- stroked ls?????????
- G23 build... any tips
- help! 00 civ Ex w/ JDM b18c swap
- H22 into eg exhaust size
- Pic request B or h2b series into eg slave cylinder
- TPS sensor volt test
- h2b tq specs
- 5 lug and D-series, Axle help
- EG B18c1 swap emmissions question
- O2 Wiring Problem
- tps question
- NEED HELP ASAP b20 b16 question
- advice on gsr motor
- No O2 sensor on my K20 hatch
- need help quick
- jdm pr3 rocker arms question( need help ????????)
- saturated injectors with p13?
- OBX vs Megan Racing Header
- F23a?
- 92 si hatch with 2000 LS motor. Overheating problem. Cant figure it out.
- Please help me starting my swap
- P13 vs. P72 odb1
- H2B with Out the Kit?
- Oil Pressure
- B series into 1989 Integra??
- AN fuel line and fitting sizes?
- B20b Vtec with Stock Internals. Need Help !
- d15b7 into a 85 civic hatback
- h22 in ek o2 sensor.
- K20
- b20 vtec-90 integra
- Adding coolant after the swap
- obd0 to obd1 conversion
- What do I do with this hybrid?$$$$$$$
- 2000 b18b1 in 1991 ef
- b18a1 with ls rods and b16 pistons??
- could u use a stock back mount for a h22ek swap
- B18A with cable trans into 92 civic
- obd0 code 7
- JDM Brembos on EK9 hubs??
- EGR sensor and EGR control solenoid valve
- can wiring harness connectors be purchased separately?
- b17a1/b18c1
- gsr with a b16 head question????
- emissions question
- D15/D16 Head swap Finished,
- Avid Racing EK Motor Mount Install How-To and Review
- JDM h22a-vtec Obd1 Injector Size: Confirmation 310 or 345 CC? Trouble Turning Over
- k swap question
- h22a5 on eg..italian job
- 94 GSR wiring harness
- Few questions on bseries hybrid parts
- LSVtec B18B1 PCV?
- Help!!
- JDM D15b into 2000 Civic DX questions
- Bottom end bolts from a b16 to a b18b
- 94 dx d15 in 90 civic
- JDM B18c smog (high NOx)!!
- F20B in Ek wiring help
- What to check before buying an engine!
- qsd flywheel bolts
- Stalling/doesn't rev past 4K... Any help??
- 2000 gsr engine into a 96 LS integra?? please help?? rpm not working
- H22 Swap Power steering help
- motor bogs after VTEC - HELP!!!
- Wiring Pinouts
- H22 in eg gauge cluster question
- best head to put on b20b
- 99 Teg going on Boost I need to convert to OBD1 help
- I'm now in a bind: 2000 Int Gsr and I have potentially 3 options to go with.
- Notchy Gearbox
- eg or ek with subaru or evo engine
- F20B or H22A???
- QSD H2b eg kit where timing mark??
- b18cR crank into b16a ?
- ENGINE TECH's HELP!!
- jdm gsr swap please help
- b18c5 with ls tranny
- Joone's Street Power A/M Candy H2B EG Build
- 82 Civic H22 Swap
- b16b into eg hatch need help asap
- b18c4 (gsr motor) into ek3 hatch
- h2b L bracket in eg
- B series swap CV boot problems
- help rhd b20swap wont stay idle..
- LSVtec water hose question
- Need pics of RSX shifter in action in EG/DC chassis.
- 98 cr-v w/ jdm b20?
- Civic ABS Information Required
- Vacuum help!
- help with cam timing on mini me
- cable tranny
- help with d15b7 intake mani to z6 mani
- How to drop motor from bottom
- JDM B18C1 in 93 Hatch DX........need some help
- D series EG civic wiring info needed for H22 swap
- 1991 crx ac help
- H2b problem wont pass 5k
- B/D Transmission Parts Interchangable? (Searched but not many answers)
- F22 swap
- will h22a head gasket work on h22a4 block?
- Ground Question on K20A2 EG swap
- f23/h22 problems
- Opinions on LS swapped EG transmission options
- H2B vs. K20 Swap
- H22 EG owners - Anyone not have a mangled dented header?
- finished my h2b f20b in my 99si but have a problem
- If i have a type r ecu do i need a resistor box for my injectors..????
- OBDII JDM H22/91 OBDI Accord EX. Why different dizzy and injectors
- S2K pin outs? and pics?
- hasport egh2
- Help with with obd0 jdm b16 wiring harness for crx?!!
- k series throttle bodies
- OBDII JDM H22 into 91 Accord wiring and sensor questions
- resistor box
- B16 block, B17 crank and rods
- D17 stroker
- H22 vs. B Series Weight
- h22a eg
- running p73 ecu with stock h22 injectors
- What head do I have?
- misc .complete underhood bolt set
- Need help about a b18c1 swap done by a previous owner?
- upgrading to itr sways
- H22A VS G23 take no prisoners
- What engines can drop into a 92 civic Dx? D15? D16?
- innovative ek b-series mounts ground clearance?
- ls-vtec head gasket question.
- Front Stoppers
- Need A Few Testimonies On Skunk2 Tuner Series Stage2 Cams For Stock Block H22s
- Those of you using ITR transmission...
- Better choice of motor mounts - haev Avids now H22 EH swap.
- how this h2b kit?
- 2 step launch control
- JDM B20 into 00 EK (EM1)
- auto Ls swap into 98ex coupe
- upgrading to ITR suspension components
- HELP PLZ: 99 GSR into 99 Civic EX
- H22A + EG CIVIC + Powersteering
- What manual tranny bolts to the 3.5L V6
- ignition help needed
- Planning Swap...Need some advice.
- D16z6 buggy/sand rail build
- project h2b delsol h22/h23 conversion
- h22 swap problems
- Problem, I need some help!
- LSVTEC Oil Feed Line Question
- Need Help With EF H22 Axles
- motor surge when light off but not when they are on
- Vtec problems
- why is my motor missing.
- Swapping a b18b1 in an EJ8 Coupe..have a couple questions for the experts.
- gsr head on b16a block what timing belt
- 92 civic hatchback with gsr swap fuel pump problem...
- Covert OBD II Injector on OBD I harness
- Tuning ls/turbo crx
- LS/VTEC with PCT Pistons. Yes or no?
- How do you "drop in" an engine?
- HONTEC RS EVO.........
- B series motor
- JDM B20 with Gsr head into an 88 CRX DX wiring HELLP!
- crx gsr problems help!!!!!!!!!!
- H22A4 into DB7 integra
- b16 springs in a ls head with shims?
- D16Z6 head on a D16ZC
- LS-Vtec Not starting....???
- b16a3 block with 99 si head Ref'able?
- twin cam d16 zc question ?
- Wiring B16b into eg sir
- type r manifold on a gsr head
- OBD1 distributor into OBD2b car
- Which wiring harness??
- H22A EG Tranny problem
- Is it normal in an H2B Ek for the engine to sit slightly crooked?
- H22A1 into a 93 prelude Si
- EF Hatchy B16B
- 95 Hatch Swap Mount Question
- JDM H22 ?
- LS/VTEC into a DA questions...OBD1
- H2B EK Hatch...possible a/c?
- D16 block with D15 head?
- o2 sensor b18b eg (searched)
- 1989 integra engine swap
- Need advice on my f22 build/swap into my eg
- h2b flyweel spacer need!!
- lag at wot 3k b18b SWAP*Searched*
- Technical Drawings
- searched h22 eg problem. HELP
- 1996 ek with 1995 h22
- Whatever happened to....
- help (z6 head on y7 block) head gasket timeing belt
- where does this vacuum go? ITR intake manifold.
- I need to know what cams these are?
- f22b with p28?
- B20 swap in '97 Civic DX
- b16 with b16b pstons?
- Bent rear mount?
- HELP! No heat and its cold out
- D16y5 or D15z1 swap into EF/EG??
- Any information about 2009-2010 Hybrids?
- Where you got your engine...
- **REPORTING POSTS**
- Problems with obd2 gsr swap in eg
- Any difference between DC2 integra lower tranny brackets ?
- h2b help!
- b16 bad idle with PR3, good with PM6
- Need pics of wiring harness
- fried ecu's
- B16a OBD?
- dizzy help
- d16y8 swapp
- H22 swap into... what?
- are they reliable to buy from or not?
- H2B Hytech Header!!!??
- M2b4 LSD shift cables?
- what driver side engine mount?
- b series
- quick swap question
- d16Y7 ecu in a Type R
- B16B in del sol
- 96 civic w 94 JDM GSR idle problem
- LS motor into 97 civic What drivers side mount/bracket to use???????
- Theory behind H2B
- Anyone know a link to...
- K-SERIES RT4wd Civic Wagon Build
- D series into a honda city(AA)??
- someone please help!!
- poormans type r question
- h2b swap questions
- New to Hondas, quick question.
- Chipped PR3 to run D16Z6 or D15B Vtec in EF?
- K series swap
- H2B Help
- gsr valve tran into b16 head??
- Intake Manifold GSR fitment??
- H22 into civic, my alternator plug only has 3 wires?
- Need some input on SuperTech Valves in my Ls/Vtec
- b16 throttle body on a z6 manifold
- Going H2B Daily Driven. Transmission suggestions?
- s2000 help for a crx
- v tec wireeng???
- Automatic B16a transmission: obd0 style
- how did you take your ARP head studs out?
- little help plz
- Type R GSR Head Problem
- H2B CRX no spark?
- K20 in '93 hatch AEM cold air intake
- GSR vs LS
- Cant get alternator to fit. LS/vtec in 2000 HX
- need nelp with odb2 into a odb1 car
