- JDM b16a block need to be honed ?
- 97 JDM B18B into 1990 integra
- JDM B16B into a 2000 DX Sedan. Wiring Confusion
- f20b hybrid question
- Cable tranny on z6 block
- ENGINE SWAP ISSUE PLEASE HELP
- which intake on d16z6?
- ecu for b18c in 98 civic
- Gsr b20 swap wont rev past 4500
- Gsr rad hose
- oil in cylinder on new motor
- Do i need a crank sensor????
- total noob to this! B20 swap need ecu.
- help just did my b16b swap on my em1 now got p1337
- Which is better h2b h23a blue top with si tranny or k24a4 on eg hatch vx?
- y7 block y8 head
- Harness?
- new h2b swap... stuck on clearing 2 cels.
- y7 swap on my 99 civic ex
- h22 00 civic power steering help.
- F20b motor swap crank sensor help
- 00 Civic with h series not starting
- 90 crx si w lsv
- So close.. Vx (z1) bottom end + a6 head question
- JDM B16a block/GSR Head swap Q's
- help!! with ek hatch that has sat for 7 years
- coolant hoses on edelbrock b16 help....
- h2b charging system help!
- Speedometer don't work
- Ls vtec turbo idea
- 2nd Gen b16a to 91 hatch mount identification help
- 97 Civic Ex y8 to b18b Swap
- Distributor question
- JDM H22A CKP
- 96 b18b1 into 89 crx
- Del Sol Northstar Swap
- newbee stock jdm b18c ecu problems
- Identify These F20B parts for me?
- 2000 gsr swap into 98 civic ex
- f22b2 swap to f22b dohc or??
- What axles do I use?
- How well does the K-Tuned shifter work on an EG J32 swap?
- what do I need to do to put a gsr engine and trans in my 1998 civic ex five speed
- 1994 Honda Civic Hb VX
- Failing Emissions
- D15B1 to D15B2
- itr will not hold idle, need help!
- jdm b16a 1st gen
- EK hatch with Type R swap - ECU just sitting in footwell
- honda hrv vtec engine swap
- LSV wiring harness
- Couple questions about diagnosing my b18b1 swapped 95 civic hatch
- V6 VTEC engine in a civic?!
- Ls vtec poorly done in crx
- Smaller/aftermarket balancer for dohc f20b?
- first start up lsv no oil pressure
- F20c swap, compatibility questions!
- d16y8 head on d16z6 block need help!!
- burned up my pgmfi
- Is this really bad?
- B18A1 in 89 Civic SI Axle question
- Swap Time
- D15by7 with a z6 head (trying to find ECU)
- Yet another conversion question
- Engine swap question
- f20b del sol idle issue
- B20vtec running rough sounds like a subaru....help
- B20 motor help
- H22 EK motor mount install
- just got a civic with wire tuck now it won't start
- LsVtec bad mpg
- Both cars ran, now none do...
- b16a2 powersteering pump for 99-00 si different than del sol?
- Engine and transmission swap in Atlanta-- please assist!!
- b18 gsr vs b20 vtec
- How to torque crank pulley bolt
- h2b crx traction bar troubles !!!###
- Which Ecu for Mini Me
- 96 civic cx auto to 5 spd issues!!!!!!!
- B20B into 99 Civic EX
- 92 Civic - leaking oil from head gasket and crank seal
- D16Z6 Enignma
- 1998 civic hx b20b swap
- 89 civic si/B18A1 swap vacuum line for smooth idle
- Y7 to Y8 head swap - Wiring help!
- help choosing a clutch
- engine codes
- 99 EX sedan w/ 98 spec type R AC bracket question..
- Wiring part of a swap
- H22 Help!!!
- B20b swap
- found my donor.B16A and a sir trans, here we go...
- D16Z6 Swap Help Needed
- 91 civic hatch with an SiR swap
- b18b1 swap ef 89 civic hatch
- 1984 CRX MONSTER SWAP
- b18c5 type r swap into 91 civic sedan
- ls/vtec failing after damper fall.
- Zc ecu help!
- Honda civic help
- Need Some Help. New User.
- need help
- How did you solve your dc headers p1033 2000 civic b18c1
- 99 em1/H swap --> No spark...no fuel..
- K series in my 95 honda civic dx coupe help!
- Dc headers problems= p0133
- b20b 1998 honda civic hx
- motor cranking problem
- needing help b20swap
- B16a2 to b18c swap
- Swapping b16 obd1 to obd2 b18
- b18c type r build
- d15b2 to d16y7 swap issues... Circular port vs Square?
- D16y8 auto block with a d16z6 head manual help
- a little over my head
- need ecu
- Problem w/ new swap
- ECU wiring questions for P06 and Jdm b16a
- Serie B DIY front Timing belt tensioner
- PM8-5 cylinder head
- b18c serpintine belt
- b20 swapped Corvair!
- 96 ek with 99 itr
- h23a1 swap into 00' dx coupe!
- engine swap
- Engine stalling... WTF!!
- MAP-TPS-MAF??
- D16y8 block with d16z6 crank. Possible issues???
- P28 B18C1 noise and loss of power
- 1994 civic cx with h22 swap- drivers side axle rub-
- HAVE to remove trans with engine? 95 Accord
- Need a mechanic to work on h22 swap
- b7/y8 mini me
- b16a1 swap
- H22 swapped EG clutch slipping
- Vtec not engaging???
- LS/vtec questions
- F22a1 to H22 head swap
- need b18c wiring diagram
- Help: h22a civic with idling prob.
- running issues HELP!!!
- smokes after idles for a minute
- Any idea of what kind of B20 I have?
- 95 Civic Ej1 B16A1 swapped idles at 1500-2000rpm
- obd2b to obd2a jumper harness
- B20 EK auto trans axles
- Samakhans K swap Miata build
- H2b Evo kit mount question
- What is needed for a h22a swap into a 98 civic si?
- d15 or b series
- H22 FRM liner bore/hone.. who does this?
- swaping B20B into 92-95 honda civic
- rywire harness
- EF H22 front strut bar info
- F20b into EG harness questions!
- b18c crankshaft pulley bolt removal
- f23 vtec swap eg. distributor question.
- need engine harness wiring
- please some help b18c
- B18 upgrade advice
- F2B Rear mount Problem, EM1
- won't go into any gear
- 1997 civic ex y8 swap
- ECU for 2001 B18B1 to 97 civic swap - will P2E or P06 make less power?
- b18c swap
- cable b-series swap into ek questions
- B series axles
- I Need Help ASAP!!
- b20 vtec help !
- Quick B20 swap questions (into 99 teg)
- 94 integra LS cable not working for EG with LS swap? Am I stupid ?
- 94 LS throttle cable not working for EG LS swap ? Am I stupid ?
- F20B Head Stud Fitment issue
- Ls/vtec slack between cams 1/4"
- redline fuel system cleaner
- i got a d16y8 but wanna swap to a b20b
- Does a 2000 ek motor mounts fit a b series? Please help
- i got a D15b7 w aD16y8 vtec head and i bought a d15b dual vtec ??
- h22a euro r swap(ek) walbro 255 problem..
- 98 civic* gsr swap* heater control valve clearance issue* pictures
- need help...please
- JDM ITR 96 Spec Swapped 98 civic hatchback exhaust help
- d16z6 or d16y8 swap
- swap H22A7 into Accord coupe CG4 - need help
- H2b eg or boosted gsr?
- H23a VTEC H2B in a DC2?
- D16Z6 Head & D16Y8 Block -- Parts Inquiry
- 2000 Civic DX VTEC Swap
- F series 5th & FD/ M2S4 Gear box
- B20B HC engine swap from B18B, intake manifold question
- B Series Into My Del Sol
- F20b in 99 civic ex
- is the juice worth the squeeze
- Diesel Swap 98-03 Accord
- 92 civic cx d15z1 swap
- IAT wiring help with prege silinode.
- H22 swap need help
- timing belt keep loosening ls/vtec
- B18C EJ8 swap tips & comments
- K Swap back to B Swap questions
- H2B +NO BS + KS manual tensioner + S2000 crank pulley (issues)
- 2000 Honda Civic DX Engine swap inquiry
- H22 head on F20B
- F20b into 97 ex
- Obd1 b18a1 into 89 dx question :)
- h22 swap
- H2B frame clearance & balance shaft
- got a eg with b16 swap that won't start
- F2B in EF jerking in vtec
- F22b1 swap in a 91 civic wagon?
- TPS grounding issue
- 88' prelude si suggested swap??
- F23a into Ek swap question
- 98 Civic Hx Swap Help!
- help on spending 8 grand
- F20B Oil Seal Replacement
- lsvtec
- k20a2 swap in ef costs?
- B16a2 with a ls automatic in a 1999 honda civic
- Obd2-b b20b into obd2-a integra no spark issue
- ZC MOTOR MOUNT BRACKET HELP!!!!!!
- Just a thank you for the help
- My CD5 Dream Build (Dream)
- 98 civic hatch with h22swap
- Lsv problem
- EF H22_TRACTION BAR INFO
- ek hatch b16 surging
- Please help!!! Engine flooding!!
- h22 cb7 w/ p28 auto to standard conversion cel 30?
- 93 civic gsr swap TPS issue
- 98 Civic with GSR - Plugs and P0325 code
- 99-00 civic engine harness
- F23a1 Block/H23a Internals
- *Urgent* b16a kept stalling after it warms up!
- engine removal
- b20b4 swap in sedan
- 92 civic hatch h2b -17 degrees timing
- need help b18c
- No power ls/vtec
- b18c swap
- 2002 Honda Accord's Notorious Transmission
- DA clutch
- engine does not respond to idle screw/vacuum leak
- 90 Hatch b18 problem starting. Hazards start car.
- 91 crx build needing help
- B20 swap into a 94 civic coupe.
- one of them already worked on models
- B17 EF wiring Harnes question
