My H2B w/ Pro2s Dyno Tuned 249hp 182 TQ
It has
Supertech springs and retainers
Skunk2 pro 2 cams
removed butterflys
removed balance shafts
rmf looking headers i got from full throttle
68mm throttlebody
3inch intake pipe with velocity stack
everything else is still stock!!
im using ectune with a demon board
Skunk2 pro 2 cams
removed butterflys
68mm throttlebody
Re: My H2B w/ Pro2s Dyno Tuned 249hp 182 TQ
very nice, I knew they would make good power on a stock block.
Edit, get a bigger TB.
thanks, what size TB do you think i should put? i was thinking 72mm and putting a spacer to make bigger plenum to see what happens
jdm h22a block,
stock manifold, stock pistons, stock rods, stock crank, stock oil pump, stock water pump, stock thermostat. everything is stock unless i wrote mod uptop.
jdm h22a block,
68mm should be able to run well but try the 72mm if you can,the spacer would be a good addition,any idea what your compression ratio is?
honestly im not sure, its what the stock jdm h22a compression ratio is supposed to be. i havnt removed the head, i bought it from jdmenginezone and havnt opened it up. i put the springs in by forcing air in the cylinder.
wow sick!
get that head breathing some more and it'll make more, bigger tb n bigger intake piping
did you check clearances with the cams?
in a month or so im going to try a bigger tb
