PDA
View Full Version : Hybrid / Engine Swaps
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 [38] 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174
  1. IAB secondaries - how-to tell if they work
  2. 91 HONDA CRX b18c1 swap exhaust problems?!?!
  3. H2B Misconceptions
  4. 99-00 si axles different than 97 gsr axles?
  5. Putting Hydo tanny gears/ LSD into B16 Cable Trany.
  6. converding obd on a gsr motor
  7. F--- HASport's H22 EF Mount kit.
  8. do i need to convert from obd2a to obd1?
  9. setting initial timing?
  10. Pics of H22 integra.
  11. H2B Handling
  12. H22a Transmission
  13. h22a 93 hatch wiring? Please help me out
  14. d series questions
  15. obd1 = no cps?
  16. Converting CRX Si to OBD-I?
  17. wire harness question???? what is this wire???
  18. Pre-swap checklist, suggestions welcome
  19. engine building ideas
  20. 99-00 B16A2 tranny final drive
  21. BEST SWAP SHOP's in SoCAL?????
  22. k20 swap into EG civic
  23. -Searched- Question about vacuum hoses on GSR i.m. and f.p.r.
  24. 4G63 into civic...
  25. is this an ok way to go for what i am looking for?
  26. obd1 issue (wiring)
  27. PHEV! why cant the insight work with this?!
  28. D-series in a DC Integra
  29. solid check engine light
  30. [Question] Best set-up for d15b8?
  31. WTB d16y8 swap
  32. H2B and H22 Frank (G23) question
  33. K20 in EK swap no Spark
  34. Trying to wire knock sensor but can't locate the wire on the canon plug.
  35. b16 90 civic si - Has fuel but no spark
  36. H22a Transmission
  37. need help on my EK swap
  38. DUMB IT DOWN FOR ME
  39. f2d driverside mount
  40. why my track times are too slow?
  41. B18C5 IN 95 EG HATCHBACK DX (VTEC WIRING)
  42. auto/manual tranny question, searched, cant find anything
  43. what would be a good swap to put into my 1996 civic dx
  44. Euro R swap into 2000 Prelude. having problems
  45. Is this normal?
  46. b16 block with gsr head
  47. Boring out my B20. Need some opinions?
  48. Can i put a d16y8 vtec head on a d16y7
  49. Rear Trailing Arms (RTAs) - interchangeable?
  50. k20 into 96-00 civic
  51. Identify this proportioning valve please
  52. h22 in to ek axle?
  53. Project h2b EG
  54. How can you tell the difference from a manual and a auto rear transmission bracket?
  55. **Please Help**
  56. My B18A Swap Research...
  57. S2000 Motor converted to FWD?
  58. B18B1 breather box HELP
  59. D16Y7 to D16Z6 swap 97' civic help
  60. exhaust combinations?
  61. B16 Head GSR Block Tranny Trouble
  62. H2B in DA integra....stock Hood closed***no webbing cut or hood spacers**
  63. JDM Vs. USDM?????
  64. Stopper help!
  65. FIFTH GEAR SWAP INTO CABLE YS1
  66. can it be done
  67. H22 engine differences ?
  68. b18c1 swap left engine mount help needed into a 91crx
  69. B20 Vtec Header questions ???
  70. is it true? b-series clutches
  71. b20 vtec. help
  72. a/c ef with b16
  73. h22 into 98 ek dx
  74. Part Throttle Rev Limit?? Tuning With Crome
  75. b16 crx
  76. obd1 h22 into obd2b civic dizzy wiring ?????????????
  77. 6 speed h22 ?
  78. B18c Block needs answers!
  79. vibrations OOOOHHH vibrations...
  80. Video :) Distributor problem?
  81. 93 CIVIC CX EG HATCH TYPE R ITR B18 C5 95 $5600 Ebay no reserve
  82. Trouble starting DPFI to MPFI
  83. proportioning valve question?
  84. Cable GSR tranny and b16a 1st gen compatibility
  85. ? for anyone in tennessee or n. alabama
  86. will 96 spec itr 4x114 brake conversion in 95 civic work with d series axles????
  87. need help on a K20 swap in a 89 crx Si need help
  88. I'm trying to put an OBD1 B18a1 into my 93 civic dx should I a B18A1 or B18B intake manifold
  89. water pump for b18c swap?
  90. Jdm itr vss plug?
  91. surging
  92. what exhaust?
  93. Lowering entire engine and transmission assembly
  94. NEED SOME ADVICE!
  95. Comparison between REAR Brake Calipers Question
  96. h23 swap, funny idle
  97. b16 swap, 1989 CRX what CAI will work?
  98. Torque mount question
  99. F20B Crank Pulley or Machine my H22A Crank Pulley ?
  100. kswap in a ek hatch im doing for a buddy
  101. V6 Swap in-to Civic
  102. Legend C series engine into 92-95 civic
  103. * * OBD1 B-series engine into OBD2a/OBD2b civic/integra * *
  104. Vtec head taller?
  105. comments/ suggestions on my b18c (gsr) swap
  106. jdm h22a swap in 97 accord, no spark, any suggestions?
  107. b16a swap cost
  108. Timing belts parts needed when swaping a b16b or a ??
  109. air conditioning
  110. h22 swap help!!!
  111. H22A Water Pump Part Number
  112. F20b and H22a
  113. B16/B18 slave cylinders the same??
  114. parts i need...
  115. B20 Swap???
  116. NHRA CERTIFIED H2B KIT/ OFFICIAL KIT OF IDRC & BOTI
  117. jmd b18c1 swap -beginner
  118. Name this plug please...
  119. Any Leegnd/RL Owners post here?
  120. quick link to h22 swap
  121. evap (charcoal) canister w/ obd1 jumper?
  122. D16z6 into D15b v-tec E
  123. H2b KITS????
  124. Stolen Car being Helped
  125. Calling all b16 owners!!!
  126. riddle me this- B pipe length for 98 spec Apexi ITR header equipped JDM GSR in 97 hatch
  127. B18C-R into a DA6 gen-1
  128. OBD1 engine in OBD2 teg
  129. Cali Smog guys ....
  130. OBD2 A or B? Does it matter for my car?
  131. i need help quick h22 in 94 civic si
  132. h22a1 civic hatchback project!!!
  133. obd2 b18c to obd1 da questions
  134. Can i re use my GSR Throttle Cable?
  135. cwiring?
  136. D15 to F23 swap
  137. H22 Hcp mounts replacement bushings for an ek?
  138. Searched...3 quick flashes from CEL
  139. Does anybody have or know where to find B16 Cam Caps?
  140. H22 newb, questions
  141. How To make a Good swap k24/k20
  142. Has Anyone Used H22 AVID Mounts??
  143. Injectors Problem
  144. what intake will fit?
  145. H2b swap and high idle someone please help me figure out whats up
  146. ARP rod bolts LS or GSR for frank bottom end
  147. another vtec wont kick in topic
  148. 93 H22A Tranny axles same as 99 Prelude Tranny ?
  149. Need Help With Harness/Wiring for B-series Swap Into CRX
  150. GSR/LS rods??
  151. i've been searching and searching
  152. More parts breaking on my Hasport EF H22 kit.
  153. Shiftlinkage
  154. Second fuel cell
  155. EG spindle conversion
  156. K20A in 91 CRX
  157. My H2B DC2 build..
  158. k20 in a dc2. what all do u need to do that?
  159. header to use in b16 hatch
  160. Engine year
  161. Helpful Guide: For the FRM cylinder H22/H23 person doing Budget Rebuild
  162. Which harness for my B20? (DC Chassis)
  163. second o2 sensor
  164. Ecu help
  165. F23A5 into 5G civic EX & JDM H22A into '00 Accord DX
  166. 4WD CIVICS
  167. My Hydro GSR tranny and fresh B18b swap.
  168. Driver side mount question.
  169. need help!! 1996 civic ex with 17 integra ls swap...
  170. hi guys noob question
  171. Car wont start
  172. but heres my ? i bought a 94 gsr teg i want to put that motor into my 96 dx that has mini swap i alr
  173. question on obd2a and obd2b compatability
  174. JDM gsr run on b16b ecu?
  175. JDM B18C in EG swap not starting......help needed!!!!
  176. h2b?
  177. EF motor in an EG / tranny debate
  178. crazy swap question d16z6 with crx hf and si parts
  179. Deciding which way to go with the 94 civic coupe?
  180. is there a way to legalize your jdm civic motor (b16a)
  181. ac bracket confusion
  182. just got a h22a put in my ek, some problems
  183. ek k20 swap question.
  184. EG Civic H22A Tranny Removal ???
  185. which axle combo?
  186. cleaning block with head off
  187. H2B... ej/ek's?!?
  188. Trying to help out future EK H22 swap guys...
  189. NEED HELP!!! EXEDY CLUTCH PROB
  190. h22a4 into 1996 honda civic
  191. DIZZY HELP FOR LS VTEC
  192. I have a 1989 Civic DX auto sedan that I want to put a B16A + 5 speed in. What & How do I do it?
  193. b18c1 into EK hatch- what shifter bushings to use both on tranny and under chassis, the civic or teg
  194. LS swap in process, got a few ???
  195. definitive answer needed- axles for b18c into EK
  196. I dont have a check engine light!
  197. b16a swap with some problems
  198. automatic gsr motor cams
  199. 94 integra 5 speed pedals...?
  200. What AC belt for B18C w/98 EX compressor?
  201. What swap should i go with for my ek
  202. I wnat to do h23 vtec!!!
  203. H23 VTEC
  204. what intake will fit?
  205. converting an F20B obd2b small plug dizzy to obd1?
  206. what options are there to upgrade the strength of the weird driver's side mount on EK?
  207. K series block with B series head...possible????
  208. h2b.does it still affect handling?
  209. o2 sensor replacement type on b16 crx swap?
  210. ls/vtec swap, need extra plugs for the harness..... where can u get them?
  211. d16y8 in civic ex
  212. Will OEM ITR rods and pistons work on an LS crank in an LS block?
  213. Swapping just a longblock......?
  214. help me gauge this basic swap setup-
  215. 93 ls motor into 93 CX
  216. ATTN: people with cable trans in their eg/dc
  217. Where can I get my H22A M2B4 Tranny Rebuilt???
  218. H22 swap
  219. Is LSD really necessary???
  220. need help please....
  221. JDM B16a CRX... Partial Throttle problems..
  222. Del Sol Information Required.
  223. H2B in an ef, i wanna go fast, i wanna go fast!!
  224. H22A M2B4 Transmission not going out of reverse!!
  225. FPR
  226. d series question
  227. oxygen sensor heater obs2a p72 HELP!!!!!!!!
  228. Will I have problems swaping a obd1 LS block into obd2 teg with ob2 v-tec head?
  229. jdm h22a swap
  230. a/f won't adjust :crook:
  231. Cost of a K series swap on EK?
  232. LS-vtec rinning shitty
  233. B16 Swap into EK Will Not Start, checked everything, any insight?
  234. Problems after swap. Please help...
  235. h22 civic radiator hosing?
  236. h2b in an ef
  237. Questions about H2B
  238. Help with OBD to OBD1
  239. please help me with my b18c1 engine
  240. My h2b swap is SLOW...what tha hells going on?
  241. civic stock motor is dieing
  242. civic DX d15b and b18b interchangeability
  243. How much is my B20 throttle body worth?
  244. Boosted EF Hatch: H2B or B18c?
  245. ef swap handling effects
  246. civic dx b18 swap problems
  247. Axle geometry help for all my H22 Hatch Buddies.
  248. Poor Mans Type R
  249. Correct Axle???
  250. buying swaps online poll?
