has the CRAZIEST hybrid setup?
- My Hybrid / Honda-Tech meet photos:
- HElp, will it work?
- Does this mean my GSR engine is from a 94 Integra???? or was it just made in 94.
- b16a2 (92-95sir) v.s b18c /sorry so long/
- mugen chipped ecu?
- WHAT WOULD YOU GET WHILE IN JAPAN
- 94 DX b16a swap info
- Can anybody here vouch for Greg Baird in NC?
- questions, questions. 93 ls motor> 93 civic, pedals, speedo cable, wiring?
- EF b16a to crvtec, cost, fitment, etc...
- tanabe hyper super medalion
- B18cR in an EG:How fast?
- what kind transmission does a 92 dx hatch have?
- B16A swap into my 95 civic
- Knocking on startup
- can I have a 13sec car??
- 92CX - B18C1 - which AEM CAI to buy?
- 93 B18B in 93 hatch
- S1 Cable tranny problem... PLEASE HELP
- 92 CX with B16a o2 question
- B18C1 - 93CX swap - O2 sensor question
- b18a1 wiring problems -=(
- rear brake conversion?
- ac in a b20 hatch
- what will happen if I retard timing all the way?
- '00 si motor swap to a '92 cx hatch
- Gsr engine into a 92 hatch, got the install down....now what?
- b18a1 Crank in b16a1 block??
- dx to zc wiring problems help anyone
- vtec pin out for a 92 hatch?
- My VTEC wont kick in
- b16 pistons in a ls-vtec
- B16 Swap
- where can i find a LS cable tranny????
- Question about the B20 ???
- Some Pics of my Hatch
- GSR motor is ready to be installed=)
- Mini Me parts list
- Ok I missed out on the gsr at the auction but I got some other questions
- Can a B18c1 hatch go 12s
- B series Logo?
- what cams are you crvtec guys using?
- Help on a EK swap!!!
- VTEC? I thought you said VTEN!!!
- crvtec in a 93 ex coupe what 1/4 mile times
- got my jdm b20 today
- Help w 92 hatch
- Who makes 2.5 exhaust systems for 92 hb?
- throttle cable bracket for b16a in 5th gen civic
- b16 in 88crx si swap questions
- who here is done a mini me swap?
- 95 coupe..GSR Hybrid What cams to use?????????
- H22 sensors
- Hybrid CRV out there???
- Canadian GSR/Type R swap sources
- 93 GRS cable tranny Q.
- 92 B18A in a 94 Civic Hatch
- FS: 91 Civic Si B18A1 T3/T4
- Question about 555's, going to E-Town on Sunday.
- what's the bore on a 1995 B18 Motor? And what's bore on a b20b?
- B18C1 or B20VTEC
- To TPS or not to TPS, that is the question.
- 93 civic radiator handle stock ls motor?
- 97 VTEC Sol into 96 DX Hatch
- Type-r head in a 92 integra gsr ... question?
- Check out my friands jdm auctions
- lookin for a 96 up hatch
- Arias or JE Pistons for B20/Vtec?
- will i win or not???
- shift linkages problem
- B16A1 Cable trannys
- Shifter Linkage
- All I want for my B-day is a 14 sec timeslip!
- Which Helms manual for b20vtec?
- IAB -B18C1- Wiring
- ITR cat
- Coming up engine Swap
- anyone know how to hook up egr on h22 in a ej-eg???
- A complete swap comes with a header?
- a queation about headwork..
- H22 into DC chassis
- b16 valvesprings?
- Swap ?s
- USDM b18b into a crx
- U.S. b18c1 96 coupe
- USDM GSR engine + 99 Ek hatchback = swap questions
- jdm b16 codes?
- Which Intake?
- Would a b16a fit 97 civic cx hatchback???????????
- b18a swap in 1990 civic dx
- Help???Where to find info on swapping a USDM Type-R(B18C5) motor into a 98 dx hatch
- 98 H22 into a 96 Accord LX?
- B18C in a non-vtec Integra.. questions..
- both jdm b20b's on the way both motors pulled
- engine stand people
- p28 and mugen chip install question....
- Oil sending unit dimensions (thread pitch and diameter)
- :::HONDA-TECH BBQ IN VA:::
- Who makes Aftermarket rods for B20's ?
- GSR MOTOR
- B18C5 or H22a?
- Knock sensor placement LS/VTEC
- Best swap for 1993 Civic?
- Here's a tough one: B18c1 in 98 EX auto
- best cams and gears for a b18b hatch?
- Whats the difference between USDM and JDM?
- '00 gsr swap into a '95 civic with obd1 gsr ecu...some questions
- still looking for answer about that thing on top of the '00 gsr intake manifold...
- Looking for good info on mount kit for 5G Civic and H22A...
- LS/VTEC questions
- Need 4th gen axle help...
- Civic/h22a shifter cable setup
- help b16 question
- How difficult: b20z w/GSR tranny in 88-91 civic hatch?
- h22a in 91civic hatch question..
- What Parts ?
- New here, what car?
- itr speedo cluster in a 99 civic dx?
- what sensors should be on my ls block?
- hey guys I'm still a little confused ........................got rice
- I'm f-d up, there is no electrical power . .
- B16A1 wiring question
- Hybrid JRSC
- 94 civic ex head into 96 dx
- b20vtec 12:1 comp tech q's
- What to do with the tranny?
- f22 VS f20c
- knocking and burning oil, is this normal?
- IS there an OBD3 what year its it??
- looking got b16a1 swap in va/dc/md
- Can the K20 motor be swapped in the 2001+ Civics?
- HELP.. a fellow hybrid out , TECH related
- High mileage B18c w/bad tranny project....
- B18C in EK mount question
- b20vtec + eagle rods = rod bearings?
- HCP EF18 bolt-in kit or Hasports kit ?
- LS/VTEC or B20/VTEC
- Exhaust ?'s
- intake manifold problem, intake manifold leak
- New HCP B-series stock replacement mounts
- JDM B16 SIR II to Del Sol
- b18c1 into 93 cx
- OBD 1 Motor into OBD 2 Car...
- What wires do i need to run for obd2 ver 2 to obd2 ver1?
- What is the best engine to boost...b18c1 or b18b??
- H22A1 install - what error codes can I expect?
- Help with z6 swap into a 91 civic
- Please Help...
- b20vtec ?????
- 88 CRX HF to D16Z6 non-OBD to OBD1 Harness
- Wiring Vtec into a Non-Vtec Teg
- A1 trans out of usdm 91 integra...gear ratios anyone?
- throttle body
- need help on ecu options/decisions
- Interior wiring question about EG/DC2
- B16a1 into a 95cx
- What axles for a h22 in 5 gen?
- swapping a b16a2 for a b18c6 in my eg6...ive got the engine but now search wont work
- need tranny help!!! quick question
- which head gasket should I use for my B20/vtec?
- 7th Gen Civic...what choices are there?
- H22a automatic into 2000 civic 4 door?
- diff. between b16a cable lsd tranny and a hydro lsd tranny.
- Is it difficult to swap in an OBD-1 motor into an OBD-II car?
- Cracked clutch line???
- b18c1 ------> 92 vx hatch. I seached. Give some advice. Throtle cable bracket
- swap in va
- difference between 89 clutch and b16 clutch
- has anyone had their wiring harness modified by place racing?
- Jdm GSR into Usdm LS
- what is this on my tranny?
- MY PROJECT BEGINS....NEED INFO ON AXLES AND ANY OTHER INPUT U CAN GIVE.(H22 INTO 6TH GEN ACCORD)
- Vtec engine into 92 integra rs- ecu and wire harness?
- muffler w/ 2.5" opening
- b16a1 tranny?
- my motor is out started pulling my freinds motor which do u think will be easier
