PDA
View Full Version : Hybrid / Engine Swaps
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 [67] 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174
  1. Motor Swap time..
  2. b16b into 94 eg WIRING QUESTION (I DONT NEED TO PASS BAR!!!)
  3. b18b swap into 92-95 civic
  4. just swapped shift linkage problem
  5. Which motor mounts
  6. B20 daily driver
  7. Need help with poor mans r setup!!
  8. PLEASE HELP: LAST ENGINE CODE
  9. b16a1 head prices
  10. LS/Vtec in 99 Teg -- Now Power Steering doesn't fit?
  11. are the ls/vtec conversion kits legit?
  12. which obd conv. harness for 00 si motor in 93 eg???
  13. H23 with a F22 Tranny??????
  14. Type r swap help.
  15. d16z6 transmission on a b18b?
  16. F22B SOHC head swap for F22B DOHC or full engine swap.
  17. Mini Me / Intake Mani / Throttle Body ?s
  18. Mini Me Swap / Block Guard?
  19. Engine swap question please help
  20. making conversion harness?
  21. LS/VTEC which is better LS Pistons/rods or GSR pistons/rods
  22. B16 in EF<almost runs
  23. hasport mount inserts?
  24. Need Help With B16a1 swap Into A CRX HF!!!
  25. b20 idle problem
  26. insurance for your hybrid
  27. Timing belt change required?
  28. Help after Swap: No VTEC ---> CEL Code 21
  29. 95 civic
  30. CEL on NEW LSVTEC??? Sensor on TB???
  31. Help After swap No CEL at ALL and no fuel
  32. WTB(BORROW) P28 WITH H22 PROGRAM IN SO CAL...
  33. K20 in ES??
  34. cel confusion
  35. Hybrid VTEC Question
  36. B20 long block into my 92 DA to beat ITR, is it worth it? Will it be a lot faster?
  37. quality of mounts question
  38. Need help with b18b/ef swap
  39. good breakin oil
  40. What would you pay...eg hatch with h22 swap?
  41. JDM b16 wont start just backfire
  42. lots of h22 problems??
  43. LS VTEC Dowel Pins dont fit!!!! Please help!
  44. b20 ek doesn't crank, main relay doesn't click, check engine doesn't come on.
  45. vtec feels weak? b18c1 swap in 95 ex
  46. 1000cc RC's and resistor box....
  47. GSR crank into b16 block
  48. I need some confirmation...
  49. Goin to the Ref soon, any tips? (00 H22A4 swap in a 97 Acura CL)
  50. ECU Wiring H22/Civic [Pls guys..]
  51. Slicks&Tricks 1season Draging H22/Civic
  52. The ultimate Honda hybrid....
  53. gsr or h22 swap in my 94 coupe
  54. CRX Header?
  55. H22A1 head OBD 97+ H22 head
  56. eg h22 dynoed today
  57. LsVtec 2marrow, Do I have everything I need?
  58. mating gsr head with b16 block
  59. Injectors 2 and 4 not oworking after swap/MPFI ...Need help...
  60. hesitating problems when hot
  61. help with tranny. *pic*
  62. anyone tried this
  63. Aftermarket pistons in Minime
  64. LS/Vtec With the pr3???
  65. D16a6 Head Aem cam gear, D16y7 block
  66. Is this OBD0 2 OBD2b correct?
  67. Alternator problems in B16 CRX
  68. Hybrid distributor Question
  69. Quick Alternator Q
  70. a6 transmission into a b7
  71. OBD1 jdm b16a into 97 dx Hatchback.. double check my work here guys (wiring)
  72. b series swap where do the hoses go??
  73. K20a install video in EG, 200MB
  74. H23a1 ecu in a F22a1
  75. Axle poping out frequently
  76. LS harness in 91 DX??
  77. DOES HONDATA REALLY WORK??????????
  78. ECU codes?
  79. hesitation under light acceleration on my CR/VTEC swap...can't figure it out
  80. CEL 70? it doesn't exist!
  81. the differences between 94-97 and 98-01 LS headers?
  82. Need a ECU Pinout for JDM H22a
  83. have 91 teg motor want to put in 90 crx dx what i need?
  84. 97 cl suspension swap
  85. Broken older hasport mounts
  86. obd2 b16 into si delsol....help!!!!
  87. jdm h22 engine vin starts with a 3??.....
  88. jdm h22 cap and rotor......
  89. F20C in 1950 Willys Jeepster. Neo-Rod
  90. H22 Euro Accord Type-R intake manifold
  91. h22a4 in a EG hatch...injector & fuel pump question
  92. Compatible IACV for OBD1 B16A ?
  93. will a 93 Integra mount fit a 93 civic with a b series?
  94. swap the LSD from jdm AUTO trans ??
  95. B18C swap Cat question??
  96. Anyone with the AEM Hybrid Intake?
  97. which headgasket and t-belt? b18c1 block, pr3 b17 head
  98. s2k swap?
  99. Blasphemous Hybrid project.....
  100. K20A swap questions...
  101. DC 4-1 and cat?
  102. 99 gsr into a 97 dx civic
  103. this may be old K series new but..
  104. what parts to ask for with my jdmb16????
  105. timing belt on my b16 loose????
  106. Problems using FPR from d16 on a B16?
  107. b16a2 into a 92 cx
  108. ???garbage motor???
  109. k24 block w k20a2 head in eg hatch?
  110. OBD0/OBD1 conversion-Alternator problem
  111. just crashed my 92 eg hb with h22a4 and need some help
  112. Which Omni testpipe will fit my header ? *already searched*
  113. k20a2 crx
  114. gsr swap in rs integra.
  115. del sol swap?? question
  116. B18c1 SWAP INTO A EK HB..HELP!!!
  117. 6th gen w/ full front & rear GS-R brake swap
  118. Doing H22a swap into 98 Teg... problems with the axles!!!
  119. K- series in my Accord?
  120. B16A CEL question....Thanks in advance for your help
  121. need motor mounts for 96 b18b swap
  122. catalytic converter for b18c swap?
  123. Pls help me with my car......!
  124. Considering Swapping to B18C1/B18C5 in EK! ADVICE!
  125. h22 swap help
  126. Shift linkage too long ? JDM B16A in 92 Si
  127. CRVTEC - opinions for fuel setups please!
  128. h22a1 & H22a4
  129. HELP ME!!! Timing Problem!!!! B18C swap in 98 Civic EX
  130. K20 EG Timeline. Step by Step progress of the swap
  131. honda miata???
  132. HELP PLEASE...
  133. PLZ help me
  134. ek DX brake upgrade?????'s
  135. Ls Vtec Timing Belt Question
  136. anyone know which model AEM Cold Air........
  137. ZC sohc in 99 civic
  138. question about knock sensor newbie
  139. Which harness do I use?
  140. idle sits at 1500-2000 rpm's with a H22a in my EK??
  141. h22 in a eg "JDM Head lights"??
  142. Help me out guys
  143. ARP Head studs/bolt help
  144. TYPE-R TRANNY WITH H22 ENGINE?
  145. specific swap question with specific problem(b18a/90civic)
  146. HELP NOW!!!! Need pic of Del Sol VTEC shift linkage......i think I was given the wrong one
  147. IF no one can help me i'm selling the car i can not take it anymore please atlest read and try to he
  148. What are these codes?
  149. ECU wiring question
  150. gas coming out of exhaust......
  151. Engines?
  152. bored 2.0l b18 ls block vS. b20 block
  153. car died twice on the way to work this morning...no CEL...plz help!
  154. B16 swap
  155. h22 EG hatch guys..what size 15" tires are you running?
  156. b18b into 93 civic hatch dx axles questions?
  157. hybrid exhaust question
  158. Stupid questions deserve stupid answers
  159. Stainless Braided Clutch Line, Fittings and Sizes, Damper
  160. Type-R Transfer
  161. B16a into CRX vtec problem!
  162. B20/Vtec swap questions
  163. just started car, stalls after I give it gas. please help!
  164. Hasport EGH2 Mounts
  165. K20 drop in a 2000 Civic. . . with a/c?
  166. Which Combination?
  167. Specific swap. B18C1 into stock 94 Civic DX.
  168. anybody know a site for information on an h22a swap into an integra....
  169. H22A1 in EG with 2.5" kteller exhaust, popping/crackle noise??
  170. H22a Engine Question
  171. H23 Throttle body on a D-series?? will it work???
  172. Is my ECU Chipped??
  173. Swap Preparation
  174. did i pick the right swap?
  175. H22A oil pan
  176. B16 SIR II in a EJ1
  177. HELP......Ecu wires cut.....
  178. what size punch
  179. fuel pressur b20vtec
  180. eg h22 engine mounts
  181. h22A-F20B EG-OR EK.....WHICH STOCFK AXLES WITH WHAT INT MED SHAFT?
  182. Hatch with swap - Exhaust question
  183. h23 block h22 internals ??
  184. sohc knock sensor on ls/vtec ?
  185. 3 wires to 2 wires iacv conversion
  186. K20A Engine Dimensions
  187. Best Frankenstein Setup For My EF?
  188. quick axle question
  189. NOS ? on sleeved LS vtec, forged internals
  190. B16 tranny into GSR Teg...
  191. cel 14
  192. sorry guys, but more swap issues
  193. ecu jumper adapter
  194. so i just changed out my spark plugs and now my car has no power
  195. jdm b18c throttle body???
  196. b18a mount question
  197. Fitting LS Dizzy on Ls/Vtec? How to:
  198. H22 - EG - passed emissions
  199. ADDING ABS SYSTEM to DX/VX/CX 94 hatch
  200. anyone have pics of the ac in a civic w/h22a or info on what to use?
  201. Will GSR Distributor work on an obd0 b16?
  202. ls/vtech
  203. Need Help!! NO VTEC after swap
  204. b16a2 in a 92-95 civic coupe..... mount questions
  205. AC in a civic w/h22a question
  206. b18b civic swap? which year
  207. Quick motor mount question......
  208. b18b civic swap
  209. sohc vtec d16 into 85 civic sedan
  210. 4 Peeps w/H22 civic swap
  211. cost and info for k series swap to an eg
  212. h22a into an accord.
  213. B18C1 engine removal tips
  214. K20 swap in a EG help NEEDED!
  215. no check engine light
  216. O2 Sensor CEL and Knock Sensor Code on GSR Swap
  217. Chipped P28, unknown program .. help!
  218. SHould I trade my B16a for a B18b??
  219. 90-93 Accord Intermidate shaft, w/ 86-89 teg axles
  220. CRX with LS swap pulling code 14
  221. H22a in Eg help
  222. code 7 on ecu
  223. B18B LS engine into 95 Del Sol...Need Help!
  224. DIY b18b into 96 civic
  225. 01 rear crv bracket work in a 97 ej6 motor swap.
  226. Anyone know Georgia Law?
  227. GSR swap price quote
  228. h22 engine code help.....
  229. GSR swap price quote
  230. Which ecu for h22 crx?
  231. JDM B16A question...Vtec Oil Pressure Sensor...I'm confused
  232. lsvtec with stock wiring harness
  233. CIVIC EK---jdm b16a3---OBD1
  234. b series axle problems!!!! HELP!!!!
  235. OBD2a LS Dizzy on LS/VTEC? Possible?
  236. ef hatch ??? exhaust
  237. gsr oil pump for b20 vtec
  238. k20 swap in ek need help please
  239. Y8 tanny w/ B16 gears???? possable
  240. Intake manifold brace thing on ITR/CTR?
  241. p54 a/c tension wheel
  242. help asap. swap back to sohc
  243. CEL light on with jdm swap...
  244. Harness Pins and Connectors
  245. Cost to put a clutch in....?
  246. LS VTEC TURBO
  247. sick of the D15..So....
  248. help me please...b16 trouble
  249. what do i look for?
  250. LS/VTEC WIRING/ECU QUESTION --------- Please Help
