View Full Version : Hybrid / Engine Swaps
- OBD2 to OBD1 distributor conversion
- testing waters: 93 accord ex g22 build f/s
- injector question for jdm b18c type r
- h22 in eg charging problem, possible eld??
- OBD1 Distributor on type r engine
- Should I lease the new Insight?
- GSR swap into 96 hatch throwing code
- H2B Evo kit Questions
- What to look for? (K-Series)
- How to identify year of b16 head issue.......
- 4x114 question - Need Help ASAP
- Dilema of the day....
- 1995 acura integra ls automatic to stick question
- h22 into an ej1 injector questions
- jdm b20b lower manifold in 99 ek
- soch motors
- f20c into an ep3?
- AC clutch engage without oil?
- dc2 h22a1 need help with ac bracket
- h22 EG Civic wont rev past 4k, solid CEL is on
- Which harness/ECU/distributor for my swap?
- need some help h22a4 into a eg si h/b..
- h22 eg,has wierd throttle issue
- Poor Man's type r build.. internals ???
- H2B with A/c
- k20 into a dc chassis
- ITR swapped 95 teggy or clean jdm b16 EK
- ignition options
- CTR N1 pulley for b18c5 yay or nay?
- 00 B16 w/ CTR Pistons??
- B18C Eating Dizzy's Help Please
- H22 ek civic no spark
- B20 Drive side engine mount in Del Sol issue
- RSX Pistons in B20?
- F20B Turbo or NA??
- F20B in 97 Civic Coupe
- B18b1 into ej1 help
- eg6 w/ b18c1 won't pass 7k rpm!!??
- H22 turbo DC integra
- CRX B16 Swap Wiring Guru's
- P73 ecu work for F20B vtec motor?
- Electrical problems? Car died on highway and won't start.
- H22a4 into EF Wiring Question
- dose this setup need to be vented?
- Jdm B18c replacement into 01 GSR swap question
- Primary O2 sensor question
- obd2a h22 into obd2b ek help
- CG tranny, b16 LSD, 83 prelude / 86 integra shafts
- h2b swap
- QSD H2B Motor mount bracket
- JDM P72 auto ecu
- B18a head on b20 questions
- H22 EG civic, how to make steering lighter?
- 98 b16a2 VTi into 99 DC2 ITR ???? possible??
- H22a swap in EG hatch need help!!!!
- b18b1 help
- 93 b18a1 into 94 civic vtec
- vtec solenoid getting constant voltage
- my first sohc build
- Auto DC4 to H22 5spd Swap Questions
- Exospoeed H2B hood for CRX!
- My J32A2 Integra - Refusal to quit.
- JDM ITR Swap into 95 Teggy LS
- Engine teardown procedure
- What mid-shaft?
- H22 in EG CEL code 14 and cant rev past 2500
- What Brands you recommend for B18C??
- k series interchangable parts...
- k24z2?
- Ahhh Error code blues..... DEQ
- H22A4 in an EG with no sparks
- H23a1 93 civic help anyone?
- h22 in my eg wont work anymore.
- eg/eh w/h22 custom engine torque damper
- h22 ej8 nos help
- h22 girdle swap?
- K20Z3 into EK hatch.
- stock b20z block built gsr head setup
- dohc zc turbo help
- P0441 After JDM B18B Swap - EVAP
- Motor Swap: Wiring Harness Help
- '90 SI B18A1 with old ecu???
- H22a EK Throwing Two CEL Codes - 15 & 21 (Help)
- B18c ITR Swap into 5th Gen Civic
- wires cut on shock tower.92 civic.
- Help: H22 swap in EK vibration at acceleration
- OBD2 B18c in EJ1 w/ Chipped P28, No tach signal
- ls-vtec headgasket?
- gsr tranny vs b16 tranny
- 1988 Honda Civic DX with B20b, injector wiring.
- no fuel pressure
- gsr into obdIIa ek chassis
- RUNNING B16 AS LS VTEC ?
- D16Y8 to B16B swap ~ p/s pressure hose from which one?
- mini me question
- What ECU to use for a B20z?
- Dc2 type r strut bar question
- h22 eg pass. axle popping out problem.
- making sure im on the right page H2B
- f2b question
- DA vs. DC rear mount poly insert?
- Which headers & CAI for my EG/LS swap
- Which ecu/harness combo for b20v?
- 81.5 x 89mm B16A block possible?!
- thinking of buying a motor
- H22 EK Questions
- Solar powered car
- Wiring gurus chime in obd2a, obd2, aem questions.
- gsr door panels in eg
- PR4 to P75, when did honda switch over?
- B20 HELP!!!!FIRST timer!!
- h22 manual tensioner
- h22 with h23 crank
- AEM ems wiring from 00 SI to 99 Integra
- H22 1 plug Dizzy Question.. Pic inside (please help)
- DSM blue top problems
- lsvtec oil catch can???
- rc injectors need help
- compresion ratio with k20 pistons
- H22 with euro R tranny T2T4
- dont feel vtec kicking in
- HOW TO Converting JDM 36mm ITR 5 Lug to 32mm USDM???
- B20vtec swap in crx which tb cable and bracket??
- h2b swap wont go past 6500rpm
- h23 vtec help?
- Mini me/SFC-VTEC question.
- Engine light
- h22 head on f22 block
- 95 gsr into 97 ek questons
- engine building
- 95 GSR engine into 97 civic EVAP purge solenoid question
- b20vtec w/o external vtec oil line question
- TSX CrMoV retainers and Skunk2 Stage 2/3 cams question???
- h22 in eg
- 00 civic swap questionj please help
- D16z6/y7 Mini-Me build questions
- 96-98 EK civic H22A Actual swap COSTS
- Axles Binding! Please Help!
- K24A2 IN EK
- B16a2 OBD2 in OBD1 EG
- H23a Vtec: motor odb1 -> car obd2?
- Avid Racing Mounts for H22A into EG
- h22 hatch vibration when turning right
- k20a3 questions
- Rocker Arms for B-series??
- [Swap] D16 serie into EK
- h22a ek civic needs power steering
- Comp ratio on strait gsr with ls Pistons??
- H22 swap aftermarket shift boxes
- Which tensioner to use?????
- need wiring help ASAP please
- K series Inline Pro Fuel Rail. Anyone got any experience with them?
- Integra Type R AEM cold air intake
- Tuning and Injector Help
- ls vtec piston ???????
- automatic jdm trans and usdm auto trans the same?
- h22a EG RPM question.
- PLEASE Help mini me Questions
- B20vtec on OBDO b16 ECU. Safe?
- b20 swap throttle cable????
- Need Help, CEL #1 reoccuring randomly
- intake inquiry...
- EJ1 H2B setups, please post pictures of your hood clearance
- h22 swap...problems
- how do you set timing??? not so easy with this setup...
- J32a2 EK Trip Tronic build
- NEED HELP ASAP! HORRIBLE GAS MILEAGE IN K20Z1 SWAPPED EJ8
- b20 swap need help
- Rough Idle Problems
- h22 in 97 civic cx
- loom and OBD2A/B issue..
- B-series Swap*Transponder Bypass Module*
- D16Y7 block with D15B head, need help!!
- READ THIS, ECU HELP,B series, Turbo
- Sk2 pro 2s on F20b motor
- Easy 5 lug swap?? Maybe it will work
- (I Need Advice)Frankenstein Motors B-Series(which combos make the most power ?)
- priming fuel pump
- H2B turbo users? post em up!
- Rsx cluster swap HELP
- Header question.
- EG One piece fiberglass front end
- questions lsvtec with gsr crank rods and pistons
- Odd cams, quick ID help
- F22/h22/H23 Build Questions
- NEED HELP NO FUEL!?!?!?!
- mini me
- Ultimate honda swaps - Hot topics
- HELP..............
- ARP rod bolts...9mm a bad idea?
- K20/K24 Build Pics!
- H2b hood for eg?
- b18b/c
- code 8 on h22a swap. tdc position
- H2B Low Profile Valve Cover
- Obd2a into Obd2b car
- LSVTEC questions!!!!!!!!!
- JDM type r can't use scan tool - No communication
- H22 No spark
- Axle swap problems in a '90 DX hatchback
- B series to gsx AWD transmission conversion
- best intake for b18c5 swapped EK?
- B18c in EK, few problems
- where to buy J23 engine?
- b18c r?
- P8R on top of a B18b. Hybrid?
- H22 w/f22 trans in 94 ej mount issue.
- Help! Almost done my B16A swap in 99 civic
- Bisimoto crank pulley for F2D/H2D?
- Anybody running k23a???
- Evap Purge Solenoid Routing/Bypass?
- hub swap - prelude into EK CIVIC ??
- LS/VTEC build..Am I missing anything?
- Need Help With 98 EK GSR Swap Wiring~
- b17 help
- poor man type r
- H22 Del sol Shake!!
- D16z6 in ek
- b18b swap problems need expert advice
- H22 swap in euro civic
- CEL code 4 and Tacho not working
- B16 crx wiring/sensors questions
- Anybody Know anything about K24z2 Need your Insight
- Euro r h22 swap Help!
- Which axle combo for H22 EF CRX?
- lsv or b16 question
- b20 n/a vs b20v?
- msd spark plug cable for h22
- c series swap?
- Engine swap help- J into EG
- what color is tach signal on a 99 y8 dis
- 99 civic single cam dist. to 99 teg wire harness
- G23 piston question????
- h22a into 6th gen civic clearance issues (pictures)
- D16A1 in 91 Civic?
- Depin?
- OBD2 b16 engine in OBD1 integra
- reversing an lsv conversion?
- b18a1 help please
- B18c5 distributor help
- whats needed for d15b head on d16z6?
- CAR WONT STAY RUNNING....PLZ HELP ASAP!!!
- B20 Vtec venting?
- chemical bond Question - What's better than JB for cracked block?
- B18c and B16 compatibility questions
- HASPORT axle problem, H22 CRX
- OBD1 B18c into OBD2a EK3 wiring questions
- evolution h2b block template
- G23 ideas... searched already
- B16 Distributor on B18C1?
