PDA
View Full Version : Hybrid / Engine Swaps
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 [152] 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174
  1. I need a 90-93 teg intermidiate shaft...
  2. P74/75 B18B question?
  3. What dual exhaust could I get for my EG??
  4. Probably off topic
  5. JDM ITR into 92 vx
  6. Friend needs help w/swap!!
  7. What do you think I'll run with my setup?
  8. What Do I Need To Get My Car To Hit In The 12's??
  9. What tranny would you use?
  10. Why I need a fuel pump...........
  11. need help please: b16a in a 89 ef hatchback putting in a/c
  12. B16A swap is done! but not as fast?......
  13. LS/Vtec question...
  14. Alternator for B20 in Civic???
  15. vacuum pump?
  16. swapping d16 motor...to 94 ls motor..need help on modifying the dx harness
  17. ZC vs Mini Me
  18. mWhich Transmission?
  19. Cooling a B18B
  20. 93 Ex motor in to a 92 CX
  21. ls/vtec swap how to's
  22. Wiring vtec.
  23. Updated pics of the S-type...
  24. i need to know if the integra speedo cables are longer than the one for a civic/crx?
  25. anybody know this answer?? beatcha you don't ?
  26. Question about Fluidyne radiators...
  27. b16a 1st gen wiring
  28. building ls/vtec
  29. b18 swap running rich + code 43 in a 90 crx hf
  30. B16a Block for sale
  31. b18c into 96 civic EX
  32. b20 in a 97 civic
  33. H22 in 6th gen? (96)
  34. Raxels/driveshaftshop/other axles poll
  35. Mixed information!?!
  36. strange idle issues
  37. header, cat, exhaust combo...
  38. new clutch required in dx and hf swaps?
  39. Pics of Apexi ws?
  40. did the 89 teg have a halfshaft?
  41. wtb: 89 integra axle shaft
  42. B18B w/ B16 head NO vtec
  43. www.importbuilders.com
  44. is $800 a good price for a ls long block??
  45. need help with my hybrid.....
  46. Ground Control coilover spring rate for H22 EK sedan?
  47. balancing
  48. Urgen help with connecting fuel injectors for swap
  49. Please post your set-ups and how much everything cost.
  50. Ls bore
  51. anything bad about hondamotorsonline or nippon motors?
  52. Help! B18c1 into ej/95 coupe...power steering and obd.
  53. h22 into Civic. what's this i read about an injector resistor pack?
  54. zc drop-in
  55. Problem with '93 TEG axles on '89 EF Hatch with ZC engine Tranny combo?
  56. i have my list for the gsr to crx.
  57. pls help me out i need to know if ?
  58. How much should port work cost?
  59. H22A into '94 hatchback... need pics!
  60. sohc vtec head swap?
  61. hondamotors online
  62. how do you tell the difference between jdm and usdm?
  63. How do i make Crv-tec Daily Driveable
  64. B16A in EG5,but does anyone ship to Scandinavia ?? Need help..
  65. LS/Vtec shop in New york LONG ISLAND
  66. some jdm b20b tidbits
  67. Which cheap Mounts could be used for Itr Tranny swap into EG
  68. GSR cylinder heads: What's the difference between P72-1 and P72-2??
  69. Sir1 into Eg Coupe
  70. URGENT!!! Help needed ASAP!!
  71. what sensor is this?crvtec question.
  72. H22a in EH2 Swap Resources?
  73. Jdm b18c1 in a 91 hf crx
  74. i have a carb engine......i wanna swap!!!! i dunno wut to do!!!!
  75. Need help with location for this sensor, see pics----->
  76. Package 5: LS/VTEC LONGBLOCK "Budget Upgrade" Package.
  77. bearing clearance?
  78. need help with b16 swap
  79. crank sensor
  80. which cali ref station did you go to???
  81. GSR w/ b16 head into 88 EF....clearance issues??
  82. Code 23 (knock sensor)..can't get rid of it..HELP
  83. B16 cams SUCK!!!! Should I just get some ITR's?
  84. a/f guage in a 92 civic vx w/ B18C4
  85. Apex'I WS exhaust. Straight-thru muffler?
  86. How to tell if you have a Y1 LSD TRANNY?
  87. need help!! what sized bolts to use when mounting engine on engine stand
  88. lookin for a pic of JDM LSD sticker on rear hatch??
  89. where can i get Place Racing front cross member for CRX
  90. Need OBD II B18C distributer yeasterday!
  91. Will a b16a head (1 st gen) bolt on to a b18c block (USDM) ??
  92. mini-me
  93. any info on this swap is needed
  94. Need help with axles ASAP....
  95. got an oil problem...
  96. 00si --> 96ls converter harness
  97. H22 with GSR ecu
  98. price check on ls block
  99. swap help
  100. Which oil/water pump to use for b20/vtec swap
  101. parts interchange
  102. rear disc conversion for 96 civic
  103. What could I get for around 7k?
  104. Which to choose from? Build LS block or buy b20z?
  105. making a jdm b16a1 emissions legal? what do i have to do?
  106. b18 into 90 crx hf swap questions.
  107. Wiring help with B18C in an EK! Pics inside
  108. A little Expensive huh?
  109. To those with swaps: what did you do with your old engine?
  110. Max-Rev update / Billet Motor Mounts
  111. h22 Civic guys. where did you get your engine and WHICH h22 did you get?
  112. d15 to d16
  113. My crx hf w/B20VTEC running 14's?!?
  114. B18C5 or H22 in 4th gen hatch
  115. $$ comparison of LS/VTEC and CR-VTEC
  116. Where to buy bushings for B16/CRX mounts?
  117. ls swap in ek???'s
  118. SMS 2-1/2" Stainless Steel Cat Back Group Buy Details
  119. B18c head onto a b16a2 block?
  120. Reliabilty of a H22 Hatch
  121. b16a hydro vs b16a cable
  122. which exhaust manifold to use on z6?
  123. Thinking about buying this hatch but.....
  124. Crv-tec...is it reliable?? Can it be?
  125. 90 Civic + 89 Integra LS = ???
  126. B16 sputter, code 9 Help!
  127. Please help Top Fuel Question!!
  128. Who is from Florida ?
  129. For those interested...
  130. Is this a fuel or ignition problem? Car not running well, help
  131. We'll all humbled... check out this hybrid.
  132. Swapping b17 gsr into 90 CRX? 1/4 time?
  133. 1st Gen B16A in a 6th Gen Civic
  134. How Hard is it to swap Auto to 5-Speed?? (94 DX Coupe)
  135. -vtec set-ups hereWho is running a straight b20 set-up?? Post your set-up or comments..
  136. d series?
  137. New pistons(same bore) with just honing the block?
  138. Losing brake pressure while braking, but not due to fluid loss
  139. Check out my Motor Mounts - diagnosis needed..
  140. help with cv shaft.
  141. trans question............
  142. hasport or place racing
  143. K20 (SIR, type S ) series engine into Sedan or Coupe civic 2001+ ????
  144. Import Auto Salvage : b18c5 full swap pricing? (i cant get an answer from them!)
  145. LS Vtec Coupe
  146. jdm TPS
  147. HCP Mounts???
  148. What sensor is this????
  149. Q for my friend's car
  150. Engine swap in a 7th Generation Civic
  151. motor mounts?
  152. B16 w/B16 tranny vs. B16 w/GSR tranny, both cars equal, who would win?
  153. I wanna do a Crv-tec Swap
  154. O2 Sensors for B16A 1st Gen OBD-0?????
  155. grounds
  156. b17a timing belt for ls/vtec?
  157. LS/VTEC complete
  158. engine goes in saturday!!!
  159. EK swap same as EG ?
  160. Swap shop
  161. It seems my hybrid has gone into limp mode and wont come out.
  162. EGR h22 in civic wiring
  163. my zc is dead?
  164. 2 swap questions b18a1
  165. What AEM CAI for a h22 EG swap?
  166. h22 mounts
  167. I just don't get it......
  168. Need A/C tech info for H22 hybrid???
  169. B16 in 92 hatch si
  170. Swap Info
  171. Just to be clear
  172. magnacore
  173. B16b internals in B18b/B18c1?
  174. ls allmotor 13's??
  175. How do diagnose a bad distributor?
  176. Difference b/t EG & ITR front sub-frames?
  177. Anyone have a pic of the IACV and where the idle screw is @ on a b16a?
  178. B18c5 Pricing ?'s. Plus, what's the difference(specs) between the 96-97 model vs 98+ b18c5?
  179. What MPG does your hybrid get?
  180. LS and GS-R t/b... are they the same I.D.?
  181. H22A in to a 1996 Civic Hatch? Help Please.
  182. crvtec clutch..
  183. Turbo LS motor
  184. TYPE R LSD into YS1 (93 GSR tranny)
  185. How much would it cost for me to put a 2.2L DOHC Vtec engine and manual trasmission in my del sol.
  186. radiator fan trouble?
  187. Shipping costs
  188. need help/opinions..
  189. SMOG help 4 my swap
  190. b16 2nd gen crx code 9
  191. speedo not working on a first gen crx with b16a1...
  192. USDM B18c5 harness on a JDM B18cR??
  193. Performance Mechanic Wanted!!!
  194. how 2 ZC swap............
  195. OBDII to obdI
  196. 99 dx hatch with b20z...which power steering bracket and pump will bolt on?
  197. Door panels
  198. Tryin to lower CP for a GS-R motor, need help.
  199. what is the y1, j1, s1, ys1 tranny casing made out of?
  200. speratic idle.....
  201. What do you need to drop b18b in a 96 civic cx?
  202. Re: SR20Det in Civic????
  203. Supra Engine Compatability
  204. LS with 84-86mm bore? or b20
  205. Best header compromise between power and clearance for B16 91 Civic?
  206. AWD 4gen civic?
  207. Need help with alternator belt for b16
  208. 95 cx hatch......Overheating with Ls SWAP
  209. I need all you hybrid civic coupes.............
  210. Difference in trannys
  211. Fuel Controller
  212. Have a chance to Swap Out my 99SI motor and Get what?????? Thinking about a b18c5 any suggestions
  213. B18C1 in a 1996 Civic DX hb
  214. anyone got a ZC header?
  215. Which LS Motor OBD1 or OBD2?
  216. If you have an EG with an LS swap...
  217. How to make a b20/vtec RELIABLE?
  218. Who knows the difference between B18A and B18B??
  219. Hondata, Larger injectors, and tunning: 12.6:1 on 92 octain?
  220. b18c1 in a 95 civic ex
  221. 1st gen crx swaps?????????
  222. vtec heads????
  223. will a d series alternator work with a b series bracket?
  224. Iginition timing problem! Please help!!
  225. AEM CAI on swap into 89
  226. H22 eg help
  227. Calling ZC Experts
  228. RSX oil filter increase oil pressure?
  229. Header Flange Rusting?
  230. trans in hybrid crx w/ tipe-r
  231. Cdn engine orders from US??...and b20 tidbits
  232. code 2 on a 94 gsr swap
  233. What ECU for B16a2
  234. chart for wiring ecu?
  235. F20B/C and Accord SiR-T questions
  236. For those that have ordered from hondamotorsonline...
  237. Some Engine Questions
  238. help please............
  239. Can i use the same o2 sensors??
  240. (94+) LS, GS, RS, GS-R axles the same?
  241. o2???????
  242. ARP rod bolts?
  243. LS/Vtec Question??
  244. Question about Civic Si driver's bracket
  245. h22swap
  246. h22 swap
  247. for
  248. what mounts for B-series in crx 89
  249. Which distributor??
  250. O2 sensor question for B16 swap
