View Full Version : Hybrid / Engine Swaps
- which ecu to use?
- Swap Help!
- ABS ring on axle (same between different years?)
- H22 bar'd
- few questions..
- B16a starts, idles great for a sec, then stalls. Help! Searched......
- H22 jdm vs usdm
- B20 VTEC (everything required to be stong, reliable and daily driven) ?
- GSR into EG parts list
- piston of b interchangeable ?
- HELP!!! vtec not working
- New Hydro conversion from Hasport
- h22 type s ej1 swap
- b16 vtec conversion help
- B-Series power steering?
- H serious Egnine in 98 Civic
- EF ZC swap, CEL 9 CYL Sensor
- What intermedate shaft to use
- P13 Problems. H22 in 94 EJ.
- b16 intake springs in ls head with shims??
- OBD1 GSR Shock-Tower Diagram
- Honda Fit GSR Swap
- usdm B16 in 95 EG coupe. big problem!! help needed
- swap problem
- 93 LS wiring help
- ek CX auto to LS auto
- H22 idling issues
- 98 accord, h22 euro r swap problem...
- My F23/H22 87x97mm H2B Build
- H22 EG axle ???(searched)
- I.D. on ECU Help!! And EF b swap Q.
- 95 eg coupe W/99 usdm SI swap
- H22, H2B or B series auto swaps.. who's got one?
- b16 out h22a7 in need to finalize on wiring
- skunk2 manifold
- H22 swap
- JDM D15 Vtec - Chip?
- JDM b20
- Problems with obd1 jdm b16 in my 96ek hatch
- Buying H2B need help on parts list...
- spring question
- h22 tb on gsr manifold
- LSVTEC i need info FAST
- Does my H22 Have an F Series Fuel Rail on it??? (Pics Inside)
- bent valves
- any f22/f23 sohc 1/4 times in other hondas
- need help building crv tranny for vtec use
- Will an OBD1 distributor work on a first gen B16A?
- 92 dx b16 iat questions..
- Bought a Totalled RSX-S...have a DA shell!
- Quick shifter question H22A related (will it work?)
- H2D or H2B in a EG???
- convince me to go h2b
- Pro/cons for ED chassis with h22 shifter mounting:(over or under)
- H2B DA having problems with install
- MIni mepower gain?
- h22 NO POWER HELP!!!!
- How Come No Hybrid CR-V??
- Might be dumb question but I don't know.
- ? about b18c1 and b20b windage trays
- d15b head
- b16a SiR and b16A2 EM1 question?? not the normal
- Tranny Mount Help! EK obd1 B16a
- d 2 b kitts were 2 get it..
- help on valve springs
- Valves?
- d series mini me?
- K20 into EG Swap Issues
- OBD1 swap questions
- h2b throttle came with skunk2 manifold
- How to acheive the max MPG out of b18 swap?
- Aem hybrid intake question
- H22A into a 94 Accord Manual.
- cel..knocksensor...ONLY after 3k rpm, just did b16a swap
- piston data
- F20C swapped M3!! Have you guys seen this?
- Jeremy's RT4wd CRX
- SOHC to B18C (TypeR) Motor swap... Do I have to add any sensor wires to the ECU
- What is the going rate for full k20 type s swap?
- Honda Civic Si Engine harness.. 97 obd2a civic
- NEED HELP ASAP
- altenator belt for h22 swap w/o ac???
- H22A4 into EK Hatch
- A H22 or a b18 in my 96 civic ex?
- K20z1 help bleeding clutch!!
- I got some ??'s H22 people, I wanna come back to H2b
- Urgent question! b20/vtec related
- JDM P30 OBD-1 ECU throwing a code 22...
- help with b20 head p8r
- best standalone system for k series ej1?
- b16 with p28 ecu rev limit at 7400?
- help with b16 swap idle problem...gurus please help
- rpm tach and speed odometer crazy
- Which engine harness to use on Dart block B16 head
- f22 in eg. Which DS Mount?
- Golden Eagle LS/VTEC Conversion Kit - Opinions?
- H22a into 98 Civic hatch build need HELP (no start)
- New to forum - H22 Civic hatch, looking for suspension advice
- integra motor swap
- Replacing interior harness
- zc ecu question
- 97 CIviC HatchBack Dx Want to Swap HElp!!
- HELP!!!!!!!!!!! ANYONE THAT KNOWS ANYTHING ABOUT H22 HEAD BOLTED TO F22 BLOCK
- 99....2000....& 2001 type r computer.
- what throttle cable?
- K series crank pulley bolt
- s2000 ecu
- help wanted with h23a civic swap
- Oil dipstick reading
- b16a1 swap with stock d-series radiator, anyone else running hot?
- IAC on SKUNK2?
- b20 or b18c??
- b18c into ek3
- 99 Ek with b20z swap (wiring harness problem)
- D16 into accord???
- 95 head to 96 block
- b20 or gsr?
- jdm=no vtec oil pressure switch...true?
- civic harness not working on b18a1 swap
- BULDING A G22 NEED HELP
- Issue with 94 SI /GSR swap. Need help with Electrical
- Need help w/ CAI fitment
- b20 non-vtec on p72 ecu
- 96-98 EK front calipers fit on 92-95 EG?
- electrical ground question
- b20 in ef life span
- Will this PCV system work? Need help fast....swapping next week.
- mini me discussion (lots of questions)
- questions about b20's
- Trouble shooting Z6 to Y8 issues
- K24/20 Build Info
- Can any one help with my ecu issue?
- h22 in civic help
- no vtec??
- Vaccum Hose Help
- Its time for some upgrades on the B18C-R
- Built Turbo H into my teg (SEARCHED)
- need help with my crx
- Bad idle surge, running really rich, code 14 on an lsvtec
- just did swap, it dies, need fast help
- b20z vtec problem?
- CRX AXLES
- F20c/K Tranny
- k24 into ep3 whats needed
- H22 civic fuel line???
- B16 pistons in B18?
- Help k20 eg swap
- My Project: 93 Civic w/ F20B (pics and vid)
- Is this true for OBD 0 Swaps In A OBD 2A Car
- D17A7 Civic GX Natural Gas enigne switched to petrol
- b20 vtec injector help
- b20 vtec after market pistons help
- HEAD SWAP! F22A1 ENGINE, DO I GO WITH H22, H23, OR F23 HEAD
- lookin to do a K24 with k20 head swaped int an EG
- H22a into EK - Which ecu?
- code 13 on my obd0 B16?
- Lsvtec intake manifold question?
- school me on wire harnesses
- Trying to Decide b18b or b18c
- PR4 CA emissions ecu ?
- Differences betwen H22 swap into MPFI chassis and Carb chassis
- LSVTEC unreliable?
- h2b ek qsd help with driver side mount
- QSD h2b kit
- WHAT PARTS DO I GET?
- k20 question?
- Double Project. Purple Nurple and Yedi. Both EG H Swaps.
- B16A2 to JDM B18C
- will an automatic trany ecu run a manual trany car?
- best engine managment choice for the k series?
- Questions on H series..
- pwo obd0 or obd1?
- WHerce can I find a OBD1 to OBD2A jumper harness?
- AC AUTOTECHNIC fuel rail fitting size needed....
- Good shop in MD/NoVA for B-series install in EF?
- no start?
- need help with swap
- help auto to manual
- i think everyone would like to hear this story
- B16B in a '94 EG.. Was told NOT to use B16b harnes?!? Look inside, i need advice
- ??? EK22 cold air intake ???
- H2B question(s)
- F22c in eg
- ls swap into my 93 hatch...wiring questions..PLEASE HELP!!!
- OBDI engine harness and distributor into OBDII H22 Prelude questions
- B20B PCV
- H2B Crx Questions
- ITR 5 lug swap to del sol
- gsr in eg,try to rev=sputter
- ///// DISTRIBUTER AND ALTANATOR WIRING HELP \\\\\
- Honda suspension/brake help, swap to non honda platform.
- Where can i buy a hondata k pro ecu?????HELP!!!
- which oil pickup?
- H2B EK Build
- Would anyone be interested in this product??? A "bitch" pin extraction tool for an air hammer?
- JO-TECH
- gsr swap hit some problems help!!
- itr cai on a b16
- JDM H22A Headers... HELP PLEASE!!!!
- ls vtec questions....please help??
- Anyone else driving a V-6????
- b20 vtec spark plugs, wires.. what should i use?
- ***Info on B-series in a rhd EF8/9***
- How do I check my ecu codes that it may be throwing?
- JDM H22 parts question
- K20A2 swap into EK
- Help! cant make up my F'n mind! LS-v or high comp B16?
- windage tray?
- NEED HELP
- Setting the rev limmiter on ls/vtec
- gsr oil pan on b16 serched
- Can I use the JDM H22 Wiring Harness?
- Innovative Mounts for H-series in 1988-1991 Civic/CRX?
- harness issue on 2000 SI
- Crank angle sensor (Crank fluctuation?) 'Hack'
- dx mini me swap
- tired of talking to myself . . in a pickle, NEED ADVICE!nly only ever dealt with crx or hatches,
- h2b vs h22
- CEL - Code 16 - Fuel Injectors
- H22 into 1999 Civic 1.8VTi
- h22 into eg fab questions
- LsV-T 300whp
- Dipstick Help! If you have a B18C5 Please read :)
- What is my problem? Y8 IM on A6
- I need help to pass smog test!
- honda insight engine swap
- Help needed with JDM 98 spec motor vtec install
- I Need Info On The H2B QuarterSports Kit For The EG Chasis let Me know?????
- Help me on my next build..
- LS swap in 92 civic vx
- b18b1 into EK
- hey guys!
- Stick with OBD1 or go with OBD2?
- 90 dx hatch to si obd0-obd1 conversion
- Another engine swap noob
- Hasport h22 crx questions
- Piecing Swap v.s. Buying Whole
- DCsports k20 swap header for EG chassis???
- H2b can you have a/c?
- 99 Si tranny, rebuilt, whirring noise
- Shop needed for K20 swap in New England
- H22 EK samco hoses?
- Three different H22s???
- b20b fuel rail???
- jdm to usdm swap
- which axles to get for accord?
- B20 in ek wont start
- GSR won't start (no CEL, no ignition)
- redtop engine
