View Full Version : Hybrid / Engine Swaps
- anyone go to Max Ha Racing (MHR performance)?
- B18C into LS DC Integra
- SOHC ZC?
- NOT RUNNING GOOD AT ALL.
- motor swap from hell
- Will the stock H22 TB fit on my D16Z6 intake??
- hcp ek mounts with hasport axles??????
- 95 coupe si h22a4 conversion HELP!
- my swap wont turn over
- hey guys help me finish my swap h22 sensors
- running obd1 on 2000 b16a2 and wont to go back to obd2
- main pulley problems round 2
- tach wont work....wtf?? help me please.....
- Manual tensioner, need to know if this part is needed?
- Whats Wrong With A B16
- how to check codes after swap?
- quick question?????//
- H22 EG6
- ? about b20 with itr or other tranny
- 2000+ jdm b20
- Swaped auto for 5 spd, where is the Park sensor? Won´t start.
- ok i want honnest opinions, not a world debate...CRV-TEC b20/b16
- 93 del sol with jdm b18c1 runs bad
- b18c5 SWAP IN 95 CIVIC coupe
- ls/vtec headbolts?
- K-Series Swap
- b20
- OBD2B - OBD2A Problems, please help !! Weird conversion harness problem.
- obd 1 injectors to obd 2 harness
- si steering,suspension and brake parts on eg sedan
- oil pump sensor
- rear shocks are dead
- will a gsr cai fit on my ej1 with a b18c1 swap?
- ITR in my civic swap.
- B18b tranny Q!!!!!!!!
- Which belt for ctr crank pulley
- h22 swap into 93 integra???
- !!92 cx hatch wont crank after 97 ls swap installed! help!!
- Will an h22 fit in a accord???please help!!
- need help
- WOULD THIS FIT?
- Official K20z1 into DC2!! (Information)
- ctr head on b18 block
- LOOSE TIMING BELT COVER AND CRANK PULLEY
- NEED DIY 96-00 CIVIC HATCHBACK B18C GSR OBD 2 SWAP WRITE UP!!!
- h22a header with 96 accord chassis
- HELP>>What spark plug wires fit a ZC DOHC engine?
- ls/vtec turbo
- What the best air filters
- Which Catalytic Converter?
- just a pic of my finally swapped b18c1 motor nothing special
- H22 in a EK ... about to go get BAR... any advice/tips?
- K20A RSX TYPE R
- TB pulley/ shutter adjustment ?
- whats so bad about...
- h22 dizzy ???
- K20A2 (type-s) into an eg, How much would that cost me just to get it rolling?
- Should I?
- civic si cam
- h22 swap into ek quick quetion already did search thankx
- high engine temp on highway
- Z6 in a 79 civic?
- Valve cover DZ
- Just installed AN-R header and ported out IM on H22A, im getting engine codes i dont know why?
- can someone tell me more about this cylinder head?
- Clutch wet with oil? help
- ac and power steering brackets B18c
- ls cams in a b20 head?
- is a b20 worthy?
- B20B/vtec head gasket leaking?
- h22a swap into ek i need some desperate help please.
- h22a swap ? please look inside. thanks
- LS/Vtec v.s GSR
- ef h22a swap help (searched)?????????
- d series cranks
- H22 swap Civic EG ECU question
- b20b ? with gsr head
- The name is james knight
- Need help with obd2 jdm gsr vacuum lines !!
- help with ecu
- mini me, bear with me
- H22 - 71 - P0301 - No. 1 Cylinder Misfire
- HELP PLEASE! Old motor out, help getting new one in.
- LS Crankshaft and Rods into GSR
- 4 puck sprung vs. 6 puck unsprung, clutchmasters vs act tell me what u think
- My H22 swap Done But Have Problem Axle.
- K Swap Part's List
- H22 in EK.. which throttle cable?
- B18c1 Swap - Wiring Butterly Valve/Dual-Stage Intake??
- LS/Vtec
- f22a6 into a 89 prelude si?
- car just keeps dieing
- LS VTEC TURBO finally in! Wiring Help! Please
- TSX Headr Question
- automatic B18 longblock & manual any difference??
- crankshaft pulley bolt
- 96 EK ECU Plug question.
- Pos LS tranny....
- Removing a D series engine from a CRX with no hoist? drop it out?
- motor installation cost
- Will a P2E start an h22a?
- complete H22a EK swap work on a EG civic?
- automatic turbo
- info on f22b swap into my 95dx civic
- How much is this car worth?
- 1998 civic swap?
- Geo Prizm
- Broken motor mount, need help ASAP!!!Pics inside
- USDM to JDM Conversion
- obd2 gsr swap in obd1 del sol tach broke
- h22 ek vacuum problem
- Fresh Build Wont Start
- h22 in 93 si hatch. i already searched wiring help
- Does GSR cai fit into EK
- b16 tranny in DC2 clutch line question(plz help me so i can order the part)
- K20A2 Swap In 97 ITR
- ITR swap in ek- o2 sensor question
- b18c-R swap. plug wires? spark plugs? 1/4 times
- HELP Please...Quick Question?????
- H22 in Eg hatch
- a supercharged ls in a hatch
- what axles to use?
- Having a little trouble
- Please help with IACV problem!
- Help me figure out this noise in my head...
- Help motors dead and need a replacement!
- sourcing mock up engines/trannies. where to get em
- DA Progress sway bar on a 98 Civic DX?
- B16 head/gsr block build. need help.
- b16a2 motor w/b20 tranny?!?
- 95Ls integra with gsr swap?
- wire harness choices for b18c swap
- bogging problem, low rpm, cold???
- 91 ls head on 93 ls block
- B series trans question
- b20 swap help
- GSR vs. B16a head bolt pattern------need help soon!
- witch is better gsr or type r
- B18C cable VSS question
- Best Place to buy USDM Swap
- 99 Ek Hatch-What exhaust?
- ls/vtec starting problems
- Slanted / tilted engine... yeah that could be a problem
- need some recomendations for a shop to do a swap in south east
- OEM injector driver / resistor box
- GOT A FEW QUESTIONS ON A ENGINE SWAP
- How do you take out a Single Cam in a 93 EG
- a bunch of sensor queries, and knock sensor is it sheilded??
- Looking for GSR tranny w/ LSD..
- d16y8 IM on a d17a2 motor
- Swapping gsr into 92cx hatch help!
- B20 question
- japaneseengineimport.com?
- a little Question from a noob
- 2000 gsr jdm b18c into 98 Civic HX (non-vtec) wiring?
- b18b into 92 DX hatch
- is there a polarity for the IAT sensor?
- Ej6 dash wiring Q...
- B18B w/ cable trans Into 96-00 Civic
- integra obd1 ecu m/t code b18a1
- b18a1 swap. is it worth it??
- obd2-obd1 conversion
- B16 trans problems
- ECU Not fitting?
- superior trading international (anyone bought from them)
- b20vtec turbo or NA
- H22 Whats this sensor( Last minute wiring)
- obd1 ls distrubtor work on a obd0 ls
- i'm been shoppin i have some questions
- H22a (OBD1) w/auto swap into a 98 Accord
- B18C1 into a 92 VX... runs poor... any help?
- Quick Question Resistor BOX
- Breather Chamber Lines? / alternator bolt
- HASport stage 1 axles
- b18c in civic
- H22 oil leak
- Help on Decision Making for a Motor Swap. B18C5, H22A4, K20A2
- engine dampners
- 2.3 F23 2000 accord engine fit in my civic????
- Do I need a tranny?
- Best tranny Choice for K24A2 TSX Motor ... K series Tranmission Table Inside
- need info >>> b20b installation into 93 civic cx???
- From the Far East Land of SPOON...ahhhh!
- A d16 in a n600
- 95 civic to integra gsr automatic conversion
- strengthing the h22 ek driver side mount
- 94-95 GSR Swap, What is the going rate?
- custom breaks?
- 96 specs
- h22a eg owners who have gone through the CA state smog ref
- help, i need the stock motor mount diagram ASAP
- Question about an OBD-II ITR engine in an 88-91 CRX
- AEM EMS
- 2.75 exhaust 98 gsr to big?
- p28 for 2000 JDM ITR engine
- Starter question
- B18c In Civic Problems
- Anyone with KTeller Exhaust Piping?
- b16 swap.
- JDM P73 and USDM P73 ... How do I tell the difference ?
- B17 block, what crank, rod combo's will fit?
- b16 head on b18c1 block
- guide on how to instal a b16b into an ek
- 98 type R ecu w/ b16a2
- CRX MOTOR MOUNTS
- need help for a built mini me in a crx
- K20/K24 Q's
- What size exhaust. B18 in a EG with stock exhaust "like 1.5" or something"
- Manufacture that builds conversion harness plugs...
- B18c Into 99 Civic
- head milling on a mini-me?
- 1999 Honda Civic EX
- quick question: B16 clutch fit on B18A/B18B block?
- Will a D16A6 block work in a OBD1 car?
- Problem with axles (H22 in EG hatch) .. need feedback.
- H22 w/ HCP mounts post here!!
- b20 vtec problems
- what cams are these ...
- LS to GSR Cluster Swap??? Tach is off???
- which shifter bushing set after swap?
- H23 prelude engine into a 91 civic hatch?
- Just Completed A ZC Swap... Code 4 & 8
- 00 si b16a2 into a 00 ek help.
- h22a making weird noise from timing belt etc....
- Jumper Harness Gone wrong
- Last minute H22A swap crisis!
- H22 A/c Compressor in EG Hybrid?
- B18a block with B16a pistion.......concerns????
- Head gasket thickness for a stock b16 an a mugen..
- B16 Stock Head Gasket thickness an mugen..
- jdm gsr lsd swap in to 94 ls questions
- H and C transmissions, and AT Engine to MT transmission
- Single to dual cam head help required
- b16a1 into eg6
- Anybody rockin a B20b GSR?
- at swaps are plug and play into a 1995 civic hatch?
- swap hesistates obd2 b18 eg
- Water in my motor
- z6 swap gone wrong
- JDM B18C > ECU / Harness Problems - Please help !!
- k20a in a 92-00 coupe?
- This a good price for a b18c changeover?
- h22a accord tanny side motor mount
- f20b into ej8
- obd2a motor with obd1 ecu into obd2b civic
- question about 93 b18a into a 91 civic.
- How far can you bore on stock sleeves?
- H2B kit questions
- Putting a B18C1 shortblock into my B16A swapped hatch. What do I need?
- 94-01 integra pedal assembly fit 92-95 civic?
