View Full Version : Hybrid / Engine Swaps
- jdm harness or usdm?
- Anyone ever have and problems with bad engines that were purchased through reputable companies
- are the distributer plugs the same on...
- S2000 Swap?
- Will the IACV from my DX fit ...
- ****Best Fitting Supercharger in a civic hatch w/ B16a??****
- which motor? (ls vtec, h22 or b18c)
- B18C5 in 96 EK prep
- how much have you all spent on a h22 swap
- Buying a hybrid, I have a few questions though...
- Getting ECU Error codes 14 and 8.............. How do i fix??
- K20A Swap
- h22a intake setup
- how do i make 4 carburators fit on a dohc swap
- Would it be possible to swap a B series into a honda insight???
- which headgasket
- obd1 wiring distributor
- Hybrid owners - keep your receipts or lose your car
- Small question concering h22 shifter linkage and integra center console.
- h22a Ek header clearance under the car?
- Timing OBD1 H22a- Don't have this helms- need advice
- Jdm Gsr Ecu?
- deals in NC
- axles
- Iacv
- New to hybrids! but not to honda's
- H22 just arrived!!
- Code 21 on OBD 2 B16
- B20 exhaust in hatch 92
- h22 into civic ek NEED PARTSSS!!
- CRITICAL HELP: Engine Harness related question.
- my block came in today finally!
- Questions before I buy my motor...
- need major help on b16a1 parts info have block head and intake manifold
- b16a1 block and head and intake manifold 4 sale in so cal
- Need Info. on European DC2 type R engine (already searched)
- What car for a b18c5 autox car?
- Comparing b-series dist.
- need help. asap
- Attn: people who have done auto to manual swap (wiring questions)
- Is the crank pulley bolt the same for B & D series?
- H22a on an Acura CL
- JDM B16a Oil Filter......
- dist wiring problems
- swap problem?? need advice
- Hydro tranny on a b18a
- chipping or piggy back???
- 94-up B18b into 90 EF,,, a few Q's
- B18C ecu
- CAble to hydro tranny?
- engine swap for a 89-91 prelude
- turbo GSR motor in S2k ????
- Mini-Me Questions: Y8 Head, A6 Block
- i am a little confused
- Need Help On Finishing Type R Motor Into 91 Sedan
- what kind of intake do i use in a h22a swapin a Civic HB
- StreetStyleRacing.com? Anyone heard of them?
- what do i need to do a b16 swap in a 89 civic dx
- d16z6 into a 91 civic dx
- vid of 13.4 pass
- ***need help ls eg swap allready did search***
- what do you guys think I will run?
- H22 mount kits
- How to change my tranny oil..
- Complicated Swap, need help
- 6th gen accord H22A swap wiring info help!
- 90-91 trannies same as 92-93
- J-spec H22a motor swap into a civic hatch
- F22 ECU on H22
- Honda Civic 94 w/ H22a ......Everyone help.......................................
- Difficulty of swap???
- What do I need for B18 in my Accord?
- strange hybrid setup....how will it run???
- H22 hybrids for sale (anyone)!!
- DIY Port and Polish pics
- need help h22 swap
- H22 guys..... Speedo is almost accurate if.....
- I'm so close to finishing but, I have a few ???'s
- Another swap question
- Need advice on a JDM ZC 1.6 Vtec
- 98 LS into a 95 LS.....
- ITR B18C6 into EG hatch...
- Got a quote on a Type-R changeover! Want to know if this is a good price.
- b16 setup in CRX: I have a clunking noise over rough road, pass. side
- Q: B16 in EF w/ OBD1 GSR Harness..would it work?
- Cleared all my codes, but the Check Engine light comes on after 5 minutes of driving!!!
- After B16 Swap. Engine Surging.
- h22 in accord, which fuel pump to pick up
- Distributor Fitting problem
- Another satisfied Hmotorsonline.com customer
- GSR Hatch please Help!!
- H22 Turbo...
- B18B in 94 cx, can i use the stock radiator hoses?
- ls/vtec rev limiter?
- hydro to cable trans swap. can it be done??
- Common problems with swaps?
- Anyone with LS/VTEC?
- ECU pin , do I have the right ECU??
- Wrapping up swap, car won't start. Need input.
- h22a in a teg, engine harness question
- h22a into a 93 prelude si automatic????
- i did a search, but nothing....sooooooooo
- what swap would you suggest?
- specifics on a swap
- OBDO-OBD1 harness
- Engine blocks and OBDII
- New Member - Finally made it
- anybody pass emmisions with a jdm b18c??
- Need shift cables to finish my swap, How do you remove them?
- I give up
- Fuel injectors not spraying
- swapping h22a4 into ek
- B18c1 swap into 94 EG - Radiator question
- HElp I need help with an H22!!!!!!!!!!!!!!!!!!!!!!!
- h22 swap question?
- EGR cel...
- tech ?
- code 43..?!?
- intermediate shaft length
- b20 in an ek...why does the DX ecu work better than the LS??
- H22 swap HELP!!!!!!
- Swapping a JDM ITR engine into my 2001 GSR, what will I need.
- 1985 Civic Engine Swap
- JUmper for H22 into EK?
- need help with swap
- ls/vtec headstuds
- d16y8 turbo swap into 2000 hatch
- boosting a b18c5!
- b18 swap into a 93 civic
- 93 h22a jdm in accord 94 ex wiring?
- ATTS screwin ME???
- gsr swap in a 92 civic bubble
- H22 Heater Hose Help!!
- '94 B18C GSR motor into '91 LS
- Does anyone have a H22A4 swap w/ sportshift auto tranny into Civic?
- H22 into 88-91 CRX
- after swap problems....need help and info
- please help need oem part # (b20-ek)
- my first motor swap done and running well.
- WTF? Downpipe h22, Could it be wrong?
- h22 idling at 2000?
- d series swaps
- 89 crx si b16a1//What is a good cat back and header for this car and swap???
- whats needed on a 99 ls swap n2 a 92 hb cx?
- vtec head on sohc
- Type R Eg Hatch
- EG6 swap
- Rear Disk question (searched)
- Need help from you guys again, regarding D series motors....
- Swap Wiring Nightmares
- Need Help B18C1 in 92 Hatchback VX
- I need one Eagle rod bolt.!!!!
- vacume lines?
- Vacuum lines for H22 in EK
- Engine swap; Transmission?
- B18C5 EG w/ Comptech Icebox?
- surging idle
- need to know where i can get obd1 to obd2 harness help!
- EF9......H22A??????
- Where did you get your swap and how much??
- LSvtec/B20vtec water pump - why change to B18C1/5?
- What a/c belt on 00 gsr swap
- What "little things" will I need to complete a GSR swap to my 93 Civic?
- 96-2000 shift linkage??????
- no top end...no vtec....
- New to Swapping
- Gonna try one more time... Idle issue, help needed!
- Motor weight
- b16a+ctr head...
- Y8 Intake & Exhaust Manifolds on a Y7?
- Removing your governer?
- green plug, back of block, what is it, wheres it go?
- what's the cc rating on 90-91 acura legend injectors
- ls turbo or gsr swap...which one?
- JDM B18c (gs-r) in a 89 Integra .....legal ..and fitment Questions??
- tranny question
- brake caliper swapping
- D15B dizzy work on D16A6?
- p30 pistons on ls rods... have a few questions
- i need help!!! transmission gurus!
- Once again I need help with my swap
- what do you guys think? All motor or turbo on h22EK ???
- H22 Civic road race report
- 90 Prelude-- B16A1 Motor has this been done before??I am Attempting
- h22 Civic Suspension HELP
- Hydro trans in a 90 EF, cable or electric speedo conversion Q's
- For the last time..does a GS-R exhaust fit on an EG hatch?
- k20 in EG/EK?
- IAB's on h22.. need some help.
- Mini Me...
- H22 guys.... WTB stock flywheel!!!
- Dyno Plot: JDM 00 ITR in EG.
- need a d16z6 wiring harness
- 1/4 mile times for B18B
- distrib and wiring for H22 to EK
- Question about which ECU to use for my swap?
- Swap planning
- I am new to civic's
- H22 in 91 (3G) lude?
- vtec not hitting
- o2 senor problem need some help, please?
- A quick Question for the GSR/Hatch's
- b series into EF questions! HELP
- eg H22a swap shops in Cali?
- 93 jdm h22a in 94 accord ex wiring harness ?
- JDM b18c vs JDM b18c LSD
- del sol A/C bracket mystery partially solved!
- 92vx b16 swap Q. heated O2 sensor
- 9 Pics of my hatch 95% done being painted Seal grey Metallic
- H22 guys..... T belt question.
- jdm motor to pass cali emissions
- one thing after another for motor swap
- d16 turbo or b18_?
- Help B18 swap into 89 crx si
- sohc vtec ??????????'s
- swap harness etc?????????????????????????????
- Don't have any tools and don't have anything to pull the engine out! Need help on finding some where
- HELP! i can't find this part! honda doesn't sell it, but its a honda part!
- what civic hachback is the easies to swap
- b16a1 into 86 crx si (turboed)
- Pics from East Coast H22 Hybrid Meet... (Not 56k Friendly)
- ex harness swap question
- GSr drive train in a 1990 rexsi.
- a/c setup prob in Hybrid
- Cannot get the clutch housing off, little help
- Will this work? Good Idea?
- Power gains with B18C4 block & JDM ITR o/sized pistons!!
- How Hard? 94 'teg b18 into 99 honda Civic LX
- motor swap
- h22 oil problem? is it a concern?
- LS/V-Tec Question?
- 2.0 Prelude swap?
- wiring diagram ?
- 4.785 final drive and itr lsd in a hydro ls?
- got a question/ need a answer
- What A/C bracket are u guys using for a 95 H22 swap into a 00 integra ?
- Help! o2 wiring and high fuel pressure... 56k Ouch...
- Swapping Cams...
- upper motor mount broke, 1 bolt still broken inside motor, need help.
- Anyone installed a B20 in a 1998 Integra type r
- 91 teg b16a easy question
- Mount question?
- problems finishing wiring up harness?
- Civic type r swap axles ?
- What's the deal on the B20A
- No Vtec, what could it be?
- Automatic Swap
- IAB Question
- LSVTEC in 94 Dx Hatch
