PDA
View Full Version : Hybrid / Engine Swaps
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 [142] 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174
  1. No reverse
  2. power steering for b18c1
  3. H22 weight issues
  4. 6th gen accord swap
  5. Rewiring CKF
  6. DX to SI Swap
  7. b20vtec???
  8. My stock B20b dyno
  9. h22s getting smoked?
  10. Why are GSR O2 sensors so expensive $160 from PEP boys. My old dx engine.....
  11. can a 4wire o2 replace 2 2wire o2s
  12. 1/4 time
  13. 98 JDM ITR swap into a 93 CX..
  14. ef h22 engine conversion
  15. Pros And Cons Of V8 Swap? Any comments?
  16. whats the factory v-tec crossover for the b16a sirII?
  17. LSD ? please help
  18. Need help with b16 oil leak (already) :(
  19. which axel works?
  20. Will this tranny work???
  21. Difference between D15 and D16 mounts?
  22. Putting a p28 in my '00 Si...
  23. 92 Civic H/B swap...
  24. Spoon Sports coilovers
  25. Do i need a wireing harness or can I use my stock one??
  26. gsr rear brake conversion
  27. wiring secondaries
  28. 02 Si Seats
  29. Harness swappage issues..
  30. ITR ignition in LS..
  31. What other parts are needed for an ls/vtec???
  32. senser help
  33. What is this?
  34. Which V-tec cams are better??
  35. Yes an Actual SIR linkage will work with Hasport mounts in a crx!
  36. b16a1 into a 90 dx..mounting question...
  37. Anyone looking for JDM ITR or CTR Crate Engines at a Good Price.....
  38. how is your CRVTEC holding up?
  39. H22ers axles?
  40. hybrid axle question
  41. B16a vtec selonoid
  42. VSS on the tranny...
  43. whats the best pulley to use...
  44. vtec code 21
  45. ECU question
  46. b20Vtec questions
  47. finally getting a swap. but there are questions i need to ask.
  48. Where to lift a b18c1
  49. Where did u guys get your ls/vtec engines done???
  50. Funny, but annoying... Why is my car only fast sometimes?
  51. 95 Hatch w/B16 Si motor/GSR computer??
  52. aeWhat spark plug for my B18C1
  53. Can my B18c1 Make LS/Vtec Power?
  54. Buying new engine.
  55. LS/VTEC Head Gaskets. B18/B20 same or diff.?
  56. new pics of new hybrid
  57. h23 ->h22 thermo...
  58. beaks subframe kit for EK
  59. b16a head, gsr block, any obd conflicts?
  60. Help needed for a B18A swap into a 2000 Civic hatch
  61. VX water pump 92 + EX Timing belt 96 (?) -- for MINI-Me swap? (HELP!)
  62. h22a idle
  63. (hopefully)Eg hatch which motor?
  64. JDM B18C1 in a 92 EG Hatch... wiring harness question?
  65. Pics of InfamousRS's B20Vtec install....:)
  66. Quick crossmember question.
  67. Difference in 98+ JDM ITR motors?
  68. how's this for an idea?
  69. ECU Code?
  70. Rough idle problems?????
  71. How'd you wire your JDM motor?
  72. B18A1 OBD0 into 93 Civic (OBd1)
  73. si wiring harness for a civic jdb b18c r swap?
  74. Overheating going uphill on freeway...
  75. 1991 accord swap options.......help me out
  76. automatic zc ?
  77. HELP need shift linkage
  78. Q about 'low mileage' JDM motors....
  79. B18C GSR Engine in an Automatic?
  80. why are jdm motors less expesnsive then usdm motors?
  81. anyone purchased a b18c5 from honda motors online?
  82. ECU Recommendations.-
  83. Passanger Side engine mounting points in a EK-H22?
  84. Wiring Harness???
  85. P75 ECU SUCK Major A55..........
  86. Code 21 V-TECH
  87. D16z6 wiring - HELP... QUICK!
  88. zc swap help!!!
  89. Question for those using chipped p28 on cable tranny quipped cars
  90. wiring obd1 in a 4th gen
  91. Swap Pics h22a
  92. won't idel at 2000 rpm's at all. raises and drops if I try to idel around there.
  93. b18C5 into a EK whats needed........??? searched = 0
  94. Exhaust fitment on 92 hybrid
  95. gsr TB on 1st gen B16A intake?
  96. B18B in '86 Accord
  97. Hondazvic!!!!!!!!
  98. h22a civic
  99. ecu question
  100. Someone tell me what starter this is from...
  101. What are these two brackets?
  102. y8 head on y7 block or dohc zc? advise!!!!!
  103. P28 auto to manual
  104. Please Help!!!!!!!!
  105. o2 senser help
  106. can somebody gave me a complete parts list for a h22 swap into a dx eg?
  107. Spark Plugs
  108. b20 INTO 90civic what ac braket?
  109. Rear motor mount question
  110. Difference in cable tranny's
  111. questions on my next step
  112. Which water pump/timing belt for mini-me swap?
  113. b16a overheating???
  114. pr3 ecu needed like yesterday!
  115. 6th gen EX vs HX wiring harness question
  116. trying to install skunk2 manifold..
  117. H22 Crank bolt removal tool to change the timing belt?? Any way around that?
  118. V-AFC wiring q
  119. What does an EG with a B16 an I/H/E run?
  120. CTR pistons in a B16a?
  121. 98 Prelude type s tranny in civic
  122. Code 41...H22 not starting...HELP!!!!
  123. h22 in 96EK shifter question......
  124. H22 EG need help
  125. H22 EK-- to EGR or NOT to EGR?
  126. So many swap choices! ! ! ! !
  127. Looking for a Website
  128. H22a Manifold
  129. ECU Codes
  130. anyone have a AEM type r CAI on b16 ef?
  131. donor body for CRX hybrid racecar
  132. complete 2001 B16 from a wreck into a 94 hatch.
  133. H22a reliable enough?
  134. Crx hf swap info, really need help big problem
  135. diagram needed
  136. going b18b into an 88 crx hf
  137. Need Help Quick with HMO
  138. JDM H22a MYSTERY SOLENOID! Please help.. pix
  139. GSR dash in a CX . . .
  140. Anybody know anything about swapping a JDM D15b
  141. wher he best place to buy a B series motor from?
  142. B16A2 SIR2 question
  143. JDM ITR B18C Swap into 98 Integra LS
  144. ITR exhaust on an EK?
  145. VTEC wiring.......
  146. Update pics of h22a swap and interior work..
  147. H22 swap...NO SPARK!!!! Everyone help!!!
  148. Looking for stock (or near stock) dyno's of JDM ITR motors
  149. b16a build up, need some advice form the pros.
  150. Which master cylinder should I use?
  151. LS/VTEC Nightmare PLEASE help!!!
  152. What should my hatch run???
  153. Will my header line up wth my A Pipe??
  154. Need help with a b16a swap
  155. Ok guys have i coverd all the bases??
  156. JDM swap
  157. b20b4 or b18b?
  158. Vacuum hoses on a 91 CRX w/ B16 swap
  159. b16a in Canada?
  160. anyone know the member with a 2000 h22a hatch?????
  161. OBD2 b18b into OBD1 teg gsr chasis...EVAP wiring q
  162. 01' H22a4 dizzy/external coil...how to wire??
  163. h22 questions on wiring...
  164. Odds and ends to accomplish before swap(Q's about fluids, belts, and misc.)
  165. Slave cylinder for 98 gsr in 97 hatch
  166. G2 integra -> G3 integra parts swap
  167. B20 in a crx best tranny
  168. Found these instructions for a B18C1 into an EG...are they the same for a B18c5?
  169. H22 Civic Hesitating really bad @ 6000+RPM
  170. A few ?'s on my VTEC wiring....
  171. b16a with b18c gearbox?
  172. where to buy parts for b20b???
  173. Ok Hybrid tech's let's see your hybrid Garage's???
  174. Need a few thing for a B18C5 into a EG Hatch...
  175. b16a Sir1 proformance ?s
  176. Swap Shops in PA Area?
  177. Guide to swap - B18C5 into a EG Hatch?
  178. C'mon! There has to be some of you out there!
  179. A/C swap question???
  180. b18b swap in 2000 hatch......???
  181. What size injectors?
  182. can you put a 92 dx mani on a 98 dx?
  183. h22 swap
  184. B16A in EF not getting GAS
  185. auto to manual in ek need the truth if its out there
  186. Vtec wiring...
  187. Fuel pump install ?'s
  188. b18c1 wiring help
  189. how much to expect
  190. fitting an accord type r engine into an ef
  191. Mugen oil pan and Z10 block girdle clearance issues
  192. Who will do oil squirters on my b20?
  193. b18b swap 98 hatch
  194. Wiring up a B17a into CRX...need HELP!.....
  195. how to swap a b18c5 into a 94 civc cx
  196. Cedar Falls Raceway Sept. 28th
  197. Strange random idle, Tach goes nuts, randomly stalls...
  198. where to get the conversion kit so to install hydro tranny in ef???
  199. How to rewire o2?
  200. b18b head on b16a2 block...
  201. p28???
  202. Need help with wiring harness.
  203. Car won't start...swap problem
  204. Which model EG should i choose as a starting point?
  205. What Chassis and Engine Would You Choose, If You Had it To Do Over Again...
  206. B18B swap not starting!!
  207. furious performance/totem motorsports mount kits ?????
  208. Parts list for b16a2 into 97 dx hb (verification per hybridgarage)
  209. Help, ECU choice... ummm?
  210. Ideal exhaust size for B20B VTEC?
  211. vacuum lines
  212. Gs-r into a Cx: wiring?
  213. H22 in EG (Vibrating)
  214. HERE it is finally, but only 1 pic.
  215. jdm h22 tranny rebuild?
  216. Help out on my gsr hatch wiring
  217. Which evap canister?
  218. Code 6 ECT Sensor...
  219. ecu help....
  220. Need to know what the 3 wires going to iac are. Please help
  221. b18c into EK, which pwr steering pump?
  222. d16a1(dohc) in a 87 crx?
  223. mini me swap ?
  224. what clutch for a b16A1 sir 1 88-91
  225. b18c/b16a engine clearance in a 88-91 crx.
  226. Strut Bar for EK-H22
  227. B16a2 in a 94 EX Ques?
  228. Air Intake on 4G with B16
  229. OBDII into OBDI, what do I need?
  230. Hondamotors online engine messed up
  231. B16a axles wont fit eg
  232. LS Vtec
  233. Checking Avatar
  234. need a home for h22a
  235. 4 Wire Oxygen Sensor!!!
  236. ELD wire?? on h22a/civc swap
  237. zc problems please help
  238. GSR head with ITR block update: baseline dyno
  239. Buying an engine...
  240. itr/b16 intake manifold
  241. Wire harness ??????
  242. b18c into 88 crx
  243. HELP!!! Timing belt, or retard working on a car?
  244. Sand Rail.
  245. Anyone in northeast ohio
  246. What would you pay for this setup?
  247. B16B N1 cank/rods
  248. Mini Me questions... simple ....
  249. Running rich cuz of fuel pump?
  250. B18A or B16A in a CRX
