PDA
View Full Version : Hybrid / Engine Swaps
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 [27] 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174
  1. h2b without kit?
  2. my H2B EF
  3. single plug distributor / one plug distributor dizzy d16y8?
  4. Taking out tranny on H2b swap, how hard is it??
  5. H22a into EF
  6. B18c type r swap problem/////////////////////////////////////////////////
  7. which head studs for f23/f22?
  8. 94 Accord into 96 Accord Auto HELP
  9. Q: will a B20 (CRV) head work on a LS block work? :searched:
  10. obd2a/b hybrid
  11. obd1 swap into an ek too complicated, swap out harness for obd1?? INSIDE AND OUT!
  12. 1999 CX to B16A2
  13. EG + H22 + Hasport axels and Mounts... Right axel being a turd.
  14. My answer to the EVO H2B clutch problem i was having
  15. k20/k24
  16. b18c1.....anyone...help.......
  17. Porting a B16/B18 inlet manifold to fit a P72 head
  18. quick b16a2 into eg question
  19. h2b ef, which axles which side?
  20. 87 CRX SI swap to 16A3 with GSR tranny and P72 Help please!!!!
  21. poormans type r::help plz, trouble::
  22. H22A power steering speed sensor
  23. forged pistons and rods for a f23a1
  24. Potential vacuum leak on a B-series swap
  25. hey need a little help with my mini me
  26. B Series Hybrid gods... Am I going to hell?
  27. IAT SENSOR on JDM B18C type r motor on 93 Del Sol CEL Code 10????
  28. f2b turbo questions
  29. ls vtec vs gsr with ls crank..
  30. b20z/gsr engine break-in and start up
  31. Evolution H2B in CRX Hood Clearance?
  32. b16 distributor gasket question?
  33. fuel system/injector choice for h2b eg....also air intake advise
  34. Need Help With Leaking Head Gasket!
  35. b16 and b18 alternator question????
  36. another h2b ecu?
  37. b18c1 oil pumps: can i use one off a 2000 si or does any other gen work? Cant find no one that sells
  38. CAR OVERHEATING NEED HELP!!!
  39. b18b swap into civic with b16 swap
  40. d17 block with d16 head
  41. My build plan.. What do you think?
  42. slow car
  43. My LS/Vtec Swap *!*
  44. Modifying GSR P72 Rear Engine Bracket Mount to fit EK Chassis
  45. k20 into a crx?
  46. k20Z1 eg supercharge??
  47. symptoms of a blown head gasket?
  48. ek b series vtec wiring confusion
  49. shifter bushing?
  50. manual h22 swap into automatic ek
  51. K24/K20 build question
  52. b16 block ls tranny will it work and how well?
  53. Will b18 LS skunk 2 intake manifold bolt up to b16?
  54. Well the B20 A/C braket work with a single cam compressor?
  55. Best swap for the money?
  56. need help with iacv fix
  57. f22 final drive on H22 tranny?
  58. Hard to Crank on Cold Start
  59. H22a Question??
  60. wiring problem with wideband O2 VX engine into DX chassis
  61. Need help these Hseries are headaches. Fuel line too short H2B
  62. Do I have to slice and splice the injector clips on to My DX Harness
  63. obd2 engine into obd1 car
  64. 95 GSR into 96 Civic - BAR question
  65. another H2B question
  66. i need a little help.
  67. D16Z6 into 1997 Honda Civic EX Tech Questions
  68. obd0 B16a1 into a classic mini...wiring gameplan help needed.
  69. Anyone BAR a 96 ITR motor in an EG?
  70. My H2B Euro-R JDM RHD EJ7 build thread
  71. H22 DC Integra power steering
  72. 92-96 Prelude halfshaft use with k20?
  73. Power steering pump ID
  74. Help with clutch bleeding on evo h2b??
  75. vtec not activate h22 swap
  76. Ford Zetec in CB7 swap
  77. Built Motor Mileage?
  78. K24a4 swap - Worth while?
  79. Failed state ref. experts needed.
  80. obd2a/obd2b
  81. doing a trade but need suggestions
  82. Question about 0bd2a and Obd1 wiring dizzy bad idle
  83. EK4 head On B20 bottom end
  84. Help Please. No RPM or Speedometer fignal on H-22 Swap
  85. F20c ae86 swap
  86. Wiring B series swap Ef sedan (noob question)s
  87. H22 into EG rear mount question
  88. jdm engine difference
  89. Shifter bushing?
  90. What else can a 1992 - 1995 Civic IACV Bolt Up To And Work Perfectly?
  91. Power steering on Eg with gsr motor.
  92. bogs when i bust V-TEC
  93. Which gasket set? F20B w/H22 head
  94. H22A into EG, What ECU?
  95. Help installing ITR intake manifold onto JDM B16A OBD0 motor in my 88 CRX Si.
  96. OBD 1 B18b Swap into EJ2 not starting!
  97. crvtec
  98. Check Engine Light - Code 16 - injectors - not main relay
  99. V6 swap - Anybody done it with the new Hasport kit?
  100. cant make up my mind
  101. Hesitation ONLY in Vtec
  102. Power steering on obd1 b16a
  103. need help!! H22A4 install into a 95 ' eg
  104. Whats up with my axles?
  105. ls/vtec question
  106. SOME H2B HELP NEEDED
  107. Swap coming together need help on final touches
  108. engine swap, what is everyone's favorite engine into a civic?
  109. b18b whit b16 tranny ??
  110. very high idle on h2b civic
  111. CA Bar certify K-swap????
  112. B18a1 into EJ question
  113. obd2 > obd1 cel
  114. HELP!!PLEASE!
  115. Engine questionsd
  116. obdI or obdII jdm gsr question
  117. 1.2K RPM idle...... need advice
  118. Need help with vtec solenoid wire and distributor plugs
  119. Another Jersey H2b Built
  120. d16a? help
  121. H22a problems
  122. HELP!! chopped obd1 wire harness
  123. Got some plugs left over on my H2b swap???
  124. Info ON Which Head is Better B16 OR B18c gsr
  125. engine choice dilema
  126. New To Forums
  127. Help me locate
  128. vtec not activate
  129. h22a plastic shifter?
  130. LS VTEC Cylinder Head Question
  131. B20 swap, Power Steering
  132. Oil Consumption Problem?!?! is this normal?!?!
  133. Throttle cable for eg with b16 swap
  134. No timing cover with evo kit?
  135. EG H2B kit.
  136. i have a b18a need some help
  137. Which order for injector colors?
  138. urgent!!!!!!!!!!!!!!!!! need a quick answer are all bseries bell housings the same?
  139. B20 Engine Swap Into 99 Civic SE
  140. WTF is honda thinking????
  141. calling all ek k20a owners
  142. OBD2 to OBD1 I have searched other write up and diagrams!?
  143. k20 cams
  144. o2 sensor problems!!!
  145. taking off h22 butterflies what to do with the longer bolts?
  146. K20a Owners
  147. QSD H2B plate not lining up
  148. OBD2a into 2b, I'm confused.
  149. h2b timing
  150. h22 swap question
  151. OBD diagnostic connector
  152. EK - H22 axle binding....
  153. del sol b16b swap questions
  154. How Can i BAR a K20A2 in my 1995 integra. in CALI. Questions on the swap
  155. Newbie Question: H22 swap manual to auto....
  156. H swap need help what to do with heater, CC, and egr stuff?
  157. B20 issues need help
  158. mini me d15b2
  159. Mini-Me Swap. need to clear up a few things.
  160. k24a1 with k20a2 head....
  161. NEED HELP ASAP PLEASE
  162. H22a into obd2b 2000 Si -- wiring questions
  163. B16a2 into 1997 Coupe with D16 - HARNESS questions and IMOBILIZOR
  164. when swapping an engine....
  165. NEEDED ASAP: OBD2B INTEGRA GSR VACUUM LINE DIAGRAM
  166. questions and opinions about a mini me swap
  167. B18 or H22
  168. 3in. mufflers
  169. eg/dc2
  170. B20 into EK problem
  171. ls/vtec Vs Cr-Vtec
  172. Calling all LS/Vtec gurus
  173. h22 vs. h23 - head height?
  174. anyone have a good thread on a b series swap in a 92 four door ex
  175. Quick Question on LS/VTEC knock sensor hole
  176. 96 EK hatch with b17a gsr swap, wiring complete, fuel pump not sending fuel.
  177. What are these sensors on the back of the block?
  178. which axles
  179. What mounts for H22 swap into EK?
  180. si brackets
  181. confused on mounts
  182. Axles question - GSR LSD tranny into CRX.
  183. MSD obd1 - obd2 adapters?
  184. In need of help with obd2a to obd1 gsr swap in 96 Civic DX hatch
  185. H2B Vs. H22 4.64 FD
  186. 96 cx b16a2 rear L bracket from si wont fit!!!!
  187. Have a quick question
  188. B18C - Missing coolant nipple on block.
  189. GSR Swap in EG what Intake
  190. GSR Engine HELP!!
  191. tl
  192. MULTI-PLEX ?
  193. HOW TO PICK MOTOR UP
  194. Need Help - Swapped trans, now CEL and runs rough, B18c1 EG civic
  195. b18c1 gsr swap questions
  196. Which h2b kit
  197. k24c into an 01 integra
  198. h22a ek?
  199. Mini-me starting problem possibly timing issue***
  200. coming soon
  201. Trouble with my swap
  202. euro r h2b ?
  203. f20c /k20 transmission need some info
  204. My first engine swap, yes i am a newb....b18a1 into ek
  205. Can i use a 97' h22a4 in my eg obd1 h2b?
  206. F2D - possible downfalls? ( hood spacing, clutch )
  207. Got the iabs working with the p28
  208. H22 EGR Vacuum help
  209. name this sensor
  210. obd2 h22a swap in a 94 prelude type s,what probloms will we run into??
  211. When receiving your new motor....
  212. One last q on h2b eg
  213. h22a4 motor mount bracket same as h22a1
  214. anyone a dohc F20b guru?
  215. H22 civic EGR help! EGR solenoid problem?
  216. cel code 4???
  217. h22 in a del sol, not passing emissions...
  218. K Swap Newbie questions
  219. Post up your QSD H2B EG driver side fram rail pics please!!!
  220. DESPARATE DOWN TO THE POINTOF NO RETURN!!!!!!!!! READ UP
  221. 4wire o2 sensor ECU Pins
  222. b20 swap parts into ef
  223. Cable Transmission into EK Civic Question
  224. Fitting D series AC Compressor to Integra Condenser/etc AC lines? ( H2B related )
  225. B16A2 with CTR EK9 Pistons for Daily drive
  226. Bad MAP, Leak or conection???
  227. b20 block is it possible to use Ls Crank?
  228. Car stays on????
  229. Timing belt???
  230. CRX-GSR swap: OBD2 throtltle body on OBD1 car?
  231. sharing my b20 experiences thru obd0 obd1 and obd2
  232. Evo H2B kit in eg and not having to shave the crank pulley?
  233. Easiest swaps
  234. Taking apart distributor.
  235. accord headlight swap... Help please
  236. E85 question
  237. B18c Swap Doesnt run
  238. h23 crank, h23 rods, h23 pistons in h22a block
  239. ls\vtec eagle conversion kit
  240. Motor swaps illegal?
  241. b16a into ef hatchy
  242. Which axle for crx 2.gen?
  243. f22 ej8 swap
  244. JDM H22A into DC2 I/H/Cat Fitment Question
  245. 1997 Honda Civic EX with GSR Swap
  246. b18c engine emissions in nj
  247. swapping OBD2 H22 into OBD2 integra
  248. Poor mans Type R in a DA???
  249. h22 ek with a/c and turbo
  250. will the head from a dohc F20 fit on an F23 block??
