View Full Version : Hybrid / Engine Swaps
- H22a in 94 hatch??? Looking for some good information on doin the swap
- Anyone have any B16a exhaust valves???????????
- !!!!!Wiring diagrams for 96-00 civic. Does anyone have them?!!!!!
- At least i didn't build the motor in my basement.
- (Did a Search) Vtec Wiring???
- Good Do It Your Self websites
- type r head, bolts or studs on the exhaust manifold?
- h22a mounts? what are the major differences? need for a certain hybrid project
- Anyone know a shop for D16Y8 into a CRX?
- Hybrid time?
- not getting fuel- ITR 1.8 in 99 si-and o2 sensor ?
- civic and Integra pedal assemblies
- need A/C in 00 civic ex with obd1 gsr, what do i need??
- Auto to manual hyrbrid conversion how much does it cost? and can anyone do it for me in DC?
- Those with LS/VTEC's, what pistons are you using?
- ls swap into my eg hatch? just need some confirmation...
- Help needed ASAP please...pleeease!
- Front right tranny mount from a 97 dx engine work with a b16a2?
- who would like to see something like this?
- H22a mounts. Which ones should I get?
- D-series AC compressor work on a b16a2 block? 97 dx engine
- 95 civic hatch, b series swap, need motor mount inserts... ???
- dallas meet tonight
- ls vtec head
- good price on a b18b
- ECU applications? (will an XYZ ECU fit into an ABC car...etc.. ? )
- EG civic B20B/VTEC or H22A?
- Type R in 98 hatch question
- What Kind of Cai to use in gsr hatch........
- 96 gsr complete swap into a 2000 civic ex -- what else is needed?
- 89 CRX (B16 vs. B18C)
- MY CRX will not pass emisions!!! B18A1 swap!
- Finally decided to get B18C5 for EG. But where from?
- GSR crankshaft and Pistons/rods in a b18a block??
- ahhhmmm...........CRVtec first get Teg
- "Best Bang for the buck" Radiator
- hcp rear mount problem w/ my h22 hatch
- B16a2 ACT clutch with LS tranny ???????
- JDM B20B '99 into 94 Civic...Mounts?
- has ANYONE gotten a good swap from Osaka?
- a valve cover question
- jdm?
- o2 sensor wiring question
- Whats a B series 1.8 vtec from a UK '96 5dr Civic called?
- Question about Piston rings, order of installation
- CRvtech
- b18b into a 89 civic DX hb? easy as it seems?
- I need a wire chart for hookin up my 02 sensore
- leaky trans
- sensor problems after H22 swap
- wiring harness??
- b16 cable tranny w/ b18a
- Need VIN To Connect to ECU (for 95 integra GS-R)
- fuel pump issue
- Wondering if my motor is worth moding.....
- would a h22 fit in my 90 civic hb?
- ideas .. check this out
- IAB, who needs them?
- Anything wrong with this LS/Vtec setup?
- Shopping list for H22/97 Ex Swap
- A few questions now that my swap is complete
- B18C + CRX...Ground clearence?
- Springs for H22 EK?
- help with CEL
- Which Helms to buy?
- Password:JDM? Any good?
- 97 EK B16a What ecu??
- Anyone have an extra PS bracket off a B18A or B20B/Z?
- Sir2 In a 94 RS Integ
- whats the difference between 96-99 Gsr's and 00-01's????
- Will a B16A (SiR I) bolt to a......?
- p28 or p72 ecu
- is a cx swap the same as dx swap in 5th gen
- 92-95 h22 tranny cables = 97-01 h22 tranny cables
- DOHC ZC question
- quick ? about the tranny mounts
- Cruise Swap
- Help! Need help on deciding which motor to get and what parts to use to build it"Race Crx"
- No pressure on the clutch pedal?
- I'm looking for a cable to hydro conversion..........
- Newman
- How fast should an h22 in a civic be? is 14.3 right?
- J32 swap in an accord
- b16a2 into 91 CRX??? reply only if you wanna' help...
- Happy New Years, Anyone working on any winter project? check mine out..
- timing ?
- Shift linkage H22
- H22 EK axles, HCP recommended axles, or JDMSHIT.com?
- exhaust?
- What can i do with 7K?
- Why is my *friends* car so slow? (GSR Hatch runs 15's constantly)
- ls/vtec
- b18?
- H22A vs. B18C5...only if you have done both swaps...
- GSR w/ B16 head
- calln' all h22 civic's with 30mph vibration
- idling issue, help, searching for info on 90 civic ground fix.
- Who loves secondaries?
- Throttle Cable
- What is this thing at the side of my engine block. It has a very long wire attached to it.
- i need help!!!!!
- Distributor troubles
- what to do? 90 civic hatch, h22, b18. got it all. or $100 d16 dohc?
- comptech 4-2-1 vs dc 4-1?
- diffrnt pin outs on the 99 ecu ????
- OK...help me decide what to do with my $$$
- 5g ?
- p28 w/ knock sensor
- got a b18c1
- how to install 95ls motor in 94 civic....
- Checklist for my swap... help me out?
- how do u tell the diffrence from auto or manual p13?
- LS to GSR in a crx
- Kenji? Changed my mind. May need you help?
- Info on 86 CRX Si swap???
- question on wiring vtec
- sohc f22a vtec head on f22b block
- ?V8/V6 into a honda CRX
- What engine harness for b16a swap?
- Wire harness for ZC??
- b20 in crx overheating
- I need to know valid info on LS-Vtec
- c21 ?
- SOHC VTEC-obdo or obd1?
- B16A1 swap, but Speedo doesn't work???
- DX to ZC Wiring diagram
- d16z6 need a lil help
- JDM B16a1 Motor, But what clutch do I need
- B16A wiring into a 90 Integra
- Will these axles work? HELP ASAP!
- D16A1 head on D15B1 block?
- pulling the motor...
- swap run times?
- time to swap?
- Anything Bad about skunk 2 valve spring?
- Broken Place Racing Mounts!
- How much Clearence?
- Honest opinions on difference between hydro/cable tranny
- what year did integra get obd2 version 2 update???
- Swap problem. Need Help
- ls axle question
- Where To Get: Hydraulic to Cable Conversion for 1991 Civic?
- B16A or B20..no not the normal post
- b18b cams vs b20b cams
- Let's talk about OBD's and what GSR motor for a 93 Cx!
- a Just did a swap and now CEL is on..
- Oil Pans
- bad idle on b18c5
- Swapping a D15B7 out for a D16Z6, Need help with wiring
- ITR Motor In 1991 Si Hatch
- Swap wiring question
- www.sgbodyworx.co.uk
- Swap Mileage?
- An Acura CL Engine in a Accord
- B16a head on a gsr block????????
- How can i change ek h/b to 5 stud wheels ?
- b18c5 into 92 si
- vtec cams in a non vtec head
- ecu question
- h22 in a crx....???
- Help!!Choosing Engine.. B18B Vs. B16a1
- swapping a b18c into a 98 civic dx auto
- Zc turbo Vs. B16 + simple bolt-ons
- ECU Codes
- best site for lsvtec how to?
- obd2 b20 to a second gen teg
- '92 ls Intermediate shaft work in a '95 Integra?
- B20 setup cost
- My h23/h22 plans......
- Is this correct?
- b18c?
- h22a fuel question?
- does h22 have front mount?????
- VTEC or Non-VTEC with B20 block and turbo in DA9???
- speedometer problem need help
- easy swap fpr automatic
- More from the shady-garage
- ~Injectors & B20/vtecs... some info & I would like some info~
- reasons to convert
- Doing Swap soon....Help
- Doing GSR swap myself HELP!
- Need info on conversion of 97 Civic
- b20: where to get one?
- Header fitment - 91 CRX with 96 B18B1.....
- B16B block to B18C1 head
- Engine mounting question.....
- B series transmission internals interchangeable?
- What do you think!
- Please Help, I forgot somethin really important!!!
- 93 Civic CX with 2000 SIR B16A2 engine wiring help
- h22a cell
- B16 Robd bolt Torque??HELP Asap
- header pics
- torque specs for clutch
- 3k rpm idle, rebuilt motor...alittle high?
- mount question
- totally confused... obd1 gsr 1 or 2 o2 sensors
- h22 in a 90accord
- exhaust for 92 si hatch with gsr motor??? help
- wiring pins...searched but nothing..
- Honda motors online new website?
- Any engine's bolt into 87 Civic Si?
- Imagine getting a complete GSR teg to strip parts off.
- B16, B18, B18C5, or B20......which one do i get?
- '92 civic htbk with a 97 integ ls swap
- JDM B16A Swap into a 1991 crx si... What axels?
- 97 ex wit h22(whats the best cold air for it?)
- 3g Civic w/ Integra swap carb conversion questions
- d15b swap?
- Help from people in AZ?
- any of you guys have an exploded or broken JDM S1/J1 trans?
- OBD2 B18C1 into EG OBD1 hatch
- What harness is this? Can anybody accurately tell me
- b,d,& h series garage sale looooooooooooooooookkkkkkkkkkkk
- How much for axels??
- Here are pics of what is left of my ek!
- please help with the starting problem
- increased compression
- black shit off my vale cover
- cam gear q's
- 1500 rpm jumping up and down.????
- would this ecu work for my set up? ls/vtec
- JDM b16a alternator help
- Parts Needed for Complete Motor Swap....
- those with h22's w/o ac/ps
- jdm b18c into ek what exhaust/cat to order?
- 91 octane and ctr pistons?
- Front Motor Mount
- good shop in NJ for h22 swap into accord?
- What is needed
- motor swap
- can i install a dx head on my cx block and tranny?
- Those with Aftermarket fans.. Used switch or no??
- Can I install a GSR cluster w/ my stock motor? GSR motor coming shortly..
- throttle body question
- Any ls-vtec 4 door ef's out there?
- 93 Accord - H22 swap Power steering q's?
- GSR Swap into 94 civic Q's
- problem at 3500
- h22a in to ek?
- parts list please.... h22a1 into 6th gen hatch
- Ref Station question????HELP!!!!
- obd2 to obd2 ??
- h22 injector resistor
- Wiring diagram
- what do you guys think of osaksjdmmotors.com?
- Ti Retainers do i need them ?
- 2000 itr flywheel in 2000 b16a
- Steering and cruise help
- please help can a vafc burn out the circuit for your vtec oil pressure???
