PDA
View Full Version : Hybrid / Engine Swaps
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 [173] 174
  1. anyone know how much a gsr engine weighs?
  2. H22a need help with shift linkages pls pls pls!!!!!
  3. where to get...
  4. b18b into 90 CRX
  5. 94-95 integra cluster swap from 93 civic dash harness.
  6. B16 head on a GSR block????
  7. B16A into a 86 CRX HF?
  8. Accord LX - H22 Swap.
  9. how good is it
  10. Track day at SIR(Seattle)
  11. fork Engine's
  12. which timing belt?
  13. CRVTEC or ITR???
  14. Calling all HYBRID b16a's with a 90-91 crx si........
  15. 3.2 Legend Motor in a kit car!
  16. Which dist. to use on a b16a
  17. ls/vtec in a 1st gen with teg swap
  18. Z10 radius arms fro EG's!!
  19. Gen 1 B16 distributor with 00 ITR head?
  20. Will this work: exhaust
  21. Now this IS irony, read please?
  22. Complete JDM swaps!!!
  23. Need help w/ Suspension (bushing) problem
  24. 00 Hatch w/ 97 B18C1 wiring q's...please help me...damn I sound desperate.
  25. Pics of my hatcs....
  26. Looking for a reliable source for a 96 or newer b18c motor and tranny to do a full swap
  27. JDM motors Q
  28. Want the real deal !!!!!!
  29. short shifter question
  30. ls/vtec owners? Tranny ques.?
  31. CRX Gauge Cluster
  32. HCP Mounts any opinions
  33. 92-95 Civic Si/Ex Manual Tranny
  34. What now?
  35. Crower cams vs stock cams dyno comparrisons
  36. Integra or Civic Parts?
  37. B16A valve adjustment
  38. Calling all Canadians
  39. GSR Head with B16A2 Block
  40. spoon engines
  41. question about GSR AEM CAI fitting onto my stock DX motor
  42. Will 99Si oem intake box fit a 92-95civic w/ b16???
  43. Type-R Clutch in a LS Tranny?
  44. Accord Type R
  45. Will Del Sol VTEC Radiator fit 92-95 hybrid hatch?
  46. My 97 Civic Gsr at Napierville Dragway in Montreal Canada (movie & Pics)
  47. HONDATA USERS
  48. Shorty intake
  49. Dyno'd the B20Z w/ Crower cams! Wow!
  50. B20/vtec no fuel problem
  51. which ITR bits fit a civic hatch 92-95
  52. 92-95 civic couple w/ gsr motor = 1/4 time??
  53. 1/4 times for 4dr civic hybrid
  54. B16 swap
  55. RPM activated switch?
  56. H22A in 2G 1993 Acura Integra GS
  57. Best suspension on EG B18C hybrid.
  58. ENGINE SWAP SHOPS IN THE SOUTHEAST????
  59. h22 in del sol
  60. Is endyn a real shop?
  61. Need help with Unorthodox pulley for LS/VTEC
  62. Need serious help with my gsr engine.
  63. JDM spec type-R motors, how have some of you built them (staying all motor)
  64. engine stalls...
  65. 92-95 Civic Weight
  66. The Legend lives on...
  67. Needed: 88-91 CRX Si camshaft in good condition
  68. fuse 24, vehicle speed sensor circuit
  69. H22A in 99 4door civic???
  70. CLICK TO YOUR FAVORITE HONDA ENGINE SWAP.
  71. fuel injectors!
  72. b16a head for a ls/vtec?
  73. Rear shocks/ disc converson question
  74. HELP: 4G Civic -> B18 C1
  75. How can I ..
  76. This a good deal? swap in a 95 civic cx an H22?
  77. how much do places usually charge for labor?
  78. H22 civic idle/tuning question....
  79. Car Puffing blue smoke... help me out please
  80. Intake problems.........
  81. Swap Help....Questions
  82. how much for ls/vtec head and how fast in a 92 hatch?
  83. Code 13? Can anyone shed some light?
  84. stupid question.... can i check to see if my engine is throwing codes?
  85. MOTOR PRICES?
  86. B20 questions
  87. Another Idle question-give me somewhere to start
  88. Going B16-90'STD hatchback
  89. Taking a step soon, need advice....
  90. are these tranny's different?
  91. Code 41 fixed: Now I got code 1!!!
  92. brake swap 5 gen civic
  93. i need a new oilpan for my jdm b16a..what can i use
  94. Has anyone dropped a B16 into a Del Sol?
  95. Hybrid candidate...my dad's '90 CRX HF (pic)
  96. help me with my b16 swap
  97. B&M FPR Problems
  98. GS-R to Type R Conversion
  99. H22 in a civic with Hasport mounts?
  100. Where to get wheels powdercoated in VA/DC/Md area?
  101. ENGINE WIRING HARNESS
  102. Looking for a pre wired harness for a jdm b16a swap into 91 crx si..................
  103. 2 B16 (1st Gen.) forsale.
  104. b20 swap into 98 EX
  105. B20 vtec in a lude need help with distrbutor wiring
  106. Front main seal for a ZC
  107. speed garage?
  108. NOS quesiton??
  109. Which VTEC Head is best used for a B20 CRV block?
  110. takening suggestions, $4500 and an 96 civic hatch. What engine with what parts for it
  111. Pistion replacment
  112. Advice and stuff Need for b18c swap into my 5gen ex coupe....
  113. zc swap into 89 civic lx sedan, can i keep my auto?
  114. JDM Emissions
  115. Help with B16A swap into a CRX dx
  116. Code 4 on EF B16????
  117. Thoughts on ZC swap into a '90 CRX HF...
  118. B20 with B17A crank
  119. Linkage help?
  120. ECU Install
  121. Need info on swapping heads
  122. Possible intake manifold leak ?
  123. JDM engines able to pass emissions test?
  124. Worth it ??
  125. Need info for future Hybrid
  126. What should this car be runnning in the 1/4 mile?
  127. B18A Differences?
  128. SOHC VTEC in 2g crx si.....
  129. d16z6 engine swap
  130. Need STOCK D16 VTEC.
  131. B16a into 4G Civic 4 Door, Watch Out For X-member Header Clearance
  132. code 15 ign sig output
  133. ctr pistons on a gsr block???
  134. b17 w/ crx si harness?
  135. prelude spindles(hub) for EG???
  136. Where;s the PCV valve on a b16a2?
  137. Attn Big James: H22 Accord swap
  138. obd2 engine in obd1 car
  139. Everybody Post Pics of thier Hybrid....wanna see everybodies ride :-)
  140. LS/VTEC reliability
  141. G2 integra with vtec
  142. To turbo or not to turbo...that is the question.
  143. Can u put a H22 in a 95 hatch?
  144. L@@K-B18C in a VX Hatch
  145. Starting 92 Civic CX HB ITR Conversion - checklist?
  146. will this intermediate shaft work???? HELP
  147. Good or Bad???
  148. question on CRVtec swap
  149. My hybrid lives!!!!
  150. Best gear oil for 5 speeds?
  151. F/S: All JDM Engines Starting at $1200+
  152. GSR rear brake swap conversion (what's all needed)?
  153. Can I start car without one axel?
  154. Any one have video clips of moded hybrids?
  155. H22 swap legal?
  156. Engine swap question for experts who have done it.
  157. fastest "mini me"
  158. swap question? please help
  159. What clutch should I get for B16 Swap
  160. Wiring for 95 b18c1 into a Japanese mf'd 92 dx??
  161. CRV/B17 or B18C/B17???....HELP!!!
  162. Finally hit 13 sec., need some analysis...
  163. Can't Remove Axles...What am I doing Wrong?
  164. Catch 22...Reliability VS Performance
  165. what pistons to use for a gsr?
  166. what should i expect to pay for b18b?
  167. GSR swaybar on 5G hatch.
  168. Engine Swap
  169. B20b into a 93 integra ls... will it fit?
  170. HELP, Burning Oil
  171. 2000 LX to 94 EX keep VTEC
  172. rules of thumb? 6g d16y nonvtec into 5g d16z vtec
  173. hybrid suspension Q's
  174. Places to get engine?
  175. JDM B16A timing belt...
  176. VTEC Engagement Point
  177. Intake manifold questions....
  178. Evap Perge Solinoid
  179. emissions?????
  180. B18C1 Motor???
  181. swap or ls/vtec?
  182. Skunk two Racing Vtec ECU?
  183. Dumb Question: Are there center caps for Racing Hart CP035 Wheels?
  184. Fuel Pump
  185. WTF??? Shouldn't I throw a code with O2 sensors not hooked up?
  186. Swap or what?
  187. HYBRIDS FOR SALE?
  188. need help finding right intermediate shafts
  189. LS/VTEC + stateREF= no good?
  190. Which engine should I put in which car? Help me decide!
  191. I have an LS in a Hatch but. . . . . ?
  192. Tranny conversion, how much and what parts?
  193. Will my b16 gain from GSR cams?
  194. should i do this trade?
  195. which is better.....
  196. ANYONE IN HERE LIVE IN NC?
  197. 91Si h\b with a sohc Vtec problem....help
  198. Driveshaft set rings??? Replace?
  199. need thought on what to lower my car with
  200. d series alternator on zc?
  201. going hybrid!
  202. Block questions
  203. g2, 91/93 integra owners / Ecu help, im stumped
  204. I need cam gears!
  205. Anyone with a B-series in a 88-91 EF?
  206. Problem w\ My Civic
  207. To B16A owners...
  208. Need LS/Vtec advice
  209. OT: yo SLOPOKE.........
  210. Finally got the new pistons & rings in. Here's the C/R report.
  211. B18B into 91 CRX Si
  212. highway is abusing the motor, high rpms..help!!
  213. does this sound like a good setup?
  214. b16a2 or h22a?
  215. Civic/GSR hybrid complete :)
  216. ECU code 15... help...
  217. how hard is it to fit a 2.2 vtec into a civic
  218. b16a pistons possibilities
  219. What route...
  220. distributer problem.help.help
  221. how to install a zc into a 91crxsi
  222. CRVTEC or GSR?????
  223. Finished B16a1 swap into CRX, now Vibration problems
  224. b16a header setup for b16a into 88-91
  225. HYBRID Project Completed !!!!
  226. Need opinions...B20Z or B16 into 88HF?
  227. Anyone here actually swap a b16a into 91 crx si???
  228. engine swap - HELP!
  229. Does anybody know...
  230. ss hardlines
  231. What are these hoses????????
  232. FI or NA.......that IS the question
  233. EG B18C1 hybrid hbs...please list your setups and 1/4 mile times (MPH also)
  234. ls, b16a, or ls/vtec? which one?
  235. which axles for a cable LS tranny in EG?
  236. Looking for a Civic for sale in Tampa area please help
  237. swap or supercharge???...that is the question!
  238. wiring harnesses available
  239. mini me d16a6 -> sohc vtec (head swap), need help with parts checklist
  240. mini me
  241. B20Z dyno - 168 HP and 159 TQ at the flywheel
  242. Thinking of going CRX/Hybrid from Integra.....help!??!
  243. Is this bad?
  244. dx shift linkage works with a b series motor?
  245. Where can I find the del sol VTEC radiator?
  246. Will B16A1 (cable tranny) bolt up to a b16a3 tranny?
  247. B18 series hybrid w/ Turbo
  248. Eventually moving from STR to SM with a motor swap... preliminary questions...
  249. do i need a new fuel pump?
  250. wiring for a 94 civic b16a
